Date/Time: Thu, 24 Sep 2026 23:50:17 +0000
Slow Data Downloading from Interactive Brokers
View Count: 2140
| [2021-01-19 20:34:00] |
| User1967 - Posts: 34 |
Hello, I have been using SC for a long time now but all of sudden, Sierra has slowed down tremendously while loading chart data for Stocks. Currently, I am using Sierra with IBKR data feed for stocks and it was running fine a while ago. However, for last few weeks it takes very long to update a chart making it useless to wait for stock chart to update for trading. Here is a snapshot of the screen. Please note that this has been occurring for a last few weeks only and prior to this everything was fine. http://www.sierrachart.com/image.php?Image=1611088358157.png Would appreciate your help to resolve this issue. Regards |
| [2021-01-19 21:14:36] |
You can now see the reality of Interactive Brokers terrible and unsuitable historical data. You need to use the Sierra Chart Exchange Data Feed and the US Equities exchange: Sierra Chart Exchange Data Feed Also be aware we are planning on offering a new NASDAQ data feed with market depth as part of the Denali Exchange Data Feed. ----- We are no longer as of December 28, 2020 providing the Sierra Chart provided historical data service for CQG or Interactive Brokers users. For more information, refer to this Support Board thread: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG Also refer to this post for steps that you need to do now: Jan 1, 2021 Changes to Historical Data: Interactive Brokers, CQG | Post: 245144 The solution to this problem is to use the Denali Exchange Data Feed for CME and EUREX (Upcoming in January 2021) data. Step-by-step instructions are here: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* The first calendar month of this data feed is free. Let us know if you need help with the set up and we will help you through all of the steps. In the case of CQG you will then need to contact your broker and cancel CME and EUREX exchange fees through your CQG account so you do not pay exchange fees twice. You definitively do not have to pay any market data exchange fees through your brokerage account to CQG. This is not required. For other exchanges (ICE, HKFE) you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed As an alternative to CQG, we recommend using the Sierra Chart Order Routing Service: Sierra Chart / Trading Technologies Futures Order Routing Service In regards to using CQG provided historical data, we definitely do not recommend using that. It has an additional cost of 25 USD per month. The data delivery is slow and inefficient and causes Sierra Chart to freeze during the processing of it. Only 5 days of tick data is supported from CQG. And only current futures contracts are provided. Whereas with Sierra Chart provided data feeds, you will have access to 10+ years of reliable high-speed delivered tick by tick data. Once again we do not advise using CQG historical data and it will not work well with Sierra Chart. And we also provide no technical help or support for any CQG provided historical data or real-time data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-01-19 21:17:10
| [2021-02-08 14:33:22] |
Hello, The SierraChart is continuously disconnecting to the IBKR account. This has been happening for last 3 days. Even if I switch to Denali or SierraChart Exchange Data Feed then would I be able to use my IBKR account for stock trading or I need to move to another broker? This has become irritating for me and I might need to drop using SC at all... Please help !!! |
| [2021-02-08 17:13:51] |
Let us see what we can determine about this. Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log And then when you notice the disconnection provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-08 17:13:59
| [2021-02-08 17:32:35] |
Hello, it keeps connecting and discontinuing. Here is the copy of message log as requested: Software version: 2135 64-bit | 2021-02-08 11:30:32.417 Primary Thread ID: 19208 | 2021-02-08 11:30:32.417 Usage end date: 2021-07-06 | 2021-02-08 11:30:32.417 Enabled for: Advanced Features 2. | 2021-02-08 11:30:32.417 Enabled for: Sierra Chart Historical Data Service. | 2021-02-08 11:30:32.417 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-02-08 11:30:32.417 Allow Support for Sierra Chart Data Feeds is enabled. | 2021-02-08 11:30:32.417 Current selected Data/Trading service: Interactive Brokers | 2021-02-08 11:30:32.417 Custom symbol settings values: enabled | 2021-02-08 11:30:32.417 Chart Update Interval: 500 | 2021-02-08 11:30:32.417 Intraday Data Storage Time Unit: 0 | 2021-02-08 11:30:32.417 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-02-08 11:30:32.417 2021-02-08 11:30:32 Local computer time | 2021-02-08 11:30:32.417 2021-02-08 17:30:32 Local computer time in UTC | 2021-02-08 11:30:32.417 2021-02-08 11:30:32 Local computer time in SC Time Zone | 2021-02-08 11:30:32.417 2021-02-08 17:29:16 Server time in UTC | 2021-02-08 11:30:32.417 Local computer UTC time and Server UTC time difference: 1 seconds. | 2021-02-08 11:30:32.417 Program path: C:\SierraChart\ | 2021-02-08 11:30:32.417 Data Files path: C:\SierraChart\Data\ | 2021-02-08 11:30:32.417 OS Version Number: 10.0 | 2021-02-08 11:30:32.417 Locale Setting: C | 2021-02-08 11:30:32.417 Allowed protected custom studies: zyp_download_free | 2021-02-08 11:30:32.417 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:32.967 IB TWS socket (3) | Creating socket. | 2021-02-08 11:30:32.967 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:32.967 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:33.476 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:33.476 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:33.489 Interactive Brokers | TWS time: 20210208 11:30:33 Central Standard Time | 2021-02-08 11:30:33.489 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:33.741 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:33.741 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:33.742 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:33.742 IB Account information received. | 2021-02-08 11:30:33.742 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:33.742 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:33.742 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:33.742 Triggering next historical data download in queue. | 2021-02-08 11:30:33.744 Triggering next historical data download in queue. | 2021-02-08 11:30:33.744 Triggering next historical data download in queue. | 2021-02-08 11:30:33.744 Triggering next historical data download in queue. | 2021-02-08 11:30:33.744 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:34 | 2021-02-08 11:30:33.744 Next valid order ID: 31226 | 2021-02-08 11:30:33.757 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:33.757 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:33.757 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:33.757 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:33.757 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:33.757 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:33.757 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:33.757 Next valid order ID: 31226 | 2021-02-08 11:30:33.757 Interactive Brokers | Starting real-time market data updates for: SPY. ID: 1 | 2021-02-08 11:30:33.757 Interactive Brokers | Subscribing to Symbol: SPY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.757 Interactive Brokers | Requesting security definition data for: SPY. ID: 1 | 2021-02-08 11:30:33.757 Delaying start of download for SPY | 2021-02-08 11:30:33.757 Next valid order ID: 31226 | 2021-02-08 11:30:33.757 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 2 | 2021-02-08 11:30:33.760 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.760 Interactive Brokers | Requesting security definition data for: UPS. ID: 2 | 2021-02-08 11:30:33.760 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:30:33.760 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:30:33.760 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:30:33.760 Triggering next historical data download in queue. | 2021-02-08 11:30:33.760 Interactive Brokers | Starting real-time market data updates for: NIO. ID: 3 | 2021-02-08 11:30:33.761 Interactive Brokers | Subscribing to Symbol: NIO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.761 Interactive Brokers | Requesting security definition data for: NIO. ID: 3 | 2021-02-08 11:30:33.761 Interactive Brokers | Using primary service for historical data for NIO | 2021-02-08 11:30:33.761 Added historical Intraday data request for NIO to the queue. | 2021-02-08 11:30:33.761 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-02-08 11:30:33.761 Triggering next historical data download in queue. | 2021-02-08 11:30:33.761 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 4 | 2021-02-08 11:30:33.775 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.775 Interactive Brokers | Requesting security definition data for: MSFT. ID: 4 | 2021-02-08 11:30:33.775 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:30:33.775 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:30:33.775 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:30:33.775 Triggering next historical data download in queue. | 2021-02-08 11:30:33.775 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 5 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: LGND. ID: 5 | 2021-02-08 11:30:33.794 Interactive Brokers | Starting real-time market data updates for: GME. ID: 6 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: GME. ID: 6 | 2021-02-08 11:30:33.794 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 7 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: MDGL. ID: 7 | 2021-02-08 11:30:33.794 IB TWS socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:33.794 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:33.794 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:33.794 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 8 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: IRBT. ID: 8 | 2021-02-08 11:30:33.794 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 9 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: CVNA. ID: 9 | 2021-02-08 11:30:33.794 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 10 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: SPWR. ID: 10 | 2021-02-08 11:30:33.794 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 11 | 2021-02-08 11:30:33.794 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.794 Interactive Brokers | Requesting security definition data for: SCVL. ID: 11 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 12 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: GSX. ID: 12 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 13 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: BLNK. ID: 13 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 14 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: OTRK. ID: 14 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 15 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: VIAC. ID: 15 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 16 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 16 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 17 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: CVM. ID: 17 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 18 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: RUBY. ID: 18 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 19 | 2021-02-08 11:30:33.795 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.795 Interactive Brokers | Requesting security definition data for: CAKE. ID: 19 | 2021-02-08 11:30:33.795 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 20 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: RVP. ID: 20 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: NK. ID: 21 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: NK. ID: 21 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 22 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: RXT. ID: 22 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 23 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: DDS. ID: 23 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 24 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: LAZR. ID: 24 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 25 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: AXDX. ID: 25 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 26 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: DKS. ID: 26 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 27 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: CLVS. ID: 27 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 28 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: AKTS. ID: 28 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 29 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: BYND. ID: 29 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: APT. ID: 30 | 2021-02-08 11:30:33.796 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.796 Interactive Brokers | Requesting security definition data for: APT. ID: 30 | 2021-02-08 11:30:33.796 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 31 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: HIBB. ID: 31 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 32 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: LOVE. ID: 32 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 33 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: MIK. ID: 33 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 34 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: PGEN. ID: 34 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 35 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: SKT. ID: 35 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 36 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: SENS. ID: 36 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: INO. ID: 37 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: INO. ID: 37 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 38 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: AWH. ID: 38 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 39 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: FLXN. ID: 39 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 40 | 2021-02-08 11:30:33.797 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.797 Interactive Brokers | Requesting security definition data for: OPK. ID: 40 | 2021-02-08 11:30:33.797 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 41 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: RGS. ID: 41 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 42 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: SRNE. ID: 42 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: REV. ID: 43 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: REV. ID: 43 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 44 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: EBIX. ID: 44 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 45 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: ICPT. ID: 45 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 46 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: PECK. ID: 46 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 47 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: BBBY. ID: 47 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 48 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: PRTS. ID: 48 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 49 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: KNDI. ID: 49 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 50 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: JWN. ID: 50 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 51 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: CEMI. ID: 51 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 52 | 2021-02-08 11:30:33.798 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.798 Interactive Brokers | Requesting security definition data for: LCI. ID: 52 | 2021-02-08 11:30:33.798 Interactive Brokers | Starting real-time market data updates for: TR. ID: 53 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: TR. ID: 53 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 54 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: SOLY. ID: 54 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 55 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: GOGO. ID: 55 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 56 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: DVAX. ID: 56 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 57 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: AMC. ID: 57 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 58 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: TLRY. ID: 58 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 59 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: RKT. ID: 59 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 60 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: GTT. ID: 60 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 61 | 2021-02-08 11:30:33.799 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.799 Interactive Brokers | Requesting security definition data for: OMER. ID: 61 | 2021-02-08 11:30:33.799 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 62 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: SPCE. ID: 62 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 63 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: SRG. ID: 63 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 64 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: VTVT. ID: 64 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 65 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: SDC. ID: 65 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 66 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: APRN. ID: 66 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 67 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: WKHS. ID: 67 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 68 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: PETS. ID: 68 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 69 | 2021-02-08 11:30:33.800 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.800 Interactive Brokers | Requesting security definition data for: SFIX. ID: 69 | 2021-02-08 11:30:33.800 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 70 | 2021-02-08 11:30:33.801 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.801 Interactive Brokers | Requesting security definition data for: RVLV. ID: 70 | 2021-02-08 11:30:33.801 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 71 | 2021-02-08 11:30:33.801 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.801 Interactive Brokers | Requesting security definition data for: BKE. ID: 71 | 2021-02-08 11:30:33.801 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 72 | 2021-02-08 11:30:33.801 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.801 Interactive Brokers | Requesting security definition data for: FUBO. ID: 72 | 2021-02-08 11:30:33.801 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 73 | 2021-02-08 11:30:33.801 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.801 Interactive Brokers | Requesting security definition data for: SIG. ID: 73 | 2021-02-08 11:30:33.801 Interactive Brokers | Starting real-time market data updates for: W. ID: 74 | 2021-02-08 11:30:33.801 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:33.801 Interactive Brokers | Requesting security definition data for: W. ID: 74 | 2021-02-08 11:30:33.801 Message from IB: Error reading request.Message id 5. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 5. Symbol: LGND. | 2021-02-08 11:30:33.802 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:30:33.802 Connection to the external service has been lost. | 2021-02-08 11:30:33.802 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:33.802 IB TWS socket (3) | Closed. | 2021-02-08 11:30:33.802 Canceling historical data download request for UPS Intraday data. | 2021-02-08 11:30:33.996 Removing historical data download ID 81. | 2021-02-08 11:30:33.996 Canceling historical data download request for NIO Intraday data. | 2021-02-08 11:30:33.996 Removing historical data download ID 82. | 2021-02-08 11:30:33.996 Canceling historical data download request for MSFT Intraday data. | 2021-02-08 11:30:33.996 Removing historical data download ID 83. | 2021-02-08 11:30:33.996 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:33.996 Interactive Brokers | Disconnected. | 2021-02-08 11:30:33.996 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:33.996 HD Request # 26 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: interactive_brokers.trading | 2021-02-08 11:30:34.035 HD Request # 26 | Download start date-time: 2021-02-05 12:30:13.000 | 2021-02-08 11:30:34.037 HD Request # 26 | Requesting a total of 3 days and 1221 seconds. | 2021-02-08 11:30:34.037 HD Request # 26 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174021. | 2021-02-08 11:30:34.037 HD Request # 26 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:13 for SPY. PriceType: TRADES | 2021-02-08 11:30:34.037 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:36.993 IB TWS socket (3) | Creating socket. | 2021-02-08 11:30:36.993 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:36.993 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:37.504 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:37.504 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:37.509 Interactive Brokers | TWS time: 20210208 11:30:37 Central Standard Time | 2021-02-08 11:30:37.509 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:37.767 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:37.767 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:37.769 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:37.769 IB Account information received. | 2021-02-08 11:30:37.769 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:37.769 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:37.769 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:37.769 Triggering next historical data download in queue. | 2021-02-08 11:30:37.772 Triggering next historical data download in queue. | 2021-02-08 11:30:37.772 Triggering next historical data download in queue. | 2021-02-08 11:30:37.772 Triggering next historical data download in queue. | 2021-02-08 11:30:37.773 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:38 | 2021-02-08 11:30:37.773 Next valid order ID: 31226 | 2021-02-08 11:30:37.799 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:37.799 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:37.799 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:37.799 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:37.799 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:37.799 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:37.799 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:37.799 Next valid order ID: 31226 | 2021-02-08 11:30:37.799 Next valid order ID: 31226 | 2021-02-08 11:30:37.800 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 1 | 2021-02-08 11:30:37.801 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.801 Interactive Brokers | Requesting security definition data for: UPS. ID: 1 | 2021-02-08 11:30:37.801 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:30:37.801 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:30:37.801 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:30:37.801 Triggering next historical data download in queue. | 2021-02-08 11:30:37.801 Interactive Brokers | Starting real-time market data updates for: NIO. ID: 2 | 2021-02-08 11:30:37.803 Interactive Brokers | Subscribing to Symbol: NIO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.803 Interactive Brokers | Requesting security definition data for: NIO. ID: 2 | 2021-02-08 11:30:37.803 Interactive Brokers | Using primary service for historical data for NIO | 2021-02-08 11:30:37.803 Added historical Intraday data request for NIO to the queue. | 2021-02-08 11:30:37.803 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-02-08 11:30:37.803 Triggering next historical data download in queue. | 2021-02-08 11:30:37.803 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 3 | 2021-02-08 11:30:37.835 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.835 Interactive Brokers | Requesting security definition data for: MSFT. ID: 3 | 2021-02-08 11:30:37.835 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:30:37.835 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:30:37.835 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:30:37.835 Triggering next historical data download in queue. | 2021-02-08 11:30:37.835 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 4 | 2021-02-08 11:30:37.874 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.874 Interactive Brokers | Requesting security definition data for: VXRT. ID: 4 | 2021-02-08 11:30:37.874 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:30:37.874 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:30:37.874 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:30:37.874 Triggering next historical data download in queue. | 2021-02-08 11:30:37.874 Interactive Brokers | Market data type is Live for UPS | 2021-02-08 11:30:37.902 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 5 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: LGND. ID: 5 | 2021-02-08 11:30:37.909 Interactive Brokers | Starting real-time market data updates for: GME. ID: 6 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: GME. ID: 6 | 2021-02-08 11:30:37.909 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 7 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: MDGL. ID: 7 | 2021-02-08 11:30:37.909 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 8 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: IRBT. ID: 8 | 2021-02-08 11:30:37.909 IB TWS socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:37.909 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:37.909 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:37.909 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 9 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: CVNA. ID: 9 | 2021-02-08 11:30:37.909 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 10 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: SPWR. ID: 10 | 2021-02-08 11:30:37.909 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 11 | 2021-02-08 11:30:37.909 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.909 Interactive Brokers | Requesting security definition data for: SCVL. ID: 11 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 12 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: GSX. ID: 12 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 13 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: BLNK. ID: 13 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 14 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: OTRK. ID: 14 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 15 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: VIAC. ID: 15 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 16 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 16 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 17 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: CVM. ID: 17 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 18 | 2021-02-08 11:30:37.910 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.910 Interactive Brokers | Requesting security definition data for: RUBY. ID: 18 | 2021-02-08 11:30:37.910 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 19 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: CAKE. ID: 19 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 20 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: RVP. ID: 20 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: NK. ID: 21 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: NK. ID: 21 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 22 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: RXT. ID: 22 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 23 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: DDS. ID: 23 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 24 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: LAZR. ID: 24 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 25 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: AXDX. ID: 25 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 26 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: DKS. ID: 26 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 27 | 2021-02-08 11:30:37.911 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.911 Interactive Brokers | Requesting security definition data for: CLVS. ID: 27 | 2021-02-08 11:30:37.911 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 28 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: AKTS. ID: 28 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 29 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: BYND. ID: 29 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: APT. ID: 30 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: APT. ID: 30 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 31 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: HIBB. ID: 31 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 32 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: LOVE. ID: 32 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 33 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: MIK. ID: 33 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 34 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: PGEN. ID: 34 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 35 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: SKT. ID: 35 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 36 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: SENS. ID: 36 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: INO. ID: 37 | 2021-02-08 11:30:37.912 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.912 Interactive Brokers | Requesting security definition data for: INO. ID: 37 | 2021-02-08 11:30:37.912 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 38 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: AWH. ID: 38 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 39 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: FLXN. ID: 39 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 40 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: OPK. ID: 40 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 41 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: RGS. ID: 41 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 42 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: SRNE. ID: 42 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: REV. ID: 43 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: REV. ID: 43 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 44 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: EBIX. ID: 44 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 45 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: ICPT. ID: 45 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 46 | 2021-02-08 11:30:37.913 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.913 Interactive Brokers | Requesting security definition data for: PECK. ID: 46 | 2021-02-08 11:30:37.913 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 47 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: BBBY. ID: 47 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 48 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: PRTS. ID: 48 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 49 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: KNDI. ID: 49 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 50 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: JWN. ID: 50 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 51 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: CEMI. ID: 51 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 52 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: LCI. ID: 52 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: TR. ID: 53 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: TR. ID: 53 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 54 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: SOLY. ID: 54 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 55 | 2021-02-08 11:30:37.914 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.914 Interactive Brokers | Requesting security definition data for: GOGO. ID: 55 | 2021-02-08 11:30:37.914 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 56 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: DVAX. ID: 56 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 57 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: AMC. ID: 57 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 58 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: TLRY. ID: 58 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 59 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: RKT. ID: 59 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 60 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: GTT. ID: 60 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 61 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: OMER. ID: 61 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 62 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: SPCE. ID: 62 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 63 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: SRG. ID: 63 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 64 | 2021-02-08 11:30:37.915 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.915 Interactive Brokers | Requesting security definition data for: VTVT. ID: 64 | 2021-02-08 11:30:37.915 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 65 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: SDC. ID: 65 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 66 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: APRN. ID: 66 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 67 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: WKHS. ID: 67 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 68 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: PETS. ID: 68 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 69 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: SFIX. ID: 69 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 70 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: RVLV. ID: 70 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 71 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: BKE. ID: 71 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 72 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: FUBO. ID: 72 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 73 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: SIG. ID: 73 | 2021-02-08 11:30:37.916 Interactive Brokers | Starting real-time market data updates for: W. ID: 74 | 2021-02-08 11:30:37.916 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:37.916 Interactive Brokers | Requesting security definition data for: W. ID: 74 | 2021-02-08 11:30:37.916 Message from IB: Error reading request.Message id 5. