Date/Time: Wed, 12 Feb 2025 04:05:40 +0000
foot print chart no data
View Count: 894
[2020-10-06 15:18:16]
User798547 - Posts: 54
i have data but my foot print charts do not show any bid and ask on my numberbars charts
i can not figure out how to get them back
[2020-10-06 16:27:58]
John - SC Support - Posts: 37891
Make sure you are not looking at a Daily chart, as the Numbers Bars study does not work with Daily Historical data.
Also, make sure that your Intraday Data Storage Time Unit is 1 Tick. Refer to the information here:
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
If you are continuing to have a problem, then please include a screenshot of what you are seeing so we can understand the issue.
[2020-10-06 17:28:14]
http://www.sierrachart.com/image.php?Image=1602005008746.png
thanks for the quick reply
i have my settings to tick
it was working fine last month and i have not changed any settings
but when i just re funded my account it is not showing any data
my dom is working tho
thanks for the help
[2020-10-06 17:43:58]
Attach a chartbook with the chart in it per these instructions:
[2020-10-06 18:01:30]
http://www.sierrachart.com/image.php?Image=1602007216402.png
[2020-10-06 18:31:25]
We need the actual Chartbook, not an image, so we can see how you have things setup. Follow these instructions:
[2020-10-06 18:52:31]
File attached
attachmentmy.Cht - Attached On 2020-10-06 18:51:01 UTC - Size: 79.54 KB - 321 views
[2020-10-06 19:08:12]
This is very odd, as everything looks fine when we open the chart. But looking at the image again, we notice that even the Numbers Bars Calculated Values are not showing any data. We really have no idea why this is happening, as you are getting the data feed just fine.
Can you please start a new chart and just use the ES for the symbol, do not use a Trade and Current Quote symbol. And just add the Numbers Bars Calculated Values to the chart with the default subgraph on (Ask Volume Bid Volume Difference). Then take a screenshot of that chart and let's see if you are getting the Bid and Ask data properly there.
[2020-10-06 19:28:08]
http://www.sierrachart.com/image.php?Image=1602012417988.png
[2020-10-06 20:35:20]
Sierra_Chart Engineering - Posts: 18390
After that:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
Please let us know if the issue is resolved. If not we need to get more information:
Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download".
After about a minute provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2020-10-06 20:35:34
[2020-10-06 21:04:25]
still no numbers
Software version: 2177 64-bit | 2020-10-06 17:03:10.887
Safe Mode enabled | 2020-10-06 17:03:10.887
Primary Thread ID: 4580 | 2020-10-06 17:03:10.887
Usage end date: 2020-11-05 | 2020-10-06 17:03:10.887
Enabled for: Sierra Chart Historical Data Service. | 2020-10-06 17:03:10.887
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-06 17:03:10.887
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-06 17:03:10.887
Enabled for exchange2: CME | 2020-10-06 17:03:10.887
Enabled for exchange2: CBOT (Trading Account Required) | 2020-10-06 17:03:10.887
Enabled for exchange2: COMEX (Trading Account Required) | 2020-10-06 17:03:10.887
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-10-06 17:03:10.887
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-06 17:03:10.887
Current selected Data/Trading service: CQG WebAPI | 2020-10-06 17:03:10.887
Custom symbol settings values: enabled | 2020-10-06 17:03:10.887
Chart Update Interval: 500 | 2020-10-06 17:03:10.887
Intraday Data Storage Time Unit: 0 | 2020-10-06 17:03:10.887
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-06 17:03:10.887
2020-10-06 14:03:10 Local computer time | 2020-10-06 17:03:10.887
2020-10-06 21:03:10 Local computer time in UTC | 2020-10-06 17:03:10.887
2020-10-06 17:03:10 Local computer time in SC Time Zone | 2020-10-06 17:03:10.887
2020-10-06 18:39:31 Server time in UTC | 2020-10-06 17:03:10.887
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-10-06 17:03:10.887
Program path: C:\SierraChart\ | 2020-10-06 17:03:10.887
Data Files path: C:\SierraChart\Data\ | 2020-10-06 17:03:10.887
OS Version Number: 10.0 | 2020-10-06 17:03:10.887
Locale Setting: C | 2020-10-06 17:03:10.887
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-10-06 17:03:10.887
Allowed protected custom studies: | 2020-10-06 17:03:10.887
[2020-10-06 21:58:57]
We also need you to open a chart and then fully follow these instructions:
And make sure there is no volume filtering set for the chart:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
[2020-10-06 22:18:53]
Software version: 2177 64-bit | 2020-10-06 18:10:35.944
Safe Mode enabled | 2020-10-06 18:10:35.944
Primary Thread ID: 8036 | 2020-10-06 18:10:35.944
Usage end date: 2020-11-05 | 2020-10-06 18:10:35.944
Enabled for: Sierra Chart Historical Data Service. | 2020-10-06 18:10:35.944
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-10-06 18:10:35.944
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-10-06 18:10:35.944
Enabled for exchange2: CME | 2020-10-06 18:10:35.944
Enabled for exchange2: CBOT (Trading Account Required) | 2020-10-06 18:10:35.944
Enabled for exchange2: COMEX (Trading Account Required) | 2020-10-06 18:10:35.944
