Date/Time: Wed, 09 Sep 2026 11:17:19 +0000
Issues since switching over to real time data
View Count: 747
[2021-06-23 12:13:58]
Twiggy - Posts: 10
I have just switched over to real time data after many months of simulation but i'm very confused.
The symbol I was trading 6E Euro is now no longer there and has been replaced with F.US.EU6 is this right? I want to trade the euro, pound, AUD and CAD.
My data feed only goes up to the June 14th. I have updated current symbols and I have the newest version of SC downloaded.
Finally, can you please confirm that for these instruments, F.US.EU6 (Euro) F.US.BP6 (British Pound) F.US.CA6 (CAD) F.US.DA6 (AUD) are available on Package 4 of the data feed costs for $10.40 or do I need the full data feed costs of package 1 for $31.20? Assuming that these symbols are correct for what I want to trade?
I originally had package 4 as thats what I believe I need, but have since switched to number 1 to see if that corrected the problem but it hasnt.
Thanks in advance for your help.
[2021-06-23 14:04:23]
John - SC Support - Posts: 47806
The issue with the symbols is just due to how different vendors handle symbols. We try to keep the actual symbol that is used by the exchange, but CQG uses a different format. Therefore, you must have had your Service setting set to SC Data - All Services while you were testing, and then when you changed your service to CQG, the symbols changed. What you are seeing for the symbols is correct for CQG.
The symbols you are wanting are all traded on the CME exchange, so you just needed the original exchange option you had selected CME with Market Depth for NonProfessionals. So you can deactivate the other exchange, as it is not needed. Just keep in mind that the cost of the exchanges is paid to the exchange, and they do not give refunds, so we can not issue a refund for your having selected the Full CME Group with Market Depth for NonProfessionals exchange.
As to why you are having issues with the data, we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
[2021-06-23 15:48:03]
Twiggy - Posts: 10
Thank you for the reply.
I have done what you ask above and have copied the message log below.
The symbol is F.US.EU6M21
Software version: 2276 64-bit | 2021-06-23 11:41:49.663
Primary Thread ID: 8476 | 2021-06-23 11:41:49.663
Usage end date: 2021-07-24 | 2021-06-23 11:41:49.663
Enabled for: Advanced Features 2. | 2021-06-23 11:41:49.663
Enabled for: Sierra Chart Historical Data Service. | 2021-06-23 11:41:49.663
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-23 11:41:49.663
Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-23 11:41:49.663
Enabled for exchange2: CME | 2021-06-23 11:41:49.663
Enabled for exchange2: CBOT (Trading Account Required) | 2021-06-23 11:41:49.663
Enabled for exchange2: COMEX (Trading Account Required) | 2021-06-23 11:41:49.663
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-06-23 11:41:49.663
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-23 11:41:49.663
Current selected Data/Trading service: CQG WebAPI | 2021-06-23 11:41:49.663
Custom symbol settings values: enabled | 2021-06-23 11:41:49.663
Chart Update Interval: 500 | 2021-06-23 11:41:49.663
Intraday Data Storage Time Unit: 0 | 2021-06-23 11:41:49.663
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-23 11:41:49.663
2021-06-23 15:41:49 Local computer time in UTC | 2021-06-23 11:41:49.663
2021-06-23 11:41:49 Local computer time in SC Time Zone | 2021-06-23 11:41:49.663
2021-06-23 15:38:44 Server time in UTC | 2021-06-23 11:41:49.663
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-06-23 11:41:49.663
Program path: C:\SierraChart\ | 2021-06-23 11:41:49.663
Data Files path: C:\SierraChart\Data\ | 2021-06-23 11:41:49.663
OS Version Number: 10.0 | 2021-06-23 11:41:49.664
