Date/Time: Wed, 16 Sep 2026 11:29:48 +0000
not connecting
View Count: 1098
[2021-06-16 16:12:56]
KyleK - Posts: 28
DTC Protocol Server feature not enabled for Sierra Chart account. | 2021-06-16 09:00:58.414 *
Reading Internal Order ID file. | 2021-06-16 09:00:58.414
Reading Trade Orders file. | 2021-06-16 09:00:58.512
Reading Trade Positions file. | 2021-06-16 09:00:58.513
Reading Trade Account Data files. | 2021-06-16 09:00:58.513
UDPListener (1580). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. | 2021-06-16 09:00:58.536
Software version: 2248 64-bit | 2021-06-16 09:00:58.536
Primary Thread ID: 5272 | 2021-06-16 09:00:58.536
Usage end date: 2021-08-09 | 2021-06-16 09:00:58.536
Enabled for: Sierra Chart Historical Data Service. | 2021-06-16 09:00:58.536
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-06-16 09:00:58.536
Enabled for: Delayed Denali Exchange Data Feed. | 2021-06-16 09:00:58.536
Enabled for exchange2: CME (Trading Account Required) | 2021-06-16 09:00:58.536
Enabled for exchange2: CBOT (Trading Account Required) | 2021-06-16 09:00:58.536
Enabled for exchange2: COMEX (Trading Account Required) | 2021-06-16 09:00:58.536
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-06-16 09:00:58.536
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-06-16 09:00:58.536
Current selected Data/Trading service: DTC - Sub Instance | 2021-06-16 09:00:58.536
Custom symbol settings values: enabled | 2021-06-16 09:00:58.536
Chart Update Interval: 500 | 2021-06-16 09:00:58.536
Intraday Data Storage Time Unit: 1 | 2021-06-16 09:00:58.536
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-06-16 09:00:58.536
2021-06-16 14:00:58 Local computer time in UTC | 2021-06-16 09:00:58.536
2021-06-16 09:00:58 Local computer time in SC Time Zone | 2021-06-16 09:00:58.536
2021-06-16 14:00:56 Server time in UTC | 2021-06-16 09:00:58.536
Local computer UTC time and Server UTC time difference: 2 seconds. | 2021-06-16 09:00:58.536
Program path: C:\Users\User\Downloads\SierraChart2248\SierraChartInstance_2\ | 2021-06-16 09:00:58.536
Data Files path: C:\Users\User\Downloads\SierraChart2248\SierraChartInstance_2\Data\ | 2021-06-16 09:00:58.536
OS Version Number: 10.0 | 2021-06-16 09:00:58.536
Locale Setting: C | 2021-06-16 09:00:58.536
DLLs: futuresfx-drl.dll, SAL.dll, SAL_2151_64.dll, SAL_64.dll, TTIDRL_DEC_2020_64.dll, tti_alert.dll, tti_alert_2151_64.dll, tti_alert_64.dll, tti_drl.dll, tti_drl_2151_64.dll, tti_powerlines_2151_64.dll, tti_powerlines_64.dll, tti_reversals.dll, tti_reversals_2151_64.dll, tti_reversals_64.dll, tti_volume_profile.dll, tti_volume_profile_2151_64.dll, tti_volume_profile_64.dll, UserContributedStudies_64.dll | 2021-06-16 09:00:58.536
Allowed protected custom studies: futuresfx-drl, Simon's Attraction Levels, TTI Alert, TTI DRL, TTI Powerlines, TTI Reversal Signals, TTI Volume Profile | 2021-06-16 09:00:58.536
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-16 09:00:58.594
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-16 09:00:58.742
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-16 09:00:58.742
Received 5 login tokens. | 2021-06-16 09:00:58.991
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:05.234
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:05.234
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:05.234
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:05.234
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:07.257 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:07.257
DTC Client socket (1) | Closed. | 2021-06-16 09:01:07.257
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:07.257
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:07.257
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:07.272
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:07.272
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:07.272
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:10.272
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:10.272
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:10.272
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:10.272
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:12.316 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:12.316
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:12.316
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:12.316
DTC Client socket (1) | Closed. | 2021-06-16 09:01:12.316
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:12.331
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:12.331
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:12.331
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:15.336
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:15.336
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:15.336
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:15.336
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:17.383 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:17.383
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:17.383
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:17.383
DTC Client socket (1) | Closed. | 2021-06-16 09:01:17.383
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:17.412
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:17.412
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:17.412
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:20.402
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:20.402
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:20.403
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:20.403
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:22.425 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:22.425
DTC Client socket (1) | Closed. | 2021-06-16 09:01:22.425
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:22.425
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:22.425
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:22.441
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:22.441
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:22.441
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:25.458
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:25.458
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:25.458
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:25.458
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:27.477 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:27.477
DTC Client socket (1) | Closed. | 2021-06-16 09:01:27.477
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:27.477
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:27.477
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:27.508
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:27.508
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:27.508
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:30.520
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:30.520
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:30.520
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:30.520
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:32.540 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:32.540
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:32.540
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:32.540
DTC Client socket (1) | Closed. | 2021-06-16 09:01:32.540
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:32.556
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:32.556
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:32.556
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:35.572
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:35.572
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:35.572
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:35.572
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:37.600 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:37.600
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:37.600
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:37.600
DTC Client socket (1) | Closed. | 2021-06-16 09:01:37.600
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:37.616
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:37.616
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:37.616
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:40.602
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:40.602
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:40.602
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:40.602
