Date/Time: Thu, 13 Feb 2025 06:33:58 +0000
SC Data-All Services - EUREX error downloading intraday data
View Count: 714
[2020-11-25 20:47:21] |
User365411 - Posts: 192 |
rel 2201 (and 2200) I'm not able to download intraday data from new EUREX feed (xxxxx-EUREX new naming style), the error is invalid symbol Instead Daily data was correctly downloaded. I was able to download intraday data from the old EUREX feed, then I tried the " translate symbol to current service " but it fails with the same message, invalid symbol. The problem happens on all symbols that I tried (FESX, FSTX, FDAX and others) Already done "update symbol setting from server" and " translate symbol to current service ", nothing changed. CME and other feeds works correctly. Rolling back to rel 2192 all works correctly. Can you check? TY Triggering next historical data download in queue. | 2020-11-25 21:40:43.908
Enabling compression for file: C:\SC3\Data\FSTXZ20-EUREX.scid. This may take a while. | 2020-11-25 21:41:16.511 File compression enabled. C:\SC3\Data\FSTXZ20-EUREX.scid. CompressionState=0 | 2020-11-25 21:41:16.511 FSTXZ20-EUREX 60 Min #8 | Reloading chart. | 2020-11-25 21:41:16.512 FSTXZ20-EUREX 60 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SC3\Data\FSTXZ20-EUREX.scid | 2020-11-25 21:41:16.523 SC Data - All Services | Starting real-time market data updates for: FSTXZ20-EUREX. ID: 7 Service code: eurex | 2020-11-25 21:41:17.014 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FSTXZ20-EUREX | 2020-11-25 21:41:17.015 SC Data - All Services | Requesting security definition data for: FSTXZ20-EUREX. ID: 7 | 2020-11-25 21:41:17.015 Added historical Intraday data request for FSTXZ20-EUREX to the queue. | 2020-11-25 21:41:17.015 Intraday data recording state for symbol FSTXZ20-EUREX is set to download 'Pending'. | 2020-11-25 21:41:17.015 Triggering next historical data download in queue. | 2020-11-25 21:41:17.015 Delaying start of download for FSTXZ20-EUREX | 2020-11-25 21:41:17.016 HD Request # 33 | Downloading Intraday chart data for FSTXZ20-EUREX to the file FSTXZ20-EUREX.scid. Service: eurex | 2020-11-25 21:41:22.427 HD Request # 33 | Download start date-time: 2020-11-15 21:41:22.000000. File last date-time: 00:00:00.000000 | 2020-11-25 21:41:22.429 HD Request # 33 | Requesting historical Intraday Minute data for FSTXZ20-EUREX starting at 2020-11-15 15:41:22 (Exchange time). | 2020-11-25 21:41:22.429 HD Request # 33 | Error downloading historical Intraday data for FSTXZ20-EUREX. Error: invalid symbol | 2020-11-25 21:41:24.451 HD Request # 33 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for FSTXZ20-EUREX | 2020-11-25 21:41:24.451 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2020-11-25 21:41:24.453 HD Request # 33 | Completion time: 2s | 2020-11-25 21:41:24.453 HD Request # 33 | Intraday data download complete for FSTXZ20-EUREX. Unique request ID: 34 | 2020-11-25 21:41:24.453 Removing historical data download ID 34. | 2020-11-25 21:41:24.453 Real-time Intraday chart data file updates started for FSTXZ20-EUREX | 2020-11-25 21:41:24.453 Intraday chart data file opened for FSTXZ20-EUREX | 2020-11-25 21:41:24.453 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2020-11-25 21:41:24.453 Triggering next historical data download in queue. | 2020-11-25 21:41:24.453 |
[2020-11-26 02:24:38] |