Locale Setting: C | 2021-06-23 11:41:49.664
DLLs: UserContributedStudies_64.dll | 2021-06-23 11:41:49.664
Allowed protected custom studies: | 2021-06-23 11:41:49.664
File >> Disconnect selected. | 2021-06-23 11:42:54.709
CQG WebAPI | Sending Web API Logoff message. | 2021-06-23 11:42:54.739
CQG WebSocket socket (2) | CloseSocket call. | 2021-06-23 11:42:54.739
CQG WebSocket socket (2) | Max send buffers used during socket life: 4 | 2021-06-23 11:42:54.739
CQG WebSocket socket (2) | Max send buffer size during socket life: 309 | 2021-06-23 11:42:54.739
CQG WebSocket | WebSocket closed. | 2021-06-23 11:42:54.739
CQG WebAPI | WebSocket closed. | 2021-06-23 11:42:54.739
CQG WebSocket socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-06-23 11:42:54.739
SC Data - All Services | Waiting for socket receive thread to end | 2021-06-23 11:42:54.741
DTC Client socket (3) | CloseSocket call. | 2021-06-23 11:42:54.741
DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:42:54.741
SC Data - All Services | Disconnected from the server. | 2021-06-23 11:42:54.741
SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-06-23 11:42:54.742
DTC Client socket (4) | CloseSocket call. | 2021-06-23 11:42:54.742
DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:42:54.742
SC DTC Data with Market Depth | Disconnected from the server. | 2021-06-23 11:42:54.742
CQG WebAPI | Disconnected. | 2021-06-23 11:42:54.742
CQG WebSocket socket (2) | Write has completed. Shutdown being performed. | 2021-06-23 11:42:54.766
CQG WebSocket socket (2) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:42:54.767
DTC Client socket (3) | Socket gracefully closed by remote side. | 2021-06-23 11:42:54.770
DTC Client socket (3) | Closed. | 2021-06-23 11:42:54.770
CQG WebAPI | Connecting to server api.cqg.com | 2021-06-23 11:43:04.982
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-06-23 11:43:04.982
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-06-23 11:43:04.983
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-06-23 11:43:04.983
CQG WebSocket socket (1) | Connecting to IP: 195.166.124.165. | 2021-06-23 11:43:04.983
CQG WebSocket | Opening WebSocket. | 2021-06-23 11:43:05.009
CQG WebSocket | Sending WebSocket handshake. | 2021-06-23 11:43:05.009
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-06-23 11:43:05.135
CQG WebSocket | Server header | Connection: upgrade | 2021-06-23 11:43:05.135
CQG WebSocket | Server header | Sec-WebSocket-Accept: pTzs1GMhQQFleXuufvMTMvYMCDs= | 2021-06-23 11:43:05.135
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-06-23 11:43:05.135
CQG WebSocket | Server header | Upgrade: websocket | 2021-06-23 11:43:05.135
CQG WebSocket | Server header | | 2021-06-23 11:43:05.135
CQG WebSocket | Web socket state is now open. | 2021-06-23 11:43:05.135
CQG WebAPI | WebSocket connected. | 2021-06-23 11:43:05.135
CQG WebAPI | Sending market data logon message. | 2021-06-23 11:43:05.135
CQG WebAPI | Base Time: 2021-06-19T03:27:48. 2021-06-19 03:27:48 | 2021-06-23 11:43:05.714
CQG WebAPI | Logon successful. Session Token = GPVl9aZGo+59zYCg8aANomp9IfkwXwZTD2uXgaRc0Y4ZayiKXoHQwZIz5D8q0FBhV34umZxdrqN | 2021-06-23 11:43:05.714
CQG WebAPI | Connected to server complete. | 2021-06-23 11:43:05.714
Triggering next historical data download in queue. | 2021-06-23 11:43:05.715
Triggering next historical data download in queue. | 2021-06-23 11:43:05.716
Subscribing to symbol for symbol alert. F.US.TYAZ20 | 2021-06-23 11:43:05.716
Mapping F.US.TYAZ20 to ZNZ20. Service code: cbot | 2021-06-23 11:43:05.716
SC Data - All Services | Starting real-time market data updates for: F.US.TYAZ20 (ZNZ20). ID: 1 Service code: cbot | 2021-06-23 11:43:05.716
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2021-06-23 11:43:05.716