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 5. Symbol: LGND. | 2021-02-08 11:30:37.918 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:30:37.918 Connection to the external service has been lost. | 2021-02-08 11:30:37.918 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:37.918 IB TWS socket (3) | Closed. | 2021-02-08 11:30:37.918 Canceling historical data download request for UPS Intraday data. | 2021-02-08 11:30:38.000 Removing historical data download ID 84. | 2021-02-08 11:30:38.000 Canceling historical data download request for NIO Intraday data. | 2021-02-08 11:30:38.000 Removing historical data download ID 85. | 2021-02-08 11:30:38.000 Canceling historical data download request for MSFT Intraday data. | 2021-02-08 11:30:38.000 Removing historical data download ID 86. | 2021-02-08 11:30:38.000 Canceling historical data download request for VXRT Intraday data. | 2021-02-08 11:30:38.000 Removing historical data download ID 87. | 2021-02-08 11:30:38.001 HD Request # 26 | Download canceled. | 2021-02-08 11:30:38.001 HD Request # 26 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for SPY | 2021-02-08 11:30:38.001 HD Request # 26 | Completion time: 4s | 2021-02-08 11:30:38.001 HD Request # 26 | Intraday data download complete for SPY. Unique request ID: 80 | 2021-02-08 11:30:38.001 Removing historical data download ID 80. | 2021-02-08 11:30:38.001 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:38.001 Triggering next historical data download in queue. | 2021-02-08 11:30:38.001 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:38.001 Interactive Brokers | Disconnected. | 2021-02-08 11:30:38.001 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:38.001 HD Server | HD Request #28 | Socket: 1 | Symbol: SPY | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 2219 | ClientRequestID: 28 | Username: ghsabri. | Thread:5892 | 2021-02-08 11:30:38.990 HD Server | Thread:5892 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:30:38.991 HD Server | Thread:5892 (1) | CloseSocket call. | 2021-02-08 11:30:38.991 HD Server | Thread:5892 (0) | CloseSocket call. | 2021-02-08 11:30:38.993 HD Server | Thread:5892 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:38.993 HD Server | Thread:5892 (1) | Closed. | 2021-02-08 11:30:38.993 HD Server | Thread:5892 (0) | CloseSocket call. | 2021-02-08 11:30:38.994 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:30:38.998 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:30:38.999 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:5892 | 2021-02-08 11:30:39.011 HD Server Manager | Current server count=1 | 2021-02-08 11:30:39.012 HD Server | Thread:8976 (1) | Creating socket. | 2021-02-08 11:30:39.015 HD Server | Setting DTC encoding to Binary VLS | Thread:8976 | 2021-02-08 11:30:39.015 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:8976 | 2021-02-08 11:30:39.016 HD Server | Login has been authorized. | Username: ghsabri. | Thread:8976 | 2021-02-08 11:30:39.016 HD Server | HD Request #29 | Socket: 1 | Symbol: QQQ | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-05 18:30:45 | ClientRequestID: 29 | Username: ghsabri. | Thread:8976 | 2021-02-08 11:30:39.016 Interactive Brokers | Using primary service for historical data for QQQ | 2021-02-08 11:30:39.016 Added historical Intraday data request for QQQ to the queue. | 2021-02-08 11:30:39.016 Intraday data recording state for symbol QQQ is set to download 'Pending'. | 2021-02-08 11:30:39.016 Triggering next historical data download in queue. | 2021-02-08 11:30:39.016 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:40.995 IB TWS socket (3) | Creating socket. | 2021-02-08 11:30:40.996 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:40.996 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:41.512 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:41.512 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:41.519 Interactive Brokers | TWS time: 20210208 11:30:41 Central Standard Time | 2021-02-08 11:30:41.519 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:41.771 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:41.771 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:41.773 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:41.774 IB Account information received. | 2021-02-08 11:30:41.774 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:41.774 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:41.774 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:41.774 Triggering next historical data download in queue. | 2021-02-08 11:30:41.777 Triggering next historical data download in queue. | 2021-02-08 11:30:41.777 Triggering next historical data download in queue. | 2021-02-08 11:30:41.777 Triggering next historical data download in queue. | 2021-02-08 11:30:41.777 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:42 | 2021-02-08 11:30:41.777 Next valid order ID: 31226 | 2021-02-08 11:30:41.805 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:41.805 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:41.805 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:41.805 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:41.805 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:41.806 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:41.806 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:41.806 Next valid order ID: 31226 | 2021-02-08 11:30:41.806 Interactive Brokers | Starting real-time market data updates for: QQQ. ID: 1 | 2021-02-08 11:30:41.806 Interactive Brokers | Subscribing to Symbol: QQQ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.806 Interactive Brokers | Requesting security definition data for: QQQ. ID: 1 | 2021-02-08 11:30:41.806 Delaying start of download for QQQ | 2021-02-08 11:30:41.806 Next valid order ID: 31226 | 2021-02-08 11:30:41.806 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 2 | 2021-02-08 11:30:41.836 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.836 Interactive Brokers | Requesting security definition data for: MSFT. ID: 2 | 2021-02-08 11:30:41.836 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:30:41.836 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:30:41.836 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:30:41.836 Triggering next historical data download in queue. | 2021-02-08 11:30:41.837 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 3 | 2021-02-08 11:30:41.855 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.855 Interactive Brokers | Requesting security definition data for: VXRT. ID: 3 | 2021-02-08 11:30:41.855 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:30:41.855 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:30:41.855 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:30:41.855 Triggering next historical data download in queue. | 2021-02-08 11:30:41.855 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 4 | 2021-02-08 11:30:41.883 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.883 Interactive Brokers | Requesting security definition data for: LGND. ID: 4 | 2021-02-08 11:30:41.883 Interactive Brokers | Starting real-time market data updates for: GME. ID: 5 | 2021-02-08 11:30:41.883 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.883 Interactive Brokers | Requesting security definition data for: GME. ID: 5 | 2021-02-08 11:30:41.883 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 6 | 2021-02-08 11:30:41.883 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: MDGL. ID: 6 | 2021-02-08 11:30:41.884 IB TWS socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 7 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: IRBT. ID: 7 | 2021-02-08 11:30:41.884 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:41.884 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 8 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: CVNA. ID: 8 | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 9 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: SPWR. ID: 9 | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 10 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: SCVL. ID: 10 | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 11 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: GSX. ID: 11 | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 12 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: BLNK. ID: 12 | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 13 | 2021-02-08 11:30:41.884 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.884 Interactive Brokers | Requesting security definition data for: OTRK. ID: 13 | 2021-02-08 11:30:41.884 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 14 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: VIAC. ID: 14 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 15 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 15 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 16 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: CVM. ID: 16 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 17 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: RUBY. ID: 17 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 18 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: CAKE. ID: 18 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 19 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: RVP. ID: 19 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: NK. ID: 20 | 2021-02-08 11:30:41.885 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.885 Interactive Brokers | Requesting security definition data for: NK. ID: 20 | 2021-02-08 11:30:41.885 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 21 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: RXT. ID: 21 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 22 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: DDS. ID: 22 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 23 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: LAZR. ID: 23 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 24 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: AXDX. ID: 24 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 25 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: DKS. ID: 25 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 26 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: CLVS. ID: 26 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 27 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: AKTS. ID: 27 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 28 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: BYND. ID: 28 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: APT. ID: 29 | 2021-02-08 11:30:41.886 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.886 Interactive Brokers | Requesting security definition data for: APT. ID: 29 | 2021-02-08 11:30:41.886 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 30 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: HIBB. ID: 30 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 31 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: LOVE. ID: 31 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 32 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: MIK. ID: 32 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 33 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: PGEN. ID: 33 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 34 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: SKT. ID: 34 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 35 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: SENS. ID: 35 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: INO. ID: 36 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: INO. ID: 36 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 37 | 2021-02-08 11:30:41.887 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.887 Interactive Brokers | Requesting security definition data for: AWH. ID: 37 | 2021-02-08 11:30:41.887 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 38 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: FLXN. ID: 38 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 39 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: OPK. ID: 39 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 40 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: RGS. ID: 40 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 41 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: SRNE. ID: 41 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: REV. ID: 42 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: REV. ID: 42 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 43 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: EBIX. ID: 43 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 44 | 2021-02-08 11:30:41.888 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.888 Interactive Brokers | Requesting security definition data for: ICPT. ID: 44 | 2021-02-08 11:30:41.888 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 45 | 2021-02-08 11:30:41.889 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.889 Interactive Brokers | Requesting security definition data for: PECK. ID: 45 | 2021-02-08 11:30:41.889 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 46 | 2021-02-08 11:30:41.889 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.889 Interactive Brokers | Requesting security definition data for: BBBY. ID: 46 | 2021-02-08 11:30:41.889 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 47 | 2021-02-08 11:30:41.889 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.889 Interactive Brokers | Requesting security definition data for: PRTS. ID: 47 | 2021-02-08 11:30:41.889 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 48 | 2021-02-08 11:30:41.889 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.889 Interactive Brokers | Requesting security definition data for: KNDI. ID: 48 | 2021-02-08 11:30:41.889 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 49 | 2021-02-08 11:30:41.889 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.889 Interactive Brokers | Requesting security definition data for: JWN. ID: 49 | 2021-02-08 11:30:41.889 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 50 | 2021-02-08 11:30:41.889 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.889 Interactive Brokers | Requesting security definition data for: CEMI. ID: 50 | 2021-02-08 11:30:41.889 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 51 | 2021-02-08 11:30:41.890 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.890 Interactive Brokers | Requesting security definition data for: LCI. ID: 51 | 2021-02-08 11:30:41.890 Interactive Brokers | Starting real-time market data updates for: TR. ID: 52 | 2021-02-08 11:30:41.890 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.890 Interactive Brokers | Requesting security definition data for: TR. ID: 52 | 2021-02-08 11:30:41.890 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 53 | 2021-02-08 11:30:41.890 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.890 Interactive Brokers | Requesting security definition data for: SOLY. ID: 53 | 2021-02-08 11:30:41.890 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 54 | 2021-02-08 11:30:41.890 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.890 Interactive Brokers | Requesting security definition data for: GOGO. ID: 54 | 2021-02-08 11:30:41.890 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 55 | 2021-02-08 11:30:41.890 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.890 Interactive Brokers | Requesting security definition data for: DVAX. ID: 55 | 2021-02-08 11:30:41.890 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 56 | 2021-02-08 11:30:41.891 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.891 Interactive Brokers | Requesting security definition data for: AMC. ID: 56 | 2021-02-08 11:30:41.891 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 57 | 2021-02-08 11:30:41.891 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.891 Interactive Brokers | Requesting security definition data for: TLRY. ID: 57 | 2021-02-08 11:30:41.891 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 58 | 2021-02-08 11:30:41.891 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.891 Interactive Brokers | Requesting security definition data for: RKT. ID: 58 | 2021-02-08 11:30:41.891 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 59 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: GTT. ID: 59 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 60 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: OMER. ID: 60 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 61 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: SPCE. ID: 61 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 62 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: SRG. ID: 62 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 63 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: VTVT. ID: 63 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 64 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: SDC. ID: 64 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 65 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: APRN. ID: 65 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 66 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: WKHS. ID: 66 | 2021-02-08 11:30:41.892 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 67 | 2021-02-08 11:30:41.892 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.892 Interactive Brokers | Requesting security definition data for: PETS. ID: 67 | 2021-02-08 11:30:41.893 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 68 | 2021-02-08 11:30:41.893 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.893 Interactive Brokers | Requesting security definition data for: SFIX. ID: 68 | 2021-02-08 11:30:41.893 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 69 | 2021-02-08 11:30:41.893 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.893 Interactive Brokers | Requesting security definition data for: RVLV. ID: 69 | 2021-02-08 11:30:41.893 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 70 | 2021-02-08 11:30:41.893 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.893 Interactive Brokers | Requesting security definition data for: BKE. ID: 70 | 2021-02-08 11:30:41.893 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 71 | 2021-02-08 11:30:41.893 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.893 Interactive Brokers | Requesting security definition data for: FUBO. ID: 71 | 2021-02-08 11:30:41.893 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 72 | 2021-02-08 11:30:41.893 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.893 Interactive Brokers | Requesting security definition data for: SIG. ID: 72 | 2021-02-08 11:30:41.893 Interactive Brokers | Starting real-time market data updates for: W. ID: 73 | 2021-02-08 11:30:41.893 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:41.893 Interactive Brokers | Requesting security definition data for: W. ID: 73 | 2021-02-08 11:30:41.893 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:30:41.896 Connection to the external service has been lost. | 2021-02-08 11:30:41.896 IB TWS socket (3) | Write in progress. Shutdown being delayed. PendingSize=41 | 2021-02-08 11:30:41.896 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:41.896 IB TWS socket (3) | Closed. | 2021-02-08 11:30:41.896 Canceling historical data download request for MSFT Intraday data. | 2021-02-08 11:30:41.976 Removing historical data download ID 89. | 2021-02-08 11:30:41.976 Canceling historical data download request for VXRT Intraday data. | 2021-02-08 11:30:41.976 Removing historical data download ID 90. | 2021-02-08 11:30:41.976 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:41.976 Interactive Brokers | Disconnected. | 2021-02-08 11:30:41.976 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:41.976 HD Request # 27 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: interactive_brokers.trading | 2021-02-08 11:30:42.009 HD Request # 27 | Download start date-time: 2021-02-05 12:30:12.000 | 2021-02-08 11:30:42.009 HD Request # 27 | Requesting a total of 3 days and 1230 seconds. | 2021-02-08 11:30:42.009 HD Request # 27 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174030. | 2021-02-08 11:30:42.009 HD Request # 27 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:12 for QQQ. PriceType: TRADES | 2021-02-08 11:30:42.009 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:44.983 IB TWS socket (3) | Creating socket. | 2021-02-08 11:30:44.983 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:44.983 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:45.496 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:45.496 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:45.530 Interactive Brokers | TWS time: 20210208 11:30:45 Central Standard Time | 2021-02-08 11:30:45.530 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:45.786 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:45.787 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:45.789 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:45.789 IB Account information received. | 2021-02-08 11:30:45.789 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:45.789 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:45.789 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:45.789 Triggering next historical data download in queue. | 2021-02-08 11:30:45.792 Triggering next historical data download in queue. | 2021-02-08 11:30:45.792 Triggering next historical data download in queue. | 2021-02-08 11:30:45.792 Triggering next historical data download in queue. | 2021-02-08 11:30:45.792 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:46 | 2021-02-08 11:30:45.793 Next valid order ID: 31226 | 2021-02-08 11:30:45.824 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:45.824 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:45.824 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:45.824 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:45.824 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:45.825 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:45.825 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:45.825 Next valid order ID: 31226 | 2021-02-08 11:30:45.825 Next valid order ID: 31226 | 2021-02-08 11:30:45.825 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 1 | 2021-02-08 11:30:45.911 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:45.911 Interactive Brokers | Requesting security definition data for: MSFT. ID: 1 | 2021-02-08 11:30:45.911 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:30:45.911 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:30:45.911 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:30:45.911 Triggering next historical data download in queue. | 2021-02-08 11:30:45.911 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 2 | 2021-02-08 11:30:45.937 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:45.937 Interactive Brokers | Requesting security definition data for: VXRT. ID: 2 | 2021-02-08 11:30:45.937 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:30:45.937 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:30:45.937 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:30:45.937 Triggering next historical data download in queue. | 2021-02-08 11:30:45.937 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 3 | 2021-02-08 11:30:45.961 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:45.961 Interactive Brokers | Requesting security definition data for: UPS. ID: 3 | 2021-02-08 11:30:45.961 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:30:45.961 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:30:45.961 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:30:45.961 Triggering next historical data download in queue. | 2021-02-08 11:30:45.961 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 4 | 2021-02-08 11:30:45.969 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:45.969 Interactive Brokers | Requesting security definition data for: WKHS. ID: 4 | 2021-02-08 11:30:45.969 Interactive Brokers | Using primary service for historical data for WKHS | 2021-02-08 11:30:45.969 Added historical Intraday data request for WKHS to the queue. | 2021-02-08 11:30:45.969 Intraday data recording state for symbol WKHS is set to download 'Pending'. | 2021-02-08 11:30:45.969 Triggering next historical data download in queue. | 2021-02-08 11:30:45.969 Interactive Brokers | Market data type is Live for MSFT | 2021-02-08 11:30:46.010 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\MSFT.2021-02-08.depth. This may take a while. | 2021-02-08 11:30:46.011 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\MSFT.2021-02-08.depth | 2021-02-08 11:30:46.011 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 5 | 2021-02-08 11:30:46.012 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.012 Interactive Brokers | Requesting security definition data for: LGND. ID: 5 | 2021-02-08 11:30:46.012 Interactive Brokers | Starting real-time market data updates for: GME. ID: 6 | 2021-02-08 11:30:46.012 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.012 Interactive Brokers | Requesting security definition data for: GME. ID: 6 | 2021-02-08 11:30:46.012 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 7 | 2021-02-08 11:30:46.013 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.013 Interactive Brokers | Requesting security definition data for: MDGL. ID: 7 | 2021-02-08 11:30:46.013 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 8 | 2021-02-08 11:30:46.013 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.013 Interactive Brokers | Requesting security definition data for: IRBT. ID: 8 | 2021-02-08 11:30:46.013 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 9 | 2021-02-08 11:30:46.013 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.013 Interactive Brokers | Requesting security definition data for: CVNA. ID: 9 | 2021-02-08 11:30:46.013 IB TWS socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:46.013 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:46.013 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:46.013 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 10 | 2021-02-08 11:30:46.014 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.014 Interactive Brokers | Requesting security definition data for: SPWR. ID: 10 | 2021-02-08 11:30:46.014 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 11 | 2021-02-08 11:30:46.014 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.014 Interactive Brokers | Requesting security definition data for: SCVL. ID: 11 | 2021-02-08 11:30:46.014 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 12 | 2021-02-08 11:30:46.014 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.014 Interactive Brokers | Requesting security definition data for: GSX. ID: 12 | 2021-02-08 11:30:46.014 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 13 | 2021-02-08 11:30:46.014 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.014 Interactive Brokers | Requesting security definition data for: BLNK. ID: 13 | 2021-02-08 11:30:46.014 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 14 | 2021-02-08 11:30:46.015 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.015 Interactive Brokers | Requesting security definition data for: OTRK. ID: 14 | 2021-02-08 11:30:46.015 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 15 | 2021-02-08 11:30:46.015 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.015 Interactive Brokers | Requesting security definition data for: VIAC. ID: 15 | 2021-02-08 11:30:46.015 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 16 | 2021-02-08 11:30:46.016 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.016 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 16 | 2021-02-08 11:30:46.016 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 17 | 2021-02-08 11:30:46.016 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.016 Interactive Brokers | Requesting security definition data for: CVM. ID: 17 | 2021-02-08 11:30:46.016 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 18 | 2021-02-08 11:30:46.016 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.016 Interactive Brokers | Requesting security definition data for: RUBY. ID: 18 | 2021-02-08 11:30:46.016 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 19 | 2021-02-08 11:30:46.016 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.016 