Date/Time: Tue, 04 Nov 2025 11:13:54 +0000
chart data is delayed by 10 minutes (Denali)
View Count: 682
|   [2020-05-01 16:59:30]     |
| User117347 - Posts: 46 |
                Sierra, I just switched from CQG to Denali. 1. When I open a chart the candlesticks do not move. Data is not coming in. 2. After a moment it connects and starts to trade, but the data is not live, data is delayed by 10 minutes. 3. I checked with AMP but they did not know what the problem would be. http://www.sierrachart.com/image.php?Image=1588352217881.png Please advise. Thanks, Jim  |
|   [2020-05-02 02:37:48]     |
                We do not see any reason why you would be having any issue. The most likely cause is that you do not have the option in Data/Trade Service Settings for Allow Support For Sierra Chart Data Feeds enabled. Refer to the information here: Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) If this is enabled and you are still having problems, then follow these instructions to get us a Message Log: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level  Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-02 02:38:13