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:42.625 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:42.625
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:42.625
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:42.625
DTC Client socket (1) | Closed. | 2021-06-16 09:01:42.625
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:42.640
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:42.640
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:42.640
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:45.640
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:45.640
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:45.640
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:45.640
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:47.660 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:47.660
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:47.660
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:47.660
DTC Client socket (1) | Closed. | 2021-06-16 09:01:47.660
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:47.675
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:47.675
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:47.675
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:50.679
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:50.679
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:50.679
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:50.679
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:52.697 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:52.697
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:52.697
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:52.697
DTC Client socket (1) | Closed. | 2021-06-16 09:01:52.697
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:52.713
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:52.713
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:52.713
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:01:55.717
DTC Client socket (1) | Creating socket. | 2021-06-16 09:01:55.717
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:01:55.717
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:01:55.717
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:01:57.748 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:01:57.748
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:01:57.748
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:57.748
DTC Client socket (1) | Closed. | 2021-06-16 09:01:57.748
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:01:57.763
DTC - Sub Instance | Disconnected. | 2021-06-16 09:01:57.763
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:01:57.763
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:00.787
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:00.787
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:00.787
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:00.787
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:02.813 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:02.813
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:02.813
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:02.813
DTC Client socket (1) | Closed. | 2021-06-16 09:02:02.813
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:02.828
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:02.828
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:02.828
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:05.826
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:05.826
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:05.826
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:05.826
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:07.858 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:07.858
DTC Client socket (1) | Closed. | 2021-06-16 09:02:07.858
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:07.858
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:07.858
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:07.874
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:07.874
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:07.874
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:10.890
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:10.891
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:10.891
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:10.891
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:12.910 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:12.910
DTC Client socket (1) | Closed. | 2021-06-16 09:02:12.910
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:12.910
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:12.910
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:12.925
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:12.925
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:12.925
File >> Disconnect selected. | 2021-06-16 09:02:13.493
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:13.493
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:13.493
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:23.933
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:23.933
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:23.933
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:23.933
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:25.961 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:25.961
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:25.961
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:25.961
DTC Client socket (1) | Closed. | 2021-06-16 09:02:25.961
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:25.976
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:25.976
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:25.976
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:28.987
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:28.987
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:28.988
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:28.988
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:31.002 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:31.002
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:31.002
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:31.002
DTC Client socket (1) | Closed. | 2021-06-16 09:02:31.002
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:31.017
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:31.017
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:31.017
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:34.014
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:34.014
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:34.015
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:34.015
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:36.036 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:36.036
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:36.036
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:36.036
DTC Client socket (1) | Closed. | 2021-06-16 09:02:36.036
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:36.052
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:36.052
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:36.052
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:02:39.040
DTC Client socket (1) | Creating socket. | 2021-06-16 09:02:39.040
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:02:39.040
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:02:39.040
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:02:41.060 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:02:41.060
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:02:41.060
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:41.060
DTC Client socket (1) | Closed. | 2021-06-16 09:02:41.060
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:41.076
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:41.076
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:02:41.076
File >> Disconnect selected. | 2021-06-16 09:02:43.438
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:02:43.438
DTC - Sub Instance | Disconnected. | 2021-06-16 09:02:43.438
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:23.516
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:23.516
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:23.516
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:23.516