Interactive Brokers | Requesting security definition data for: CAKE. ID: 19 | 2021-02-08 11:30:46.016 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 20 | 2021-02-08 11:30:46.016 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.016 Interactive Brokers | Requesting security definition data for: RVP. ID: 20 | 2021-02-08 11:30:46.016 Interactive Brokers | Starting real-time market data updates for: NK. ID: 21 | 2021-02-08 11:30:46.017 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.017 Interactive Brokers | Requesting security definition data for: NK. ID: 21 | 2021-02-08 11:30:46.017 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 22 | 2021-02-08 11:30:46.017 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.017 Interactive Brokers | Requesting security definition data for: RXT. ID: 22 | 2021-02-08 11:30:46.017 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 23 | 2021-02-08 11:30:46.018 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.018 Interactive Brokers | Requesting security definition data for: DDS. ID: 23 | 2021-02-08 11:30:46.018 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 24 | 2021-02-08 11:30:46.018 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.018 Interactive Brokers | Requesting security definition data for: LAZR. ID: 24 | 2021-02-08 11:30:46.018 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 25 | 2021-02-08 11:30:46.019 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.019 Interactive Brokers | Requesting security definition data for: AXDX. ID: 25 | 2021-02-08 11:30:46.019 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 26 | 2021-02-08 11:30:46.019 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.019 Interactive Brokers | Requesting security definition data for: DKS. ID: 26 | 2021-02-08 11:30:46.019 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 27 | 2021-02-08 11:30:46.019 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.019 Interactive Brokers | Requesting security definition data for: CLVS. ID: 27 | 2021-02-08 11:30:46.019 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 28 | 2021-02-08 11:30:46.019 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.019 Interactive Brokers | Requesting security definition data for: AKTS. ID: 28 | 2021-02-08 11:30:46.019 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 29 | 2021-02-08 11:30:46.019 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.019 Interactive Brokers | Requesting security definition data for: BYND. ID: 29 | 2021-02-08 11:30:46.019 Interactive Brokers | Starting real-time market data updates for: APT. ID: 30 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: APT. ID: 30 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 31 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: HIBB. ID: 31 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 32 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: LOVE. ID: 32 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 33 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: MIK. ID: 33 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 34 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: PGEN. ID: 34 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 35 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: SKT. ID: 35 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 36 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: SENS. ID: 36 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: INO. ID: 37 | 2021-02-08 11:30:46.020 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.020 Interactive Brokers | Requesting security definition data for: INO. ID: 37 | 2021-02-08 11:30:46.020 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 38 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: AWH. ID: 38 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 39 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: FLXN. ID: 39 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 40 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: OPK. ID: 40 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 41 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: RGS. ID: 41 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 42 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: SRNE. ID: 42 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: REV. ID: 43 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: REV. ID: 43 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 44 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: EBIX. ID: 44 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 45 | 2021-02-08 11:30:46.021 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.021 Interactive Brokers | Requesting security definition data for: ICPT. ID: 45 | 2021-02-08 11:30:46.021 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 46 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: PECK. ID: 46 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 47 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: BBBY. ID: 47 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 48 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: PRTS. ID: 48 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 49 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: KNDI. ID: 49 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 50 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: JWN. ID: 50 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 51 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: CEMI. ID: 51 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 52 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: LCI. ID: 52 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: TR. ID: 53 | 2021-02-08 11:30:46.022 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.022 Interactive Brokers | Requesting security definition data for: TR. ID: 53 | 2021-02-08 11:30:46.022 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 54 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: SOLY. ID: 54 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 55 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: GOGO. ID: 55 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 56 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: DVAX. ID: 56 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 57 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: AMC. ID: 57 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 58 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: TLRY. ID: 58 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 59 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: RKT. ID: 59 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 60 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: GTT. ID: 60 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 61 | 2021-02-08 11:30:46.023 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.023 Interactive Brokers | Requesting security definition data for: OMER. ID: 61 | 2021-02-08 11:30:46.023 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 62 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: SPCE. ID: 62 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 63 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: SRG. ID: 63 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 64 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: VTVT. ID: 64 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 65 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: SDC. ID: 65 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 66 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: APRN. ID: 66 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 67 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: PETS. ID: 67 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 68 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: SFIX. ID: 68 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 69 | 2021-02-08 11:30:46.024 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.024 Interactive Brokers | Requesting security definition data for: RVLV. ID: 69 | 2021-02-08 11:30:46.024 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 70 | 2021-02-08 11:30:46.025 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.025 Interactive Brokers | Requesting security definition data for: BKE. ID: 70 | 2021-02-08 11:30:46.025 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 71 | 2021-02-08 11:30:46.025 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.025 Interactive Brokers | Requesting security definition data for: FUBO. ID: 71 | 2021-02-08 11:30:46.025 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 72 | 2021-02-08 11:30:46.025 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.025 Interactive Brokers | Requesting security definition data for: SIG. ID: 72 | 2021-02-08 11:30:46.025 Interactive Brokers | Starting real-time market data updates for: W. ID: 73 | 2021-02-08 11:30:46.025 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:46.025 Interactive Brokers | Requesting security definition data for: W. ID: 73 | 2021-02-08 11:30:46.025 Message from IB: Error reading request.Message id 5. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 5. Symbol: LGND. | 2021-02-08 11:30:46.026 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:30:46.027 Connection to the external service has been lost. | 2021-02-08 11:30:46.027 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:46.027 IB TWS socket (3) | Closed. | 2021-02-08 11:30:46.027 Canceling historical data download request for MSFT Intraday data. | 2021-02-08 11:30:46.106 Removing historical data download ID 91. | 2021-02-08 11:30:46.106 Canceling historical data download request for VXRT Intraday data. | 2021-02-08 11:30:46.106 Removing historical data download ID 92. | 2021-02-08 11:30:46.106 Canceling historical data download request for UPS Intraday data. | 2021-02-08 11:30:46.106 Removing historical data download ID 93. | 2021-02-08 11:30:46.107 Canceling historical data download request for WKHS Intraday data. | 2021-02-08 11:30:46.107 Removing historical data download ID 94. | 2021-02-08 11:30:46.107 HD Request # 27 | Download canceled. | 2021-02-08 11:30:46.107 HD Request # 27 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for QQQ | 2021-02-08 11:30:46.107 HD Request # 27 | Completion time: 4s | 2021-02-08 11:30:46.107 HD Request # 27 | Intraday data download complete for QQQ. Unique request ID: 88 | 2021-02-08 11:30:46.107 Removing historical data download ID 88. | 2021-02-08 11:30:46.107 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:46.107 Triggering next historical data download in queue. | 2021-02-08 11:30:46.107 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:46.107 Interactive Brokers | Disconnected. | 2021-02-08 11:30:46.107 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:46.107 HD Server | HD Request #29 | Socket: 1 | Symbol: QQQ | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 2020 | ClientRequestID: 29 | Username: ghsabri. | Thread:8976 | 2021-02-08 11:30:47.025 HD Server | Thread:8976 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:30:47.026 HD Server | Thread:8976 (1) | CloseSocket call. | 2021-02-08 11:30:47.026 HD Server | Thread:8976 (0) | CloseSocket call. | 2021-02-08 11:30:47.028 HD Server | Thread:8976 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:47.028 HD Server | Thread:8976 (1) | Closed. | 2021-02-08 11:30:47.028 HD Server | Thread:8976 (0) | CloseSocket call. | 2021-02-08 11:30:47.028 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:30:47.032 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:30:47.033 HD Server | Thread:18152 (1) | Creating socket. | 2021-02-08 11:30:47.043 HD Server | Setting DTC encoding to Binary VLS | Thread:18152 | 2021-02-08 11:30:47.043 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:18152 | 2021-02-08 11:30:47.044 HD Server | Login has been authorized. | Username: ghsabri. | Thread:18152 | 2021-02-08 11:30:47.044 HD Server | HD Request #30 | Socket: 1 | Symbol: TICK-nyse | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:30:29 | ClientRequestID: 30 | Username: ghsabri. | Thread:18152 | 2021-02-08 11:30:47.044 Added historical Intraday data request for TICK-nyse to the queue. | 2021-02-08 11:30:47.047 Intraday data recording state for symbol TICK-nyse is set to download 'Pending'. | 2021-02-08 11:30:47.047 Triggering next historical data download in queue. | 2021-02-08 11:30:47.047 HD Request # 28 | Downloading Intraday chart data for TICK-nyse to the file TICK-nyse.scid. Service: statscalc | 2021-02-08 11:30:47.047 HD Request # 28 | Download start date-time: 2021-02-08 11:30:26.000 | 2021-02-08 11:30:47.048 HD Request # 28 | Using server: ds12.sierracharts.com port 10149 | 2021-02-08 11:30:47.048 Socket (3) | Creating socket. | 2021-02-08 11:30:47.048 Socket (3) | Connecting to IP: 204.15.197.14. | 2021-02-08 11:30:47.048 HD Request # 28 | Setting DTC encoding to Binary VLS | 2021-02-08 11:30:47.155 HD Request # 28 | Sending historical data logon request message. | 2021-02-08 11:30:47.155 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:8976 | 2021-02-08 11:30:47.262 HD Server Manager | Current server count=1 | 2021-02-08 11:30:47.262 HD Request # 28 | Requesting Intraday data. Start date-time: 2021-02-08 11:30:26. Record interval: 0. Symbol: TICK-nyse | 2021-02-08 11:30:47.691 HD Request # 28 | Decompressing data. | 2021-02-08 11:30:47.734 HD Request # 28 | Receiving Intraday data for TICK-nyse starting at 2021-02-08 11:30:26 | 2021-02-08 11:30:47.735 Socket (3) | CloseSocket call. | 2021-02-08 11:30:47.735 HD Request # 28 | Historical data for TICK-nyse is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:30:47.736 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:30:47.736 Historical data download thread signaled to stop. | 2021-02-08 11:30:47.736 HD Request # 28 | Timestamp of first Intraday data file record written: 2021-02-08 11:30:27 | 2021-02-08 11:30:47.736 HD Request # 28 | Received 21 records from 2021-02-08 11:30:26.000 to 2021-02-08 11:30:46.000 (20.0 seconds) and wrote 20 records for TICK-nyse | 2021-02-08 11:30:47.736 HD Request # 28 | Completion time: 0s | 2021-02-08 11:30:47.736 HD Request # 28 | Intraday data download complete for TICK-nyse. Unique request ID: 95 | 2021-02-08 11:30:47.736 Removing historical data download ID 95. | 2021-02-08 11:30:47.736 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:47.736 Triggering next historical data download in queue. | 2021-02-08 11:30:47.736 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:30:47.780 Socket (3) | Closed. | 2021-02-08 11:30:47.780 HD Server | HD Request #30 | Socket: 1 | Symbol: TICK-nyse | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 18 | ClientRequestID: 30 | Username: ghsabri. | Thread:18152 | 2021-02-08 11:30:48.054 HD Server | Thread:18152 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:30:48.055 HD Server | Thread:18152 (1) | CloseSocket call. | 2021-02-08 11:30:48.055 HD Server | Thread:18152 (0) | CloseSocket call. | 2021-02-08 11:30:48.057 HD Server | Thread:18152 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:48.057 HD Server | Thread:18152 (1) | Closed. | 2021-02-08 11:30:48.057 HD Server | Thread:18152 (0) | CloseSocket call. | 2021-02-08 11:30:48.057 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:30:48.086 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:30:48.086 HD Server | Thread:448 (1) | Creating socket. | 2021-02-08 11:30:48.104 HD Server | Setting DTC encoding to Binary VLS | Thread:448 | 2021-02-08 11:30:48.105 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:448 | 2021-02-08 11:30:48.105 HD Server | Login has been authorized. | Username: ghsabri. | Thread:448 | 2021-02-08 11:30:48.105 HD Server | HD Request #31 | Socket: 1 | Symbol: NISS-NYSE | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:30:27 | ClientRequestID: 31 | Username: ghsabri. | Thread:448 | 2021-02-08 11:30:48.106 Added historical Intraday data request for NISS-NYSE to the queue. | 2021-02-08 11:30:48.120 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2021-02-08 11:30:48.120 Triggering next historical data download in queue. | 2021-02-08 11:30:48.120 HD Request # 29 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2021-02-08 11:30:48.120 HD Request # 29 | Download start date-time: 2021-02-08 11:30:27.000 | 2021-02-08 11:30:48.121 HD Request # 29 | Using server: ds4.sierracharts.com port 10150 | 2021-02-08 11:30:48.121 Socket (3) | Creating socket. | 2021-02-08 11:30:48.121 Socket (3) | Connecting to IP: 192.81.56.146. | 2021-02-08 11:30:48.121 HD Request # 29 | Setting DTC encoding to Binary VLS | 2021-02-08 11:30:48.223 HD Request # 29 | Sending historical data logon request message. | 2021-02-08 11:30:48.223 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:18152 | 2021-02-08 11:30:48.270 HD Server Manager | Current server count=1 | 2021-02-08 11:30:48.270 HD Request # 29 | Requesting Intraday data. Start date-time: 2021-02-08 11:30:27. Record interval: 0. Symbol: NISS-NYSE | 2021-02-08 11:30:48.747 HD Request # 29 | Decompressing data. | 2021-02-08 11:30:48.793 HD Request # 29 | Receiving Intraday data for NISS-NYSE starting at 2021-02-08 11:30:27 | 2021-02-08 11:30:48.793 Socket (3) | CloseSocket call. | 2021-02-08 11:30:48.794 HD Request # 29 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:30:48.794 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:30:48.794 Historical data download thread signaled to stop. | 2021-02-08 11:30:48.794 HD Request # 29 | Timestamp of first Intraday data file record written: 2021-02-08 11:30:28 | 2021-02-08 11:30:48.794 HD Request # 29 | Received 21 records from 2021-02-08 11:30:27.000 to 2021-02-08 11:30:47.000 (20.0 seconds) and wrote 20 records for NISS-NYSE | 2021-02-08 11:30:48.795 HD Request # 29 | Completion time: 0s | 2021-02-08 11:30:48.795 HD Request # 29 | Intraday data download complete for NISS-NYSE. Unique request ID: 96 | 2021-02-08 11:30:48.795 Removing historical data download ID 96. | 2021-02-08 11:30:48.795 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:48.795 Triggering next historical data download in queue. | 2021-02-08 11:30:48.795 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:30:48.840 Socket (3) | Closed. | 2021-02-08 11:30:48.840 HD Server | Thread:448 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:30:49.130 HD Server | HD Request #31 | Socket: 1 | Symbol: NISS-NYSE | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 21 | ClientRequestID: 31 | Username: ghsabri. | Thread:448 | 2021-02-08 11:30:49.130 HD Server | Thread:448 (1) | CloseSocket call. | 2021-02-08 11:30:49.130 HD Server | Thread:448 (0) | CloseSocket call. | 2021-02-08 11:30:49.131 HD Server | Thread:448 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:49.131 HD Server | Thread:448 (1) | Closed. | 2021-02-08 11:30:49.131 HD Server | Thread:448 (0) | CloseSocket call. | 2021-02-08 11:30:49.131 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:30:49.149 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:30:49.149 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:49.157 IB TWS socket (1) | Creating socket. | 2021-02-08 11:30:49.157 IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:49.157 HD Server | Thread:17736 (3) | Creating socket. | 2021-02-08 11:30:49.164 HD Server | Setting DTC encoding to Binary VLS | Thread:17736 | 2021-02-08 11:30:49.164 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:17736 | 2021-02-08 11:30:49.165 HD Server | Login has been authorized. | Username: ghsabri. | Thread:17736 | 2021-02-08 11:30:49.165 HD Server | HD Request #32 | Socket: 3 | Symbol: NQ-202103-GLOBEX | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:20:28 | ClientRequestID: 32 | Username: ghsabri. | Thread:17736 | 2021-02-08 11:30:49.165 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:49.663 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:49.664 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-202103-GLOBEX | 2021-02-08 11:30:49.665 Added historical Intraday data request for NQ-202103-GLOBEX to the queue. | 2021-02-08 11:30:49.665 Intraday data recording state for symbol NQ-202103-GLOBEX is set to download 'Pending'. | 2021-02-08 11:30:49.665 Triggering next historical data download in queue. | 2021-02-08 11:30:49.665 HD Request # 30 | Downloading Intraday chart data for NQ-202103-GLOBEX to the file NQ-202103-GLOBEX.scid. Service: cme | 2021-02-08 11:30:49.665 HD Request # 30 | Download start date-time: 2021-02-08 11:20:28.000 | 2021-02-08 11:30:49.666 HD Request # 30 | Using server: ds23.sierracharts.com port 10149 | 2021-02-08 11:30:49.667 Socket (4) | Creating socket. | 2021-02-08 11:30:49.667 Socket (4) | Connecting to IP: 216.1.90.130. | 2021-02-08 11:30:49.667 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:49.668 Interactive Brokers | TWS time: 20210208 11:30:50 Central Standard Time | 2021-02-08 11:30:49.668 HD Request # 30 | Setting DTC encoding to Binary VLS | 2021-02-08 11:30:49.756 HD Request # 30 | Sending historical data logon request message. | 2021-02-08 11:30:49.756 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:49.929 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:49.929 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:49.942 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:49.942 IB Account information received. | 2021-02-08 11:30:49.942 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:49.942 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:49.942 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:49.942 Triggering next historical data download in queue. | 2021-02-08 11:30:49.945 Triggering next historical data download in queue. | 2021-02-08 11:30:49.945 Triggering next historical data download in queue. | 2021-02-08 11:30:49.945 Triggering next historical data download in queue. | 2021-02-08 11:30:49.945 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:50 | 2021-02-08 11:30:49.945 Next valid order ID: 31226 | 2021-02-08 11:30:49.972 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:49.972 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:49.972 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:49.972 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:49.972 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:49.972 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:49.972 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:49.972 Next valid order ID: 31226 | 2021-02-08 11:30:49.972 Next valid order ID: 31226 | 2021-02-08 11:30:49.972 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:448 | 2021-02-08 11:30:49.974 HD Server Manager | Current server count=1 | 2021-02-08 11:30:49.974 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 1 | 2021-02-08 11:30:49.974 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:49.974 Interactive Brokers | Requesting security definition data for: WKHS. ID: 1 | 2021-02-08 11:30:49.974 Interactive Brokers | Using primary service for historical data for WKHS | 2021-02-08 11:30:49.974 Added historical Intraday data request for WKHS to the queue. | 2021-02-08 11:30:49.974 Intraday data recording state for symbol WKHS is set to download 'Pending'. | 2021-02-08 11:30:49.974 Triggering next historical data download in queue. | 2021-02-08 11:30:49.974 Delaying start of download for WKHS | 2021-02-08 11:30:50.038 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 2 | 2021-02-08 11:30:50.054 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.054 Interactive Brokers | Requesting security definition data for: LGND. ID: 2 | 2021-02-08 11:30:50.054 Interactive Brokers | Starting real-time market data updates for: GME. ID: 3 | 2021-02-08 11:30:50.054 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.054 Interactive Brokers | Requesting security definition data for: GME. ID: 3 | 2021-02-08 11:30:50.054 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 4 | 2021-02-08 11:30:50.054 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.054 Interactive Brokers | Requesting security definition data for: MDGL. ID: 4 | 2021-02-08 11:30:50.054 IB TWS socket (1) | Socket gracefully closed by remote side. | 2021-02-08 11:30:50.054 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 5 | 2021-02-08 11:30:50.054 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.054 Interactive Brokers | Requesting security definition data for: IRBT. ID: 5 | 2021-02-08 11:30:50.054 IB TWS socket (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:50.054 IB TWS socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:50.054 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 6 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: CVNA. ID: 6 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 7 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: SPWR. ID: 7 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 8 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: SCVL. ID: 8 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 9 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: GSX. ID: 9 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 10 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: BLNK. ID: 10 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 11 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: OTRK. ID: 11 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 12 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: VIAC. ID: 12 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 13 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 13 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 14 | 2021-02-08 11:30:50.055 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.055 Interactive Brokers | Requesting security definition data for: CVM. ID: 14 | 2021-02-08 11:30:50.055 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 15 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: RUBY. ID: 15 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 16 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: CAKE. ID: 16 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 17 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: RVP. ID: 17 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: NK. ID: 18 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: NK. ID: 18 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 19 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: RXT. ID: 19 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 20 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: DDS. ID: 20 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 21 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: LAZR. ID: 21 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 22 | 2021-02-08 11:30:50.056 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.056 Interactive Brokers | Requesting security definition data for: AXDX. ID: 22 | 2021-02-08 11:30:50.056 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 23 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: DKS. ID: 23 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 24 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: CLVS. ID: 24 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 25 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: AKTS. ID: 25 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 26 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: BYND. ID: 26 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: APT. ID: 27 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: APT. ID: 27 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 28 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: HIBB. ID: 28 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 29 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: LOVE. ID: 29 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 30 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: MIK. ID: 30 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 31 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: PGEN. ID: 31 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 32 | 2021-02-08 11:30:50.057 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.057 Interactive Brokers | Requesting security definition data for: SKT. ID: 32 | 2021-02-08 11:30:50.057 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 33 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: SENS. ID: 33 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: INO. ID: 34 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: INO. ID: 34 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 35 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: AWH. ID: 35 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 36 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: FLXN. ID: 36 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 37 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: OPK. ID: 37 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 38 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: RGS. ID: 38 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 39 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: SRNE. ID: 39 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: REV. ID: 40 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: REV. ID: 40 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 41 | 2021-02-08 11:30:50.058 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.058 Interactive Brokers | Requesting security definition data for: EBIX. ID: 41 | 2021-02-08 11:30:50.058 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 42 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: ICPT. ID: 42 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 43 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: PECK. ID: 43 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 44 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: BBBY. ID: 44 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 45 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: PRTS. ID: 45 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 46 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: KNDI. ID: 46 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 47 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: JWN. ID: 47 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 48 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: CEMI. ID: 48 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 49 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: LCI. ID: 49 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: TR. ID: 50 | 2021-02-08 11:30:50.059 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.059 Interactive Brokers | Requesting security definition data for: TR. ID: 50 | 2021-02-08 11:30:50.059 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 51 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: SOLY. ID: 51 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 52 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: GOGO. ID: 52 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 53 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: DVAX. ID: 53 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 54 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: AMC. ID: 54 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 55 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: TLRY. ID: 55 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 56 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: RKT. ID: 56 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 57 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: GTT. ID: 57 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 58 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: OMER. ID: 58 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 59 | 2021-02-08 11:30:50.060 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.060 Interactive Brokers | Requesting security definition data for: SPCE. ID: 59 | 2021-02-08 11:30:50.060 