CQG WebAPI | Sending symbol resolution request for F.US.TYAZ20. ID: 408620 | 2021-06-23 11:43:05.716
SC Data - All Services | Requesting security definition data for: F.US.TYAZ20 (ZNZ20). ID: 1 | 2021-06-23 11:43:05.716
Subscribing to symbol for symbol alert. F.US.TYAH21 | 2021-06-23 11:43:05.716
Mapping F.US.TYAH21 to ZNH21. Service code: cbot | 2021-06-23 11:43:05.716
SC Data - All Services | Starting real-time market data updates for: F.US.TYAH21 (ZNH21). ID: 2 Service code: cbot | 2021-06-23 11:43:05.716
CQG WebAPI | Sending symbol resolution request for F.US.TYAH21. ID: 408621 | 2021-06-23 11:43:05.716
SC Data - All Services | Requesting security definition data for: F.US.TYAH21 (ZNH21). ID: 2 | 2021-06-23 11:43:05.716
Updated verified funded futures trading account ending date to: 2021-07-23 15:43:05 | 2021-06-23 11:43:05.716
DTC Client socket (3) | Creating socket. | 2021-06-23 11:43:05.717
DTC Client socket (3) | New receive buffer size: 5242880 | 2021-06-23 11:43:05.717
DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2021-06-23 11:43:05.717
CQG WebAPI | Sending Trade Accounts request message. | 2021-06-23 11:43:05.772
No download requests in the queue to start downloads for. | 2021-06-23 11:43:05.772
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-23 11:43:05.814
Symbol Error - F.US.TYAZ20 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-23 11:43:05.814
CQG WebAPI | Brokerage name: AMP. Account Name: 141556 | 2021-06-23 11:43:05.814
CQG WebAPI | Sending collateral subscribe request. | 2021-06-23 11:43:05.814
CQG WebAPI | Received message: Requested symbol was not found. | 2021-06-23 11:43:05.815
Symbol Error - F.US.TYAH21 is unknown, unavailable, or improperly formatted. Requested symbol was not found. | 2021-06-23 11:43:05.815
SC Data - All Services | Network connection to server complete. | 2021-06-23 11:43:05.844
SC Data - All Services | Starting socket receive thread. | 2021-06-23 11:43:05.844
SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2021-06-23 11:43:05.844
Mapping F.US.EU6M21 to 6EM21. Service code: cme | 2021-06-23 11:43:05.923
SC Data - All Services | Starting real-time market data updates for: F.US.EU6M21 (6EM21). ID: 3 Service code: cme | 2021-06-23 11:43:05.923
CQG WebAPI | Sending symbol resolution request for F.US.EU6M21. ID: 408624 | 2021-06-23 11:43:05.923
SC Data - All Services | Requesting security definition data for: F.US.EU6M21 (6EM21). ID: 3 | 2021-06-23 11:43:05.923
Added historical Intraday data request for F.US.EU6M21 to the queue. | 2021-06-23 11:43:05.923
Intraday data recording state for symbol F.US.EU6M21 is set to download 'Pending'. | 2021-06-23 11:43:05.923
Triggering next historical data download in queue. | 2021-06-23 11:43:05.923
Delaying start of download for F.US.EU6M21 | 2021-06-23 11:43:05.959
CQG WebAPI | Received symbol resolution report for symbol F.US.EU6M21. Search Symbol: F.US.EU6M21. Request ID: 408624. Contract ID: 1. | 2021-06-23 11:43:06.055
SC Data - All Services | Setting DTC encoding to Binary VLS | 2021-06-23 11:43:06.063
SC Data - All Services | Sending logon request message. | 2021-06-23 11:43:06.063
SC Data - All Services | Received logon response. | 2021-06-23 11:43:06.942
SC Data - All Services | Server Name: SC Realtime Server. | 2021-06-23 11:43:06.942
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2021-06-23 11:43:06.942
SC Data - All Services | Successfully connected. | 2021-06-23 11:43:06.942
SC Data - All Services | Trading is not supported. | 2021-06-23 11:43:06.942
SC Data - All Services | Restarting real-time data updates for symbol: F.US.EU6M21 -> 6EM21 | 2021-06-23 11:43:06.942
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAH21 -> ZNH21 | 2021-06-23 11:43:06.942
