Date/Time: Wed, 12 Feb 2025 09:04:37 +0000
Cannot connect to "Trading Evaluator - Delayed" service
View Count: 692
[2020-10-20 09:42:37]
User785900 - Posts: 5
I am using Sierra Chart (Package 3) with login credentials provided by AMP Futures. I normally use the "CQG WebAPI" service, which works fine. I wanted to try out Sierra Chart's Delayed Exchange Data Feed, so I followed the documentation here: Delayed Exchange Data Feed
The documentation says that the delayed data is accessible through the "SC Data - All Services", "Trading Evaluator - Delayed", or "SC Futures Order Routing/Data" service. In my Sierra Chart, the "SC Data - All Services" option appears as "SC Data - All Services (Not enabled on package)", which I assume means that I cannot use it for one reason or another. So I selected the "Trading Evaluator - Delayed" service instead. But when I try to connect, there is an error. A "Service Connection Error" window pops up and says "Connection error: Trade account not assigned" (see full log messages below).
Is this because the Delayed Exchange Data Feed is not available in AMP's Sierra Chart? Do I need to subscribe directly to Sierra Chart Package 3 to be able to access the Delayed Exchange Data Feed?
Software version: 2182 64-bit | 2020-10-20 09:27:59.841
Primary Thread ID: 8772 | 2020-10-20 09:27:59.841
Usage end date: 2020-11-08 | 2020-10-20 09:27:59.841
Enabled for: Sierra Chart Historical Data Service. | 2020-10-20 09:27:59.841
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-20 09:27:59.841
Allow Support for Sierra Chart Data Feeds is disabled. | 2020-10-20 09:27:59.841
Current selected Data/Trading service: Trading Evaluator - Delayed | 2020-10-20 09:27:59.841
Custom symbol settings values: enabled | 2020-10-20 09:27:59.841
Chart Update Interval: 500 | 2020-10-20 09:27:59.841
Intraday Data Storage Time Unit: 1 | 2020-10-20 09:27:59.841
Time Zone: +00:00:00 (UTC+00) | 2020-10-20 09:27:59.841
2020-10-20 17:27:59 Local computer time | 2020-10-20 09:27:59.841
2020-10-20 09:27:59 Local computer time in UTC | 2020-10-20 09:27:59.841
2020-10-20 09:27:59 Local computer time in SC Time Zone | 2020-10-20 09:27:59.841
2020-10-20 09:27:36 Server time in UTC | 2020-10-20 09:27:59.841
Local computer UTC time and Server UTC time difference: 3 seconds. | 2020-10-20 09:27:59.841
Program path: C:\SierraChart\ | 2020-10-20 09:27:59.841
Data Files path: C:\SierraChart\Data\ | 2020-10-20 09:27:59.841
OS Version Number: 10.0 | 2020-10-20 09:27:59.841
Locale Setting: C | 2020-10-20 09:27:59.841
DLLs: UserContributedStudies_64.dll | 2020-10-20 09:27:59.841
Allowed protected custom studies: | 2020-10-20 09:27:59.841
Trading Evaluator - Delayed | Connecting to the server delayedevaluator.sierracharts.com. Port 11251 | 2020-10-20 09:28:09.230
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2020-10-20 09:28:09.230
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-20 09:28:09.231
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2020-10-20 09:28:09.231
Trading Evaluator - Delayed | Network connection to server complete. | 2020-10-20 09:28:09.502
Trading Evaluator - Delayed | Starting socket receive thread. | 2020-10-20 09:28:09.502
Trading Evaluator - Delayed | Sending encoding request to server: Binary VLS | 2020-10-20 09:28:09.503
Trading Evaluator - Delayed | Setting DTC encoding to Binary VLS | 2020-10-20 09:28:10.305
Trading Evaluator - Delayed | Sending logon request message. | 2020-10-20 09:28:10.305
Trading Evaluator - Delayed | Received logon response. | 2020-10-20 09:28:10.573
Trading Evaluator - Delayed | Server Name: SC DTC Server. | 2020-10-20 09:28:10.573
Trading Evaluator - Delayed | Server protocol version: 8. Client protocol version: 8 | 2020-10-20 09:28:10.573
Trading Evaluator - Delayed | Connection error: Trade account not assigned. | 2020-10-20 09:28:10.573 *
Trading Evaluator - Delayed | Waiting for socket receive thread to end | 2020-10-20 09:28:10.620
DTC Client socket (1) | CloseSocket call. | 2020-10-20 09:28:10.620
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-20 09:28:10.620
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-20 09:28:10.621
Trading Evaluator - Delayed | Disconnected. | 2020-10-20 09:28:10.621
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-20 09:28:10.884
DTC Client socket (1) | Closed. | 2020-10-20 09:28:10.884
[2020-10-20 13:40:59]
John - SC Support - Posts: 37891
You do not have a Simulated Futures Trading Account. Therefore, you need to follow through the Setup Instructions for the Simulated Futures Trading Service here:
Simulated Futures Trading Service: Setup Instructions
[2020-10-20 15:41:50]
Okay, I followed all the steps until step 12. On step 12, I get the same error: "Connection error: Trade account not assigned." (full log messages below).