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 60 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: SRG. ID: 60 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 61 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: VTVT. ID: 61 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 62 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: SDC. ID: 62 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 63 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: APRN. ID: 63 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 64 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: PETS. ID: 64 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 65 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: SFIX. ID: 65 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 66 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: RVLV. ID: 66 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 67 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: BKE. ID: 67 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 68 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: FUBO. ID: 68 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 69 | 2021-02-08 11:30:50.061 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.061 Interactive Brokers | Requesting security definition data for: SIG. ID: 69 | 2021-02-08 11:30:50.061 Interactive Brokers | Starting real-time market data updates for: W. ID: 70 | 2021-02-08 11:30:50.062 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:50.062 Interactive Brokers | Requesting security definition data for: W. ID: 70 | 2021-02-08 11:30:50.062 IB TWS socket (1) | CloseSocket call. | 2021-02-08 11:30:50.063 Connection to the external service has been lost. | 2021-02-08 11:30:50.063 IB TWS socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:50.063 IB TWS socket (1) | Closed. | 2021-02-08 11:30:50.063 HD Request # 31 | Downloading Intraday chart data for WKHS to the file WKHS.scid. Service: interactive_brokers.trading | 2021-02-08 11:30:50.155 HD Request # 31 | Download start date-time: 2021-02-05 12:30:10.000 | 2021-02-08 11:30:50.155 HD Request # 31 | Requesting a total of 3 days and 1240 seconds. | 2021-02-08 11:30:50.155 HD Request # 31 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174040. | 2021-02-08 11:30:50.155 HD Request # 31 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:10 for WKHS. PriceType: TRADES | 2021-02-08 11:30:50.155 HD Request # 31 | Download canceled. | 2021-02-08 11:30:50.182 HD Request # 31 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for WKHS | 2021-02-08 11:30:50.182 HD Request # 31 | Completion time: 0s | 2021-02-08 11:30:50.182 HD Request # 31 | Intraday data download complete for WKHS. Unique request ID: 98 | 2021-02-08 11:30:50.182 Removing historical data download ID 98. | 2021-02-08 11:30:50.182 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:50.182 Triggering next historical data download in queue. | 2021-02-08 11:30:50.182 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:50.182 Interactive Brokers | Disconnected. | 2021-02-08 11:30:50.182 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:50.182 HD Request # 30 | Requesting Intraday data. Start date-time: 2021-02-08 11:20:28. Record interval: 0. Symbol: NQH21 | 2021-02-08 11:30:50.261 HD Request # 30 | Decompressing data. | 2021-02-08 11:30:50.310 HD Request # 30 | Receiving Intraday data for NQ-202103-GLOBEX starting at 2021-02-08 11:20:28 | 2021-02-08 11:30:50.312 Socket (4) | CloseSocket call. | 2021-02-08 11:30:50.312 HD Request # 30 | Historical data for NQ-202103-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:30:50.312 Socket (4) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:30:50.312 Historical data download thread signaled to stop. | 2021-02-08 11:30:50.312 HD Request # 30 | Timestamp of first Intraday data file record written: 2021-02-08 11:20:29 | 2021-02-08 11:30:50.312 HD Request # 30 | Received 99 records from 2021-02-08 11:20:28.000 to 2021-02-08 11:20:50.003 (22.0 seconds) and wrote 89 records for NQ-202103-GLOBEX | 2021-02-08 11:30:50.312 HD Request # 30 | Completion time: 1s | 2021-02-08 11:30:50.313 HD Request # 30 | Intraday data download complete for NQ-202103-GLOBEX. Unique request ID: 97 | 2021-02-08 11:30:50.313 Removing historical data download ID 97. | 2021-02-08 11:30:50.313 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:50.313 Interactive Brokers | Using primary service for historical data for NQ-202103-GLOBEX | 2021-02-08 11:30:50.313 Added historical Intraday data request for NQ-202103-GLOBEX to the queue. | 2021-02-08 11:30:50.313 Intraday data recording state for symbol NQ-202103-GLOBEX is set to download 'Pending'. | 2021-02-08 11:30:50.313 Triggering next historical data download in queue. | 2021-02-08 11:30:50.313 Triggering next historical data download in queue. | 2021-02-08 11:30:50.313 Socket (4) | Socket gracefully closed by remote side. | 2021-02-08 11:30:50.362 Socket (4) | Closed. | 2021-02-08 11:30:50.362 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:53.194 IB TWS socket (1) | Creating socket. | 2021-02-08 11:30:53.194 IB TWS socket (1) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:53.194 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:53.708 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:53.708 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:53.743 Interactive Brokers | TWS time: 20210208 11:30:54 Central Standard Time | 2021-02-08 11:30:53.743 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:54.003 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:54.003 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:54.004 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:54.004 IB Account information received. | 2021-02-08 11:30:54.004 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:54.004 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:54.004 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:54.004 Triggering next historical data download in queue. | 2021-02-08 11:30:54.006 Triggering next historical data download in queue. | 2021-02-08 11:30:54.006 Triggering next historical data download in queue. | 2021-02-08 11:30:54.006 Triggering next historical data download in queue. | 2021-02-08 11:30:54.006 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:54 | 2021-02-08 11:30:54.006 Next valid order ID: 31226 | 2021-02-08 11:30:54.022 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:54.022 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:54.022 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:54.022 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:54.022 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:54.022 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:54.022 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:54.022 Next valid order ID: 31226 | 2021-02-08 11:30:54.022 HD Request # 32 | Downloading Intraday chart data for NQ-202103-GLOBEX to the file NQ-202103-GLOBEX.scid. Service: interactive_brokers.trading | 2021-02-08 11:30:54.022 HD Request # 32 | Download start date-time: 2021-02-08 11:20:50.000 | 2021-02-08 11:30:54.023 HD Request # 32 | Requesting a total of 0 days and 5404 seconds. | 2021-02-08 11:30:54.023 HD Request # 32 | IB Backfill - Seconds requested: 5404. Seconds Remaining: 0. | 2021-02-08 11:30:54.023 HD Request # 32 | Requesting 5404 Seconds of data at 30 secs with ending date-time at 2021-02-08 12:40:54 for NQ-202103-GLOBEX. PriceType: TRADES | 2021-02-08 11:30:54.023 Next valid order ID: 31226 | 2021-02-08 11:30:54.023 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 2 | 2021-02-08 11:30:54.024 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.024 Interactive Brokers | Requesting security definition data for: LGND. ID: 2 | 2021-02-08 11:30:54.024 Interactive Brokers | Starting real-time market data updates for: GME. ID: 3 | 2021-02-08 11:30:54.024 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.024 Interactive Brokers | Requesting security definition data for: GME. ID: 3 | 2021-02-08 11:30:54.024 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 4 | 2021-02-08 11:30:54.024 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.024 Interactive Brokers | Requesting security definition data for: MDGL. ID: 4 | 2021-02-08 11:30:54.024 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 5 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: IRBT. ID: 5 | 2021-02-08 11:30:54.025 IB TWS socket (1) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:54.025 IB TWS socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:54.025 IB TWS socket (1) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 6 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: CVNA. ID: 6 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 7 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: SPWR. ID: 7 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 8 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: SCVL. ID: 8 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 9 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: GSX. ID: 9 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 10 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: BLNK. ID: 10 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 11 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: OTRK. ID: 11 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 12 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: VIAC. ID: 12 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 13 | 2021-02-08 11:30:54.025 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.025 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 13 | 2021-02-08 11:30:54.025 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 14 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: CVM. ID: 14 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 15 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: RUBY. ID: 15 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 16 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: CAKE. ID: 16 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 17 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: RVP. ID: 17 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: NK. ID: 18 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: NK. ID: 18 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 19 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: RXT. ID: 19 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 20 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: DDS. ID: 20 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 21 | 2021-02-08 11:30:54.026 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.026 Interactive Brokers | Requesting security definition data for: LAZR. ID: 21 | 2021-02-08 11:30:54.026 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 22 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: AXDX. ID: 22 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 23 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: DKS. ID: 23 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 24 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: CLVS. ID: 24 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 25 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: AKTS. ID: 25 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 26 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: BYND. ID: 26 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: APT. ID: 27 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: APT. ID: 27 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 28 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: HIBB. ID: 28 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 29 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: LOVE. ID: 29 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 30 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.027 Interactive Brokers | Requesting security definition data for: MIK. ID: 30 | 2021-02-08 11:30:54.027 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 31 | 2021-02-08 11:30:54.027 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: PGEN. ID: 31 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 32 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: SKT. ID: 32 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 33 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: SENS. ID: 33 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: INO. ID: 34 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: INO. ID: 34 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 35 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: AWH. ID: 35 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 36 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: FLXN. ID: 36 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 37 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: OPK. ID: 37 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 38 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: RGS. ID: 38 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 39 | 2021-02-08 11:30:54.028 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.028 Interactive Brokers | Requesting security definition data for: SRNE. ID: 39 | 2021-02-08 11:30:54.028 Interactive Brokers | Starting real-time market data updates for: REV. ID: 40 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: REV. ID: 40 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 41 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: EBIX. ID: 41 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 42 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: ICPT. ID: 42 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 43 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: PECK. ID: 43 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 44 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: BBBY. ID: 44 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 45 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: PRTS. ID: 45 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 46 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: KNDI. ID: 46 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 47 | 2021-02-08 11:30:54.029 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.029 Interactive Brokers | Requesting security definition data for: JWN. ID: 47 | 2021-02-08 11:30:54.029 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 48 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: CEMI. ID: 48 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 49 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: LCI. ID: 49 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: TR. ID: 50 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: TR. ID: 50 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 51 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: SOLY. ID: 51 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 52 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: GOGO. ID: 52 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 53 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: DVAX. ID: 53 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 54 | 2021-02-08 11:30:54.030 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.030 Interactive Brokers | Requesting security definition data for: AMC. ID: 54 | 2021-02-08 11:30:54.030 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 55 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: TLRY. ID: 55 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 56 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: RKT. ID: 56 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 57 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: GTT. ID: 57 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 58 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: OMER. ID: 58 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 59 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: SPCE. ID: 59 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 60 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: SRG. ID: 60 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 61 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: VTVT. ID: 61 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 62 | 2021-02-08 11:30:54.031 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.031 Interactive Brokers | Requesting security definition data for: SDC. ID: 62 | 2021-02-08 11:30:54.031 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 63 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: APRN. ID: 63 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 64 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: WKHS. ID: 64 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 65 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: PETS. ID: 65 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 66 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: SFIX. ID: 66 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 67 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: RVLV. ID: 67 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 68 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: BKE. ID: 68 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 69 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: FUBO. ID: 69 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 70 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: SIG. ID: 70 | 2021-02-08 11:30:54.032 Interactive Brokers | Starting real-time market data updates for: W. ID: 71 | 2021-02-08 11:30:54.032 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:54.032 Interactive Brokers | Requesting security definition data for: W. ID: 71 | 2021-02-08 11:30:54.032 Message from IB: Error reading request.Message id 2. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 2. Symbol: LGND. | 2021-02-08 11:30:54.034 IB TWS socket (1) | CloseSocket call. | 2021-02-08 11:30:54.034 Connection to the external service has been lost. | 2021-02-08 11:30:54.034 IB TWS socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:54.034 IB TWS socket (1) | Closed. | 2021-02-08 11:30:54.034 HD Request # 32 | Download canceled. | 2021-02-08 11:30:54.208 HD Request # 32 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for NQ-202103-GLOBEX | 2021-02-08 11:30:54.208 HD Request # 32 | Completion time: 0s | 2021-02-08 11:30:54.208 HD Request # 32 | Intraday data download complete for NQ-202103-GLOBEX. Unique request ID: 99 | 2021-02-08 11:30:54.208 Removing historical data download ID 99. | 2021-02-08 11:30:54.208 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:30:54.208 Triggering next historical data download in queue. | 2021-02-08 11:30:54.208 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:54.208 Interactive Brokers | Disconnected. | 2021-02-08 11:30:54.208 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:54.208 HD Server | HD Request #32 | Socket: 3 | Symbol: NQ-202103-GLOBEX | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 18 | ClientRequestID: 32 | Username: ghsabri. | Thread:17736 | 2021-02-08 11:30:55.182 HD Server | Thread:17736 (3) | Socket gracefully closed by remote side. | 2021-02-08 11:30:55.183 HD Server | Thread:17736 (3) | CloseSocket call. | 2021-02-08 11:30:55.183 HD Server | Thread:17736 (0) | CloseSocket call. | 2021-02-08 11:30:55.184 HD Server | Thread:17736 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:55.184 HD Server | Thread:17736 (0) | CloseSocket call. | 2021-02-08 11:30:55.184 HD Server | Thread:17736 (3) | Closed. | 2021-02-08 11:30:55.184 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:30:55.188 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:30:55.188 HD Server | Thread:7992 (1) | Creating socket. | 2021-02-08 11:30:55.207 HD Server | Setting DTC encoding to Binary VLS | Thread:7992 | 2021-02-08 11:30:55.208 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:7992 | 2021-02-08 11:30:55.209 HD Server | Login has been authorized. | Username: ghsabri. | Thread:7992 | 2021-02-08 11:30:55.209 HD Server | HD Request #33 | Socket: 1 | Symbol: SPY | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-05 18:30:40 | ClientRequestID: 33 | Username: ghsabri. | Thread:7992 | 2021-02-08 11:30:55.209 Interactive Brokers | Using primary service for historical data for SPY | 2021-02-08 11:30:55.209 Added historical Intraday data request for SPY to the queue. | 2021-02-08 11:30:55.209 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2021-02-08 11:30:55.209 Triggering next historical data download in queue. | 2021-02-08 11:30:55.209 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:17736 | 2021-02-08 11:30:55.274 HD Server Manager | Current server count=1 | 2021-02-08 11:30:55.274 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:30:57.195 IB TWS socket (3) | Creating socket. | 2021-02-08 11:30:57.196 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:30:57.196 Interactive Brokers | Sending API sign: API | 2021-02-08 11:30:57.706 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:30:57.707 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:30:57.767 Interactive Brokers | TWS time: 20210208 11:30:58 Central Standard Time | 2021-02-08 11:30:57.767 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:30:58.032 Interactive Brokers | Waiting for account information. | 2021-02-08 11:30:58.032 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:30:58.038 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:30:58.038 IB Account information received. | 2021-02-08 11:30:58.038 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:30:58.038 Interactive Brokers | Connected to Live account. | 2021-02-08 11:30:58.038 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:30:58.038 Triggering next historical data download in queue. | 2021-02-08 11:30:58.042 Triggering next historical data download in queue. | 2021-02-08 11:30:58.042 Triggering next historical data download in queue. | 2021-02-08 11:30:58.042 Triggering next historical data download in queue. | 2021-02-08 11:30:58.043 Updated verified funded futures trading account ending date to: 2021-03-10 17:30:58 | 2021-02-08 11:30:58.043 Next valid order ID: 31226 | 2021-02-08 11:30:58.078 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:58.078 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:30:58.078 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:30:58.078 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:30:58.078 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:30:58.079 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:30:58.079 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:30:58.079 Next valid order ID: 31226 | 2021-02-08 11:30:58.079 Next valid order ID: 31226 | 2021-02-08 11:30:58.079 Interactive Brokers | Starting real-time market data updates for: SPY. ID: 1 | 2021-02-08 11:30:58.082 Interactive Brokers | Subscribing to Symbol: SPY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.082 Interactive Brokers | Requesting security definition data for: SPY. ID: 1 | 2021-02-08 11:30:58.082 Delaying start of download for SPY | 2021-02-08 11:30:58.082 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 2 | 2021-02-08 11:30:58.103 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.103 Interactive Brokers | Requesting security definition data for: MSFT. ID: 2 | 2021-02-08 11:30:58.103 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:30:58.103 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:30:58.103 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:30:58.103 Triggering next historical data download in queue. | 2021-02-08 11:30:58.103 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 3 | 2021-02-08 11:30:58.138 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.138 Interactive Brokers | Requesting security definition data for: VXRT. ID: 3 | 2021-02-08 11:30:58.138 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:30:58.138 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:30:58.138 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:30:58.138 Triggering next historical data download in queue. | 2021-02-08 11:30:58.138 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 4 | 2021-02-08 11:30:58.164 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.164 Interactive Brokers | Requesting security definition data for: UPS. ID: 4 | 2021-02-08 11:30:58.164 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:30:58.164 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:30:58.164 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:30:58.164 Triggering next historical data download in queue. | 2021-02-08 11:30:58.164 Interactive Brokers | Starting real-time market data updates for: NIO. ID: 5 | 2021-02-08 11:30:58.167 Interactive Brokers | Subscribing to Symbol: NIO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.167 Interactive Brokers | Requesting security definition data for: NIO. ID: 5 | 2021-02-08 11:30:58.167 Interactive Brokers | Using primary service for historical data for NIO | 2021-02-08 11:30:58.167 Added historical Intraday data request for NIO to the queue. | 2021-02-08 11:30:58.167 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-02-08 11:30:58.167 Triggering next historical data download in queue. | 2021-02-08 11:30:58.167 Interactive Brokers | Market data type is Live for SPY | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: QS. ID: 6 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: QS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: QS. ID: 6 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 7 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: BLNK. ID: 7 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: MRNA. ID: 8 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: MRNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: MRNA. ID: 8 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: JMIA. ID: 9 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: JMIA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: JMIA. ID: 9 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: BIGC. ID: 10 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: BIGC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: BIGC. ID: 10 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: CHWY. ID: 11 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: CHWY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: CHWY. ID: 11 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: ENPH. ID: 12 | 2021-02-08 11:30:58.187 Interactive Brokers | Subscribing to Symbol: ENPH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.187 Interactive Brokers | Requesting security definition data for: ENPH. ID: 12 | 2021-02-08 11:30:58.187 Interactive Brokers | Starting real-time market data updates for: NVAX. ID: 13 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: NVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: NVAX. ID: 13 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: NNOX. ID: 14 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: NNOX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: NNOX. ID: 14 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: Z. ID: 15 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: Z, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: Z. ID: 15 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: BNTX. ID: 16 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: BNTX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: BNTX. ID: 16 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: OSTK. ID: 17 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: OSTK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: OSTK. ID: 17 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: FSLY. ID: 18 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: FSLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: FSLY. ID: 18 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: CRWD. ID: 19 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: CRWD, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: CRWD. ID: 19 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: PTON. ID: 20 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: PTON, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: PTON. ID: 20 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 21 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: SFIX. ID: 21 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 22 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: BYND. ID: 22 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: BILI. ID: 23 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: BILI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: BILI. ID: 23 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: SE. ID: 24 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: SE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: SE. ID: 24 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: TDOC. ID: 25 | 2021-02-08 11:30:58.188 Interactive Brokers | Subscribing to Symbol: TDOC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.188 Interactive Brokers | Requesting security definition data for: TDOC. ID: 25 | 2021-02-08 11:30:58.188 Interactive Brokers | Starting real-time market data updates for: ETSY. ID: 26 | 2021-02-08 11:30:58.189 Interactive Brokers | Subscribing to Symbol: ETSY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.189 Interactive Brokers | Requesting security definition data for: ETSY. ID: 26 | 2021-02-08 11:30:58.189 Interactive Brokers | Starting real-time market data updates for: DDOG. ID: 27 | 2021-02-08 11:30:58.189 Interactive Brokers | Subscribing to Symbol: DDOG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.189 Interactive Brokers | Requesting security definition data for: DDOG. ID: 27 | 2021-02-08 11:30:58.189 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 28 | 2021-02-08 11:30:58.202 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.202 Interactive Brokers | Requesting security definition data for: WKHS. ID: 28 | 2021-02-08 11:30:58.202 Interactive Brokers | Using primary service for historical data for WKHS | 2021-02-08 11:30:58.202 Added historical Intraday data request for WKHS to the queue. | 2021-02-08 11:30:58.202 Intraday data recording state for symbol WKHS is set to download 'Pending'. | 2021-02-08 11:30:58.202 Triggering next historical data download in queue. | 2021-02-08 11:30:58.202 Interactive Brokers | Market data type is Live for MSFT | 2021-02-08 11:30:58.244 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\MSFT.2021-02-08.depth. This may take a while. | 2021-02-08 11:30:58.244 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\MSFT.2021-02-08.depth | 2021-02-08 11:30:58.245 Interactive Brokers | Market data type is Live for VXRT | 2021-02-08 11:30:58.290 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-nyse. ID: 29 Service code: statscalc | 2021-02-08 11:30:58.296 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2021-02-08 11:30:58.296 SC DTC Data with Market Depth | Requesting security definition data for: TICK-nyse. ID: 29 | 2021-02-08 11:30:58.297 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 30 Service code: statscalc | 2021-02-08 11:30:58.297 SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 30 | 2021-02-08 11:30:58.297 Interactive Brokers | Starting real-time market data updates for: NQ-202103-GLOBEX. ID: 31 | 2021-02-08 11:30:58.297 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 202103, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.297 Interactive Brokers | Requesting security definition data for: NQ-202103-GLOBEX. ID: 31 | 2021-02-08 11:30:58.297 Interactive Brokers | Starting real-time market data updates for: QQQ. ID: 32 | 2021-02-08 11:30:58.297 Interactive Brokers | Subscribing to Symbol: QQQ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.297 Interactive Brokers | Requesting security definition data for: QQQ. ID: 32 | 2021-02-08 