Date/Time: Tue, 25 Feb 2025 19:07:01 +0000
Denali feed- Not loading data
View Count: 705
[2021-04-12 17:30:33]
Yeager - Posts: 131
Hi, I am now paying for Denali CME bundle and Eurx feed. When I log into SC with this account id, The symbols have changed automatically, but the data I am getting seems to be limited on all products to the last 5 to 10 days and Im only getting live realtime from a handful of markets.
Please help.
I am switching back to the amp subscription account feed for now, but have little days remaining on this. ID: ACxxxx18
[2021-04-12 19:51:00]
John - SC Support - Posts: 38165
You need to only be logging into your Sierra Chart software with the account from which you posted this Support Board thread. Do NOT use the other account. The other account only still exists since we have added time to let people switch.
The account from which you posted has the correct Usage Time and has the Denali Exchange Data Feed active.
If you have logged into your Sierra Chart software with this account and you are having the issue you mention above, then do the following:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-04-13 22:11:24]
Yeager - Posts: 131
So I fixed the market profile as I had package 10 instead of 11 ie standard rather than advanced. Apologies.
However, I can only see Top of book on my ladders for 6E and CL. I have full book on DAX.
[2021-04-14 03:14:05]
You need to activate the exchange fees that support market depth for the exchanges that you need:
Real-Time Exchange Data Feeds Available From Sierra Chart: Adding Support for CME Market Depth Data
[2021-04-26 09:45:34]
Yeager - Posts: 131
Hi John,
Here is the message log after a clearing of it as requested. I recently connected to LIVE trading account. However when I log in, on my profile page, it says that the trading account is not verified since last september? Could this be an issue? I have an AMP account.
I have also noted at about 4pm GMT and 7am to 8am GMT thatall the charts seem to be performing a type of reference check and seem to be stuckj in an update loop where they all glitch constantly.
Software version: 2230 64-bit | 2021-04-26 10:40:52.952
(Message log removed)
Date Time Of Last Edit: 2021-04-26 15:26:58
[2021-04-26 15:27:55]
First you can disable the heartbeat logging. You do not need that. You can disable that through Global Settings >> Sierra Chart Server Settings.
We want you to do this again, and then follow the instructions below. You might be connecting to a demo account.
Reconnect to the data feed:
We are not sure exactly what is happening. We want you to update to the current version:
And if you have any further issue, provide the Message Log at the time.
Date Time Of Last Edit: 2021-04-26 15:30:27