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:25.545 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:25.545
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:25.545
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:25.545
DTC Client socket (1) | Closed. | 2021-06-16 09:03:25.545
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:25.560
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:25.560
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:25.560
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:28.576
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:28.576
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:28.577
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:28.577
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:30.595 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:30.595
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:30.595
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:30.595
DTC Client socket (1) | Closed. | 2021-06-16 09:03:30.595
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:30.611
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:30.611
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:30.611
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:33.614
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:33.614
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:33.614
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:33.614
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:35.636 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:35.636
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:35.636
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:35.636
DTC Client socket (1) | Closed. | 2021-06-16 09:03:35.636
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:35.650
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:35.650
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:35.650
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:38.664
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:38.664
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:38.664
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:38.664
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:40.684 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:40.684
DTC Client socket (1) | Closed. | 2021-06-16 09:03:40.684
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:40.684
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:40.684
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:40.699
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:40.699
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:40.699
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:43.712
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:43.712
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:43.712
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:43.712
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:45.727 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:45.727
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:45.727
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:45.727
DTC Client socket (1) | Closed. | 2021-06-16 09:03:45.727
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:45.743
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:45.743
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:45.743
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:48.753
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:48.753
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:48.753
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:48.753
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:50.771 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:50.771
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:50.771
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:50.771
DTC Client socket (1) | Closed. | 2021-06-16 09:03:50.771
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:50.786
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:50.786
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:50.786
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:53.800
DTC Client socket (1) | Creating socket. | 2021-06-16 09:03:53.800
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:03:53.800
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:53.800
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:03:55.820 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:03:55.820
DTC Client socket (1) | Closed. | 2021-06-16 09:03:55.820
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:03:55.820
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:55.820
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:03:55.835
DTC - Sub Instance | Disconnected. | 2021-06-16 09:03:55.835
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:03:55.835
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:03:58.848
DTC Client socket (2) | Creating socket. | 2021-06-16 09:03:58.848
DTC Client socket (2) | New receive buffer size: 5242880 | 2021-06-16 09:03:58.848
DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:03:58.848
DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:00.866 *
DTC Client socket (2) | CloseSocket call. | 2021-06-16 09:04:00.866
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:00.866
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:00.866
DTC Client socket (2) | Closed. | 2021-06-16 09:04:00.866
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:00.881
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:00.881
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:00.881
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:03.869
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:03.869
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:03.869
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:03.869
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:05.892 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:05.892
DTC Client socket (1) | Closed. | 2021-06-16 09:04:05.892
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:05.892
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:05.892
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:05.907
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:05.907
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:05.907
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:08.905
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:08.905
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:08.905
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:08.905
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:10.924 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:10.924
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:10.924
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:10.924
DTC Client socket (1) | Closed. | 2021-06-16 09:04:10.924
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:10.939
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:10.939
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:10.939
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:13.931
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:13.931
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:13.931
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:13.931
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:15.952 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:15.952
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:15.952
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:15.952
DTC Client socket (1) | Closed. | 2021-06-16 09:04:15.952
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:15.967
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:15.968
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:15.968
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:18.989
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:18.989
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:18.989
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:18.989
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:21.012 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:21.012
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:21.012
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:21.012
DTC Client socket (1) | Closed. | 2021-06-16 09:04:21.012
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:21.027
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:21.027
