Date/Time: Thu, 10 Sep 2026 12:19:30 +0000
Problem putting in a live trade
View Count: 1119
[2021-05-18 16:30:25]
User811550 - Posts: 5
I switched to live to trade in Sierra and when I put on trade to take a position it switches to Sim automobility and takes the position in SIM mod instead of Live and not sure what is going on.
I changed my AMP to Data routing only but never received any confirmation from them not sure what is going on.
[2021-05-18 16:41:48]
John - SC Support - Posts: 47822
You do not have your Sierra Chart setup to connect to your AMP account. Most likely you are setup at AMP to use CQG for your order routing. If this is the case, then follow these instructions to connect your Sierra Chart to your CQG account:
CQG Trading Platform Service: Setup Instructions
[2021-05-19 02:13:05]
I called my AMP Broker and explained to them what you said about and explained my problem that I am not able to take a live trade and it keeps going to SiM and it takes the trade position in SIM. I told them I had gone into my client portal in AMP and changed my existing live trading account data feed to Sierra Chart- Denali- CQG order routing only several days ago and for them to check this for me because I wanted to use Denali feed through Sierra Chart he said yes it had been and everything looked good. They asked me what I put in the data trade service setting in Sierra Chart I told him SC Data all services. He told me I need to change that to CQG WebAPI trading to live trade. So I did that when I got home and now I'm not seeing the (M) as I was seeing before and now I Daily Intraday charts are not loading all the way.
I'm confused I'm I still using Denali if I use CQG WebAPI?
Why am I not seeing the (M)?
Did AMP just not change me to Sierra Chart- Denali- CQG order routing only and that's why I am having problems?
Date Time Of Last Edit: 2021-05-19 02:14:48
[2021-05-19 07:35:00]
Reconnect to the data feed:
[2021-05-19 11:30:03]
Software version: 2258 64-bit | 2021-05-19 07:24:30.249
Primary Thread ID: 12276 | 2021-05-19 07:24:30.249
Usage end date: 2021-06-04 | 2021-05-19 07:24:30.250
Enabled for: Advanced Features 2. | 2021-05-19 07:24:30.250
Enabled for: Sierra Chart Historical Data Service. | 2021-05-19 07:24:30.250
Enabled for: Denali Real-Time Exchange Data Feed. | 2021-05-19 07:24:30.250
Enabled for: Delayed Denali Exchange Data Feed. | 2021-05-19 07:24:30.250
Enabled for exchange2: CME (Trading Account Required) | 2021-05-19 07:24:30.250
Enabled for exchange2: CBOT (Trading Account Required) | 2021-05-19 07:24:30.250
Enabled for exchange2: COMEX (Trading Account Required) | 2021-05-19 07:24:30.250
Enabled for exchange2: NYMEX (Trading Account Required) | 2021-05-19 07:24:30.250
Allow Support for Sierra Chart Data Feeds is enabled. | 2021-05-19 07:24:30.250
Current selected Data/Trading service: CQG WebAPI | 2021-05-19 07:24:30.250
Custom symbol settings values: disabled | 2021-05-19 07:24:30.250
Chart Update Interval: 500 | 2021-05-19 07:24:30.250
Intraday Data Storage Time Unit: 0 | 2021-05-19 07:24:30.250
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-05-19 07:24:30.250
2021-05-19 11:24:30 Local computer time in UTC | 2021-05-19 07:24:30.250
2021-05-19 07:24:30 Local computer time in SC Time Zone | 2021-05-19 07:24:30.250
2021-05-19 11:11:39 Server time in UTC | 2021-05-19 07:24:30.250
Local computer UTC time and Server UTC time difference: 0 seconds. | 2021-05-19 07:24:30.250
Program path: C:\SierraChart\ | 2021-05-19 07:24:30.250
Data Files path: C:\SierraChart\Data\ | 2021-05-19 07:24:30.250
OS Version Number: 10.0 | 2021-05-19 07:24:30.251
Locale Setting: C | 2021-05-19 07:24:30.251
DLLs: UserContributedStudies_64.dll | 2021-05-19 07:24:30.252
Allowed protected custom studies: | 2021-05-19 07:24:30.252
CQG WebAPI | Connecting to server api.cqg.com | 2021-05-19 07:24:38.891
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-05-19 07:24:38.891
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2021-05-19 07:24:38.892
CQG WebSocket socket (1) | New receive buffer size: 5242880 | 2021-05-19 07:24:38.892
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2021-05-19 07:24:38.892
CQG WebSocket | Opening WebSocket. | 2021-05-19 07:24:38.940
CQG WebSocket | Sending WebSocket handshake. | 2021-05-19 07:24:38.940
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-19 07:24:39.090
CQG WebSocket | Server header | Connection: upgrade | 2021-05-19 07:24:39.090
CQG WebSocket | Server header | Sec-WebSocket-Accept: CLYJwnJZwlxSiuemhhs9yEP96XY= | 2021-05-19 07:24:39.090
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-05-19 07:24:39.090
CQG WebSocket | Server header | Upgrade: websocket | 2021-05-19 07:24:39.090
CQG WebSocket | Server header | | 2021-05-19 07:24:39.090
CQG WebSocket | Web socket state is now open. | 2021-05-19 07:24:39.090
CQG WebAPI | WebSocket connected. | 2021-05-19 07:24:39.090
CQG WebAPI | Sending market data logon message. | 2021-05-19 07:24:39.090
CQG WebAPI | Base Time: 2021-05-15T05:25:08. 2021-05-15 05:25:08 | 2021-05-19 07:24:39.262