11:30:58.297 Interactive Brokers | Starting real-time market data updates for: IWM. ID: 33 | 2021-02-08 11:30:58.297 Interactive Brokers | Subscribing to Symbol: IWM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.297 DTC Client socket (4) | Creating socket. | 2021-02-08 11:30:58.297 Interactive Brokers | Requesting security definition data for: IWM. ID: 33 | 2021-02-08 11:30:58.297 DTC Client socket (4) | Connecting to IP: 204.15.197.14. | 2021-02-08 11:30:58.297 Interactive Brokers | Market data type is Live for UPS | 2021-02-08 11:30:58.331 Interactive Brokers | Market data type is Live for NIO | 2021-02-08 11:30:58.332 SC DTC Data with Market Depth | Connected to server. | 2021-02-08 11:30:58.340 SC DTC Data with Market Depth | Starting socket receive thread. | 2021-02-08 11:30:58.340 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2021-02-08 11:30:58.340 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 34 | 2021-02-08 11:30:58.359 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.359 Interactive Brokers | Requesting security definition data for: LGND. ID: 34 | 2021-02-08 11:30:58.359 Interactive Brokers | Starting real-time market data updates for: GME. ID: 35 | 2021-02-08 11:30:58.359 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.359 Interactive Brokers | Requesting security definition data for: GME. ID: 35 | 2021-02-08 11:30:58.359 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 36 | 2021-02-08 11:30:58.359 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.359 Interactive Brokers | Requesting security definition data for: MDGL. ID: 36 | 2021-02-08 11:30:58.359 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 37 | 2021-02-08 11:30:58.359 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.359 Interactive Brokers | Requesting security definition data for: IRBT. ID: 37 | 2021-02-08 11:30:58.359 IB TWS socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:58.359 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:30:58.359 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:30:58.359 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 38 | 2021-02-08 11:30:58.359 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.359 Interactive Brokers | Requesting security definition data for: CVNA. ID: 38 | 2021-02-08 11:30:58.359 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 39 | 2021-02-08 11:30:58.360 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.360 Interactive Brokers | Requesting security definition data for: SPWR. ID: 39 | 2021-02-08 11:30:58.360 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 40 | 2021-02-08 11:30:58.360 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.360 Interactive Brokers | Requesting security definition data for: SCVL. ID: 40 | 2021-02-08 11:30:58.360 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 41 | 2021-02-08 11:30:58.360 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.360 Interactive Brokers | Requesting security definition data for: GSX. ID: 41 | 2021-02-08 11:30:58.360 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 42 | 2021-02-08 11:30:58.360 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.360 Interactive Brokers | Requesting security definition data for: OTRK. ID: 42 | 2021-02-08 11:30:58.360 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 43 | 2021-02-08 11:30:58.360 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.360 Interactive Brokers | Requesting security definition data for: VIAC. ID: 43 | 2021-02-08 11:30:58.360 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 44 | 2021-02-08 11:30:58.360 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.360 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 44 | 2021-02-08 11:30:58.360 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 45 | 2021-02-08 11:30:58.361 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.361 Interactive Brokers | Requesting security definition data for: CVM. ID: 45 | 2021-02-08 11:30:58.361 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 46 | 2021-02-08 11:30:58.361 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.361 Interactive Brokers | Requesting security definition data for: RUBY. ID: 46 | 2021-02-08 11:30:58.361 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 47 | 2021-02-08 11:30:58.361 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.361 Interactive Brokers | Requesting security definition data for: CAKE. ID: 47 | 2021-02-08 11:30:58.361 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 48 | 2021-02-08 11:30:58.361 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.361 Interactive Brokers | Requesting security definition data for: RVP. ID: 48 | 2021-02-08 11:30:58.361 Interactive Brokers | Starting real-time market data updates for: NK. ID: 49 | 2021-02-08 11:30:58.361 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.361 Interactive Brokers | Requesting security definition data for: NK. ID: 49 | 2021-02-08 11:30:58.361 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 50 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: RXT. ID: 50 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 51 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: DDS. ID: 51 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 52 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: LAZR. ID: 52 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 53 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: AXDX. ID: 53 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 54 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: DKS. ID: 54 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 55 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: CLVS. ID: 55 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 56 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: AKTS. ID: 56 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: APT. ID: 57 | 2021-02-08 11:30:58.362 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.362 Interactive Brokers | Requesting security definition data for: APT. ID: 57 | 2021-02-08 11:30:58.362 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 58 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: HIBB. ID: 58 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 59 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: LOVE. ID: 59 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 60 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: MIK. ID: 60 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 61 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: PGEN. ID: 61 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 62 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: SKT. ID: 62 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 63 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: SENS. ID: 63 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: INO. ID: 64 | 2021-02-08 11:30:58.363 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.363 Interactive Brokers | Requesting security definition data for: INO. ID: 64 | 2021-02-08 11:30:58.363 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 65 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.364 Interactive Brokers | Requesting security definition data for: AWH. ID: 65 | 2021-02-08 11:30:58.364 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 66 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.364 Interactive Brokers | Requesting security definition data for: FLXN. ID: 66 | 2021-02-08 11:30:58.364 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 67 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.364 Interactive Brokers | Requesting security definition data for: OPK. ID: 67 | 2021-02-08 11:30:58.364 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 68 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.364 Interactive Brokers | Requesting security definition data for: RGS. ID: 68 | 2021-02-08 11:30:58.364 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 69 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.364 Interactive Brokers | Requesting security definition data for: SRNE. ID: 69 | 2021-02-08 11:30:58.364 Interactive Brokers | Starting real-time market data updates for: REV. ID: 70 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.364 Interactive Brokers | Requesting security definition data for: REV. ID: 70 | 2021-02-08 11:30:58.364 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 71 | 2021-02-08 11:30:58.364 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: EBIX. ID: 71 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 72 | 2021-02-08 11:30:58.365 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: ICPT. ID: 72 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 73 | 2021-02-08 11:30:58.365 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: PECK. ID: 73 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 74 | 2021-02-08 11:30:58.365 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: BBBY. ID: 74 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 75 | 2021-02-08 11:30:58.365 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: PRTS. ID: 75 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 76 | 2021-02-08 11:30:58.365 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: KNDI. ID: 76 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 77 | 2021-02-08 11:30:58.365 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.365 Interactive Brokers | Requesting security definition data for: JWN. ID: 77 | 2021-02-08 11:30:58.365 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 78 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: CEMI. ID: 78 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 79 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: LCI. ID: 79 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: TR. ID: 80 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: TR. ID: 80 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 81 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: SOLY. ID: 81 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 82 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: GOGO. ID: 82 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 83 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: DVAX. ID: 83 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 84 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: AMC. ID: 84 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 85 | 2021-02-08 11:30:58.366 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.366 Interactive Brokers | Requesting security definition data for: TLRY. ID: 85 | 2021-02-08 11:30:58.366 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 86 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: RKT. ID: 86 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 87 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: GTT. ID: 87 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 88 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: OMER. ID: 88 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 89 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: SPCE. ID: 89 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 90 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: SRG. ID: 90 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 91 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: VTVT. ID: 91 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 92 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: SDC. ID: 92 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 93 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: APRN. ID: 93 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 94 | 2021-02-08 11:30:58.367 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.367 Interactive Brokers | Requesting security definition data for: PETS. ID: 94 | 2021-02-08 11:30:58.367 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 95 | 2021-02-08 11:30:58.368 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.368 Interactive Brokers | Requesting security definition data for: RVLV. ID: 95 | 2021-02-08 11:30:58.368 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 96 | 2021-02-08 11:30:58.368 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.368 Interactive Brokers | Requesting security definition data for: BKE. ID: 96 | 2021-02-08 11:30:58.368 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 97 | 2021-02-08 11:30:58.368 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.368 Interactive Brokers | Requesting security definition data for: FUBO. ID: 97 | 2021-02-08 11:30:58.368 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 98 | 2021-02-08 11:30:58.368 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.368 Interactive Brokers | Requesting security definition data for: SIG. ID: 98 | 2021-02-08 11:30:58.368 Interactive Brokers | Starting real-time market data updates for: W. ID: 99 | 2021-02-08 11:30:58.368 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:30:58.368 Interactive Brokers | Requesting security definition data for: W. ID: 99 | 2021-02-08 11:30:58.368 Message from IB: Error reading request.Message id 34. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 34. Symbol: LGND. | 2021-02-08 11:30:58.369 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:30:58.369 Connection to the external service has been lost. | 2021-02-08 11:30:58.369 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:30:58.369 IB TWS socket (3) | Closed. | 2021-02-08 11:30:58.369 Canceling historical data download request for MSFT Intraday data. | 2021-02-08 11:30:58.436 Removing historical data download ID 101. | 2021-02-08 11:30:58.436 Canceling historical data download request for VXRT Intraday data. | 2021-02-08 11:30:58.436 Removing historical data download ID 102. | 2021-02-08 11:30:58.436 Canceling historical data download request for UPS Intraday data. | 2021-02-08 11:30:58.436 Removing historical data download ID 103. | 2021-02-08 11:30:58.436 Canceling historical data download request for NIO Intraday data. | 2021-02-08 11:30:58.436 Removing historical data download ID 104. | 2021-02-08 11:30:58.436 Canceling historical data download request for WKHS Intraday data. | 2021-02-08 11:30:58.436 Removing historical data download ID 105. | 2021-02-08 11:30:58.436 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:30:58.436 Interactive Brokers | Disconnected. | 2021-02-08 11:30:58.437 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:30:58.437 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2021-02-08 11:30:58.437 SC DTC Data with Market Depth | Sending logon request message. | 2021-02-08 11:30:58.437 HD Request # 33 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: interactive_brokers.trading | 2021-02-08 11:30:58.941 HD Request # 33 | Download start date-time: 2021-02-05 12:30:13.000 | 2021-02-08 11:30:58.942 HD Request # 33 | Requesting a total of 3 days and 1245 seconds. | 2021-02-08 11:30:58.942 HD Request # 33 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174045. | 2021-02-08 11:30:58.942 HD Request # 33 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:13 for SPY. PriceType: TRADES | 2021-02-08 11:30:58.942 SC DTC Data with Market Depth | Received logon response. | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Successfully connected. | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Trading is not supported. | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-nyse | 2021-02-08 11:30:59.110 SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2021-02-08 11:30:59.249 SC DTC Data with Market Depth | Received security definition for symbol TICK-nyse | 2021-02-08 11:30:59.249 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:31:01.453 IB TWS socket (3) | Creating socket. | 2021-02-08 11:31:01.453 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:31:01.453 Interactive Brokers | Sending API sign: API | 2021-02-08 11:31:01.956 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:31:01.956 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:31:01.976 Interactive Brokers | TWS time: 20210208 11:31:02 Central Standard Time | 2021-02-08 11:31:01.976 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:31:02.233 Interactive Brokers | Waiting for account information. | 2021-02-08 11:31:02.233 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:31:02.235 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:31:02.235 IB Account information received. | 2021-02-08 11:31:02.235 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:31:02.235 Interactive Brokers | Connected to Live account. | 2021-02-08 11:31:02.235 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:31:02.235 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2021-02-08 11:31:02.235 DTC Client socket (4) | CloseSocket call. | 2021-02-08 11:31:02.235 SC DTC Data with Market Depth | Disconnected from the server. | 2021-02-08 11:31:02.235 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:31:02.235 Triggering next historical data download in queue. | 2021-02-08 11:31:02.238 Triggering next historical data download in queue. | 2021-02-08 11:31:02.238 Triggering next historical data download in queue. | 2021-02-08 11:31:02.238 Triggering next historical data download in queue. | 2021-02-08 11:31:02.238 Updated verified funded futures trading account ending date to: 2021-03-10 17:31:02 | 2021-02-08 11:31:02.238 Next valid order ID: 31226 | 2021-02-08 11:31:02.264 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:02.264 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:02.264 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:31:02.264 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:31:02.264 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:31:02.265 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:31:02.265 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:31:02.265 Next valid order ID: 31226 | 2021-02-08 11:31:02.265 Next valid order ID: 31226 | 2021-02-08 11:31:02.265 DTC Client socket (4) | Socket gracefully closed by remote side. | 2021-02-08 11:31:02.279 DTC Client socket (4) | Closed. | 2021-02-08 11:31:02.279 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 1 | 2021-02-08 11:31:02.292 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.293 Interactive Brokers | Requesting security definition data for: UPS. ID: 1 | 2021-02-08 11:31:02.293 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:31:02.293 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:31:02.293 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:31:02.293 Triggering next historical data download in queue. | 2021-02-08 11:31:02.293 Interactive Brokers | Starting real-time market data updates for: NIO. ID: 2 | 2021-02-08 11:31:02.295 Interactive Brokers | Subscribing to Symbol: NIO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.295 Interactive Brokers | Requesting security definition data for: NIO. ID: 2 | 2021-02-08 11:31:02.295 Interactive Brokers | Using primary service for historical data for NIO | 2021-02-08 11:31:02.295 Added historical Intraday data request for NIO to the queue. | 2021-02-08 11:31:02.295 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-02-08 11:31:02.295 Triggering next historical data download in queue. | 2021-02-08 11:31:02.295 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 3 | 2021-02-08 11:31:02.316 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.316 Interactive Brokers | Requesting security definition data for: LGND. ID: 3 | 2021-02-08 11:31:02.316 Interactive Brokers | Starting real-time market data updates for: GME. ID: 4 | 2021-02-08 11:31:02.316 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.316 Interactive Brokers | Requesting security definition data for: GME. ID: 4 | 2021-02-08 11:31:02.316 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 5 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: MDGL. ID: 5 | 2021-02-08 11:31:02.317 IB TWS socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 6 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: IRBT. ID: 6 | 2021-02-08 11:31:02.317 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:31:02.317 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 7 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: CVNA. ID: 7 | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 8 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: SPWR. ID: 8 | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 9 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: SCVL. ID: 9 | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 10 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: GSX. ID: 10 | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 11 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: BLNK. ID: 11 | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 12 | 2021-02-08 11:31:02.317 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.317 Interactive Brokers | Requesting security definition data for: OTRK. ID: 12 | 2021-02-08 11:31:02.317 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 13 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: VIAC. ID: 13 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 14 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 14 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 15 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: CVM. ID: 15 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 16 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: RUBY. ID: 16 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 17 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: CAKE. ID: 17 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 18 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: RVP. ID: 18 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: NK. ID: 19 | 2021-02-08 11:31:02.318 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.318 Interactive Brokers | Requesting security definition data for: NK. ID: 19 | 2021-02-08 11:31:02.318 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 20 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: RXT. ID: 20 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 21 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: DDS. ID: 21 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 22 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: LAZR. ID: 22 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 23 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: AXDX. ID: 23 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 24 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: DKS. ID: 24 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 25 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: CLVS. ID: 25 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 26 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: AKTS. ID: 26 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 27 | 2021-02-08 11:31:02.319 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.319 Interactive Brokers | Requesting security definition data for: BYND. ID: 27 | 2021-02-08 11:31:02.319 Interactive Brokers | Starting real-time market data updates for: APT. ID: 28 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: APT. ID: 28 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 29 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: HIBB. ID: 29 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 30 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: LOVE. ID: 30 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 31 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: MIK. ID: 31 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 32 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: PGEN. ID: 32 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 33 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: SKT. ID: 33 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 34 | 2021-02-08 11:31:02.320 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.320 Interactive Brokers | Requesting security definition data for: SENS. ID: 34 | 2021-02-08 11:31:02.320 Interactive Brokers | Starting real-time market data updates for: INO. ID: 35 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: INO. ID: 35 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 36 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: AWH. ID: 36 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 37 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: FLXN. ID: 37 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 38 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: OPK. ID: 38 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 39 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: RGS. ID: 39 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 40 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: SRNE. ID: 40 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: REV. ID: 41 | 2021-02-08 11:31:02.321 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.321 Interactive Brokers | Requesting security definition data for: REV. ID: 41 | 2021-02-08 11:31:02.321 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 42 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: EBIX. ID: 42 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 43 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: ICPT. ID: 43 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 44 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: PECK. ID: 44 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 45 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: BBBY. ID: 45 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 46 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: PRTS. ID: 46 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 47 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: KNDI. ID: 47 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 48 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: JWN. ID: 48 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 49 | 2021-02-08 11:31:02.322 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.322 Interactive Brokers | Requesting security definition data for: CEMI. ID: 49 | 2021-02-08 11:31:02.322 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 50 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: LCI. ID: 50 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: TR. ID: 51 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: TR. ID: 51 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 52 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: SOLY. ID: 52 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 53 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: GOGO. ID: 53 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 54 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: DVAX. ID: 54 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 55 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: AMC. ID: 55 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 56 | 2021-02-08 11:31:02.323 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.323 Interactive Brokers | Requesting security definition data for: TLRY. ID: 56 | 2021-02-08 11:31:02.323 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 57 | 2021-02-08 11:31:02.324 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.324 Interactive Brokers | Requesting security definition data for: RKT. ID: 57 | 2021-02-08 11:31:02.324 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 58 | 2021-02-08 11:31:02.324 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.324 Interactive Brokers | Requesting security definition data for: GTT. ID: 58 | 2021-02-08 11:31:02.324 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 59 | 2021-02-08 11:31:02.324 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.324 Interactive Brokers | Requesting security definition data for: OMER. ID: 59 | 2021-02-08 11:31:02.324 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 60 | 2021-02-08 11:31:02.324 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.324 Interactive Brokers | Requesting security definition data for: SPCE. ID: 60 | 2021-02-08 11:31:02.324 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 61 | 2021-02-08 11:31:02.324 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.324 Interactive Brokers | Requesting security definition data for: SRG. ID: 61 | 2021-02-08 11:31:02.324 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 62 | 2021-02-08 11:31:02.324 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.324 Interactive Brokers | Requesting security definition data for: VTVT. ID: 62 | 2021-02-08 11:31:02.324 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 63 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: SDC. ID: 63 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 64 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: APRN. ID: 64 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 65 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: WKHS. ID: 65 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 66 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: PETS. ID: 66 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 67 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: SFIX. ID: 67 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 68 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: RVLV. ID: 68 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 69 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: BKE. ID: 69 | 2021-02-08 11:31:02.325 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 70 | 2021-02-08 11:31:02.325 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.325 Interactive Brokers | Requesting security definition data for: FUBO. ID: 70 | 2021-02-08 11:31:02.326 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 71 | 2021-02-08 11:31:02.326 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.326 Interactive Brokers | Requesting security definition data for: SIG. ID: 71 | 2021-02-08 11:31:02.326 Interactive Brokers | Starting real-time market data updates for: W. ID: 72 | 2021-02-08 11:31:02.326 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:02.326 Interactive Brokers | Requesting security definition data for: W. ID: 72 | 2021-02-08 11:31:02.326 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:31:02.327 Connection to the external service has been lost. | 2021-02-08 11:31:02.327 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:02.327 IB TWS socket (3) | Closed. | 2021-02-08 11:31:02.328 Canceling historical data download request for UPS Intraday data. | 2021-02-08 11:31:02.431 Removing historical data download ID 106. | 2021-02-08 11:31:02.431 Canceling historical data download request for NIO Intraday data. | 2021-02-08 11:31:02.431 Removing historical data download ID 107. | 2021-02-08 11:31:02.431 HD Request # 33 | Download canceled. | 2021-02-08 11:31:02.431 HD Request # 33 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for SPY | 2021-02-08 11:31:02.431 HD Request # 33 | Completion time: 4s | 2021-02-08 11:31:02.431 HD Request # 33 | Intraday data download complete for SPY. Unique request ID: 100 | 2021-02-08 11:31:02.431 Removing historical data download ID 100. | 2021-02-08 11:31:02.431 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:02.431 Triggering next historical data download in queue. | 2021-02-08 11:31:02.431 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:31:02.431 Interactive Brokers | Disconnected. | 2021-02-08 11:31:02.432 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:31:02.432 HD Server | HD Request #33 | Socket: 1 | Symbol: SPY | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 2219 | ClientRequestID: 33 | Username: ghsabri. | Thread:7992 | 2021-02-08 11:31:03.242 HD Server | Thread:7992 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:03.243 HD Server | Thread:7992 (1) | CloseSocket call. | 2021-02-08 11:31:03.243 HD Server | Thread:7992 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:03.244 