Date/Time: Tue, 25 Feb 2025 05:07:13 +0000
data bars are not showing up
View Count: 609
[2021-04-05 05:39:48]
timin - Posts: 36
hi, i have just started up my chartbook, and all the charts that i was using on friday are no longer displaying the information. for example, all of my footprint charts are blank, my volume bars are blank. the only thing that is working are my candlestick charts. is there a reason for this? i just changed my data from cqg back to denali, but all the data is coming in, so its not a data problem. does my account no longer have access to non-candlesick data?(which i doubt). In my chart settings, the 'graph draw type' is set to blank, but i dont think this is the problem because when i set it to anything thats not blank i still dont get anything. what can be done?
thanks
[2021-04-05 16:20:58]
John - SC Support - Posts: 38150
On March 2, 2021 you changed from Package 5 to Package 3. At that time you would not have had access to the Numbers Bars or Drawn Volume by Price graphs, as these are in the Advanced Package.
When you switched to Package 10 on March 30, 2021, this does not change the ability to get access to the Advanced Package, as Package 10 is the Standard Package + the Denali Exchange Data Feed Fee.
Therefore, if you want to have access to the Advanced Package options, you would need to change to Package 11.
Refer to the following for the Package descriptions:
Description of Service Packages and Pricing: Packages
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