CQG WebAPI | Logon successful. Session Token = XuyZnEl7hrWeq1nhdjX/aq0culNEy5TxYD5CRJOUONEUcYwjo/wRMe5g4faBY7UAvPaKaUBUs5N | 2021-05-19 07:24:39.262
CQG WebAPI | Connected to server complete. | 2021-05-19 07:24:39.262
Triggering next historical data download in queue. | 2021-05-19 07:24:39.266
Updated verified funded futures trading account ending date to: 2021-06-18 11:24:39 | 2021-05-19 07:24:39.266
CQG WebAPI | Sending Trade Accounts request message. | 2021-05-19 07:24:39.266
No download requests in the queue to start downloads for. | 2021-05-19 07:24:39.266
CQG WebAPI | Brokerage name: AMP. Account Name: 131106 | 2021-05-19 07:24:39.368
CQG WebAPI | Sending collateral subscribe request. | 2021-05-19 07:24:39.368
CQG WebAPI | Sending positions subscribe request. RequestID: 675860 | 2021-05-19 07:24:44.349
CQG WebAPI | Sending orders subscribe request. RequestID: 675861 | 2021-05-19 07:24:44.349
Socket (3) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-19 07:25:04.318
Socket (3) | Closed. | 2021-05-19 07:25:04.319
CQG WebSocket socket (14) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-19 07:25:04.319
CQG WebSocket socket (14) | Closed. | 2021-05-19 07:25:04.319
DTC Client socket (15) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-19 07:25:04.319
DTC Client socket (15) | Closed. | 2021-05-19 07:25:04.319
File >> Disconnect selected. | 2021-05-19 07:25:12.442
CQG WebAPI | Sending Web API Logoff message. | 2021-05-19 07:25:12.442
CQG WebSocket socket (1) | CloseSocket call. | 2021-05-19 07:25:12.442
CQG WebSocket | WebSocket closed. | 2021-05-19 07:25:12.442
CQG WebAPI | WebSocket closed. | 2021-05-19 07:25:12.442
CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2021-05-19 07:25:12.442
CQG WebAPI | Disconnected. | 2021-05-19 07:25:12.442
CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2021-05-19 07:25:12.489
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2021-05-19 07:25:12.489
CQG WebAPI | Connecting to server api.cqg.com | 2021-05-19 07:25:18.942
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2021-05-19 07:25:18.942
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2021-05-19 07:25:18.943
CQG WebSocket socket (2) | New receive buffer size: 5242880 | 2021-05-19 07:25:18.943
CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2021-05-19 07:25:18.943
CQG WebSocket | Opening WebSocket. | 2021-05-19 07:25:18.989
CQG WebSocket | Sending WebSocket handshake. | 2021-05-19 07:25:18.989
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2021-05-19 07:25:19.130
CQG WebSocket | Server header | Connection: upgrade | 2021-05-19 07:25:19.130
CQG WebSocket | Server header | Sec-WebSocket-Accept: 8x7UC3p6snljtr+IW+amt/jf41g= | 2021-05-19 07:25:19.130
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2021-05-19 07:25:19.130
CQG WebSocket | Server header | Upgrade: websocket | 2021-05-19 07:25:19.130
CQG WebSocket | Server header | | 2021-05-19 07:25:19.130
CQG WebSocket | Web socket state is now open. | 2021-05-19 07:25:19.130
CQG WebAPI | WebSocket connected. | 2021-05-19 07:25:19.130
CQG WebAPI | Sending market data logon message. | 2021-05-19 07:25:19.130
CQG WebAPI | Base Time: 2021-05-15T05:25:08. 2021-05-15 05:25:08 | 2021-05-19 07:25:19.285
CQG WebAPI | Logon successful. Session Token = Kv5ut+cEtGhwR5m1OIR0SmiAfm8eWFRFXERmTFhjplYfWYWsSvOcnbke4KzqwEID+yVlq7iFOZ4 | 2021-05-19 07:25:19.285
CQG WebAPI | Connected to server complete. | 2021-05-19 07:25:19.285
Triggering next historical data download in queue. | 2021-05-19 07:25:19.285
Updated verified funded futures trading account ending date to: 2021-06-18 11:25:19 | 2021-05-19 07:25:19.285
CQG WebAPI | Sending Trade Accounts request message. | 2021-05-19 07:25:19.286
No download requests in the queue to start downloads for. | 2021-05-19 07:25:19.286
CQG WebAPI | Brokerage name: AMP. Account Name: 131106 | 2021-05-19 07:25:19.381
CQG WebAPI | Sending collateral subscribe request. | 2021-05-19 07:25:19.381
CQG WebAPI | Sending positions subscribe request. RequestID: 675864 | 2021-05-19 07:25:24.278
CQG WebAPI | Sending orders subscribe request. RequestID: 675865 | 2021-05-19 07:25:24.278
Socket (3) | Deleting network socket now after delay. | 2021-05-19 07:25:34.331
CQG WebSocket socket (14) | Deleting network socket now after delay. | 2021-05-19 07:25:34.331
DTC Client socket (15) | Deleting network socket now after delay. | 2021-05-19 07:25:34.331
CQG WebSocket socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2021-05-19 07:27:34.379
CQG WebSocket socket (1) | Closed. | 2021-05-19 07:27:34.380
[2021-05-19 14:42:14]
What is in the log looks good, and you are making your connection to CQG.
What we want you to do is to open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will ensure that your symbols are set to the CQG symbols.
Then let us know if you have an issue.
Keep in mind, the Denali Exchange Data Feed is just data. Sierra Chart is setup to allow our data to be used when you are using another trading service. Refer to the following for more information:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Let us know if you continue to have an issue after you update the symbols.
