Date/Time: Sun, 19 May 2024 04:36:43 +0000
SC/TT Routing w/Denali Feed - Order Fill Data/Stats Issue
View Count: 860
[2020-02-03 21:32:09] |
User379468 - Posts: 508 |
v2040. One live trade in Trade Stats is showing massive max open loss/ruining the correct Stats because Low During Position is 0 instead of the correct price. 1. What caused this? 2. How can it be fixed? Manually trying to edit the Low During Position in Trade Activity/Fills to correct it duplicates the trade instead and further skews the Trade Stats to be incorrect. Date Time Of Last Edit: 2020-02-03 21:32:31
[2020-02-04 11:16:18] |
We will look this over and see what scenarios this can happen under and see how best to resolve this.
[2020-02-05 18:19:32] |
1, 2. The cause apparently is from an inserted fill from the TT system. It might be a duplicate. Can you tell us the date and time and Time Zone of that fill and we will check and remove any duplicates and then we will have you re-download the fills. We have already implemented a patch to prevent the high/low values from being 0 in this case. This will be released next week. Manually trying to edit the Low During Position in Trade Activity/Fills to correct it duplicates the trade instead and further skews the Trade Stats to be incorrect. We could not reproduce this, but there might be a duplicate for another reason. And that is why we need the details of the fill so we can check on the server.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-05 18:21:25
[2020-02-11 22:52:48] |
1. 2020-01-09 09:33:44.000 BP 2020-01-09 09:36:00.001 EP, NY -5 EST/-4 EDT. Symbol Trade Type Entry DateTime Exit DateTime Entry Price Exit Price Trade Quantity Max Open Quantity Max Closed Quantity Profit/Loss (t) Cumulative Profit/Loss (t) FlatToFlat Profit/Loss (t) FlatToFlat Max Open Profit (t) FlatToFlat Max Open Loss (t) Max Open Profit (t) Max Open Loss (t) Entry Efficiency Exit Efficiency Total Efficiency Commission (C) High Price While Open Low Price While Open Note Open Position Quantity Close Position Quantity Duration YMH20_FUT_CBOT (********) Long 2020-01-09 09:33:44.000 BP 2020-01-09 09:36:00.001 EP 28881 28840 2 2 2 -410.00, -41 -410.00, -41 -410.00, -41 F 0.00, 0 -144610.00, -14461 0.00, 0 -144405.00, -14441 0.0% 49.9% -50.1% 0.00 28881 0 1 0 00:02:16 Date Time Of Last Edit: 2020-02-11 22:53:06
[2020-02-13 19:32:34] |
We have confirmed there are no duplicate order fills for your Trade Account for that date on the servers.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-13 19:32:39
[2020-02-13 20:19:04] |
So how can the original problem in Post #1 be fixed?
[2020-02-15 23:41:26] |
We apologize for the delay. You just need to edit any duplicate trade activity entries: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Also refer to this thread here: Duplicate Order Fill Issue One live trade in Trade Stats is showing massive max open loss/ruining the correct Stats because Low During Position is 0 instead of the correct price. You can only manually correct this value through the Trade Activity Log entry editor. This will not happen going forward from this point in time.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-15 23:42:46
