Date/Time: Mon, 24 Feb 2025 18:29:50 +0000
problems with AMP connectivity and trading
View Count: 656
[2021-03-18 17:06:27]
User61576 - Posts: 445
hi
my trade-->"account balance window" is not updated
account with AMP
any idea what shall I do?
another issue is that when trying to send an order and I get
SC Futures Order Routing/Data order update (Order reject). Info: TT order update (Rejected). Text: Account acXXXXXX not found. Text: Parent order. Tag: SimpleBracket.twconfig. Internal Order ID: 56515. Service Order ID: 4917483. Symbol: ESM21_FUT_CME. Account: ACXXXXXX | 2021-03-18 09:38:53.917 *
[2021-03-18 20:20:09]
John - SC Support - Posts: 38143
AMP is no longer supporting the Sierra Chart Order Routing Service. You should have received information from AMP that they were moving you to CQG for order routing. If you have your CQG information, then you need to follow these instructions to setup your Sierra Chart to connect to CQG:
CQG Trading Platform Service: Setup Instructions
If you do not have the CQG information then get with AMP and ask them about it. Once you get the credentials, follow the instructions as noted above.
After you complete the instructions, then open your Chartbooks and select Edit >> Translate Symbols to Current Service to update your symbols to CQG symbols.
[2021-03-18 20:24:47]
so my data feed will be Denali but execution will be through CQG?
[2021-03-18 20:53:53]
Correct.
[2021-03-19 10:19:05]
if my feed is Denali, why there is a symbol change?
also if I have 2 instances, 1 in live trading through CQG, and the 2nd instance with Denali (in terms of symbol structure)? or it's both denlai juts the structure of the name is different?
[2021-03-19 14:14:49]
The symbols are different depending on the service selected. All services use a different set of symbols. We take care of translating the symbol for the specific service to what you need from the data feed. But you do need to select the right symbol for the service that is selected. The best way to do this is to open all new symbols from the Find Symbol page.
And if you change the setting for Service in the Data/Trade Service Settings, you are asked to update the symbols, but it is also a good idea to select Edit >> Translate Symbols to Current Service.
