Date/Time: Fri, 21 Feb 2025 18:28:09 +0000
Cannot connect to data when I moved laptop to another network
View Count: 588
[2021-01-18 08:32:18]
George Pitchurov - Posts: 5
My data feed (delayed, level 5 subscription) works fine from home. When I move my laptop to the office network, it does not load data. Error log follows.
Generally, I'd like to know if the issue is due to 1) my laptop changing its assigned IP (is sierra locked by IP?), or 2) there are some closed ports in the network gateway that Sierra needs? We have linux machine for a gateway and I can administer it if given instructions.
Software version: 2207 64-bit | 2021-01-18 03:25:05.128
Primary Thread ID: 8128 | 2021-01-18 03:25:05.128
Usage end date: 2021-02-15 | 2021-01-18 03:25:05.128
Enabled for: Advanced Features 2. | 2021-01-18 03:25:05.128
Enabled for: Sierra Chart Historical Data Service. | 2021-01-18 03:25:05.128
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2021-01-18 03:25:05.128
Allow Support for Sierra Chart Data Feeds is disabled. | 2021-01-18 03:25:05.128
Current selected Data/Trading service: SC Data - All Services | 2021-01-18 03:25:05.128
Custom symbol settings values: enabled | 2021-01-18 03:25:05.128
Chart Update Interval: 500 | 2021-01-18 03:25:05.128
Intraday Data Storage Time Unit: 0 | 2021-01-18 03:25:05.128
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2021-01-18 03:25:05.128
2021-01-18 08:25:05 Local computer time in UTC | 2021-01-18 03:25:05.128
2021-01-18 03:25:05 Local computer time in SC Time Zone | 2021-01-18 03:25:05.128
2021-01-15 06:37:16 Server time in UTC | 2021-01-18 03:25:05.128
Local computer UTC time and Server UTC time difference: 22 seconds. | 2021-01-18 03:25:05.128
Notice: Your computer's clock is off by 22 seconds. For help with this, press the 'Send for Analysis' button. | 2021-01-18 03:25:05.128
Program path: C:\SierraChart\ | 2021-01-18 03:25:05.128
Data Files path: C:\SierraChart\Data\ | 2021-01-18 03:25:05.128
OS Version Number: 6.1 | 2021-01-18 03:25:05.128
Locale Setting: C | 2021-01-18 03:25:05.128
DLLs: UserContributedStudies_64.dll | 2021-01-18 03:25:05.129
Allowed protected custom studies: | 2021-01-18 03:25:05.129
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:25:18.634 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:25:18.634
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:25:18.634
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:25:18.634
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:25:18.634
DTC Client socket (1) | Closed. | 2021-01-18 03:25:18.634
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:25:18.634
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10044 | 2021-01-18 03:25:20.644
DTC Client socket (1) | Creating socket. | 2021-01-18 03:25:20.645
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:25:20.645
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-01-18 03:25:20.645
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:25:41.647 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:25:41.647
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:25:41.647
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:25:41.647
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:25:41.647
DTC Client socket (1) | Closed. | 2021-01-18 03:25:41.647
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:25:41.647
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2021-01-18 03:25:43.654
DTC Client socket (1) | Creating socket. | 2021-01-18 03:25:43.654
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:25:43.654
DTC Client socket (1) | Connecting to IP: 64.38.174.178. | 2021-01-18 03:25:43.654
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:26:04.654 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:26:04.654
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:26:04.654
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:26:04.654
DTC Client socket (1) | Closed. | 2021-01-18 03:26:04.654
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:26:04.654
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:26:04.654
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10044 | 2021-01-18 03:26:06.664
DTC Client socket (1) | Creating socket. | 2021-01-18 03:26:06.675
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:26:06.675
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-01-18 03:26:06.675
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:26:27.675 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:26:27.675
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:26:27.675
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:26:27.675
DTC Client socket (1) | Closed. | 2021-01-18 03:26:27.675
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:26:27.675
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:26:27.676
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10043 | 2021-01-18 03:26:29.689
