Date/Time: Fri, 28 Mar 2025 07:03:32 +0000
Flickering Trade Window
View Count: 1374
[2020-09-12 21:39:02] |
Gary Number 2 - Posts: 131 |
All Trade Windows attached to a Trade DOM or Chart flicker about once per second. If I detach the Trade Window from a Trade DOM or Chart, it stops flickering. So over the past few weeks I've resorted to detaching the trade window, but it is definitely some sort of bug which should be fixed. It's definitely distracting when attached and is a basic functionality that is not working correctly. Thank you This is the same issue this user posted under programming help mistakenly I think. Flashing Trade Window |
[2020-09-14 02:45:06] |
Anything?
[2020-09-14 10:41:49] |
Not sure what we can do to help with this. It is not something that we observe. And it most likely is an operating system level issue. Windows really is absolute garbage in this area. It is horrendous, the absolute trash that Microsoft puts out, with all of the money they have. That trade window eventually is going to be replaced with something new but not until next year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-14 10:42:02
[2021-02-03 18:26:17] |
I know SC Eng. has stated the Trade Window will eventually be replaced this year, but if interested, I did find the issue. Attaching a Control Bar to either side of a chart produces the blinking/flickering effect FOR ME (emphasis). Resizing the DOM has no effect on replication, FYI. I've attached a video of the issue if SC or others are interested. It's now not a concern for me at all. However, it may help SC pinpoint potential causes. Please see video link (no screenshot because the effect is a blinking Trade Window). The video is just over a minute long but the issue can be observed in the first 30 seconds. Link is to a short video at Screencast-O-Matic. http://somup.com/crneFroPOQ |
[2021-02-04 13:44:19] |
Ok thank you.
[2021-02-07 09:34:38] |
User557768 - Posts: 1 |
I had a similar flicker issue and I was able to get rid of it by unchecking Support Multiple Rows in Tabs settings.
[2022-11-29 05:29:06] |
Acro - Posts: 442 |
I found the above post very useful as I had this issue in openGL. Currently I have chosen "No" for both Support Multiple Rows for MDI Tabs and Show Arrows Before MDI Tabs in Global settings - General Settings - Windows and this seems to be helping |