HD Server | Thread:7992 (0) | CloseSocket call. | 2021-02-08 11:31:03.244 HD Server | Thread:7992 (1) | Closed. | 2021-02-08 11:31:03.244 HD Server | Thread:7992 (0) | CloseSocket call. | 2021-02-08 11:31:03.244 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:03.251 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:03.252 HD Server | Thread:3740 (1) | Creating socket. | 2021-02-08 11:31:03.270 HD Server | Setting DTC encoding to Binary VLS | Thread:3740 | 2021-02-08 11:31:03.270 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:3740 | 2021-02-08 11:31:03.271 HD Server | Login has been authorized. | Username: ghsabri. | Thread:3740 | 2021-02-08 11:31:03.271 HD Server | HD Request #34 | Socket: 1 | Symbol: TICK-nyse | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:30:46 | ClientRequestID: 34 | Username: ghsabri. | Thread:3740 | 2021-02-08 11:31:03.271 Added historical Intraday data request for TICK-nyse to the queue. | 2021-02-08 11:31:03.271 Intraday data recording state for symbol TICK-nyse is set to download 'Pending'. | 2021-02-08 11:31:03.271 Triggering next historical data download in queue. | 2021-02-08 11:31:03.271 HD Request # 34 | Downloading Intraday chart data for TICK-nyse to the file TICK-nyse.scid. Service: statscalc | 2021-02-08 11:31:03.271 HD Request # 34 | Download start date-time: 2021-02-08 11:30:46.000 | 2021-02-08 11:31:03.272 HD Request # 34 | Using server: ds12.sierracharts.com port 10150 | 2021-02-08 11:31:03.272 Socket (3) | Creating socket. | 2021-02-08 11:31:03.272 Socket (3) | Connecting to IP: 204.15.197.14. | 2021-02-08 11:31:03.272 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:7992 | 2021-02-08 11:31:03.320 HD Server Manager | Current server count=1 | 2021-02-08 11:31:03.320 HD Request # 34 | Setting DTC encoding to Binary VLS | 2021-02-08 11:31:03.390 HD Request # 34 | Sending historical data logon request message. | 2021-02-08 11:31:03.390 HD Request # 34 | Requesting Intraday data. Start date-time: 2021-02-08 11:30:46. Record interval: 0. Symbol: TICK-nyse | 2021-02-08 11:31:03.931 HD Request # 34 | Decompressing data. | 2021-02-08 11:31:03.977 HD Request # 34 | Receiving Intraday data for TICK-nyse starting at 2021-02-08 11:30:46 | 2021-02-08 11:31:03.977 Socket (3) | CloseSocket call. | 2021-02-08 11:31:03.978 HD Request # 34 | Historical data for TICK-nyse is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:31:03.978 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:31:03.978 Historical data download thread signaled to stop. | 2021-02-08 11:31:03.978 HD Request # 34 | Timestamp of first Intraday data file record written: 2021-02-08 11:30:47 | 2021-02-08 11:31:03.979 HD Request # 34 | Received 17 records from 2021-02-08 11:30:46.000 to 2021-02-08 11:31:02.000 (16.0 seconds) and wrote 16 records for TICK-nyse | 2021-02-08 11:31:03.979 HD Request # 34 | Completion time: 0s | 2021-02-08 11:31:03.979 HD Request # 34 | Intraday data download complete for TICK-nyse. Unique request ID: 108 | 2021-02-08 11:31:03.979 Removing historical data download ID 108. | 2021-02-08 11:31:03.979 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:03.979 Triggering next historical data download in queue. | 2021-02-08 11:31:03.979 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:04.026 Socket (3) | Closed. | 2021-02-08 11:31:04.026 HD Server | HD Request #34 | Socket: 1 | Symbol: TICK-nyse | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 17 | ClientRequestID: 34 | Username: ghsabri. | Thread:3740 | 2021-02-08 11:31:04.271 HD Server | Thread:3740 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:04.272 HD Server | Thread:3740 (1) | CloseSocket call. | 2021-02-08 11:31:04.272 HD Server | Thread:3740 (0) | CloseSocket call. | 2021-02-08 11:31:04.273 HD Server | Thread:3740 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:04.274 HD Server | Thread:3740 (0) | CloseSocket call. | 2021-02-08 11:31:04.274 HD Server | Thread:3740 (1) | Closed. | 2021-02-08 11:31:04.274 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:04.278 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:04.278 HD Server | Thread:20304 (1) | Creating socket. | 2021-02-08 11:31:04.298 HD Server | Setting DTC encoding to Binary VLS | Thread:20304 | 2021-02-08 11:31:04.298 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:20304 | 2021-02-08 11:31:04.298 HD Server | Login has been authorized. | Username: ghsabri. | Thread:20304 | 2021-02-08 11:31:04.298 HD Server | HD Request #35 | Socket: 1 | Symbol: NISS-NYSE | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:30:47 | ClientRequestID: 35 | Username: ghsabri. | Thread:20304 | 2021-02-08 11:31:04.299 Added historical Intraday data request for NISS-NYSE to the queue. | 2021-02-08 11:31:04.299 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2021-02-08 11:31:04.299 Triggering next historical data download in queue. | 2021-02-08 11:31:04.299 HD Request # 35 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2021-02-08 11:31:04.299 HD Request # 35 | Download start date-time: 2021-02-08 11:30:47.000 | 2021-02-08 11:31:04.300 HD Request # 35 | Using server: ds4.sierracharts.com port 10149 | 2021-02-08 11:31:04.300 Socket (3) | Creating socket. | 2021-02-08 11:31:04.300 Socket (3) | Connecting to IP: 192.81.56.146. | 2021-02-08 11:31:04.300 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:3740 | 2021-02-08 11:31:04.331 HD Server Manager | Current server count=1 | 2021-02-08 11:31:04.331 HD Request # 35 | Setting DTC encoding to Binary VLS | 2021-02-08 11:31:04.392 HD Request # 35 | Sending historical data logon request message. | 2021-02-08 11:31:04.392 HD Request # 35 | Requesting Intraday data. Start date-time: 2021-02-08 11:30:47. Record interval: 0. Symbol: NISS-NYSE | 2021-02-08 11:31:04.978 HD Request # 35 | Decompressing data. | 2021-02-08 11:31:05.021 HD Request # 35 | Receiving Intraday data for NISS-NYSE starting at 2021-02-08 11:30:47 | 2021-02-08 11:31:05.022 Socket (3) | CloseSocket call. | 2021-02-08 11:31:05.022 HD Request # 35 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:31:05.022 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:31:05.022 Historical data download thread signaled to stop. | 2021-02-08 11:31:05.022 HD Request # 35 | Timestamp of first Intraday data file record written: 2021-02-08 11:30:48 | 2021-02-08 11:31:05.023 HD Request # 35 | Received 19 records from 2021-02-08 11:30:47.000 to 2021-02-08 11:31:05.000 (18.0 seconds) and wrote 18 records for NISS-NYSE | 2021-02-08 11:31:05.023 HD Request # 35 | Completion time: 1s | 2021-02-08 11:31:05.023 HD Request # 35 | Intraday data download complete for NISS-NYSE. Unique request ID: 109 | 2021-02-08 11:31:05.023 Removing historical data download ID 109. | 2021-02-08 11:31:05.023 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:05.023 Triggering next historical data download in queue. | 2021-02-08 11:31:05.023 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:05.065 Socket (3) | Closed. | 2021-02-08 11:31:05.065 HD Server | HD Request #35 | Socket: 1 | Symbol: NISS-NYSE | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 19 | ClientRequestID: 35 | Username: ghsabri. | Thread:20304 | 2021-02-08 11:31:05.315 HD Server | Thread:20304 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:05.317 HD Server | Thread:20304 (1) | CloseSocket call. | 2021-02-08 11:31:05.317 HD Server | Thread:20304 (0) | CloseSocket call. | 2021-02-08 11:31:05.318 HD Server | Thread:20304 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:05.318 HD Server | Thread:20304 (1) | Closed. | 2021-02-08 11:31:05.318 HD Server | Thread:20304 (0) | CloseSocket call. | 2021-02-08 11:31:05.318 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:20304 | 2021-02-08 11:31:05.322 HD Server Manager | Current server count=0 | 2021-02-08 11:31:05.322 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:05.323 HD Server Manager | Started new historical data server. Count=1 | 2021-02-08 11:31:05.323 HD Server | Thread:5128 (1) | Creating socket. | 2021-02-08 11:31:05.345 HD Server | Setting DTC encoding to Binary VLS | Thread:5128 | 2021-02-08 11:31:05.346 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:5128 | 2021-02-08 11:31:05.347 HD Server | Login has been authorized. | Username: ghsabri. | Thread:5128 | 2021-02-08 11:31:05.347 HD Server | HD Request #36 | Socket: 1 | Symbol: QQQ | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-05 18:30:45 | ClientRequestID: 36 | Username: ghsabri. | Thread:5128 | 2021-02-08 11:31:05.348 Interactive Brokers | Using primary service for historical data for QQQ | 2021-02-08 11:31:05.348 Added historical Intraday data request for QQQ to the queue. | 2021-02-08 11:31:05.348 Intraday data recording state for symbol QQQ is set to download 'Pending'. | 2021-02-08 11:31:05.348 Triggering next historical data download in queue. | 2021-02-08 11:31:05.348 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:31:05.442 IB TWS socket (3) | Creating socket. | 2021-02-08 11:31:05.442 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:31:05.442 Interactive Brokers | Sending API sign: API | 2021-02-08 11:31:05.949 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:31:05.949 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:31:05.973 Interactive Brokers | TWS time: 20210208 11:31:06 Central Standard Time | 2021-02-08 11:31:05.973 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:31:06.229 Interactive Brokers | Waiting for account information. | 2021-02-08 11:31:06.229 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:31:06.260 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:31:06.260 IB Account information received. | 2021-02-08 11:31:06.260 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:31:06.260 Interactive Brokers | Connected to Live account. | 2021-02-08 11:31:06.260 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:31:06.260 Triggering next historical data download in queue. | 2021-02-08 11:31:06.263 Triggering next historical data download in queue. | 2021-02-08 11:31:06.263 Triggering next historical data download in queue. | 2021-02-08 11:31:06.263 Triggering next historical data download in queue. | 2021-02-08 11:31:06.263 Updated verified funded futures trading account ending date to: 2021-03-10 17:31:06 | 2021-02-08 11:31:06.263 Next valid order ID: 31226 | 2021-02-08 11:31:06.293 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:06.293 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:06.293 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:31:06.293 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:31:06.293 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:31:06.293 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:31:06.293 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:31:06.293 Next valid order ID: 31226 | 2021-02-08 11:31:06.293 Interactive Brokers | Starting real-time market data updates for: QQQ. ID: 1 | 2021-02-08 11:31:06.293 Interactive Brokers | Subscribing to Symbol: QQQ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.293 Interactive Brokers | Requesting security definition data for: QQQ. ID: 1 | 2021-02-08 11:31:06.293 Delaying start of download for QQQ | 2021-02-08 11:31:06.293 Next valid order ID: 31226 | 2021-02-08 11:31:06.294 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 2 | 2021-02-08 11:31:06.294 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.294 Interactive Brokers | Requesting security definition data for: MSFT. ID: 2 | 2021-02-08 11:31:06.294 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:31:06.294 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:31:06.294 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:31:06.294 Triggering next historical data download in queue. | 2021-02-08 11:31:06.294 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 3 | 2021-02-08 11:31:06.317 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.317 Interactive Brokers | Requesting security definition data for: LGND. ID: 3 | 2021-02-08 11:31:06.317 Interactive Brokers | Starting real-time market data updates for: GME. ID: 4 | 2021-02-08 11:31:06.318 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.318 Interactive Brokers | Requesting security definition data for: GME. ID: 4 | 2021-02-08 11:31:06.318 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 5 | 2021-02-08 11:31:06.318 IB TWS socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:06.318 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.318 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:31:06.318 Interactive Brokers | Requesting security definition data for: MDGL. ID: 5 | 2021-02-08 11:31:06.318 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:31:06.318 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 6 | 2021-02-08 11:31:06.318 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.318 Interactive Brokers | Requesting security definition data for: IRBT. ID: 6 | 2021-02-08 11:31:06.318 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 7 | 2021-02-08 11:31:06.318 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.318 Interactive Brokers | Requesting security definition data for: CVNA. ID: 7 | 2021-02-08 11:31:06.318 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 8 | 2021-02-08 11:31:06.318 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.318 Interactive Brokers | Requesting security definition data for: SPWR. ID: 8 | 2021-02-08 11:31:06.318 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 9 | 2021-02-08 11:31:06.319 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.319 Interactive Brokers | Requesting security definition data for: SCVL. ID: 9 | 2021-02-08 11:31:06.319 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 10 | 2021-02-08 11:31:06.319 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.319 Interactive Brokers | Requesting security definition data for: GSX. ID: 10 | 2021-02-08 11:31:06.319 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 11 | 2021-02-08 11:31:06.319 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.319 Interactive Brokers | Requesting security definition data for: BLNK. ID: 11 | 2021-02-08 11:31:06.319 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 12 | 2021-02-08 11:31:06.319 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.319 Interactive Brokers | Requesting security definition data for: OTRK. ID: 12 | 2021-02-08 11:31:06.319 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 13 | 2021-02-08 11:31:06.319 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.319 Interactive Brokers | Requesting security definition data for: VIAC. ID: 13 | 2021-02-08 11:31:06.319 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 14 | 2021-02-08 11:31:06.319 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.319 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 14 | 2021-02-08 11:31:06.319 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 15 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: CVM. ID: 15 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 16 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: RUBY. ID: 16 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 17 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: CAKE. ID: 17 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 18 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: RVP. ID: 18 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: NK. ID: 19 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: NK. ID: 19 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 20 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: RXT. ID: 20 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 21 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: DDS. ID: 21 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 22 | 2021-02-08 11:31:06.320 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.320 Interactive Brokers | Requesting security definition data for: LAZR. ID: 22 | 2021-02-08 11:31:06.320 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 23 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: AXDX. ID: 23 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 24 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: DKS. ID: 24 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 25 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: CLVS. ID: 25 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 26 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: AKTS. ID: 26 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 27 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: BYND. ID: 27 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: APT. ID: 28 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: APT. ID: 28 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 29 | 2021-02-08 11:31:06.321 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.321 Interactive Brokers | Requesting security definition data for: HIBB. ID: 29 | 2021-02-08 11:31:06.321 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 30 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: LOVE. ID: 30 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 31 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: MIK. ID: 31 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 32 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: PGEN. ID: 32 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 33 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: SKT. ID: 33 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 34 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: SENS. ID: 34 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: INO. ID: 35 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: INO. ID: 35 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 36 | 2021-02-08 11:31:06.322 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.322 Interactive Brokers | Requesting security definition data for: AWH. ID: 36 | 2021-02-08 11:31:06.322 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 37 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.323 Interactive Brokers | Requesting security definition data for: FLXN. ID: 37 | 2021-02-08 11:31:06.323 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 38 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.323 Interactive Brokers | Requesting security definition data for: OPK. ID: 38 | 2021-02-08 11:31:06.323 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 39 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.323 Interactive Brokers | Requesting security definition data for: RGS. ID: 39 | 2021-02-08 11:31:06.323 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 40 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.323 Interactive Brokers | Requesting security definition data for: SRNE. ID: 40 | 2021-02-08 11:31:06.323 Interactive Brokers | Starting real-time market data updates for: REV. ID: 41 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.323 Interactive Brokers | Requesting security definition data for: REV. ID: 41 | 2021-02-08 11:31:06.323 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 42 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.323 Interactive Brokers | Requesting security definition data for: EBIX. ID: 42 | 2021-02-08 11:31:06.323 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 43 | 2021-02-08 11:31:06.323 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: ICPT. ID: 43 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 44 | 2021-02-08 11:31:06.324 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: PECK. ID: 44 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 45 | 2021-02-08 11:31:06.324 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: BBBY. ID: 45 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 46 | 2021-02-08 11:31:06.324 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: PRTS. ID: 46 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 47 | 2021-02-08 11:31:06.324 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: KNDI. ID: 47 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 48 | 2021-02-08 11:31:06.324 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: JWN. ID: 48 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 49 | 2021-02-08 11:31:06.324 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.324 Interactive Brokers | Requesting security definition data for: CEMI. ID: 49 | 2021-02-08 11:31:06.324 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 50 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: LCI. ID: 50 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: TR. ID: 51 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: TR. ID: 51 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 52 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: SOLY. ID: 52 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 53 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: GOGO. ID: 53 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 54 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: DVAX. ID: 54 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 55 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: AMC. ID: 55 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 56 | 2021-02-08 11:31:06.325 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.325 Interactive Brokers | Requesting security definition data for: TLRY. ID: 56 | 2021-02-08 11:31:06.325 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 57 | 2021-02-08 11:31:06.326 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.326 Interactive Brokers | Requesting security definition data for: RKT. ID: 57 | 2021-02-08 11:31:06.326 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 58 | 2021-02-08 11:31:06.326 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.326 Interactive Brokers | Requesting security definition data for: GTT. ID: 58 | 2021-02-08 11:31:06.326 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 59 | 2021-02-08 11:31:06.326 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.326 Interactive Brokers | Requesting security definition data for: OMER. ID: 59 | 2021-02-08 11:31:06.326 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 60 | 2021-02-08 11:31:06.326 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.326 Interactive Brokers | Requesting security definition data for: SPCE. ID: 60 | 2021-02-08 11:31:06.326 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 61 | 2021-02-08 11:31:06.326 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.326 Interactive Brokers | Requesting security definition data for: SRG. ID: 61 | 2021-02-08 11:31:06.326 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 62 | 2021-02-08 11:31:06.326 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.326 Interactive Brokers | Requesting security definition data for: VTVT. ID: 62 | 2021-02-08 11:31:06.326 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 63 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: SDC. ID: 63 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 64 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: APRN. ID: 64 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 65 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: WKHS. ID: 65 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 66 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: PETS. ID: 66 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 67 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: SFIX. ID: 67 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 68 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: RVLV. ID: 68 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 69 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: BKE. ID: 69 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 70 | 2021-02-08 11:31:06.327 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.327 Interactive Brokers | Requesting security definition data for: FUBO. ID: 70 | 2021-02-08 11:31:06.327 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 71 | 2021-02-08 11:31:06.328 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.328 Interactive Brokers | Requesting security definition data for: SIG. ID: 71 | 2021-02-08 11:31:06.328 Interactive Brokers | Starting real-time market data updates for: W. ID: 72 | 2021-02-08 11:31:06.328 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:06.328 Interactive Brokers | Requesting security definition data for: W. ID: 72 | 2021-02-08 11:31:06.328 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:31:06.330 Connection to the external service has been lost. | 2021-02-08 11:31:06.330 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:06.330 IB TWS socket (3) | Closed. | 2021-02-08 11:31:06.330 HD Request # 36 | Downloading Intraday chart data for QQQ to the file QQQ.scid. Service: interactive_brokers.trading | 2021-02-08 11:31:06.401 HD Request # 36 | Download start date-time: 2021-02-05 12:30:12.000 | 2021-02-08 11:31:06.401 HD Request # 36 | Requesting a total of 3 days and 1254 seconds. | 2021-02-08 11:31:06.401 HD Request # 36 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174054. | 2021-02-08 11:31:06.401 HD Request # 36 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:12 for QQQ. PriceType: TRADES | 2021-02-08 11:31:06.401 Canceling historical data download request for MSFT Intraday data. | 2021-02-08 11:31:06.431 Removing historical data download ID 111. | 2021-02-08 11:31:06.431 HD Request # 36 | Download canceled. | 2021-02-08 11:31:06.431 HD Request # 36 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for QQQ | 2021-02-08 11:31:06.431 HD Request # 36 | Completion time: 0s | 2021-02-08 11:31:06.431 HD Request # 36 | Intraday data download complete for QQQ. Unique request ID: 110 | 2021-02-08 11:31:06.431 Removing historical data download ID 110. | 2021-02-08 11:31:06.431 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:06.431 Triggering next historical data download in queue. | 2021-02-08 11:31:06.432 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:31:06.432 Interactive Brokers | Disconnected. | 2021-02-08 11:31:06.432 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:31:06.432 HD Server | HD Request #36 | Socket: 1 | Symbol: QQQ | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 2020 | ClientRequestID: 36 | Username: ghsabri. | Thread:5128 | 2021-02-08 11:31:07.372 HD Server | Thread:5128 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:07.373 HD Server | Thread:5128 (1) | CloseSocket call. | 2021-02-08 11:31:07.373 HD Server | Thread:5128 (0) | CloseSocket call. | 2021-02-08 11:31:07.374 HD Server | Thread:5128 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:07.374 HD Server | Thread:5128 (1) | Closed. | 2021-02-08 11:31:07.375 HD Server | Thread:5128 (0) | CloseSocket call. | 2021-02-08 11:31:07.375 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:07.377 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:07.378 HD Server | Thread:20312 (1) | Creating socket. | 2021-02-08 11:31:07.390 HD Server | Setting DTC encoding to Binary VLS | Thread:20312 | 2021-02-08 11:31:07.391 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:20312 | 2021-02-08 11:31:07.391 HD Server | Login has been authorized. | Username: ghsabri. | Thread:20312 | 2021-02-08 11:31:07.391 HD Server | HD Request #37 | Socket: 1 | Symbol: NQ-202103-GLOBEX | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:20:50 | ClientRequestID: 37 | Username: ghsabri. | Thread:20312 | 2021-02-08 11:31:07.391 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-202103-GLOBEX | 2021-02-08 11:31:07.392 Added historical Intraday data request for NQ-202103-GLOBEX to the queue. | 2021-02-08 11:31:07.392 Intraday data recording state for symbol NQ-202103-GLOBEX is set to download 'Pending'. | 2021-02-08 11:31:07.392 Triggering next historical data download in queue. | 2021-02-08 11:31:07.392 HD Request # 37 | Downloading Intraday chart data for NQ-202103-GLOBEX to the file NQ-202103-GLOBEX.scid. Service: cme | 2021-02-08 11:31:07.392 HD Request # 37 | Download start date-time: 2021-02-08 11:20:50.000 | 2021-02-08 11:31:07.392 HD Request # 37 | Using server: ds21.sierracharts.com port 10150 | 2021-02-08 11:31:07.392 Socket (3) | Creating socket. | 2021-02-08 11:31:07.392 Socket (3) | Connecting to IP: 216.1.90.129. | 2021-02-08 11:31:07.392 HD Request # 37 | Setting DTC encoding to Binary VLS | 2021-02-08 11:31:07.467 HD Request # 37 | Sending historical data logon request message. | 2021-02-08 11:31:07.467 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:5128 | 2021-02-08 11:31:07.676 HD Server Manager | Current server count=1 | 2021-02-08 11:31:07.676 HD Request # 37 | Requesting Intraday data. Start date-time: 2021-02-08 11:20:50. Record interval: 0. Symbol: NQH21 | 2021-02-08 11:31:07.949 HD Request # 37 | Decompressing data. | 2021-02-08 11:31:07.983 HD Request # 37 | Receiving Intraday data for NQ-202103-GLOBEX starting at 2021-02-08 11:20:50 | 2021-02-08 11:31:07.984 Socket (3) | CloseSocket call. | 2021-02-08 11:31:07.985 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:31:07.985 HD Request # 37 | Historical data for NQ-202103-GLOBEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:31:07.985 Historical data download thread signaled to stop. | 2021-02-08 11:31:07.986 HD Request # 37 | Timestamp of first Intraday data file record written: 2021-02-08 11:20:51 | 2021-02-08 11:31:07.986 HD Request # 37 | Received 121 records from 2021-02-08 11:20:50.000 to 2021-02-08 11:21:08.004 (18.0 seconds) and wrote 117 records for NQ-202103-GLOBEX | 2021-02-08 11:31:07.986 HD Request # 37 | Completion time: 0s | 2021-02-08 11:31:07.986 HD Request # 37 | Intraday data download complete for NQ-202103-GLOBEX. Unique request ID: 112 | 2021-02-08 11:31:07.986 Removing historical data download ID 112. | 2021-02-08 11:31:07.986 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:07.986 Interactive Brokers | Using primary service for historical data for NQ-202103-GLOBEX | 2021-02-08 11:31:07.986 Added historical Intraday data request for NQ-202103-GLOBEX to the queue. | 2021-02-08 11:31:07.986 Intraday data recording state for symbol NQ-202103-GLOBEX is set to download 'Pending'. | 2021-02-08 11:31:07.986 Triggering next historical data download in queue. | 2021-02-08 11:31:07.986 Triggering next historical data download in queue. | 2021-02-08 11:31:07.986 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:08.019 Socket (3) | Closed. | 2021-02-08 11:31:08.019 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:31:09.464 IB TWS socket (3) | Creating socket. | 2021-02-08 11:31:09.464 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:31:09.464 Interactive Brokers | Sending API sign: API | 2021-02-08 11:31:09.976 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:31:09.976 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:31:09.981 Interactive Brokers | TWS time: 20210208 11:31:10 Central Standard Time | 2021-02-08 11:31:09.981 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:31:10.241 Interactive Brokers | Waiting for account information. | 2021-02-08 11:31:10.241 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:31:10.245 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:31:10.245 IB Account information received. | 2021-02-08 11:31:10.245 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:31:10.245 Interactive Brokers | Connected to Live account. | 2021-02-08 11:31:10.245 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:31:10.245 Triggering next historical data download in queue. | 2021-02-08 11:31:10.249 Triggering next historical data download in queue. | 2021-02-08 11:31:10.249 Triggering next historical data download in queue. | 2021-02-08 11:31:10.249 Triggering next historical data download in queue. | 2021-02-08 11:31:10.249 Updated verified funded futures trading account ending date to: 2021-03-10 17:31:10 | 2021-02-08 11:31:10.249 Next valid order ID: 31226 | 2021-02-08 11:31:10.280 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:10.280 