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:21.027
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:24.039
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:24.039
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:24.039
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:24.039
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:26.061 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:26.061
DTC Client socket (1) | Closed. | 2021-06-16 09:04:26.061
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:26.061
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:26.061
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:26.076
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:26.077
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:26.077
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:29.097
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:29.097
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:29.097
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:29.097
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:31.113 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:31.113
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:31.113
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:31.113
DTC Client socket (1) | Closed. | 2021-06-16 09:04:31.113
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:31.128
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:31.129
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:31.129
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:34.123
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:34.123
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:34.123
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:34.123
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:36.142 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:36.142
DTC Client socket (1) | Closed. | 2021-06-16 09:04:36.142
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:36.142
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:36.142
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:36.157
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:36.157
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:36.157
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:39.159
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:39.159
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:39.159
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:39.159
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:41.183 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:41.183
DTC Client socket (1) | Closed. | 2021-06-16 09:04:41.183
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:41.183
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:41.183
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:41.198
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:41.198
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:41.198
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:44.225
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:44.225
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:44.225
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:44.225
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:46.250 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:46.250
DTC Client socket (1) | Closed. | 2021-06-16 09:04:46.250
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:46.250
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:46.250
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:46.265
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:46.265
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:46.265
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:49.267
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:49.267
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:49.267
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:49.267
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:51.290 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:51.290
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:51.290
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:51.290
DTC Client socket (1) | Closed. | 2021-06-16 09:04:51.290
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:51.305
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:51.305
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:51.305
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:54.307
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:54.307
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:54.307
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:54.307
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:04:56.329 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:04:56.329
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:04:56.329
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:56.329
DTC Client socket (1) | Closed. | 2021-06-16 09:04:56.329
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:04:56.344
DTC - Sub Instance | Disconnected. | 2021-06-16 09:04:56.344
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:04:56.344
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:04:59.348
DTC Client socket (1) | Creating socket. | 2021-06-16 09:04:59.348
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:04:59.348
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:04:59.348
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:01.365 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:01.365
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:01.365
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:01.365
DTC Client socket (1) | Closed. | 2021-06-16 09:05:01.365
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:01.380
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:01.380
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:01.380
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:04.371
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:04.371
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:04.371
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:04.371
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:06.392 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:06.392
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:06.392
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:06.392
DTC Client socket (1) | Closed. | 2021-06-16 09:05:06.392
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:06.408
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:06.408
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:06.408
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:09.423
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:09.423
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:09.423
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:09.423
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:11.443 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:11.443
DTC Client socket (1) | Closed. | 2021-06-16 09:05:11.443
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:11.443
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:11.443
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:11.458
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:11.458
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:11.458
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:14.466
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:14.466
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:14.466
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:14.466
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:16.489 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:16.489
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:16.489
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:16.489
DTC Client socket (1) | Closed. | 2021-06-16 09:05:16.489
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:16.504
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:16.504
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:16.504
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:19.506
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:19.506
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:19.506
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:19.506
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:21.543 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:21.543
