Date/Time: Sat, 26 Sep 2026 04:23:44 +0000
Chart not updating real time and no depth
View Count: 1080
| [2020-04-17 13:21:08] |
| User423419 - Posts: 16 |
Hi, I have Service package 5. This morning when loading my charts, the charts load up to the current time, but then stop from there. For example, I use a 10 sec chart. When I upload the chart, it loads the bars up to the current time, but then no bars are formed in real time after. Also, there's no market depth showing on the chart. Thanks |
| [2020-04-17 15:59:03] |
| John - SC Support - Posts: 48028 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-17 16:11:18] |
First we want you to update to current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-04-18 05:11:19] |
Software version: 2086 64-bit | 2020-04-18 05:06:48.805 OpenGL enabled | 2020-04-18 05:06:48.805 Primary Thread ID: 12756 | 2020-04-18 05:06:48.805 Usage end date: 2020-05-12 | 2020-04-18 05:06:48.805 Enabled for: Advanced Features 2. | 2020-04-18 05:06:48.805 Enabled for: Sierra Chart Historical Data Service. | 2020-04-18 05:06:48.805 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-04-18 05:06:48.805 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-18 05:06:48.805 Enabled for exchange2: CME (Trading Account Required) | 2020-04-18 05:06:48.805 Enabled for exchange2: CBOT (Trading Account Required) | 2020-04-18 05:06:48.805 Enabled for exchange2: COMEX (Trading Account Required) | 2020-04-18 05:06:48.805 Enabled for exchange2: NYMEX (Trading Account Required) | 2020-04-18 05:06:48.805 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-04-18 05:06:48.805 Current selected Data/Trading service: Rithmic Trading | 2020-04-18 05:06:48.805 Custom symbol settings values: enabled | 2020-04-18 05:06:48.805 Chart Update Interval: 500 | 2020-04-18 05:06:48.805 Intraday Data Storage Time Unit: 1 | 2020-04-18 05:06:48.805 Time Zone: +00:00:00 (UTC+00) | 2020-04-18 05:06:48.805 2020-04-17 23:06:48 Local computer time | 2020-04-18 05:06:48.805 2020-04-18 05:06:48 Local computer time in UTC | 2020-04-18 05:06:48.805 2020-04-18 05:06:48 Local computer time in SC Time Zone | 2020-04-18 05:06:48.805 2020-04-18 05:03:00 Server time in UTC | 2020-04-18 05:06:48.805 Local computer UTC time and Server UTC time difference: 2 seconds. | 2020-04-18 05:06:48.805 Program path: D:\SierraChart\ | 2020-04-18 05:06:48.805 Data Files path: D:\SierraChart\Data\ | 2020-04-18 05:06:48.805 OS Version Number: 10.0 | 2020-04-18 05:06:48.805 Locale Setting: C | 2020-04-18 05:06:48.805 DLLs: sst_ateam.dll, sst_ateam_64.dll, sst_FreeBundle.dll, sst_FreeBundle_64.dll, UserContributedStudies_64.dll | 2020-04-18 05:06:48.805 File >> Disconnect selected. | 2020-04-18 05:07:02.787 DTC Client socket (1) | CloseSocket call. | 2020-04-18 05:07:02.838 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-18 05:07:02.838 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-04-18 05:07:02.839 DTC Client socket (1) | Closed. | 2020-04-18 05:07:02.839 DTC Client socket (2) | CloseSocket call. | 2020-04-18 05:07:02.843 SC Data - All Services | Disconnected from the server. | 2020-04-18 05:07:02.843 Rithmic Trading | Disconnected. | 2020-04-18 05:07:02.843 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-04-18 05:07:02.843 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-04-18 05:07:02.881 DTC Client socket (2) | Closed. | 2020-04-18 05:07:02.881 Rithmic Trading | Port for executable: 50492 | 2020-04-18 05:07:10.606 Listening socket (1892). Port 50492 | Closed. | 2020-04-18 05:07:10.606 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-04-18 05:07:10.607 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50492. Current folder: D:\SierraChart\Rim | 2020-04-18 05:07:10.609 Rithmic Trading | Bridge process is not running! | 2020-04-18 05:07:12.603 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50492 | 2020-04-18 05:07:12.603 DTC Client socket (1) | Creating socket. | 2020-04-18 