We do not have this problem when using version 2201 or any version. There must be a problem with the Symbol Settings. We want you to disable this setting on the Global Symbol Settings window: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) After that follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings This is the result of the download we did: Added historical Intraday data request for FSTXZ20-EUREX to the queue. | 2020-11-25 21:23:57.246
Intraday data recording state for symbol FSTXZ20-EUREX is set to download 'Pending'. | 2020-11-25 21:23:57.246 Triggering next historical data download in queue. | 2020-11-25 21:23:57.246 HD Request # 56 | Downloading Intraday chart data for FSTXZ20-EUREX to the file FSTXZ20-EUREX.scid. Service: eurex | 2020-11-25 21:23:57.246 Reloading all charts with filename: FSTXZ20-EUREX.scid | 2020-11-25 21:23:57.247 HD Request # 56 | Download start date-time: 2020-10-26 22:23:57.000000. File last date-time: 00:00:00.000000 | 2020-11-25 21:23:57.247 HD Request # 56 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2020-11-25 21:23:57.247 Socket (1) | Creating socket. | 2020-11-25 21:23:57.248 Socket (1) | New receive buffer size: 5242880 | 2020-11-25 21:23:57.248 Socket (1) | Connecting to IP: 8.18.161.133. | 2020-11-25 21:23:57.248 FSTXZ20-EUREX 1 Min #30 | Reloading chart. | 2020-11-25 21:23:57.688 HD Request # 56 | Setting DTC encoding to Binary VLS | 2020-11-25 21:23:57.762 HD Request # 56 | Sending historical data logon request message. | 2020-11-25 21:23:57.762 HD Request # 56 | Requesting Intraday data. Start date-time: 2020-10-26 22:23:57. Record interval: 0. Symbol: FSZ20 | 2020-11-25 21:23:58.541 HD Request # 56 | Decompressing data. | 2020-11-25 21:23:58.792 HD Request # 56 | Receiving Intraday data for FSTXZ20-EUREX starting at 2020-10-27 04:00:58.217000 | 2020-11-25 21:23:59.556 Socket (1) | CloseSocket call. | 2020-11-25 21:23:59.558 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-25 21:23:59.558 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-25 21:23:59.558 Historical data download thread signaled to stop. | 2020-11-25 21:23:59.559 HD Request # 56 | Timestamp of first Intraday data file record written: 2020-10-27 04:00:58.217000 | 2020-11-25 21:23:59.559 HD Request # 56 | Received 5813 records from 2020-10-27 04:00:58.217000 to 2020-11-25 15:59:56.051000 (29.5 days) and wrote 5813 records for FSTXZ20-EUREX | 2020-11-25 21:23:59.559 HD Request # 56 | Add time&sales data | Remembered last file record date-time: 2020-11-25 20:59:56.051000 | 2020-11-25 21:23:59.560 HD Request # 56 | Completion time: 2s | 2020-11-25 21:23:59.560 HD Request # 56 | Intraday data download complete for FSTXZ20-EUREX. Unique request ID: 55 | 2020-11-25 21:23:59.560 Removing historical data download ID 55. | 2020-11-25 21:23:59.560 Real-time Intraday chart data file updates started for FSTXZ20-EUREX | 2020-11-25 21:23:59.560 Intraday chart data file opened for FSTXZ20-EUREX | 2020-11-25 21:23:59.560 HD Request # 56 | Enabling Intraday chart updating for symbol. | 2020-11-25 21:23:59.560 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-26 02:26:22
[2020-11-26 09:53:03] |
We want you to disable this setting on the Global Symbol Settings window: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) After that follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Already done, did not works. So I take fresh install of each release between 2192 and 2201 and found that everything works fine up to version 2198. From 2199 I get "invalid symbol" error downloading intraday data (daily data works) only for the EUREX feed. So something happened between those 2 release. I'am on windows 7. Please can you check? TY LOG downloading FSTXZ20-EUREX on 2198 release Software version: 2198 64-bit | 2020-11-26 10:00:15.837
