Date/Time: Thu, 10 Sep 2026 01:06:52 +0000
Previous version(s) questions?
View Count: 1040
[2020-08-20 19:00:53]
User22396 - Posts: 191
Hello support...I came across one of my old trading laptops with various previous versions installed that I want to try to dig into so I can revisit some 'custom studies' I created and also research ideas in these old chartbooks...
I believe there is a version 'cutoff' where these older dll's won't work with the current versions and will need to be re-coded/re-compiled. What is the oldest version that will allow the older dll's to 'work'? I am not looking to use that cutoff version with any live data I just want to retrieve any coded studies/chartbooks to study and then try to 'bring' into the present if that makes sense?
For example I tried to login to version1032 from 2013 and version1398 from 2016 and both return 'invalid account name or PW" using my current credentials so I assume some sort of version cutoff exists?
Any help appreciated...thanks
[2020-08-20 19:59:58]
Recompiling is all that is necessary. In some cases some minor code updates are needed but that will be very obvious as the source code is compiled as to what to do.
As long as you have the source code, then you just need to recompile the studies.
As far as what is the earliest version that is currently supported we have to look that up but it is not going to be earlier than about 1550.
Date Time Of Last Edit: 2020-08-20 20:23:42
[2020-08-20 20:23:32]
Post above has been updated.
[2020-08-21 16:29:40]
Is it possible to 'login' to unsupported versions (earlier than v1550) in an offline capacity?
[2020-08-21 19:57:45]
No.