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:10.280 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:31:10.280 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:31:10.280 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:31:10.280 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:31:10.280 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:31:10.280 Next valid order ID: 31226 | 2021-02-08 11:31:10.280 HD Request # 38 | Downloading Intraday chart data for NQ-202103-GLOBEX to the file NQ-202103-GLOBEX.scid. Service: interactive_brokers.trading | 2021-02-08 11:31:10.280 HD Request # 38 | Download start date-time: 2021-02-08 11:21:08.000 | 2021-02-08 11:31:10.281 HD Request # 38 | Requesting a total of 0 days and 5402 seconds. | 2021-02-08 11:31:10.281 HD Request # 38 | IB Backfill - Seconds requested: 5402. Seconds Remaining: 0. | 2021-02-08 11:31:10.281 HD Request # 38 | Requesting 5402 Seconds of data at 30 secs with ending date-time at 2021-02-08 12:41:10 for NQ-202103-GLOBEX. PriceType: TRADES | 2021-02-08 11:31:10.281 Next valid order ID: 31226 | 2021-02-08 11:31:10.281 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 2 | 2021-02-08 11:31:10.314 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.314 Interactive Brokers | Requesting security definition data for: MSFT. ID: 2 | 2021-02-08 11:31:10.314 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:31:10.314 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:31:10.315 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:31:10.315 Triggering next historical data download in queue. | 2021-02-08 11:31:10.315 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 3 | 2021-02-08 11:31:10.356 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.356 Interactive Brokers | Requesting security definition data for: VXRT. ID: 3 | 2021-02-08 11:31:10.356 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:31:10.356 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:31:10.356 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:31:10.356 Triggering next historical data download in queue. | 2021-02-08 11:31:10.356 HD Request # 38 | Processing historical data message from TWS | 2021-02-08 11:31:10.392 HD Request # 38 | Receiving Intraday data for NQ-202103-GLOBEX starting at 2021-02-08 11:11:30 | 2021-02-08 11:31:10.392 HD Request # 38 | Received 41 records and wrote 40 records from 2021-02-08 11:11:00 to 2021-02-08 11:31:00. | 2021-02-08 11:31:10.393 HD Request # 38 | Timestamp of first Intraday data file record written: 2021-02-08 11:21:30 | 2021-02-08 11:31:10.393 HD Request # 38 | Received 41 records from 2021-02-08 11:11:30.000 to 2021-02-08 11:31:00.000 (19.5 minutes) and wrote 20 records for NQ-202103-GLOBEX | 2021-02-08 11:31:10.393 HD Request # 38 | Completion time: 0s | 2021-02-08 11:31:10.394 HD Request # 38 | Intraday data download complete for NQ-202103-GLOBEX. Unique request ID: 113 | 2021-02-08 11:31:10.394 Removing historical data download ID 113. | 2021-02-08 11:31:10.394 Real-time Intraday chart data file updates started for NQ-202103-GLOBEX | 2021-02-08 11:31:10.394 Intraday chart data file opened for NQ-202103-GLOBEX | 2021-02-08 11:31:10.394 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:10.394 Triggering next historical data download in queue. | 2021-02-08 11:31:10.394 Delaying start of download for MSFT | 2021-02-08 11:31:10.394 HD Server | HD Request #37 | Socket: 1 | Symbol: NQ-202103-GLOBEX | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 39 | ClientRequestID: 37 | Username: ghsabri. | Thread:20312 | 2021-02-08 11:31:10.399 HD Server | Thread:20312 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:10.400 HD Server | Thread:20312 (1) | CloseSocket call. | 2021-02-08 11:31:10.400 HD Server | Thread:20312 (0) | CloseSocket call. | 2021-02-08 11:31:10.401 HD Server | Thread:20312 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:10.402 HD Server | Thread:20312 (1) | Closed. | 2021-02-08 11:31:10.402 HD Server | Thread:20312 (0) | CloseSocket call. | 2021-02-08 11:31:10.402 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:10.410 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:10.411 Interactive Brokers | Market data type is Live for MSFT | 2021-02-08 11:31:10.427 Enabling compression for file: C:\SierraChart\Data\MarketDepthData\MSFT.2021-02-08.depth. This may take a while. | 2021-02-08 11:31:10.427 Opened cached Depth file: C:\SierraChart\Data\MarketDepthData\MSFT.2021-02-08.depth | 2021-02-08 11:31:10.427 HD Server | Thread:8204 (1) | Creating socket. | 2021-02-08 11:31:10.431 HD Server | Setting DTC encoding to Binary VLS | Thread:8204 | 2021-02-08 11:31:10.432 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:8204 | 2021-02-08 11:31:10.432 HD Server | Login has been authorized. | Username: ghsabri. | Thread:8204 | 2021-02-08 11:31:10.432 HD Server | HD Request #38 | Socket: 1 | Symbol: TICK-nyse | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:31:02 | ClientRequestID: 38 | Username: ghsabri. | Thread:8204 | 2021-02-08 11:31:10.433 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 4 | 2021-02-08 11:31:10.433 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.433 Interactive Brokers | Requesting security definition data for: LGND. ID: 4 | 2021-02-08 11:31:10.433 Interactive Brokers | Starting real-time market data updates for: GME. ID: 5 | 2021-02-08 11:31:10.433 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.433 Interactive Brokers | Requesting security definition data for: GME. ID: 5 | 2021-02-08 11:31:10.433 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 6 | 2021-02-08 11:31:10.433 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.433 Interactive Brokers | Requesting security definition data for: MDGL. ID: 6 | 2021-02-08 11:31:10.433 IB TWS socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:31:10.433 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 7 | 2021-02-08 11:31:10.433 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:31:10.433 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.433 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:31:10.433 Interactive Brokers | Requesting security definition data for: IRBT. ID: 7 | 2021-02-08 11:31:10.433 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 8 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: CVNA. ID: 8 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 9 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: SPWR. ID: 9 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 10 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: SCVL. ID: 10 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 11 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: GSX. ID: 11 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 12 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: BLNK. ID: 12 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 13 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: OTRK. ID: 13 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 14 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: VIAC. ID: 14 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 15 | 2021-02-08 11:31:10.434 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.434 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 15 | 2021-02-08 11:31:10.434 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 16 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: CVM. ID: 16 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 17 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: RUBY. ID: 17 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 18 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: CAKE. ID: 18 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 19 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: RVP. ID: 19 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: NK. ID: 20 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: NK. ID: 20 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 21 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: RXT. ID: 21 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 22 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: DDS. ID: 22 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 23 | 2021-02-08 11:31:10.435 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.435 Interactive Brokers | Requesting security definition data for: LAZR. ID: 23 | 2021-02-08 11:31:10.435 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 24 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: AXDX. ID: 24 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 25 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: DKS. ID: 25 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 26 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: CLVS. ID: 26 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 27 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: AKTS. ID: 27 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 28 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: BYND. ID: 28 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: APT. ID: 29 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: APT. ID: 29 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 30 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: HIBB. ID: 30 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 31 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: LOVE. ID: 31 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 32 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: MIK. ID: 32 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 33 | 2021-02-08 11:31:10.436 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.436 Interactive Brokers | Requesting security definition data for: PGEN. ID: 33 | 2021-02-08 11:31:10.436 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 34 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: SKT. ID: 34 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 35 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: SENS. ID: 35 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: INO. ID: 36 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: INO. ID: 36 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 37 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: AWH. ID: 37 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 38 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: FLXN. ID: 38 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 39 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: OPK. ID: 39 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 40 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: RGS. ID: 40 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 41 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: SRNE. ID: 41 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: REV. ID: 42 | 2021-02-08 11:31:10.437 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.437 Interactive Brokers | Requesting security definition data for: REV. ID: 42 | 2021-02-08 11:31:10.437 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 43 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: EBIX. ID: 43 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 44 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: ICPT. ID: 44 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 45 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: PECK. ID: 45 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 46 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: BBBY. ID: 46 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 47 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: PRTS. ID: 47 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 48 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: KNDI. ID: 48 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 49 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: JWN. ID: 49 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 50 | 2021-02-08 11:31:10.438 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.438 Interactive Brokers | Requesting security definition data for: CEMI. ID: 50 | 2021-02-08 11:31:10.438 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 51 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: LCI. ID: 51 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: TR. ID: 52 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: TR. ID: 52 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 53 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: SOLY. ID: 53 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 54 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: GOGO. ID: 54 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 55 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: DVAX. ID: 55 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 56 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: AMC. ID: 56 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 57 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: TLRY. ID: 57 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 58 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: RKT. ID: 58 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 59 | 2021-02-08 11:31:10.439 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.439 Interactive Brokers | Requesting security definition data for: GTT. ID: 59 | 2021-02-08 11:31:10.439 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 60 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: OMER. ID: 60 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 61 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: SPCE. ID: 61 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 62 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: SRG. ID: 62 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 63 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: VTVT. ID: 63 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 64 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: SDC. ID: 64 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 65 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: APRN. ID: 65 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 66 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: WKHS. ID: 66 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 67 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: PETS. ID: 67 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 68 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: SFIX. ID: 68 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 69 | 2021-02-08 11:31:10.440 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.440 Interactive Brokers | Requesting security definition data for: RVLV. ID: 69 | 2021-02-08 11:31:10.440 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 70 | 2021-02-08 11:31:10.441 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.441 Interactive Brokers | Requesting security definition data for: BKE. ID: 70 | 2021-02-08 11:31:10.441 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 71 | 2021-02-08 11:31:10.441 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.441 Interactive Brokers | Requesting security definition data for: FUBO. ID: 71 | 2021-02-08 11:31:10.441 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 72 | 2021-02-08 11:31:10.441 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.441 Interactive Brokers | Requesting security definition data for: SIG. ID: 72 | 2021-02-08 11:31:10.441 Interactive Brokers | Starting real-time market data updates for: W. ID: 73 | 2021-02-08 11:31:10.441 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:10.441 Interactive Brokers | Requesting security definition data for: W. ID: 73 | 2021-02-08 11:31:10.441 Message from IB: Error reading request.Message id 4. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 4. Symbol: LGND. | 2021-02-08 11:31:10.442 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:31:10.442 Connection to the external service has been lost. | 2021-02-08 11:31:10.442 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:10.442 IB TWS socket (3) | Closed. | 2021-02-08 11:31:10.443 Added historical Intraday data request for TICK-nyse to the queue. | 2021-02-08 11:31:10.459 Triggering next historical data download in queue. | 2021-02-08 11:31:10.459 HD Request # 39 | Downloading Intraday chart data for TICK-nyse to the file TICK-nyse.scid. Service: statscalc | 2021-02-08 11:31:10.459 HD Request # 39 | Download start date-time: 2021-02-08 11:31:02.000 | 2021-02-08 11:31:10.459 HD Request # 39 | Using server: ds12.sierracharts.com port 10149 | 2021-02-08 11:31:10.459 Socket (3) | Creating socket. | 2021-02-08 11:31:10.460 Socket (3) | Connecting to IP: 204.15.197.14. | 2021-02-08 11:31:10.460 HD Request # 40 | Downloading Intraday chart data for MSFT to the file MSFT.scid. Service: interactive_brokers.trading | 2021-02-08 11:31:10.509 HD Request # 40 | Download start date-time: 2021-02-05 12:30:12.000 | 2021-02-08 11:31:10.510 HD Request # 40 | Requesting a total of 3 days and 1258 seconds. | 2021-02-08 11:31:10.510 HD Request # 40 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174058. | 2021-02-08 11:31:10.510 HD Request # 40 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:12 for MSFT. PriceType: TRADES | 2021-02-08 11:31:10.510 Canceling historical data download request for VXRT Intraday data. | 2021-02-08 11:31:10.570 Removing historical data download ID 115. | 2021-02-08 11:31:10.570 HD Request # 40 | Download canceled. | 2021-02-08 11:31:10.570 HD Request # 40 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for MSFT | 2021-02-08 11:31:10.570 HD Request # 40 | Completion time: 0s | 2021-02-08 11:31:10.570 HD Request # 40 | Intraday data download complete for MSFT. Unique request ID: 114 | 2021-02-08 11:31:10.570 Removing historical data download ID 114. | 2021-02-08 11:31:10.570 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:10.570 Triggering next historical data download in queue. | 2021-02-08 11:31:10.570 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:31:10.570 Interactive Brokers | Disconnected. | 2021-02-08 11:31:10.570 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:31:10.570 HD Request # 39 | Setting DTC encoding to Binary VLS | 2021-02-08 11:31:10.574 HD Request # 39 | Sending historical data logon request message. | 2021-02-08 11:31:10.574 HD Request # 39 | Requesting Intraday data. Start date-time: 2021-02-08 11:31:02. Record interval: 0. Symbol: TICK-nyse | 2021-02-08 11:31:10.620 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:20312 | 2021-02-08 11:31:10.661 HD Server Manager | Current server count=1 | 2021-02-08 11:31:10.661 HD Request # 39 | Decompressing data. | 2021-02-08 11:31:10.666 HD Request # 39 | Receiving Intraday data for TICK-nyse starting at 2021-02-08 11:31:02 | 2021-02-08 11:31:10.667 Socket (3) | CloseSocket call. | 2021-02-08 11:31:10.667 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:31:10.667 HD Request # 39 | Historical data for TICK-nyse is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:31:10.681 Historical data download thread signaled to stop. | 2021-02-08 11:31:10.681 HD Request # 39 | Timestamp of first Intraday data file record written: 2021-02-08 11:31:03 | 2021-02-08 11:31:10.681 HD Request # 39 | Received 9 records from 2021-02-08 11:31:02.000 to 2021-02-08 11:31:10.000 (8.0 seconds) and wrote 8 records for TICK-nyse | 2021-02-08 11:31:10.681 HD Request # 39 | Completion time: 0s | 2021-02-08 11:31:10.682 HD Request # 39 | Intraday data download complete for TICK-nyse. Unique request ID: 116 | 2021-02-08 11:31:10.682 Removing historical data download ID 116. | 2021-02-08 11:31:10.682 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:10.682 Triggering next historical data download in queue. | 2021-02-08 11:31:10.682 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:10.713 Socket (3) | Closed. | 2021-02-08 11:31:10.713 HD Server | Thread:8204 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:11.440 HD Server | HD Request #38 | Socket: 1 | Symbol: TICK-nyse | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 9 | ClientRequestID: 38 | Username: ghsabri. | Thread:8204 | 2021-02-08 11:31:11.440 HD Server | Thread:8204 (1) | CloseSocket call. | 2021-02-08 11:31:11.440 HD Server | Thread:8204 (0) | CloseSocket call. | 2021-02-08 11:31:11.442 HD Server | Thread:8204 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:11.442 HD Server | Thread:8204 (1) | Closed. | 2021-02-08 11:31:11.442 HD Server | Thread:8204 (0) | CloseSocket call. | 2021-02-08 11:31:11.442 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:11.444 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:11.444 HD Server | Thread:19984 (1) | Creating socket. | 2021-02-08 11:31:11.455 HD Server | Setting DTC encoding to Binary VLS | Thread:19984 | 2021-02-08 11:31:11.456 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:19984 | 2021-02-08 11:31:11.456 HD Server | Login has been authorized. | Username: ghsabri. | Thread:19984 | 2021-02-08 11:31:11.456 HD Server | HD Request #39 | Socket: 1 | Symbol: NISS-NYSE | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-08 17:31:05 | ClientRequestID: 39 | Username: ghsabri. | Thread:19984 | 2021-02-08 11:31:11.456 Added historical Intraday data request for NISS-NYSE to the queue. | 2021-02-08 11:31:11.457 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2021-02-08 11:31:11.457 Triggering next historical data download in queue. | 2021-02-08 11:31:11.457 HD Request # 41 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2021-02-08 11:31:11.457 HD Request # 41 | Download start date-time: 2021-02-08 11:31:05.000 | 2021-02-08 11:31:11.457 HD Request # 41 | Using server: ds4.sierracharts.com port 10150 | 2021-02-08 11:31:11.457 Socket (3) | Creating socket. | 2021-02-08 11:31:11.457 Socket (3) | Connecting to IP: 192.81.56.146. | 2021-02-08 11:31:11.458 HD Request # 41 | Setting DTC encoding to Binary VLS | 2021-02-08 11:31:11.559 HD Request # 41 | Sending historical data logon request message. | 2021-02-08 11:31:11.559 HD Request # 41 | Requesting Intraday data. Start date-time: 2021-02-08 11:31:05. Record interval: 0. Symbol: NISS-NYSE | 2021-02-08 11:31:11.604 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:8204 | 2021-02-08 11:31:11.630 HD Server Manager | Current server count=1 | 2021-02-08 11:31:11.630 HD Request # 41 | Decompressing data. | 2021-02-08 11:31:11.650 HD Request # 41 | Receiving Intraday data for NISS-NYSE starting at 2021-02-08 11:31:05 | 2021-02-08 11:31:11.650 Socket (3) | CloseSocket call. | 2021-02-08 11:31:11.651 HD Request # 41 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2021-02-08 11:31:11.651 Socket (3) | Shutdown started. Waiting for graceful close. | 2021-02-08 11:31:11.651 Historical data download thread signaled to stop. | 2021-02-08 11:31:11.651 HD Request # 41 | Timestamp of first Intraday data file record written: 2021-02-08 11:31:06 | 2021-02-08 11:31:11.651 HD Request # 41 | Received 7 records from 2021-02-08 11:31:05.000 to 2021-02-08 11:31:11.000 (6.0 seconds) and wrote 6 records for NISS-NYSE | 2021-02-08 11:31:11.651 HD Request # 41 | Completion time: 0s | 2021-02-08 11:31:11.651 HD Request # 41 | Intraday data download complete for NISS-NYSE. Unique request ID: 117 | 2021-02-08 11:31:11.651 Removing historical data download ID 117. | 2021-02-08 11:31:11.651 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:11.651 Triggering next historical data download in queue. | 2021-02-08 11:31:11.651 Socket (3) | Socket gracefully closed by remote side. | 2021-02-08 11:31:11.697 Socket (3) | Closed. | 2021-02-08 11:31:11.697 HD Server | HD Request #39 | Socket: 1 | Symbol: NISS-NYSE | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 7 | ClientRequestID: 39 | Username: ghsabri. | Thread:19984 | 2021-02-08 11:31:12.456 HD Server | Thread:19984 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:12.456 HD Server | Thread:19984 (1) | CloseSocket call. | 2021-02-08 11:31:12.456 HD Server | Thread:19984 (0) | CloseSocket call. | 2021-02-08 11:31:12.457 HD Server | Thread:19984 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:12.457 HD Server | Thread:19984 (1) | Closed. | 2021-02-08 11:31:12.457 HD Server | Thread:19984 (0) | CloseSocket call. | 2021-02-08 11:31:12.457 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:12.460 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:12.460 HD Server | Thread:16648 (1) | Creating socket. | 2021-02-08 11:31:12.471 HD Server | Setting DTC encoding to Binary VLS | Thread:16648 | 2021-02-08 11:31:12.472 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:16648 | 2021-02-08 11:31:12.473 HD Server | Login has been authorized. | Username: ghsabri. | Thread:16648 | 2021-02-08 11:31:12.473 HD Server | HD Request #40 | Socket: 1 | Symbol: SPY | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-05 18:30:40 | ClientRequestID: 40 | Username: ghsabri. | Thread:16648 | 2021-02-08 11:31:12.473 Interactive Brokers | Using primary service for historical data for SPY | 2021-02-08 11:31:12.473 Added historical Intraday data request for SPY to the queue. | 2021-02-08 11:31:12.473 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2021-02-08 11:31:12.473 Triggering next historical data download in queue. | 2021-02-08 11:31:12.473 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:19984 | 2021-02-08 11:31:12.630 HD Server Manager | Current server count=1 | 2021-02-08 11:31:12.630 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:31:13.578 IB TWS socket (3) | Creating socket. | 2021-02-08 11:31:13.578 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:31:13.579 Interactive Brokers | Sending API sign: API | 2021-02-08 11:31:14.088 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:31:14.088 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:31:14.226 Interactive Brokers | TWS time: 20210208 11:31:14 Central Standard Time | 2021-02-08 11:31:14.226 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:31:14.477 Interactive Brokers | Waiting for account information. | 2021-02-08 11:31:14.477 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:31:14.479 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:31:14.479 IB Account information received. | 2021-02-08 11:31:14.479 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:31:14.479 Interactive Brokers | Connected to Live account. | 2021-02-08 11:31:14.479 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:31:14.479 Triggering next historical data download in queue. | 2021-02-08 11:31:14.483 Triggering next historical data download in queue. | 2021-02-08 11:31:14.483 Triggering next historical data download in queue. | 2021-02-08 11:31:14.483 Triggering next historical data download in queue. | 2021-02-08 11:31:14.483 Updated verified funded futures trading account ending date to: 2021-03-10 17:31:14 | 2021-02-08 11:31:14.484 Next valid order ID: 31226 | 2021-02-08 11:31:14.523 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:14.523 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:14.523 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:31:14.523 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:31:14.523 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:31:14.525 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:31:14.525 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:31:14.525 Next valid order ID: 31226 | 2021-02-08 11:31:14.525 Next valid order ID: 31226 | 2021-02-08 11:31:14.525 Interactive Brokers | Starting real-time market data updates for: SPY. ID: 1 | 2021-02-08 11:31:14.525 Interactive Brokers | Subscribing to Symbol: SPY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.526 Interactive Brokers | Requesting security definition data for: SPY. ID: 1 | 2021-02-08 11:31:14.526 Delaying start of download for SPY | 2021-02-08 11:31:14.526 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 2 | 2021-02-08 11:31:14.526 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.526 Interactive Brokers | Requesting security definition data for: VXRT. ID: 2 | 2021-02-08 11:31:14.526 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:31:14.526 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:31:14.526 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:31:14.526 Triggering next historical data download in queue. | 2021-02-08 11:31:14.527 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 3 | 2021-02-08 11:31:14.544 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.544 Interactive Brokers | Requesting security definition data for: UPS. ID: 3 | 2021-02-08 11:31:14.544 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:31:14.544 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:31:14.544 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:31:14.544 Triggering next historical data download in queue. | 2021-02-08 11:31:14.544 Interactive Brokers | Starting real-time market data updates for: NIO. ID: 4 | 2021-02-08 11:31:14.545 Interactive Brokers | Subscribing to Symbol: NIO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.546 Interactive Brokers | Requesting security definition data for: NIO. ID: 4 | 2021-02-08 11:31:14.546 Interactive Brokers | Using primary service for historical data for NIO | 2021-02-08 11:31:14.546 Added historical Intraday data request for NIO to the queue. | 2021-02-08 11:31:14.546 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-02-08 11:31:14.546 Triggering next historical data download in queue. | 2021-02-08 11:31:14.546 Interactive Brokers | Starting real-time market data updates for: LGND. ID: 5 | 2021-02-08 11:31:14.568 Interactive Brokers | Subscribing to Symbol: LGND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.568 Interactive Brokers | Requesting security definition data for: LGND. ID: 5 | 2021-02-08 11:31:14.568 Interactive Brokers | Starting real-time market data updates for: GME. ID: 6 | 2021-02-08 11:31:14.568 Interactive Brokers | Subscribing to Symbol: GME, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.568 Interactive Brokers | Requesting security definition data for: GME. ID: 6 | 2021-02-08 11:31:14.568 Interactive Brokers | Starting real-time market data updates for: MDGL. ID: 7 | 2021-02-08 11:31:14.568 Interactive Brokers | Subscribing to Symbol: MDGL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: MDGL. ID: 7 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: IRBT. ID: 8 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: IRBT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 IB TWS socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: IRBT. ID: 8 | 2021-02-08 11:31:14.569 IB TWS socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2021-02-08 11:31:14.569 IB TWS socket (3) | Socket send error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: CVNA. ID: 9 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: CVNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: CVNA. ID: 9 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: SPWR. ID: 10 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: SPWR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: SPWR. ID: 10 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: SCVL. ID: 11 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: SCVL, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: SCVL. ID: 11 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: GSX. ID: 12 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: GSX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: GSX. ID: 12 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 13 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: BLNK. ID: 13 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: OTRK. ID: 14 | 2021-02-08 11:31:14.569 Interactive Brokers | Subscribing to Symbol: OTRK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.569 Interactive Brokers | Requesting security definition data for: OTRK. ID: 14 | 2021-02-08 11:31:14.569 Interactive Brokers | Starting real-time market data updates for: VIAC. ID: 15 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: VIAC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: VIAC. ID: 15 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: FIZZ. ID: 16 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: FIZZ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: FIZZ. ID: 16 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: CVM. ID: 17 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: CVM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: CVM. ID: 17 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: RUBY. ID: 18 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: RUBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: RUBY. ID: 18 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: CAKE. ID: 19 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: CAKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: CAKE. ID: 19 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: RVP. ID: 20 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: RVP, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: RVP. ID: 20 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: NK. ID: 21 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: NK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: NK. ID: 21 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: RXT. ID: 22 | 2021-02-08 11:31:14.570 Interactive Brokers | Subscribing to Symbol: RXT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.570 Interactive Brokers | Requesting security definition data for: RXT. ID: 22 | 2021-02-08 11:31:14.570 Interactive Brokers | Starting real-time market data updates for: DDS. ID: 23 | 2021-02-08 11:31:14.571 Interactive Brokers | Subscribing to Symbol: DDS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.571 Interactive Brokers | Requesting security definition data for: DDS. ID: 23 | 2021-02-08 11:31:14.571 Interactive Brokers | Starting real-time market data updates for: LAZR. ID: 24 | 2021-02-08 11:31:14.571 Interactive Brokers | Subscribing to Symbol: LAZR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.571 Interactive Brokers | Requesting security definition data for: LAZR. ID: 24 | 2021-02-08 11:31:14.571 Interactive Brokers | Starting real-time market data updates for: AXDX. ID: 25 | 2021-02-08 11:31:14.571 Interactive Brokers | Subscribing to Symbol: AXDX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.571 Interactive Brokers | Requesting security definition data for: AXDX. ID: 25 | 2021-02-08 11:31:14.571 Interactive Brokers | Starting real-time market data updates for: DKS. ID: 26 | 2021-02-08 11:31:14.571 Interactive Brokers | Subscribing to Symbol: DKS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.571 Interactive Brokers | Requesting security definition data for: DKS. ID: 26 | 2021-02-08 11:31:14.571 Interactive Brokers | Starting real-time market data updates for: CLVS. ID: 27 | 2021-02-08 11:31:14.571 Interactive Brokers | Subscribing to Symbol: CLVS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.571 Interactive Brokers | Requesting security definition data for: CLVS. ID: 27 | 2021-02-08 11:31:14.571 Interactive Brokers | Starting real-time market data updates for: AKTS. ID: 28 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: AKTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: AKTS. ID: 28 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 29 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: BYND. ID: 29 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: APT. ID: 30 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: APT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: APT. ID: 30 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: HIBB. ID: 31 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: HIBB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: HIBB. ID: 31 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: LOVE. ID: 32 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: LOVE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: LOVE. ID: 32 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: MIK. ID: 33 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: MIK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: MIK. ID: 33 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: PGEN. ID: 34 | 2021-02-08 11:31:14.572 Interactive Brokers | Subscribing to Symbol: PGEN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.572 Interactive Brokers | Requesting security definition data for: PGEN. ID: 34 | 2021-02-08 11:31:14.572 Interactive Brokers | Starting real-time market data updates for: SKT. ID: 35 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: SKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: SKT. ID: 35 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: SENS. ID: 36 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: SENS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: SENS. ID: 36 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: INO. ID: 37 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: INO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: INO. ID: 37 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: AWH. ID: 38 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: AWH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: AWH. ID: 38 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: FLXN. ID: 39 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: FLXN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: FLXN. ID: 39 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: OPK. ID: 40 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: OPK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: OPK. ID: 40 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: RGS. ID: 41 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: RGS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: RGS. ID: 41 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: SRNE. ID: 42 | 2021-02-08 11:31:14.573 Interactive Brokers | Subscribing to Symbol: SRNE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.573 Interactive Brokers | Requesting security definition data for: SRNE. ID: 42 | 2021-02-08 11:31:14.573 Interactive Brokers | Starting real-time market data updates for: REV. ID: 43 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: REV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: REV. ID: 43 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: EBIX. ID: 44 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: EBIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: EBIX. ID: 44 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: ICPT. ID: 45 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: ICPT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: ICPT. ID: 45 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: PECK. ID: 46 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: PECK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: PECK. ID: 46 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: BBBY. ID: 47 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: BBBY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: BBBY. ID: 47 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: PRTS. ID: 48 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: PRTS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: PRTS. ID: 48 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: KNDI. ID: 49 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: KNDI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: KNDI. ID: 49 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: JWN. ID: 50 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: JWN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: JWN. ID: 50 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: CEMI. ID: 51 | 2021-02-08 11:31:14.574 Interactive Brokers | Subscribing to Symbol: CEMI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.574 Interactive Brokers | Requesting security definition data for: CEMI. ID: 51 | 2021-02-08 11:31:14.574 Interactive Brokers | Starting real-time market data updates for: LCI. ID: 52 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: LCI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: LCI. ID: 52 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: TR. ID: 53 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: TR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: TR. ID: 53 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: SOLY. ID: 54 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: SOLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: SOLY. ID: 54 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: GOGO. ID: 55 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: GOGO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: GOGO. ID: 55 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: DVAX. ID: 56 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: DVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: DVAX. ID: 56 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: AMC. ID: 57 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: AMC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: AMC. ID: 57 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: TLRY. ID: 58 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: TLRY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: TLRY. ID: 58 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: RKT. ID: 59 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: RKT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: RKT. ID: 59 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: GTT. ID: 60 | 2021-02-08 11:31:14.575 Interactive Brokers | Subscribing to Symbol: GTT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.575 Interactive Brokers | Requesting security definition data for: GTT. ID: 60 | 2021-02-08 11:31:14.575 Interactive Brokers | Starting real-time market data updates for: OMER. ID: 61 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: OMER, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: OMER. ID: 61 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: SPCE. ID: 62 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: SPCE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NYSE, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: SPCE. ID: 62 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: SRG. ID: 63 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: SRG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: SRG. ID: 63 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: VTVT. ID: 64 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: VTVT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: VTVT. ID: 64 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: SDC. ID: 65 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: SDC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: SDC. ID: 65 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: APRN. ID: 66 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: APRN, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: APRN. ID: 66 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 67 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: WKHS. ID: 67 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: PETS. ID: 68 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: PETS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: PETS. ID: 68 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 69 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: SFIX. ID: 69 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: RVLV. ID: 70 | 2021-02-08 11:31:14.576 Interactive Brokers | Subscribing to Symbol: RVLV, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.576 Interactive Brokers | Requesting security definition data for: RVLV. ID: 70 | 2021-02-08 11:31:14.576 Interactive Brokers | Starting real-time market data updates for: BKE. ID: 71 | 2021-02-08 11:31:14.577 Interactive Brokers | Subscribing to Symbol: BKE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.577 Interactive Brokers | Requesting security definition data for: BKE. ID: 71 | 2021-02-08 11:31:14.577 Interactive Brokers | Starting real-time market data updates for: FUBO. ID: 72 | 2021-02-08 11:31:14.577 Interactive Brokers | Subscribing to Symbol: FUBO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.577 Interactive Brokers | Requesting security definition data for: FUBO. ID: 72 | 2021-02-08 11:31:14.577 Interactive Brokers | Starting real-time market data updates for: SIG. ID: 73 | 2021-02-08 11:31:14.577 Interactive Brokers | Subscribing to Symbol: SIG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.577 Interactive Brokers | Requesting security definition data for: SIG. ID: 73 | 2021-02-08 11:31:14.577 Interactive Brokers | Starting real-time market data updates for: W. ID: 74 | 2021-02-08 11:31:14.577 Interactive Brokers | Subscribing to Symbol: W, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:14.577 Interactive Brokers | Requesting security definition data for: W. ID: 74 | 2021-02-08 11:31:14.577 Message from IB: Error reading request.Message id 5. Attempted read beyond end of socket stream - . IB Error Code: 320. Request ID: 5. Symbol: LGND. | 2021-02-08 11:31:14.578 IB TWS socket (3) | CloseSocket call. | 2021-02-08 11:31:14.578 Connection to the external service has been lost. | 2021-02-08 11:31:14.578 IB TWS socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:14.578 IB TWS socket (3) | Closed. | 2021-02-08 11:31:14.578 HD Request # 42 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: interactive_brokers.trading | 2021-02-08 11:31:14.653 HD Request # 42 | Download start date-time: 2021-02-05 12:30:13.000 | 2021-02-08 11:31:14.653 HD Request # 42 | Requesting a total of 3 days and 1261 seconds. | 2021-02-08 11:31:14.653 HD Request # 42 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 174061. | 2021-02-08 11:31:14.653 HD Request # 42 | Requesting 1 Day of data at 30 secs with ending date-time at 2021-02-06 12:20:13 for SPY. PriceType: TRADES | 2021-02-08 11:31:14.653 Canceling historical data download request for VXRT Intraday data. | 2021-02-08 11:31:14.724 Removing historical data download ID 119. | 2021-02-08 11:31:14.724 Canceling historical data download request for UPS Intraday data. | 2021-02-08 11:31:14.724 Removing historical data download ID 120. | 2021-02-08 11:31:14.724 Canceling historical data download request for NIO Intraday data. | 2021-02-08 11:31:14.724 Removing historical data download ID 121. | 2021-02-08 11:31:14.724 HD Request # 42 | Download canceled. | 2021-02-08 11:31:14.724 HD Request # 42 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for SPY | 2021-02-08 11:31:14.724 HD Request # 42 | Completion time: 0s | 2021-02-08 11:31:14.724 HD Request # 42 | Intraday data download complete for SPY. Unique request ID: 118 | 2021-02-08 11:31:14.724 Removing historical data download ID 118. | 2021-02-08 11:31:14.724 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2021-02-08 11:31:14.724 Triggering next historical data download in queue. | 2021-02-08 11:31:14.724 IB TWS socket (0) | CloseSocket call. | 2021-02-08 11:31:14.724 Interactive Brokers | Disconnected. | 2021-02-08 11:31:14.724 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2021-02-08 11:31:14.724 HD Server | HD Request #40 | Socket: 1 | Symbol: SPY | ServiceCode: DTCSubInstance | RecordInterval: 1 | Records Served: 2219 | ClientRequestID: 40 | Username: ghsabri. | Thread:16648 | 2021-02-08 11:31:15.482 HD Server | Thread:16648 (1) | Socket gracefully closed by remote side. | 2021-02-08 11:31:15.484 HD Server | Thread:16648 (1) | CloseSocket call. | 2021-02-08 11:31:15.485 HD Server | Thread:16648 (0) | CloseSocket call. | 2021-02-08 11:31:15.487 HD Server | Thread:16648 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2021-02-08 11:31:15.487 HD Server | Thread:16648 (1) | Closed. | 2021-02-08 11:31:15.487 HD Server | Thread:16648 (0) | CloseSocket call. | 2021-02-08 11:31:15.487 HD Server Manager | Incoming connection from IP: 127.0.0.1 | 2021-02-08 11:31:15.490 HD Server Manager | Started new historical data server. Count=2 | 2021-02-08 11:31:15.491 HD Server | Thread:15440 (1) | Creating socket. | 2021-02-08 11:31:15.502 HD Server | Setting DTC encoding to Binary VLS | Thread:15440 | 2021-02-08 11:31:15.502 HD Server | Received login. Requesting authorization. | Username: ghsabri. | Thread:15440 | 2021-02-08 11:31:15.502 HD Server | Login has been authorized. | Username: ghsabri. | Thread:15440 | 2021-02-08 11:31:15.502 HD Server | HD Request #41 | Socket: 1 | Symbol: QQQ | ServiceCode: DTCSubInstance | RecordInterval: 1 | MaximumDaysRequested: 0 | Start date-time: 2021-02-05 18:30:45 | ClientRequestID: 41 | Username: ghsabri. | Thread:15440 | 2021-02-08 11:31:15.503 Interactive Brokers | Using primary service for historical data for QQQ | 2021-02-08 11:31:15.517 Added historical Intraday data request for QQQ to the queue. | 2021-02-08 11:31:15.517 Intraday data recording state for symbol QQQ is set to download 'Pending'. | 2021-02-08 11:31:15.517 Triggering next historical data download in queue. | 2021-02-08 11:31:15.517 HD Server | Server thread ending. Closing socket. | Username: ghsabri. | Thread:16648 | 2021-02-08 11:31:15.640 HD Server Manager | Current server count=1 | 2021-02-08 11:31:15.640 Interactive Brokers | Connecting to 127.0.0.1:7496 | 2021-02-08 11:31:17.711 IB TWS socket (3) | Creating socket. | 2021-02-08 11:31:17.711 IB TWS socket (3) | Connecting to IP: 127.0.0.1. | 2021-02-08 11:31:17.711 Interactive Brokers | Sending API sign: API | 2021-02-08 11:31:18.221 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2021-02-08 11:31:18.221 Interactive Brokers | TWS server version: 136 | 2021-02-08 11:31:18.229 Interactive Brokers | TWS time: 20210208 11:31:18 Central Standard Time | 2021-02-08 11:31:18.229 Interactive Brokers | Connected. Sending Start API command. | 2021-02-08 11:31:18.482 Interactive Brokers | Waiting for account information. | 2021-02-08 11:31:18.482 Interactive Brokers | Sending request for contract details for contract ID 265598 | 2021-02-08 11:31:18.487 Interactive Brokers | Sending request for contract details for contract ID 104863799 | 2021-02-08 11:31:18.487 IB Account information received. | 2021-02-08 11:31:18.487 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2021-02-08 11:31:18.487 Interactive Brokers | Connected to Live account. | 2021-02-08 11:31:18.487 Interactive Brokers | Connected to data and trading server. | 2021-02-08 11:31:18.487 Triggering next historical data download in queue. | 2021-02-08 11:31:18.491 Triggering next historical data download in queue. | 2021-02-08 11:31:18.491 Triggering next historical data download in queue. | 2021-02-08 11:31:18.491 Triggering next historical data download in queue. | 2021-02-08 11:31:18.491 Updated verified funded futures trading account ending date to: 2021-03-10 17:31:18 | 2021-02-08 11:31:18.491 Next valid order ID: 31226 | 2021-02-08 11:31:18.520 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:18.520 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2021-02-08 11:31:18.520 Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2021-02-08 11:31:18.520 Message from IB: Sec-def data farm connection is OK:secdefil. IB Error Code: 2158. Request ID: -1. | 2021-02-08 11:31:18.520 Interactive Brokers | Received contract details for symbol AAPL-STK-SMART-USD | 2021-02-08 11:31:18.520 Interactive Brokers | Received contract details for symbol VIPS-STK-SMART-USD | 2021-02-08 11:31:18.520 Interactive Brokers | All contract details received for symbols used for trading. Starting timer to request trading data. | 2021-02-08 11:31:18.520 Next valid order ID: 31226 | 2021-02-08 11:31:18.520 Interactive Brokers | Starting real-time market data updates for: QQQ. ID: 1 | 2021-02-08 11:31:18.520 Interactive Brokers | Subscribing to Symbol: QQQ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.520 Interactive Brokers | Requesting security definition data for: QQQ. ID: 1 | 2021-02-08 11:31:18.520 Delaying start of download for QQQ | 2021-02-08 11:31:18.520 Next valid order ID: 31226 | 2021-02-08 11:31:18.536 Interactive Brokers | Starting real-time market data updates for: QS. ID: 2 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: QS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: QS. ID: 2 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: BLNK. ID: 3 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: BLNK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: BLNK. ID: 3 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: MRNA. ID: 4 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: MRNA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: MRNA. ID: 4 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: JMIA. ID: 5 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: JMIA, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: JMIA. ID: 5 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: BIGC. ID: 6 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: BIGC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: BIGC. ID: 6 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: CHWY. ID: 7 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: CHWY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: CHWY. ID: 7 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: ENPH. ID: 8 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: ENPH, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: ENPH. ID: 8 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: NVAX. ID: 9 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: NVAX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: NVAX. ID: 9 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: NNOX. ID: 10 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: NNOX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: NNOX. ID: 10 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: Z. ID: 11 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: Z, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: Z. ID: 11 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: BNTX. ID: 12 | 2021-02-08 11:31:18.537 Interactive Brokers | Subscribing to Symbol: BNTX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.537 Interactive Brokers | Requesting security definition data for: BNTX. ID: 12 | 2021-02-08 11:31:18.537 Interactive Brokers | Starting real-time market data updates for: OSTK. ID: 13 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: OSTK, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: OSTK. ID: 13 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: FSLY. ID: 14 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: FSLY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: FSLY. ID: 14 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: CRWD. ID: 15 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: CRWD, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: CRWD. ID: 15 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: PTON. ID: 16 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: PTON, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: PTON. ID: 16 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: SFIX. ID: 17 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: SFIX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: SFIX. ID: 17 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: BYND. ID: 18 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: BYND, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: BYND. ID: 18 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: BILI. ID: 19 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: BILI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: BILI. ID: 19 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: SE. ID: 20 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: SE, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: SE. ID: 20 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: TDOC. ID: 21 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: TDOC, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: TDOC. ID: 21 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: ETSY. ID: 22 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: ETSY, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: ETSY. ID: 22 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: DDOG. ID: 23 | 2021-02-08 11:31:18.538 Interactive Brokers | Subscribing to Symbol: DDOG, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.538 Interactive Brokers | Requesting security definition data for: DDOG. ID: 23 | 2021-02-08 11:31:18.538 Interactive Brokers | Starting real-time market data updates for: WKHS. ID: 24 | 2021-02-08 11:31:18.549 Interactive Brokers | Subscribing to Symbol: WKHS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.549 Interactive Brokers | Requesting security definition data for: WKHS. ID: 24 | 2021-02-08 11:31:18.549 Interactive Brokers | Using primary service for historical data for WKHS | 2021-02-08 11:31:18.549 Added historical Intraday data request for WKHS to the queue. | 2021-02-08 11:31:18.549 Intraday data recording state for symbol WKHS is set to download 'Pending'. | 2021-02-08 11:31:18.549 Triggering next historical data download in queue. | 2021-02-08 11:31:18.549 Interactive Brokers | Market data type is Live for QQQ | 2021-02-08 11:31:18.607 Interactive Brokers | Starting real-time market data updates for: MSFT. ID: 25 | 2021-02-08 11:31:18.618 Interactive Brokers | Subscribing to Symbol: MSFT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: NASDAQ, Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.618 Interactive Brokers | Requesting security definition data for: MSFT. ID: 25 | 2021-02-08 11:31:18.618 Interactive Brokers | Using primary service for historical data for MSFT | 2021-02-08 11:31:18.618 Added historical Intraday data request for MSFT to the queue. | 2021-02-08 11:31:18.618 Intraday data recording state for symbol MSFT is set to download 'Pending'. | 2021-02-08 11:31:18.618 Triggering next historical data download in queue. | 2021-02-08 11:31:18.618 Interactive Brokers | Starting real-time market data updates for: VXRT. ID: 26 | 2021-02-08 11:31:18.638 Interactive Brokers | Subscribing to Symbol: VXRT, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.638 Interactive Brokers | Requesting security definition data for: VXRT. ID: 26 | 2021-02-08 11:31:18.638 Interactive Brokers | Using primary service for historical data for VXRT | 2021-02-08 11:31:18.638 Added historical Intraday data request for VXRT to the queue. | 2021-02-08 11:31:18.638 Intraday data recording state for symbol VXRT is set to download 'Pending'. | 2021-02-08 11:31:18.638 Triggering next historical data download in queue. | 2021-02-08 11:31:18.638 Interactive Brokers | Market data type is Live for QS | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for BLNK | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for MRNA | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for JMIA | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for BIGC | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for CHWY | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for ENPH | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for NVAX | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for NNOX | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for Z | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for BNTX | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for OSTK | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for FSLY | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for CRWD | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for PTON | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for SFIX | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for BYND | 2021-02-08 11:31:18.657 Interactive Brokers | Market data type is Live for BILI | 2021-02-08 11:31:18.658 Interactive Brokers | Market data type is Live for SE | 2021-02-08 11:31:18.658 Interactive Brokers | Market data type is Live for TDOC | 2021-02-08 11:31:18.658 Interactive Brokers | Market data type is Live for ETSY | 2021-02-08 11:31:18.658 Interactive Brokers | Market data type is Live for DDOG | 2021-02-08 11:31:18.658 Interactive Brokers | Starting real-time market data updates for: UPS. ID: 27 | 2021-02-08 11:31:18.659 Interactive Brokers | Subscribing to Symbol: UPS, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.659 Interactive Brokers | Requesting security definition data for: UPS. ID: 27 | 2021-02-08 11:31:18.659 Interactive Brokers | Using primary service for historical data for UPS | 2021-02-08 11:31:18.659 Added historical Intraday data request for UPS to the queue. | 2021-02-08 11:31:18.659 Intraday data recording state for symbol UPS is set to download 'Pending'. | 2021-02-08 11:31:18.659 Triggering next historical data download in queue. | 2021-02-08 11:31:18.659 Interactive Brokers | Starting real-time market data updates for: NIO. ID: 28 | 2021-02-08 11:31:18.661 Interactive Brokers | Subscribing to Symbol: NIO, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2021-02-08 11:31:18.661 Interactive Brokers | Requesting security definition data for: NIO. ID: 28 | 2021-02-08 11:31:18.661 Interactive Brokers | Using primary service for historical data for NIO | 2021-02-08 11:31:18.661 Added historical Intraday data request for NIO to the queue. | 2021-02-08 11:31:18.661 Intraday data recording state for symbol NIO is set to download 'Pending'. | 2021-02-08 11:31:18.661 Triggering next historical data download in queue. | 2021-02-08 11:31:18.661 |
| [2021-02-08 18:03:54] |
Ok definitely we recommend not using at all the Interactive Brokers data feed and instead switch to the Sierra Chart Exchange Data Feed for US equities data: Sierra Chart Exchange Data Feed This is definitely recommended. As long as there are no market data requests going to Interactive Brokers you should avoid the problem. And no we are not going to help with whatever the problem is with market data requests to IB because the problem is on the Interactive Brokers side. That is clear from the log. We are not going to get involved in this at all. We will only help with our own data feeds. You can still trade using Interactive Brokers and using the Sierra Chart Exchange Data Feed at the same time. If you need any help setting up the data feed, let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-02-09 01:36:42
| [2021-05-19 15:21:04] |
| User1967 - Posts: 34 |
Hello, Reference my this earlier query, it was mentioned that you have been working on offering Denali Exhange Feed with NASDAQ equities (full market depth). Is this ready now? In other words, do we have a reliable US Equities Exchange Data Feed available (Denali or SC Exchange Data Feed) with Level II Market Depth that can be used with my Interactive Brokers Account? Regards, GH Sabri |
| [2021-05-19 15:27:42] |
| John - SC Support - Posts: 48003 |
The new NASDAQ feed is not ready yet. When it is, it will be announced in the Sticky threads on the top of the Support Board.
| [2021-05-19 15:39:38] |
In the absence of NASDAQ data feed, what reliable options we have for Interactive Brokers to trade the US Equities: Will SC Real Time Exchange data feed be good enough? Which exchanges will be required along with it (with Level II Market Depth as well)?
| [2021-05-19 16:24:56] |
You can use the data from the Sierra Chart Exchange Data Feed. The data is reliable. It just does not have the Level 2 data. Refer to the information here: Sierra Chart Exchange Data Feed Another option would be IQ Feed. Refer to the information here: DTN IQ Feed Data Service For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-05-19 19:29:36] |
When using the Sierra Chart Exchange Data Feed you will want to activate the US equities exchange along with it to get the real-time US equities data. Please we do not recommend IQ Feed. Use our own data feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