Primary Thread ID: 39356 | 2020-11-26 10:00:15.837 Usage end date: 2020-12-22 | 2020-11-26 10:00:15.837 Enabled for: Advanced Features 2. | 2020-11-26 10:00:15.837 Enabled for: Sierra Chart Historical Data Service. | 2020-11-26 10:00:15.837 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-11-26 10:00:15.837 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-11-26 10:00:15.837 Current selected Data/Trading service: SC Data - All Services | 2020-11-26 10:00:15.837 Custom symbol settings values: enabled | 2020-11-26 10:00:15.837 Chart Update Interval: 500 | 2020-11-26 10:00:15.837 Intraday Data Storage Time Unit: 1 | 2020-11-26 10:00:15.837 Time Zone: +00:00:00 (UTC+00) | 2020-11-26 10:00:15.837 2020-11-26 10:00:15 Local computer time in UTC | 2020-11-26 10:00:15.837 2020-11-26 10:00:15 Local computer time in SC Time Zone | 2020-11-26 10:00:15.837 2020-11-26 09:59:56 Server time in UTC | 2020-11-26 10:00:15.837 Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-11-26 10:00:15.837 Program path: C:\sc2198\ | 2020-11-26 10:00:15.837 Data Files path: C:\sc2198\Data\ | 2020-11-26 10:00:15.837 OS Version Number: 6.1 | 2020-11-26 10:00:15.837 Locale Setting: C | 2020-11-26 10:00:15.837 DLLs: UserContributedStudies_64.dll | 2020-11-26 10:00:15.838 Allowed protected custom studies: | 2020-11-26 10:00:15.838 File >> Disconnect selected. | 2020-11-26 10:00:19.845 SC Data - All Services | Disconnected. | 2020-11-26 10:00:19.845 SC Data - All Services | Connected to server complete. | 2020-11-26 10:00:21.625 Triggering next historical data download in queue. | 2020-11-26 10:00:21.625 Triggering next historical data download in queue. | 2020-11-26 10:00:21.625 Triggering next historical data download in queue. | 2020-11-26 10:00:21.625 Triggering next historical data download in queue. | 2020-11-26 10:00:21.625 Enabling compression for file: C:\sc2198\Data\FSTXZ20-EUREX.scid. This may take a while. | 2020-11-26 10:01:12.035 File compression enabled. C:\sc2198\Data\FSTXZ20-EUREX.scid. CompressionState=0 | 2020-11-26 10:01:12.035 FSTXZ20-EUREX 1 Min #1 | Reloading chart. | 2020-11-26 10:01:12.036 FSTXZ20-EUREX 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\sc2198\Data\FSTXZ20-EUREX.scid | 2020-11-26 10:01:12.047 SC Data - All Services | Starting real-time market data updates for: FSTXZ20-EUREX. ID: 1 Service code: eurex | 2020-11-26 10:01:12.528 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FSTXZ20-EUREX | 2020-11-26 10:01:12.528 SC Data - All Services | Requesting security definition data for: FSTXZ20-EUREX. ID: 1 | 2020-11-26 10:01:12.528 Starting DelayedDownloadMonitoringTimer | 2020-11-26 10:01:12.528 Starting HDTimeoutTimer | 2020-11-26 10:01:12.528 Added historical Intraday data request for FSTXZ20-EUREX to the queue. | 2020-11-26 10:01:12.528 Intraday data recording state for symbol FSTXZ20-EUREX is set to download 'Pending'. | 2020-11-26 10:01:12.528 Triggering next historical data download in queue. | 2020-11-26 10:01:12.528 Delaying start of download for FSTXZ20-EUREX | 2020-11-26 10:01:12.530 HD Request # 1 | Downloading Intraday chart data for FSTXZ20-EUREX to the file FSTXZ20-EUREX.scid. Service: eurex | 2020-11-26 10:01:17.597 HD Request # 1 | Download start date-time: 2020-11-21 10:01:17.000000. File last date-time: 00:00:00.000000 | 2020-11-26 10:01:17.598 HD Request # 1 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2020-11-26 10:01:17.598 Socket (1) | Creating socket. | 2020-11-26 10:01:17.599 Socket (1) | New receive buffer size: 5242880 | 2020-11-26 10:01:17.599 Socket (1) | Connecting to IP: 8.18.161.133. | 2020-11-26 10:01:17.599 HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-11-26 10:01:17.867 HD Request # 1 | Sending historical data logon request message. | 2020-11-26 10:01:17.867 HD Request # 1 | Requesting Intraday data. Start date-time: 2020-11-21 10:01:17. Record interval: 1. Symbol: FSZ20 | 2020-11-26 10:01:18.521 HD Request # 1 | Decompressing data. | 2020-11-26 10:01:18.652 HD Request # 1 | Receiving Intraday data for FSTXZ20-EUREX starting at 2020-11-23 08:05:16.472000 | 2020-11-26 10:01:18.654 Socket (1) | CloseSocket call. | 2020-11-26 10:01:18.657 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-26 10:01:18.657 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-26 10:01:18.657 Historical data download thread signaled to stop. | 2020-11-26 10:01:18.657 HD Request # 1 | Timestamp of first Intraday data file record written: 2020-11-23 08:05:16.472000 | 2020-11-26 10:01:18.658 HD Request # 1 | Received 243 records from 2020-11-23 08:05:16.472000 to 2020-11-26 09:49:24.112000 (3.1 days) and wrote 243 records for FSTXZ20-EUREX | 2020-11-26 10:01:18.658 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2020-11-26 09:49:24.112000 | 2020-11-26 10:01:18.660 HD Request # 1 | Completion time: 1s | 2020-11-26 10:01:18.660 HD Request # 1 | Intraday data download complete for FSTXZ20-EUREX. Unique request ID: 1 | 2020-11-26 10:01:18.660 Removing historical data download ID 1. | 2020-11-26 10:01:18.660 Real-time Intraday chart data file updates started for FSTXZ20-EUREX | 2020-11-26 10:01:18.660 Opened cached Intraday file: C:\sc2198\Data\FSTXZ20-EUREX.scid. Thread ID: 39356 | 2020-11-26 10:01:18.662 Intraday chart data file opened for FSTXZ20-EUREX | 2020-11-26 10:01:18.662 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2020-11-26 10:01:18.662 Triggering next historical data download in queue. | 2020-11-26 10:01:18.662 Socket (1) | Socket gracefully closed by remote side. | 2020-11-26 10:01:18.787 Socket (1) | Closed. | 2020-11-26 10:01:18.787 ************************************************************************************************************** LOG downloading FSTXZ20-EUREX on 2199 release (updated log, in the previous version of the log there were references to the DTC server which I had probably activated involuntarily, the issue anyway persist) Software version: 2199 64-bit | 2020-11-26 22:10:49.143
Primary Thread ID: 130784 | 2020-11-26 22:10:49.143 Usage end date: 2020-12-22 | 2020-11-26 22:10:49.143 Enabled for: Advanced Features 2. | 2020-11-26 22:10:49.143 Enabled for: Sierra Chart Historical Data Service. | 2020-11-26 22:10:49.143 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-11-26 22:10:49.143 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-11-26 22:10:49.143 Current selected Data/Trading service: SC Data - All Services | 2020-11-26 22:10:49.143 Custom symbol settings values: disabled | 2020-11-26 22:10:49.143 Chart Update Interval: 500 | 2020-11-26 22:10:49.143 Intraday Data Storage Time Unit: 1 | 2020-11-26 22:10:49.143 Time Zone: +00:00:00 (UTC+00) | 2020-11-26 22:10:49.143 2020-11-26 22:10:49 Local computer time in UTC | 2020-11-26 22:10:49.143 2020-11-26 22:10:49 Local computer time in SC Time Zone | 2020-11-26 22:10:49.143 2020-11-26 22:10:35 Server time in UTC | 2020-11-26 22:10:49.143 Local computer UTC time and Server UTC time difference: 3 seconds. | 2020-11-26 22:10:49.143 Program path: C:\SC2199A\ | 2020-11-26 22:10:49.143 