Software version: 2182 64-bit | 2020-10-20 15:37:19.122
Primary Thread ID: 3324 | 2020-10-20 15:37:19.122
Usage end date: 2020-11-08 | 2020-10-20 15:37:19.122
Enabled for: Sierra Chart Historical Data Service. | 2020-10-20 15:37:19.122
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-20 15:37:19.122
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-20 15:37:19.122
Current selected Data/Trading service: Trading Evaluator - Delayed | 2020-10-20 15:37:19.122
Custom symbol settings values: enabled | 2020-10-20 15:37:19.122
Chart Update Interval: 500 | 2020-10-20 15:37:19.122
Intraday Data Storage Time Unit: 1 | 2020-10-20 15:37:19.122
Time Zone: +00:00:00 (UTC+00) | 2020-10-20 15:37:19.122
2020-10-20 23:37:19 Local computer time | 2020-10-20 15:37:19.122
2020-10-20 15:37:19 Local computer time in UTC | 2020-10-20 15:37:19.122
2020-10-20 15:37:19 Local computer time in SC Time Zone | 2020-10-20 15:37:19.122
2020-10-20 15:34:50 Server time in UTC | 2020-10-20 15:37:19.122
Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-10-20 15:37:19.122
Program path: C:\SierraChart\ | 2020-10-20 15:37:19.122
Data Files path: C:\SierraChart\Data\ | 2020-10-20 15:37:19.122
OS Version Number: 10.0 | 2020-10-20 15:37:19.123
Locale Setting: C | 2020-10-20 15:37:19.123
DLLs: UserContributedStudies_64.dll | 2020-10-20 15:37:19.123
Allowed protected custom studies: | 2020-10-20 15:37:19.123
Trading Evaluator - Delayed | Connecting to the server delayedevaluator.sierracharts.com. Port 11251 | 2020-10-20 15:37:27.240
DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2020-10-20 15:37:27.240
DTC Client socket (1) | New receive buffer size: 5242880 | 2020-10-20 15:37:27.241
DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2020-10-20 15:37:27.241
Trading Evaluator - Delayed | Network connection to server complete. | 2020-10-20 15:37:27.502
Trading Evaluator - Delayed | Starting socket receive thread. | 2020-10-20 15:37:27.502
Trading Evaluator - Delayed | Sending encoding request to server: Binary VLS | 2020-10-20 15:37:27.503
Trading Evaluator - Delayed | Setting DTC encoding to Binary VLS | 2020-10-20 15:37:28.272
Trading Evaluator - Delayed | Sending logon request message. | 2020-10-20 15:37:28.272
Trading Evaluator - Delayed | Received logon response. | 2020-10-20 15:37:28.534
Trading Evaluator - Delayed | Server Name: SC DTC Server. | 2020-10-20 15:37:28.534
Trading Evaluator - Delayed | Server protocol version: 8. Client protocol version: 8 | 2020-10-20 15:37:28.534
Trading Evaluator - Delayed | Connection error: Trade account not assigned. | 2020-10-20 15:37:28.534 *
Trading Evaluator - Delayed | Waiting for socket receive thread to end | 2020-10-20 15:37:28.584
DTC Client socket (1) | CloseSocket call. | 2020-10-20 15:37:28.584
DTC Client socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-20 15:37:28.584
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-10-20 15:37:28.585
Trading Evaluator - Delayed | Disconnected. | 2020-10-20 15:37:28.585
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-10-20 15:37:28.839
DTC Client socket (1) | Closed. | 2020-10-20 15:37:28.839
[2020-10-20 16:30:01]
Everything looks correct on our end. We want you to do a Forced Login, which updates your local version with the information from our servers. Refer to the information here for how to do this:
Sierra Chart - Software Login Instructions: Forced Login
[2020-10-20 16:52:45]
I did a Forced Login by following the instructions in the link, but I still get the same error message in a pop up window "Connection error: Trade account not assigned". I closed Sierra Chart to try another Forced Login, but I get the same result again.
Can you confirm that this problem is not caused by using login credentials provided by AMP Futures?
Extra information: I went to "Home >> (Table of Contents) Account Control Panel / Purchase Services >> Account Control Panel >> Trade Account Data and Order Entry" and found that the "Connection Status" section says: "Connected: False | Last Logon Failed - Username or Password is incorrect". The "Action Log" section shows:
id  Date Time  Message
5  Wed Oct 21 2020 00:54:57 GMT+0800 (Taipei Standard Time)  Connection closed.
4  Wed Oct 21 2020 00:54:54 GMT+0800 (Taipei Standard Time)  Requesting available exchanges. 9456
3  Wed Oct 21 2020 00:54:54 GMT+0800 (Taipei Standard Time)  Requesting Current Positions. 9967
2  Wed Oct 21 2020 00:54:54 GMT+0800 (Taipei Standard Time)  Requesting open orders. 1237
1  Wed Oct 21 2020 00:54:54 GMT+0800 (Taipei Standard Time)  Logon response received.
0  Wed Oct 21 2020 00:54:54 GMT+0800 (Taipei Standard Time)  Requesting security definitions for symbol: undefined |
Date Time Of Last Edit: 2020-10-20 16:57:37
[2020-10-20 19:01:03]
There is an issue on the server related to this. We are implementing a temporary solution.
[2020-10-20 19:03:30]
This is now resolved.
[2020-10-20 19:16:29]
All good now. Thank you!