05:07:12.603 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-18 05:07:12.603 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-18 05:07:14.604 * DTC Client socket (1) | CloseSocket call. | 2020-04-18 05:07:14.605 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-18 05:07:14.605 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-18 05:07:14.605 DTC Client socket (1) | Closed. | 2020-04-18 05:07:14.605 DTC Client socket (0) | CloseSocket call. | 2020-04-18 05:07:14.623 Rithmic Trading | Disconnected. | 2020-04-18 05:07:14.623 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-18 05:07:14.623 Rithmic Trading | Port for executable: 50494 | 2020-04-18 05:07:16.628 Listening socket (1976). Port 50494 | Closed. | 2020-04-18 05:07:16.628 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-04-18 05:07:16.638 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50494. Current folder: D:\SierraChart\Rim | 2020-04-18 05:07:16.640 Rithmic Trading | Bridge process is not running! | 2020-04-18 05:07:18.643 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50494 | 2020-04-18 05:07:18.643 DTC Client socket (1) | Creating socket. | 2020-04-18 05:07:18.643 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-18 05:07:18.643 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-18 05:07:20.643 * DTC Client socket (1) | CloseSocket call. | 2020-04-18 05:07:20.646 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-18 05:07:20.646 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-18 05:07:20.646 DTC Client socket (1) | Closed. | 2020-04-18 05:07:20.646 DTC Client socket (0) | CloseSocket call. | 2020-04-18 05:07:20.664 Rithmic Trading | Disconnected. | 2020-04-18 05:07:20.664 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-18 05:07:20.664 Rithmic Trading | Port for executable: 50502 | 2020-04-18 05:07:22.675 Listening socket (1936). Port 50502 | Closed. | 2020-04-18 05:07:22.675 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-04-18 05:07:22.675 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50502. Current folder: D:\SierraChart\Rim | 2020-04-18 05:07:22.677 Rithmic Trading | Bridge process is not running! | 2020-04-18 05:07:24.686 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50502 | 2020-04-18 05:07:24.686 DTC Client socket (1) | Creating socket. | 2020-04-18 05:07:24.686 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-18 05:07:24.686 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2020-04-18 05:07:26.688 * DTC Client socket (1) | CloseSocket call. | 2020-04-18 05:07:26.692 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-18 05:07:26.692 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-18 05:07:26.692 DTC Client socket (1) | Closed. | 2020-04-18 05:07:26.692 DTC Client socket (0) | CloseSocket call. | 2020-04-18 05:07:26.712 Rithmic Trading | Disconnected. | 2020-04-18 05:07:26.712 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-18 05:07:26.712 Rithmic Trading | Port for executable: 50504 | 2020-04-18 05:07:28.723 Listening socket (2032). Port 50504 | Closed. | 2020-04-18 05:07:28.723 Rithmic Trading | Starting server: D:\SierraChart\Rim\DTCBridge.exe | 2020-04-18 05:07:28.724 Created process D:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:50504. Current folder: D:\SierraChart\Rim | 2020-04-18 05:07:28.725 Rithmic Trading | Bridge process is running. | 2020-04-18 05:07:30.716 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50504 | 2020-04-18 05:07:30.716 DTC Client socket (1) | Creating socket. | 2020-04-18 05:07:30.716 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-18 05:07:30.716 Rithmic Trading | Connected to server. | 2020-04-18 05:07:30.728 Rithmic Trading | Starting socket receive thread. | 2020-04-18 05:07:30.728 Rithmic Trading | Sending encoding request to server: Binary VLS | 2020-04-18 05:07:30.728 Rithmic Trading | Setting DTC encoding to Binary VLS | 2020-04-18 05:07:30.734 Rithmic