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:21.543
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:21.543
DTC Client socket (1) | Closed. | 2021-06-16 09:05:21.543
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:21.558
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:21.558
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:21.558
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:24.563
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:24.563
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:24.563
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:24.563
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:26.582 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:26.582
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:26.582
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:26.582
DTC Client socket (1) | Closed. | 2021-06-16 09:05:26.582
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:26.597
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:26.597
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:26.597
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:29.607
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:29.607
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:29.607
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:29.607
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:31.626 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:31.626
DTC Client socket (1) | Closed. | 2021-06-16 09:05:31.626
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:31.626
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:31.626
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:31.642
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:31.642
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:31.642
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:34.636
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:34.636
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:34.636
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:34.636
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:36.658 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:36.658
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:36.658
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:36.658
DTC Client socket (1) | Closed. | 2021-06-16 09:05:36.658
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:36.673
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:36.673
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:36.673
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:39.683
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:39.683
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:39.683
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:39.683
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:41.703 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:41.703
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:41.703
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:41.703
DTC Client socket (1) | Closed. | 2021-06-16 09:05:41.703
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:41.719
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:41.719
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:41.719
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:44.727
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:44.728
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:44.728
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:44.728
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:46.745 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:46.745
DTC Client socket (1) | Closed. | 2021-06-16 09:05:46.745
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:46.745
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:46.745
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:46.760
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:46.760
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:46.760
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:49.768
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:49.768
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:49.768
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:49.768
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:51.788 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:51.788
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:51.788
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:51.788
DTC Client socket (1) | Closed. | 2021-06-16 09:05:51.788
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:51.803
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:51.804
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:51.804
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:54.814
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:54.814
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:54.814
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:54.814
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:05:56.831 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:05:56.831
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:05:56.831
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:56.831
DTC Client socket (1) | Closed. | 2021-06-16 09:05:56.831
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:05:56.847
DTC - Sub Instance | Disconnected. | 2021-06-16 09:05:56.847
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:05:56.847
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:05:59.840
DTC Client socket (1) | Creating socket. | 2021-06-16 09:05:59.840
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:05:59.840
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:05:59.840
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:06:01.862 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:06:01.862
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:06:01.862
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:06:01.862
DTC Client socket (1) | Closed. | 2021-06-16 09:06:01.862
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:06:01.877
DTC - Sub Instance | Disconnected. | 2021-06-16 09:06:01.877
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:06:01.877
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:06:04.883
DTC Client socket (1) | Creating socket. | 2021-06-16 09:06:04.883
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:06:04.883
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:06:04.883
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 09:06:06.908 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:06:06.908
DTC Client socket (1) | Closed. | 2021-06-16 09:06:06.908
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 09:06:06.908
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:06:06.908
DTC Client socket (0) | CloseSocket call. | 2021-06-16 09:06:06.923
DTC - Sub Instance | Disconnected. | 2021-06-16 09:06:06.923
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 09:06:06.923
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 09:06:09.940
DTC Client socket (1) | Creating socket. | 2021-06-16 09:06:09.940
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 09:06:09.940
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 09:06:09.940
File >> Disconnect selected. | 2021-06-16 09:06:10.495
DTC Client socket (1) | CloseSocket call. | 2021-06-16 09:06:10.495
DTC - Sub Instance | Disconnected. | 2021-06-16 09:06:10.495
DTC Client socket (1) | Closed. | 2021-06-16 09:06:10.495
The message log has been sent to support. | 2021-06-16 09:08:26.174 *
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2021-06-16 09:08:26.174
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | New receive buffer size: 32768 | 2021-06-16 09:08:26.174
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 95.216.233.104. | 2021-06-16 09:08:26.174
Sending of the Message Log is completed. The response was saved to C:\Users\User\Downloads\SierraChart2248\SierraChartInstance_2\Data\MessageLogAnalysis.htm | 2021-06-16 09:08:27.103
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. | 2021-06-16 09:08:27.368
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2021-06-16 09:08:27.368
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2021-06-16 09:08:27.505
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2021-06-16 09:08:27.505
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 10:43:15.007
DTC Client socket (1) | Creating socket. | 2021-06-16 10:43:15.007
