Date/Time: Mon, 25 Nov 2024 09:20:58 +0000
NQ futures Numbers Bars Study
View Count: 1891
[2014-01-27 15:36:21]
User94740 - Posts: 333
Hi SC, it seems I have a challenge with the data being displayed for NQ
http://www.sierrachart.com/image.php?l=1390836932587.png
[2014-01-27 17:26:04]
Go to that chart and select Chart >> Chart Settings. Press the Apply Global Symbol Settings button. Press OK. Let us know if that does not solve the problem.
[2014-01-27 17:27:14]
problem still exists
[2014-01-27 17:52:33]
This is not making sense. It is not clear why you are having this problem.
Update Sierra Chart by selecting Help >> Download Current Version. Please be sure to do this.
After the update is completed, then perform a Full Reset of the symbol settings as explained here:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings
And reapply the symbol settings to the chart after.
Date Time Of Last Edit: 2014-01-27 17:54:03
[2014-01-27 18:10:59]
I fail to find any sense either in installing the newest version, because the study is working on the other 17 instruments I trade, but anything is possible
[2014-01-27 18:23:13]
Please update to the newest version.
[2014-01-27 22:42:37]
done, but still a no-go
[2014-01-27 22:51:33]
We will have to help you with remote assistance. What would be a good time for you?
[2014-01-27 23:04:43]
right now?
[2014-01-27 23:24:29]
We can help you now. Please select Help >> Accept Remote Assistance.
After about 10 seconds you will see remote assistance window appear. We need the ID number. Give us the ID number through an account support ticket here:
https://www.sierrachart.com/usercp.php?page=SupportTickets
We will then connect in remotely and you can accept the connection. We do not need any audio. After connecting just show us the chart that has a problem and we will check on it.
Date Time Of Last Edit: 2014-01-27 23:24:53
[2014-01-28 03:14:36]
There was a decimal point position problem with the futures contract data with the Sierra Chart Futures Data Feed from around 2010 and earlier for the NQ and ES. This is now resolved.