Trading | Sending logon request message. | 2020-04-18 05:07:30.734 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2020-04-18 05:07:30.746 Rithmic Trading | Message from server: Logging is enabled. Log file: D:\SierraChart\Rim\Rithmic.log | 2020-04-18 05:07:30.746 Rithmic Trading | Message from server: Connecting to Rithmic Paper Trading server. | 2020-04-18 05:07:30.746 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2020-04-18 05:07:31.182 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2020-04-18 05:07:31.274 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2020-04-18 05:07:31.479 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2020-04-18 05:07:31.576 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2020-04-18 05:07:31.751 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2020-04-18 05:07:31.841 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2020-04-18 05:07:32.008 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2020-04-18 05:07:32.099 Rithmic Trading | Received logon response. | 2020-04-18 05:07:32.739 Rithmic Trading | Server Name: SC DTC Bridge. | 2020-04-18 05:07:32.739 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2020-04-18 05:07:32.739 Rithmic Trading | Successfully connected. IB='OneUpTrader', Firm='OneUpTrader'. | 2020-04-18 05:07:32.739 Rithmic Trading | Trading is supported. | 2020-04-18 05:07:32.739 Rithmic Trading | Order cancel and replace is supported. | 2020-04-18 05:07:32.739 Rithmic Trading | OCO Orders supported. | 2020-04-18 05:07:32.739 Rithmic Trading | Connected to data and trading server. | 2020-04-18 05:07:32.739 Triggering next historical data download in queue. | 2020-04-18 05:07:32.739 Triggering next historical data download in queue. | 2020-04-18 05:07:32.739 Triggering next historical data download in queue. | 2020-04-18 05:07:32.739 Triggering next historical data download in queue. | 2020-04-18 05:07:32.739 Using SC exchange feed2. Symbol: CL?#-NYMEX | 2020-04-18 05:07:32.793 Mapping CLM0-NYMEX to CLM20. Service code: nymex | 2020-04-18 05:07:32.793 SC Data - All Services | Starting real-time market data updates for: CLM0-NYMEX (CLM20). ID: 1 Service code: nymex | 2020-04-18 05:07:32.793 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 443 | 2020-04-18 05:07:32.793 SC Data - All Services | Requesting security definition data for: CLM0-NYMEX (CLM20). ID: 1 | 2020-04-18 05:07:32.793 Requesting market depth updates for: CLM0-NYMEX if supported. | 2020-04-18 05:07:32.793 Separate subscription for market depth updates not supported. CLM0-NYMEX | 2020-04-18 05:07:32.793 Using SC exchange feed2. Symbol: CL?#-NYMEX | 2020-04-18 05:07:32.793 Added historical Intraday data request for CLM0-NYMEX to the queue. | 2020-04-18 05:07:32.793 Intraday data recording state for symbol CLM0-NYMEX is set to download 'Pending'. | 2020-04-18 05:07:32.793 Triggering next historical data download in queue. | 2020-04-18 05:07:32.793 DTC Client socket (2) | Creating socket. | 2020-04-18 05:07:32.793 DTC Client socket (2) | Connecting to IP: 216.1.90.130. | 2020-04-18 05:07:32.793 Delaying start of download for CLM0-NYMEX | 2020-04-18 05:07:32.824 SC Data - All Services | Connected to server. | 2020-04-18 05:07:32.837 SC Data - All Services | Starting socket receive thread. | 2020-04-18 05:07:32.837 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-04-18 05:07:32.837 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2020-04-18 05:07:32.865 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-04-18 05:07:32.907 SC Data - All Services | Sending logon request message. | 2020-04-18 05:07:32.907 Rithmic Trading | Starting real-time market data updates for: F.US.CLEM20. ID: 2 | 2020-04-18 05:07:32.923 Rithmic Trading | Requesting security definition data for: F.US.CLEM20. ID: 2 | 2020-04-18 05:07:32.923 Rithmic Trading | Using primary service for historical data for F.US.CLEM20 | 2020-04-18 05:07:32.923 Added