DTC Client socket (1) | Creating socket. | 2021-01-18 03:26:29.690
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:26:29.690
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-01-18 03:26:29.690
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:26:50.684 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:26:50.684
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:26:50.684
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:26:50.684
DTC Client socket (1) | Closed. | 2021-01-18 03:26:50.684
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:26:50.684
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:26:50.685
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10044 | 2021-01-18 03:26:52.684
DTC Client socket (1) | Creating socket. | 2021-01-18 03:26:52.685
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:26:52.686
DTC Client socket (1) | Connecting to IP: 64.38.174.178. | 2021-01-18 03:26:52.686
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:27:13.686 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:27:13.686
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:27:13.686
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:27:13.686
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:27:13.686
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:27:13.686
DTC Client socket (1) | Closed. | 2021-01-18 03:27:13.686
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10043 | 2021-01-18 03:27:15.694
DTC Client socket (1) | Creating socket. | 2021-01-18 03:27:15.694
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:27:15.694
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-01-18 03:27:15.694
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:27:36.697 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:27:36.697
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:27:36.697
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:27:36.697
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:27:36.697
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:27:36.697
DTC Client socket (1) | Closed. | 2021-01-18 03:27:36.697
SC DTC Delayed Exchange Data | Connecting to the server ds12-2.sierracharts.com. Port 10044 | 2021-01-18 03:27:38.702
DTC Client socket (1) | Creating socket. | 2021-01-18 03:27:38.702
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:27:38.702
DTC Client socket (1) | Connecting to IP: 204.15.197.13. | 2021-01-18 03:27:38.702
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:27:59.706 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:27:59.706
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:27:59.706
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:27:59.706
DTC Client socket (1) | Closed. | 2021-01-18 03:27:59.706
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:27:59.706
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:27:59.706
SC DTC Delayed Exchange Data | Connecting to the server ds13.sierracharts.com. Port 10043 | 2021-01-18 03:28:01.715
DTC Client socket (1) | Creating socket. | 2021-01-18 03:28:01.715
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:28:01.715
DTC Client socket (1) | Connecting to IP: 64.38.174.178. | 2021-01-18 03:28:01.715
DTC Client socket (1) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2021-01-18 03:28:22.720 *
DTC Client socket (1) | CloseSocket call. | 2021-01-18 03:28:22.720
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2021-01-18 03:28:22.720
DTC Client socket (0) | CloseSocket call. | 2021-01-18 03:28:22.720
DTC Client socket (1) | Closed. | 2021-01-18 03:28:22.720
SC DTC Delayed Exchange Data | Disconnected from the server. | 2021-01-18 03:28:22.720
SC DTC Delayed Exchange Data | Data feed disconnected. Will reconnect in 2 seconds. | 2021-01-18 03:28:22.720
SC DTC Delayed Exchange Data | Connecting to the server ds23.sierracharts.com. Port 10044 | 2021-01-18 03:28:24.723
DTC Client socket (1) | Creating socket. | 2021-01-18 03:28:24.727
DTC Client socket (1) | New receive buffer size: 5242880 | 2021-01-18 03:28:24.727
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2021-01-18 03:28:24.727
[2021-01-18 10:16:33]
This is the problem:
Your network is blocking the connection. This is one of the servers:
[2021-01-18 10:24:55]
thanks, how is it blocking it, by a disabled port? What I need to do, enable port?
[2021-01-18 11:41:37]
We would not know. You need to do your own investigation as to the cause. Most likely the port is getting blocked.
[2021-01-25 08:58:21]
Could you then please tell me what is the port range that you (SIERRA) require to communicate? So I can talk and try enabling that.
[2021-01-25 09:27:31]
This is from your log above:
You can see the Port numbers above. And you can run a ping to these domain names like ds13.sierracharts.com to discover the IP address.