Data Files path: C:\SC2199A\Data\ | 2020-11-26 22:10:49.143 OS Version Number: 6.1 | 2020-11-26 22:10:49.143 Locale Setting: C | 2020-11-26 22:10:49.143 DLLs: UserContributedStudies_64.dll | 2020-11-26 22:10:49.144 Allowed protected custom studies: | 2020-11-26 22:10:49.144 File >> Disconnect selected. | 2020-11-26 22:11:15.816 SC Data - All Services | Disconnected. | 2020-11-26 22:11:15.817 SC Data - All Services | Connected to server complete. | 2020-11-26 22:11:18.316 Triggering next historical data download in queue. | 2020-11-26 22:11:18.316 Triggering next historical data download in queue. | 2020-11-26 22:11:18.316 Triggering next historical data download in queue. | 2020-11-26 22:11:18.316 Triggering next historical data download in queue. | 2020-11-26 22:11:18.316 FSTXZ20-EUREX 1 Min #1 | Reloading chart. | 2020-11-26 22:11:45.941 FSTXZ20-EUREX 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SC2199A\Data\FSTXZ20-EUREX.scid | 2020-11-26 22:11:45.952 SC Data - All Services | Starting real-time market data updates for: FSTXZ20-EUREX. ID: 1 Service code: eurex | 2020-11-26 22:11:46.453 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FSTXZ20-EUREX | 2020-11-26 22:11:46.453 SC Data - All Services | Requesting security definition data for: FSTXZ20-EUREX. ID: 1 | 2020-11-26 22:11:46.453 Starting DelayedDownloadMonitoringTimer | 2020-11-26 22:11:46.453 Starting HDTimeoutTimer | 2020-11-26 22:11:46.453 Added historical Intraday data request for FSTXZ20-EUREX to the queue. | 2020-11-26 22:11:46.453 Intraday data recording state for symbol FSTXZ20-EUREX is set to download 'Pending'. | 2020-11-26 22:11:46.453 Triggering next historical data download in queue. | 2020-11-26 22:11:46.453 Delaying start of download for FSTXZ20-EUREX | 2020-11-26 22:11:46.454 HD Request # 1 | Downloading Intraday chart data for FSTXZ20-EUREX to the file FSTXZ20-EUREX.scid. Service: eurex | 2020-11-26 22:11:51.522 HD Request # 1 | Download start date-time: 2020-11-21 22:11:51.000000. File last date-time: 00:00:00.000000 | 2020-11-26 22:11:51.524 HD Request # 1 | Requesting historical Intraday Minute data for FSTXZ20-EUREX starting at 2020-11-21 17:11:51 (Exchange time). | 2020-11-26 22:11:51.524 HD Request # 1 | Error downloading historical Intraday data for FSTXZ20-EUREX. Error: invalid symbol | 2020-11-26 22:11:52.504 HD Request # 1 | Received 0 records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds) and wrote 0 records for FSTXZ20-EUREX | 2020-11-26 22:11:52.504 HD Request # 1 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2020-11-26 22:11:52.506 HD Request # 1 | Completion time: 1s | 2020-11-26 22:11:52.506 HD Request # 1 | Intraday data download complete for FSTXZ20-EUREX. Unique request ID: 1 | 2020-11-26 22:11:52.506 Removing historical data download ID 1. | 2020-11-26 22:11:52.506 Real-time Intraday chart data file updates started for FSTXZ20-EUREX | 2020-11-26 22:11:52.506 Opened cached Intraday file: C:\SC2199A\Data\FSTXZ20-EUREX.scid. Thread ID: 130784 | 2020-11-26 22:11:52.507 Intraday chart data file opened for FSTXZ20-EUREX | 2020-11-26 22:11:52.507 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2020-11-26 22:11:52.507 Triggering next historical data download in queue. | 2020-11-26 22:11:52.508 Date Time Of Last Edit: 2020-11-26 22:19:15
[2020-11-26 18:31:04] |
User722856 - Posts: 78 |
@SC: I can confirm what user User365411 is writing. I have the same problem with Eurex from version above v2198. Should i post my log? |
[2020-11-26 20:39:12] |
We are checking this again.