historical Intraday data request for F.US.CLEM20 to the queue. | 2020-04-18 05:07:32.923 Intraday data recording state for symbol F.US.CLEM20 is set to download 'Pending'. | 2020-04-18 05:07:32.923 Triggering next historical data download in queue. | 2020-04-18 05:07:32.923 Delaying start of download for F.US.CLEM20 | 2020-04-18 05:07:32.926 Symbol Error - F.US.CLEM20 is unknown, unavailable, or improperly formatted. | 2020-04-18 05:07:32.926 Requesting market depth updates for: F.US.CLEM20 if supported. | 2020-04-18 05:07:33.061 Rithmic Trading | Market Depth data has been rejected for symbol: F.US.CLEM20. Invalid symbol | 2020-04-18 05:07:33.072 HD Request # 4 | Downloading Intraday chart data for F.US.CLEM20 to the file F.US.CLEM20.scid. Service: rithmic.trading | 2020-04-18 05:07:33.423 HD Request # 4 | Download start date-time: 2020-04-17 12:51:41.000 | 2020-04-18 05:07:33.423 HD Request # 4 | Sending historical data request. Start date-time: 2020-04-17 12:51:41. Record interval: 1. Symbol: F.US.CLEM20 | 2020-04-18 05:07:33.423 HD Request # 4 | Error downloading historical Intraday data for F.US.CLEM20. Historical data request rejected because the symbol is not valid | 2020-04-18 05:07:33.426 HD Request # 4 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for F.US.CLEM20 | 2020-04-18 05:07:33.426 HD Request # 4 | Completion time: 0s | 2020-04-18 05:07:33.426 HD Request # 4 | Intraday data download complete for F.US.CLEM20. Unique request ID: 5 | 2020-04-18 05:07:33.426 Removing historical data download ID 5. | 2020-04-18 05:07:33.426 Real-time Intraday chart data file updates started for F.US.CLEM20 | 2020-04-18 05:07:33.426 Opened cached Intraday file: D:\SierraChart\Data\F.US.CLEM20.scid. Thread ID: 12756 | 2020-04-18 05:07:33.426 Intraday chart data file opened for F.US.CLEM20 | 2020-04-18 05:07:33.426 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2020-04-18 05:07:33.426 Triggering next historical data download in queue. | 2020-04-18 05:07:33.426 SC Data - All Services | Received logon response. | 2020-04-18 05:07:33.534 SC Data - All Services | Server Name: SC Realtime Server. | 2020-04-18 05:07:33.534 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-04-18 05:07:33.534 SC Data - All Services | Successfully connected. | 2020-04-18 05:07:33.534 SC Data - All Services | Trading is not supported. | 2020-04-18 05:07:33.534 SC Data - All Services | Restarting real-time data updates for symbol: CLM0-NYMEX -> CLM20 | 2020-04-18 05:07:33.534 SC Data - All Services | Clearing market depth for CLM0-NYMEX | 2020-04-18 05:07:33.623 Opened cached Depth file: D:\SierraChart\Data\MarketDepthData\CLM0-NYMEX.2020-04-18.depth | 2020-04-18 05:07:33.623 SC Data - All Services | Received security definition for symbol CLM0-NYMEX | 2020-04-18 05:07:33.654 HD Request # 5 | Downloading Intraday chart data for CLM0-NYMEX to the file CLM0-NYMEX.scid. Service: nymex | 2020-04-18 05:07:38.299 HD Request # 5 | Download start date-time: 2020-04-17 20:59:58.000 | 2020-04-18 05:07:38.300 HD Request # 5 | Using server: ds23.sierracharts.com port 10150 | 2020-04-18 05:07:38.300 Socket (3) | Creating socket. | 2020-04-18 05:07:38.300 Socket (3) | Connecting to IP: 216.1.90.130. | 2020-04-18 05:07:38.300 HD Request # 5 | Setting DTC encoding to Binary VLS | 2020-04-18 05:07:38.389 HD Request # 5 | Sending historical data logon request message. | 2020-04-18 05:07:38.389 HD Request # 5 | Requesting Intraday data. Start date-time: 2020-04-17 20:59:58. Record interval: 1. Symbol: CLM20 | 2020-04-18 05:07:38.882 HD Request # 5 | Decompressing data. | 2020-04-18 05:07:38.919 HD Request # 5 | Receiving Intraday data for CLM0-NYMEX starting at 2020-04-17 20:59:58 | 2020-04-18 05:07:38.919 Socket (3) | CloseSocket call. | 2020-04-18 05:07:38.919 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-18 05:07:38.919 Historical data download thread signaled to stop. | 2020-04-18 05:07:38.924 HD Request # 5 | Timestamp of first Intraday data file record written: 2020-04-17 20:59:58 | 2020-04-18 05:07:38.924 HD Request # 5 | Received 1 record from 2020-04-17 20:59:58.000 to 2020-04-17 20:59:58.000 (0.0 seconds) and wrote 1 record for CLM0-NYMEX | 2020-04-18 05:07:38.924 HD Request # 5 | Completion time: 0s | 2020-04-18 05:07:38.927 HD Request # 5 | Intraday data download complete for CLM0-NYMEX. Unique request ID: 4 | 2020-04-18 05:07:38.927 Removing historical data download ID 4. | 2020-04-18 05:07:38.927 Real-time Intraday chart data file updates started for CLM0-NYMEX | 2020-04-18 05:07:38.927 Opened cached Intraday file: D:\SierraChart\Data\CLM0-NYMEX.scid. Thread ID: 12756 | 2020-04-18 05:07:38.927 Intraday chart data file opened for CLM0-NYMEX | 2020-04-18 05:07:38.927 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2020-04-18 05:07:38.927 Triggering next historical data download in queue. | 2020-04-18 05:07:38.927 Socket (3) | Socket gracefully closed by remote side. | 2020-04-18 05:07:38.960 Socket (3) | Closed. | 2020-04-18 05:07:38.960 *this is after market close, so I'm not sure if that'll make a difference in what you need to see. I've also updated to the current version. Thanks |
| [2020-04-18 11:34:40] |
Make sure the symbols are correct. Use this Edit menu command to translate them to match the current service: Edit Menu: Edit >> Translate Symbols To Current Service Tell us what symbol is not updating in real time if there still is a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-18 11:34:54
| [2020-04-21 00:05:04] |
Okay, I did that, still no depth and chart still isn't updating real time. I completely reinstalled sierra last night and it was working last night and this morning, but is no longer working. The symbol I'm using is F.US.CLEM20- Crude Oil June Contract |
| [2020-04-21 01:14:42] |
nvm, got it fixed. Thanks for the help guys
| [2020-04-21 01:57:09] |
Okay understood.
| [2020-04-21 14:53:56] |
| User209995 - Posts: 2 |
I am having the same issue.Here is the message log: Software version: 2088 64-bit | 2020-04-21 08:48:25.684 Primary Thread ID: 4588 | 2020-04-21 08:48:25.684 Usage end date: 2020-08-11 | 2020-04-21 08:48:25.684 Enabled for: Advanced Features 2. | 2020-04-21 08:48:25.684 Enabled for: Sierra Chart Historical Data Service. | 2020-04-21 08:48:25.684 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-04-21 08:48:25.684 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-21 08:48:25.684 Enabled for exchange2: CME | 2020-04-21 08:48:25.684 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-04-21 08:48:25.684 Current selected Data/Trading service: SC Data - All Services | 2020-04-21 08:48:25.684 Custom symbol settings values: disabled | 2020-04-21 08:48:25.684 Chart Update Interval: 500 | 2020-04-21 08:48:25.684 Intraday Data Storage Time Unit: 0 | 2020-04-21 08:48:25.684 Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-04-21 08:48:25.684 2020-04-21 08:48:25 Local computer time | 2020-04-21 08:48:25.684 2020-04-21 14:48:25 Local computer time in UTC | 2020-04-21 08:48:25.684 2020-04-21 08:48:25 Local computer time in SC Time Zone | 2020-04-21 08:48:25.684 2020-04-21 14:40:50 Server time in UTC | 2020-04-21 08:48:25.684 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-04-21 08:48:25.684 Program path: C:\SierraChart\ | 2020-04-21 08:48:25.684 Data Files path: C:\SierraChart\Data\ | 2020-04-21 08:48:25.684 OS Version Number: 10.0 | 2020-04-21 08:48:25.685 Locale Setting: C | 2020-04-21 08:48:25.685 DLLs: MAutoFloorCeiling.dll, MAutoFloorCeiling_64.dll, MBidAskOscillator.dll, MBidAskOscillator_64.dll, MBoxChart.dll, MBoxChart_64.dll, MBoxHistogram.dll, MBoxHistogram_64.dll, MCumulativeDelta.dll, MCumulativeDelta_64.dll, MGannSwing.dll, MGannSwing_64.dll, MPace.dll, MPace_64.dll, MWaveChart.dll, MWaveChart_64.dll, MWaveHistogram.dll, MWaveHistogram_64.dll, PullStack_64.dll, RP_SmoothedProfile.