Enabled for exchange2: NYMEX (Trading Account Required) | 2020-10-06 18:10:35.944
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-10-06 18:10:35.944
Current selected Data/Trading service: CQG WebAPI | 2020-10-06 18:10:35.944
Custom symbol settings values: enabled | 2020-10-06 18:10:35.944
Chart Update Interval: 500 | 2020-10-06 18:10:35.944
Intraday Data Storage Time Unit: 0 | 2020-10-06 18:10:35.944
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-10-06 18:10:35.944
2020-10-06 15:10:35 Local computer time | 2020-10-06 18:10:35.944
2020-10-06 22:10:35 Local computer time in UTC | 2020-10-06 18:10:35.944
2020-10-06 18:10:35 Local computer time in SC Time Zone | 2020-10-06 18:10:35.944
2020-10-06 22:09:15 Server time in UTC | 2020-10-06 18:10:35.944
Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-10-06 18:10:35.944
Program path: C:\SierraChart\ | 2020-10-06 18:10:35.944
Data Files path: C:\SierraChart\Data\ | 2020-10-06 18:10:35.944
OS Version Number: 10.0 | 2020-10-06 18:10:35.945
Locale Setting: C | 2020-10-06 18:10:35.945
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-10-06 18:10:35.945
Allowed protected custom studies: | 2020-10-06 18:10:35.945
Added historical Intraday data request for F.US.GCEZ20 to the queue. | 2020-10-06 18:10:51.563
Intraday data recording state for symbol F.US.GCEZ20 is set to download 'Pending'. | 2020-10-06 18:10:51.563
Triggering next historical data download in queue. | 2020-10-06 18:10:51.563
HD Request # 2 | Downloading Intraday chart data for F.US.GCEZ20 to the file F.US.GCEZ20.scid. Service: comex | 2020-10-06 18:10:51.563
Reloading all charts with filename: F.US.GCEZ20.scid | 2020-10-06 18:10:51.623
HD Request # 2 | Download start date-time: 2020-04-03 18:10:51.000000. File last date-time: 00:00:00.000000 | 2020-10-06 18:10:51.624
HD Request # 2 | Using server: ds21.sierracharts.com port 10150 | 2020-10-06 18:10:51.625
Socket (3) | Creating socket. | 2020-10-06 18:10:51.631
Socket (3) | New receive buffer size: 5242880 | 2020-10-06 18:10:51.631
Socket (3) | Connecting to IP: 216.1.90.129. | 2020-10-06 18:10:51.631
HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-10-06 18:10:51.788
HD Request # 2 | Sending historical data logon request message. | 2020-10-06 18:10:51.788
F.US.GCEZ20[M] 1 Min #1 | Reloading chart. | 2020-10-06 18:10:51.960
F.US.GCEZ20[M] 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\F.US.GCEZ20.scid | 2020-10-06 18:10:51.967
HD Request # 2 | Requesting Intraday data. Start date-time: 2020-04-03 18:10:51. Record interval: 0. Symbol: GCZ20 | 2020-10-06 18:10:52.300
HD Request # 2 | Decompressing data. | 2020-10-06 18:10:52.376
HD Request # 2 | Receiving Intraday data for F.US.GCEZ20 starting at 2020-04-05 18:00:04.000000 | 2020-10-06 18:10:52.637
HD Request # 2 | Timestamp of first Intraday data file record written: 2020-04-05 18:00:04.000000 | 2020-10-06 18:10:53.977
Socket (3) | CloseSocket call. | 2020-10-06 18:14:08.916
Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-10-06 18:14:08.916
Historical data download thread signaled to stop. | 2020-10-06 18:14:08.916
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-10-06 18:14:08.916
HD Request # 2 | Received 12645688 records from 2020-04-05 18:00:04.000000 to 2020-10-06 18:14:05.628000 (184.0 days) and wrote 12645688 records for F.US.GCEZ20 | 2020-10-06 18:14:08.917
HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2020-10-06 22:14:05.628000 | 2020-10-06 18:14:08.921
HD Request # 2 | Completion time: 3m 17s | 2020-10-06 18:14:08.921
HD Request # 2 | Intraday data download complete for F.US.GCEZ20. Unique request ID: 2 | 2020-10-06 18:14:08.921
Removing historical data download ID 2. | 2020-10-06 18:14:08.921
Real-time Intraday chart data file updates started for F.US.GCEZ20 | 2020-10-06 18:14:08.921
Intraday chart data file opened for F.US.GCEZ20 | 2020-10-06 18:14:08.921
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2020-10-06 18:14:08.921
Triggering next historical data download in queue. | 2020-10-06 18:14:08.921
Socket (3) | Socket gracefully closed by remote side. | 2020-10-06 18:14:08.992
Socket (3) | Closed. | 2020-10-06 18:14:08.992
Opened cached Intraday file: C:\SierraChart\Data\F.US.GCEZ20.scid. Thread ID: 8680 | 2020-10-06 18:14:12.900
hope i sent the right info
thanks alot for helping me out
[2020-10-06 22:32:06]
You definitely are getting the correct data. Did you check the volume filtering as explained above? Post an image of what you currently see following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage
[2020-10-06 22:45:27]
yes the volume filter are at 0
[2020-10-07 14:08:09]
i am still not getting any data to my number bar charts, is there any thing i can do to get this going again
thanks
[2020-10-07 17:52:28]
Open a new Intraday chart.
Reset the Numbers Bars study to default:
Chart Studies: Resetting Default Study Settings For an Individual Study
And then add the Numbers Bars study to the chart without any modification and then check to see if you still have the issue.
If so post an image of the chart by following these instructions:
Increase the chart bar spacing significantly before taking the chart image so it is easier to see each column.
Date Time Of Last Edit: 2020-10-07 17:53:08
