Date/Time: Tue, 04 Nov 2025 14:59:29 +0000
Euronext Real Time Stocks (Teletrader now only provide 15 minutes delayed)
View Count: 1378
|   [2020-09-10 08:16:50]     |
| User612903 - Posts: 51 |
                Hello, Up to now I was using Teletrader + Sierra Charts to receive Real Time Stock data for European Stocks. It seems like teletrader are not providing this anymore. What are the options to get those data into Sierra Charts ? Is there a way to get the Euronext data through any other provider ? Regards,  |
|   [2020-09-10 10:45:40]     |
                Yes we actually have this now through the Sierra Chart Exchange Data Feed.  We will get a symbol listing and get back to you. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2020-09-10 14:09:39]     |
                Good to hear that you now provide this through the Sierra Chart Exchange Data Feed. Are the european stocks provided through Euronext, or through CBOE Europe ? Thanks for the listing, much appreciated. regards,  |
|   [2020-09-11 07:33:14]     |
                Hello,  Could you please let me know how I can access the Euronext data ? Teletrader just let me down and I need to find another solution ASAP. Thanks for your help. Regards,  |
|   [2020-09-11 10:13:46]     |
                We apologize for the delay. You will need to use the Sierra Chart Exchange Data Feed. Instructions: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions You will want to activate the exchange: Cboe Europe Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-11 10:14:13
|   [2020-09-11 11:49:19]     |
                Hello,  Thank you for coming back to me. I beleived I followed the steps : - I activated the Real Time Connexion - I've sign the agreement - I've activated CBOE Europe When I search by symbol or by description, nothing happens. I tried to search for "BNP", "AIR", "A". Nothing happens. Here is the log : Software version: 2163 64-bit | 2020-09-11 11:42:45.552 Primary Thread ID: 38352 | 2020-09-11 11:42:45.552 Usage end date: 2021-01-26 | 2020-09-11 11:42:45.552 Enabled for: Sierra Chart Historical Data Service. | 2020-09-11 11:42:45.552 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-09-11 11:42:45.552 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-09-11 11:42:45.552 Enabled for exchange: Cboe Europe | 2020-09-11 11:42:45.552 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-09-11 11:42:45.552 Current selected Data/Trading service: SC Data - All Services | 2020-09-11 11:42:45.552 Custom symbol settings values: disabled | 2020-09-11 11:42:45.552 Chart Update Interval: 500 | 2020-09-11 11:42:45.552 Intraday Data Storage Time Unit: 0 | 2020-09-11 11:42:45.552 Time Zone: +00:00:00 (UTC+00) | 2020-09-11 11:42:45.552 2020-09-11 13:42:45 Local computer time | 2020-09-11 11:42:45.552 2020-09-11 11:42:45 Local computer time in UTC | 2020-09-11 11:42:45.552 2020-09-11 11:42:45 Local computer time in SC Time Zone | 2020-09-11 11:42:45.552 2020-09-11 11:41:56 Server time in UTC | 2020-09-11 11:42:45.552 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-09-11 11:42:45.552 Program path: C:\SierraChart\ | 2020-09-11 11:42:45.552 Data Files path: C:\SierraChart\Data\ | 2020-09-11 11:42:45.552 OS Version Number: 10.0 | 2020-09-11 11:42:45.552 Locale Setting: C | 2020-09-11 11:42:45.553 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-09-11 11:42:45.553 Allowed protected custom studies: | 2020-09-11 11:42:45.553 SC Data - All Services | Sending symbol search request. Search text: BNP | 2020-09-11 11:43:22.509 SC Data - All Services | Sending symbol search request. Search text: BNP | 2020-09-11 11:43:30.021 Did I miss something ? Regards,  |
|   [2020-09-14 11:03:35]     |
                We apologize for the delay. The correct symbol is BNP.FP We corrected the issue with the symbol search. Follow the instructions here to update the Symbol Settings for the search to function properly.: Global Symbol Settings: Update Global Symbol Settings We realize the session times are not set correctly for the symbol settings. We have to correct those. For now you need to manually set them: Chart Session Times Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2020-09-14 21:28:02]     |
                Thank you, It is now working. One more question, If I connect Sierra Chart to a broker, let say Interactive Broker, will I be able to display the data from Euronext (according to the fact that IB Data comes from Euronext). Or the trading service is only for passing order and doesn't come with data? Regards,  |
|   [2020-09-14 22:47:15]     |
                We would have to set up symbol mapping if you want to use this data feed with Interactive Brokers. We would have to know some example symbols you use for Euronext equities with Interactive Brokers. Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing  |
|   [2020-09-15 07:05:06]     |
| RobinhoodFR - Posts: 13 |
                Hello I am interested in the Cboe Europe exchange, part of the Sierra Chart Exchange Data Feed. I have some questions: - What kind of data is available: trades? Level1? - Do you provide all the trades/quotes or just summary message/aggregated data? - Could you confirm these data are realtime? - If yes, is it possible to access to this stream using DTC? - Do you provide historical tick by tick data for this exchange and if yes, since how long? Thanks a lot for your reply and your time, Best regards,  |
|   [2020-09-15 08:37:51]     |
                Hi again Sierra, What i was asking is not if it's possible to map CBOE data feed with Interactive Brokers symbols. The question is : If I connect sierra with IB (or any other broker), can I display the chart from the broker directly in Sierra (with the broker data, not sierra chart data) ? Regards,  |
|   [2020-09-15 12:37:16]     |
                 - What kind of data is available: trades? Level1? Yes.- Do you provide all the trades/quotes or just summary message/aggregated data? It is a tick by tick data feed.- Could you confirm these data are realtime? Yes.- If yes, is it possible to access to this stream using DTC? Yes for your own use on the same computer:Data and Trading Communications (DTC) Protocol Server - Do you provide historical tick by tick data for this exchange and if yes, since how long? Yes the data goes back to 2018-07-25.: If I connect sierra with IB (or any other broker), can I display the chart from the broker directly in Sierra (with the broker data, not sierra chart data) ?
Yes but only with Interactive Brokers in this case. Refer to:Interactive Brokers Trading Service Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-15 12:37:49