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 10:43:15.007
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 10:43:15.007
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 10:43:17.039 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 10:43:17.039
DTC Client socket (1) | Closed. | 2021-06-16 10:43:17.039
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 10:43:17.039
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:17.039
DTC Client socket (0) | CloseSocket call. | 2021-06-16 10:43:17.054
DTC - Sub Instance | Disconnected. | 2021-06-16 10:43:17.054
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:17.054
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 10:43:20.065
DTC Client socket (1) | Creating socket. | 2021-06-16 10:43:20.065
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 10:43:20.065
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 10:43:20.065
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 10:43:22.088 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 10:43:22.089
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 10:43:22.089
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:22.089
DTC Client socket (1) | Closed. | 2021-06-16 10:43:22.089
DTC Client socket (0) | CloseSocket call. | 2021-06-16 10:43:22.104
DTC - Sub Instance | Disconnected. | 2021-06-16 10:43:22.104
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:22.104
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 10:43:25.099
DTC Client socket (1) | Creating socket. | 2021-06-16 10:43:25.099
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 10:43:25.099
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 10:43:25.099
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 10:43:27.122 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 10:43:27.122
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 10:43:27.122
DTC Client socket (1) | Closed. | 2021-06-16 10:43:27.122
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:27.122
DTC Client socket (0) | CloseSocket call. | 2021-06-16 10:43:27.137
DTC - Sub Instance | Disconnected. | 2021-06-16 10:43:27.137
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:27.137
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 10:43:30.149
DTC Client socket (1) | Creating socket. | 2021-06-16 10:43:30.149
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 10:43:30.149
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 10:43:30.149
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 10:43:32.172 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 10:43:32.172
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 10:43:32.172
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:32.172
DTC Client socket (1) | Closed. | 2021-06-16 10:43:32.172
DTC Client socket (0) | CloseSocket call. | 2021-06-16 10:43:32.202
DTC - Sub Instance | Disconnected. | 2021-06-16 10:43:32.202
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:32.202
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 10:43:35.215
DTC Client socket (1) | Creating socket. | 2021-06-16 10:43:35.215
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 10:43:35.215
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 10:43:35.215
DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2021-06-16 10:43:37.231 *
DTC Client socket (1) | CloseSocket call. | 2021-06-16 10:43:37.231
DTC Client socket (1) | Closed. | 2021-06-16 10:43:37.231
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2021-06-16 10:43:37.231
Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:37.231
DTC Client socket (0) | CloseSocket call. | 2021-06-16 10:43:37.246
DTC - Sub Instance | Disconnected. | 2021-06-16 10:43:37.246
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-06-16 10:43:37.246
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2021-06-16 10:43:40.262
DTC Client socket (1) | Creating socket. | 2021-06-16 10:43:40.262
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-06-16 10:43:40.262
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2021-06-16 10:43:40.262
File >> Disconnect selected. | 2021-06-16 10:43:41.033
DTC Client socket (1) | CloseSocket call. | 2021-06-16 10:43:41.033
DTC - Sub Instance | Disconnected. | 2021-06-16 10:43:41.033
DTC Client socket (1) | Closed. | 2021-06-16 10:43:41.033
The message log has been sent to support. | 2021-06-16 10:48:00.429 *
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Creating socket. Using TLS 1.2. | 2021-06-16 10:48:00.429
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | New receive buffer size: 32768 | 2021-06-16 10:48:00.429
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Connecting to IP: 95.216.233.104. | 2021-06-16 10:48:00.429
Sending of the Message Log is completed. The response was saved to C:\Users\User\Downloads\SierraChart2248\SierraChartInstance_2\Data\MessageLogAnalysis.htm | 2021-06-16 10:48:01.469
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | CloseSocket call. | 2021-06-16 10:48:01.733
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Shutdown started. Waiting for graceful close. | 2021-06-16 10:48:01.733
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Socket gracefully closed by remote side. | 2021-06-16 10:48:01.871
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (1) | Closed. | 2021-06-16 10:48:01.871
[2021-06-16 16:18:43]
John - SC Support - Posts: 47903
You need to update to the current Release in order to be able to continue to use the New Instance option. You can update using the Fast Update option:
[2021-06-16 18:37:34]
KyleK - Posts: 28
The link you have sent I'm still not able to update. What are the other troubleshooting options?
[2021-06-16 18:45:31]
There isn't any other troubleshooting to be done. The issue is simply that older versions of Sierra Chart will not allow the use of a New Instance due to changes in the software. Your only option in order to be able to use the New Instance option is to update to the current release.
If you need help with performing the update, let us know.
[2021-06-17 17:35:27]
KyleK - Posts: 28
John have sent error message when trying to update version. Please advise.thanks
[2021-06-17 18:50:53]
Here is the problem from the log:
Failed to create folder: C:\Users\User\Downloads\SierraChart2248\DownloadedInstallationFiles\ACS_Source\. Windows error code 5: Access is denied.
The user that you are running as when doing the installation does not have permission to write or create a folder in the above folder. Refer to the following:
Software Download: Resolving 'Access is Denied' Errors
[2021-06-17 19:12:33]
KyleK - Posts: 28
John, in programs i have no Sierra charts where do i find this??
[2021-06-17 19:21:39]
Your Sierra Chart is installed in C:\Users\User\Downloads\SierraChart2248
[2021-06-17 19:46:24]
KyleK - Posts: 28
program
path and installation path match and still getting the error
[2021-06-17 19:54:23]
KyleK - Posts: 28
the windows log is different in installer shows a widows error code.
[2021-06-17 19:58:35]
KyleK - Posts: 28
where do I find the windows Log?
[2021-06-17 20:10:53]
The Installer log is in the Installer window when you perform the update. From the log you sent us earlier, the Windows error was #5, as we quoted above, which is an "Access is Denied" error.
Apart from what we referenced you to in the documentation, there is not much else we can do. You would need to figure out how your system is setup in order to allow the software to perform the update.
[2021-06-17 20:36:15]
KyleK - Posts: 28
this was downloaded through the zip file installer dos that mean anything?
[2021-06-17 20:58:42]
Sorry, we are not understanding. If you installed using the Zip installer, there will not be any log. If there was an issue, you should have been notified by the operating system that it could not copy the files, or could not open the Zip file or something to that end.
[2021-06-17 21:06:15]
KyleK - Posts: 28
John, this install back in April was with the Zipp file install. Is that why I am having a problem?
[2021-06-17 21:12:01]
No. It does not matter how the original was done. But, if you had to use the Zip installer back then, then that is probably due to the same reason we are suggesting using it now. The installer must not have access to that file folder.
You will find the information for the Zip Installer here:
Software Download: Sierra Chart Zip Installer
[2021-06-17 21:25:04]
KyleK - Posts: 28
ok i figured it out all good now