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-04-21 08:48:25.685 File >> Disconnect selected. | 2020-04-21 08:51:21.799 SC Data - All Services | Disconnected. | 2020-04-21 08:51:21.951 SC Data - All Services | Connected to data server. | 2020-04-21 08:51:23.583 Triggering next historical data download in queue. | 2020-04-21 08:51:23.583 Triggering next historical data download in queue. | 2020-04-21 08:51:23.583 Triggering next historical data download in queue. | 2020-04-21 08:51:23.583 Triggering next historical data download in queue. | 2020-04-21 08:51:23.583 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2020-04-21 08:51:23.583 SC Data - All Services | Starting real-time market data updates for: ESM20. ID: 1 | 2020-04-21 08:51:23.734 SC Data - All Services | Subscribing to streaming market data in the service client is not supported. Symbol: ESM20 | 2020-04-21 08:51:23.734 SC Data - All Services | Requesting security definition data for: ESM20. ID: 1 | 2020-04-21 08:51:23.734 Added historical Intraday data request for ESM20 to the queue. | 2020-04-21 08:51:23.734 Intraday data recording state for symbol ESM20 is set to download 'Pending'. | 2020-04-21 08:51:23.734 Triggering next historical data download in queue. | 2020-04-21 08:51:23.734 Delaying start of download for ESM20 | 2020-04-21 08:51:23.745 Requesting market depth updates for: ESM20 if supported. | 2020-04-21 08:51:23.874 Separate subscription for market depth updates not supported. ESM20 | 2020-04-21 08:51:23.874 HD Request # 3 | Downloading Intraday chart data for ESM20 to the file ESM20.scid. Service: cme | 2020-04-21 08:51:28.698 HD Request # 3 | Download start date-time: 2020-04-21 08:31:10.000 | 2020-04-21 08:51:28.698 HD Request # 3 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-04-21 08:51:28.698 Socket (1) | Creating socket. | 2020-04-21 08:51:28.698 Socket (1) | Connecting to IP: 8.18.161.135. | 2020-04-21 08:51:28.698 HD Request # 3 | Setting DTC encoding to Binary VLS | 2020-04-21 08:51:29.139 HD Request # 3 | Sending historical data logon request message. | 2020-04-21 08:51:29.139 HD Request # 3 | Requesting Intraday data. Start date-time: 2020-04-21 08:31:10. Record interval: 0. Symbol: ESM20 | 2020-04-21 08:51:29.807 HD Request # 3 | Decompressing data. | 2020-04-21 08:51:30.029 HD Request # 3 | Receiving Intraday data for ESM20 starting at 2020-04-21 08:31:10 | 2020-04-21 08:51:30.484 Socket (1) | CloseSocket call. | 2020-04-21 08:51:30.705 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-21 08:51:30.705 Historical data download thread signaled to stop. | 2020-04-21 08:51:30.705 HD Request # 3 | Timestamp of first Intraday data file record written: 2020-04-21 08:31:11 | 2020-04-21 08:51:30.705 HD Request # 3 | Received 22750 records from 2020-04-21 08:31:10.000 to 2020-04-21 08:41:30.019 (10.3 minutes) and wrote 22709 records for ESM20 | 2020-04-21 08:51:30.705 HD Request # 3 | Completion time: 2s | 2020-04-21 08:51:30.708 HD Request # 3 | Intraday data download complete for ESM20. Unique request ID: 3 | 2020-04-21 08:51:30.708 Removing historical data download ID 3. | 2020-04-21 08:51:30.708 Real-time Intraday chart data file updates started for ESM20 | 2020-04-21 08:51:30.708 Intraday chart data file opened for ESM20 | 2020-04-21 08:51:30.708 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2020-04-21 08:51:30.708 Triggering next historical data download in queue. | 2020-04-21 08:51:30.708 Socket (1) | Socket gracefully closed by remote side. | 2020-04-21 08:51:30.926 Socket (1) | Closed. | 2020-04-21 08:51:30.926 Chart #12 has tagged chart #7 for full recalculation. Chartbook: ES_Master.Cht | 2020-04-21 08:51:31.175 ESM20 144 Trades #7 | Performing a full recalculation because it has been tagged. Chartbook: ES_Master.Cht | 2020-04-21 08:51:31.508 |
| [2020-04-21 15:26:46] |
Nevermind. I disconnected and connected to my live account and then reconnected to sc data and it is working now. Thank you