SC Data - All Services | Restarting real-time data updates for symbol: F.US.TYAZ20 -> ZNZ20 | 2021-06-23 11:43:06.942
SC Data - All Services | Real-time data for symbol F.US.EU6M21 is currently unavailable. | 2021-06-23 11:43:07.164
SC Data - All Services | Received security definition for symbol F.US.EU6M21 | 2021-06-23 11:43:07.164
SC Data - All Services | Real-time data for symbol F.US.TYAH21 is currently unavailable. | 2021-06-23 11:43:07.164
SC Data - All Services | Received security definition for symbol F.US.TYAH21 | 2021-06-23 11:43:07.164
SC Data - All Services | Real-time data for symbol F.US.TYAZ20 is currently unavailable. | 2021-06-23 11:43:07.164
SC Data - All Services | Received security definition for symbol F.US.TYAZ20 | 2021-06-23 11:43:07.164
CQG WebAPI | Sending positions subscribe request. RequestID: 408625 | 2021-06-23 11:43:10.706
CQG WebAPI | Sending orders subscribe request. RequestID: 408626 | 2021-06-23 11:43:10.706
HD Request # 11 | Downloading Intraday chart data for F.US.EU6M21 to the file F.US.EU6M21.scid. Service: cme | 2021-06-23 11:43:12.840
HD Request # 11 | Download start date-time: 2021-06-14 10:15:11.000000. File last date-time: 2021-06-14 10:15:11.335001 | 2021-06-23 11:43:12.841
HD Request # 11 | Using server: ds23.sierracharts.com port 10149 | 2021-06-23 11:43:12.843
Socket (5) | Creating socket. | 2021-06-23 11:43:12.843
Socket (5) | New receive buffer size: 5242880 | 2021-06-23 11:43:12.843
Socket (5) | Connecting to IP: 216.1.90.130. | 2021-06-23 11:43:12.843
HD Request # 11 | Setting DTC encoding to Binary VLS | 2021-06-23 11:43:13.122
HD Request # 11 | Sending historical data logon request message. | 2021-06-23 11:43:13.122
HD Request # 11 | Requesting Intraday data. Start date-time: 2021-06-14 10:15:11. Record interval: 0. Symbol: 6EM21 | 2021-06-23 11:43:13.710
HD Request # 11 | Decompressing data. | 2021-06-23 11:43:13.831
HD Request # 11 | Receiving Intraday data for F.US.EU6M21 starting at 2021-06-14 10:15:11.335000 | 2021-06-23 11:43:13.833
Socket (5) | CloseSocket call. | 2021-06-23 11:43:13.833
Historical data download thread signaled to stop. | 2021-06-23 11:43:13.834
HD Request # 11 | Received 2 records from 2021-06-14 10:15:11.335000 to 2021-06-14 10:15:11.335001 (0.0 seconds) and wrote 0 records for F.US.EU6M21 | 2021-06-23 11:43:13.834
Socket (5) | Shutdown started. Waiting for graceful close. | 2021-06-23 11:43:13.834
HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2021-06-14 14:15:11.335001 | 2021-06-
23 11:43:13.835
HD Request # 11 | Completion time: 1s | 2021-06-23 11:43:13.835
HD Request # 11 | Intraday data download complete for F.US.EU6M21. Unique request ID: 10 | 2021-06-23 11:43:13.835
Removing historical data download ID 10. | 2021-06-23 11:43:13.835
Real-time Intraday chart data file updates started for F.US.EU6M21 | 2021-06-23 11:43:13.835
Intraday chart data file opened for F.US.EU6M21 | 2021-06-23 11:43:13.835
HD Request # 11 | Enabling Intraday chart updating for symbol. | 2021-06-23 11:43:13.835
Triggering next historical data download in queue. | 2021-06-23 11:43:13.835
No download requests in the queue to start downloads for. | 2021-06-23 11:43:13.835
Socket (5) | Socket gracefully closed by remote side. | 2021-06-23 11:43:13.956
Socket (5) | Closed. | 2021-06-23 11:43:13.956
[2021-06-23 17:18:56]
We are not seeing any issues with the data for F.US.EU6M21. Note that the M contract is no longer the active contract, so that is probably where the issue is. You should change to the U contract.
The only thing we see in the log are the following:
But, if you deactivated the Full CME Group with Market Depth, then that may explain this, as the system is looking to CQG for this symbol instead of the Denali feed (this symbol is traded on the CBOT, not the CME).
