Date/Time: Sat, 04 May 2024 13:01:34 +0000
PARALLEL RAYS TOOL.
View Count: 670
[2020-01-27 17:59:29] |
User725605 - Posts: 60 |
I have been successfully using the Parallel Ray Tool up until a couple of days ago. I have formatted the tool with progression lines as can be seen in the attachment below. Two dysfunctional things have occurred for no explicable reason to my knowledge. 1. As seen in the attachment,the tool will not show up unless I compress the chart to an extreme. This was categorically Not the case a few days ago. 2. After a couple of hours the tool disappears completely from my charts or will not show. The next day or later in the same day if I wish to reference these levels(at the same price levels originally marked,)they are simply not there. |
F.US.EPH20 1 Min #18 2020-01-27 12_27_14.464.png / V - Attached On 2020-01-27 17:58:51 UTC - Size: 28.57 KB - 207 views |
[2020-01-27 22:05:25] |
Sierra_Chart Engineering - Posts: 14211 |
Provide that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-01-28 16:34:48] |
RE:Parallel Ray Tool Issue. I have reverted back to version 2028 of Sierra and the parallel ray tool seems to be working as before. This forces me to suspect that the problem has been caused by something gone awry in one of your most recent updates. I hope this helps towards solving this annoying issue. |
[2020-01-28 20:32:14] |
But we need your Chartbook with the chart to be able to test this and determine what the problem is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-01-28 20:32:28
[2020-01-28 21:45:50] |
TO SIERRA ENGINEERING. CHARTBOOK AS PER YOUR REQUEST.
Date Time Of Last Edit: 2020-01-29 18:49:09
Private File |
[2020-01-29 16:24:15] |
John - SC Support - Posts: 31362 |
We found the problem and have it fixed. It will be in the next Pre-Release (v 2042). When available, you can update using the Fast Update option. Refer to the instructions here: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