[2020-11-26 20:52:25] |
We are still not able to reproduce the problem. This is with a completely fresh installation: SC Data - All Services | Starting real-time market data updates for: FSTXZ20-EUREX. ID: 1 Service code: eurex | 2020-11-26 20:51:24.762
SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: FSTXZ20-EUREX | 2020-11-26 20:51:24.762 SC Data - All Services | Requesting security definition data for: FSTXZ20-EUREX. ID: 1 | 2020-11-26 20:51:24.762 Added historical Intraday data request for FSTXZ20-EUREX to the queue. | 2020-11-26 20:51:24.762 Intraday data recording state for symbol FSTXZ20-EUREX is set to download 'Pending'. | 2020-11-26 20:51:24.762 Triggering next historical data download in queue. | 2020-11-26 20:51:24.762 Delaying start of download for FSTXZ20-EUREX | 2020-11-26 20:51:24.762 HD Request # 8 | Downloading Intraday chart data for FSTXZ20-EUREX to the file FSTXZ20-EUREX.scid. Service: eurex | 2020-11-26 20:51:29.677 HD Request # 8 | Download start date-time: 2020-05-24 20:51:29.000000. File last date-time: 00:00:00.000000 | 2020-11-26 20:51:29.677 HD Request # 8 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-11-26 20:51:29.677 Socket (1) | Creating socket. | 2020-11-26 20:51:29.706 Socket (1) | New receive buffer size: 5242880 | 2020-11-26 20:51:29.706 Socket (1) | Connecting to IP: 8.18.161.133. | 2020-11-26 20:51:29.706 Socket (8) | Deleting network socket now after delay. | 2020-11-26 20:51:29.928 HD Request # 8 | Setting DTC encoding to Binary VLS | 2020-11-26 20:51:30.053 HD Request # 8 | Sending historical data logon request message. | 2020-11-26 20:51:30.053 HD Request # 8 | Requesting Intraday data. Start date-time: 2020-05-24 20:51:29. Record interval: 1. Symbol: FSZ20 | 2020-11-26 20:51:30.747 HD Request # 8 | Decompressing data. | 2020-11-26 20:51:30.916 HD Request # 8 | Receiving Intraday data for FSTXZ20-EUREX starting at 2020-06-24 09:13:21.000000 | 2020-11-26 20:51:31.608 Socket (1) | CloseSocket call. | 2020-11-26 20:51:31.611 Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-11-26 20:51:31.611 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-11-26 20:51:31.611 Historical data download thread signaled to stop. | 2020-11-26 20:51:31.611 HD Request # 8 | Timestamp of first Intraday data file record written: 2020-06-24 09:13:21.000000 | 2020-11-26 20:51:31.611 HD Request # 8 | Received 7745 records from 2020-06-24 09:13:21.000000 to 2020-11-26 17:26:22.012000 (155.3 days) and wrote 7745 records for FSTXZ20-EUREX | 2020-11-26 20:51:31.611 HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2020-11-26 17:26:22.012000 | 2020-11-26 20:51:31.611 HD Request # 8 | Completion time: 2s | 2020-11-26 20:51:31.611 HD Request # 8 | Intraday data download complete for FSTXZ20-EUREX. Unique request ID: 12 | 2020-11-26 20:51:31.611 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-11-26 21:34:23] |
We will need to do a remote assistance session with one of you to look into this issue further. One thing to be aware of, with a new installation, is that it takes about 10 seconds or so to receive symbol settings. So if a Chartbook was opened before those settings were received, it would result in a failure of historical data downloading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-11-26 21:34:40
[2020-11-26 21:50:20] |
Just installed 2201 release on other pc, same credentials, windows 10 this time, with no prior SC install. Same problem with eurex, cme works. So, the problem is not machine specific, probably there is something in my account on your server, probably some kind of authentication or authorization for this specific feed that cause this issue. Or perhaps me and the other user with same problem live in same nation and can be an unreachable server? Between 2198 e 2199 something changed. NOTE: I had edited log 2199 in post #3, realized that the DTC server message was probably activated by me, so take a new fresh install in new folder, the log refer to this new installation in folder SC2199A, problem persist anyway. Date Time Of Last Edit: 2020-11-26 22:24:08
[2020-11-27 18:13:11] |
@SC #7 a) Sorry for the late Response, we can do a remote assistance session if you want. I am from Germany, it is already evening here. I am available from now and the next 2 hours if you need me. --> Or we can schedule something for Monday 2020-11-30 ? b) I made a new/fresh install v2201 and have the same error. I sent you my LOG from this new install via the option "Send for Analysis" v2198 working without problems. Date Time Of Last Edit: 2020-11-27 18:30:59
[2020-11-27 19:10:36] |
We are calling now.
[2020-11-27 19:56:52] |
We found the problem. We are resolving now. We are putting out version 2203.
[2020-11-27 21:12:34] |
@SC: v2203 is working. Thank you for fast response. You are great! |
[2020-11-27 23:12:13] |
Just installed rel 2203, confirm it's working to me too. Thank you all guys! |
