Date/Time: Mon, 25 Nov 2024 00:27:17 +0000
Not able to connect to ZenFire 28.12.
View Count: 1827
[2013-12-28 13:49:34]
Peter Power - Posts: 70
I am not able to connect to ZenFire anymore. Is the restriction for using this datafeed already in place?
My log file:
Software version: 1066 | 2013-12-28 13:37:35
Usage end date: 2014-11-17 | 2013-12-28 13:37:35
Enabled for: Sierra Chart Historical Data Service. | 2013-12-28 13:37:35
Active service: Zen-Fire | 2013-12-28 13:37:35
Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2013-12-28 13:37:35
2013-12-28 13:37:35 Local computer clock time | 2013-12-28 13:37:35
2013-12-28 13:37:35 GMT time | 2013-12-28 13:37:35
2013-12-28 13:37:35 Time zone adjusted time | 2013-12-28 13:37:35
Time difference to server time: 0 seconds. | 2013-12-28 13:37:35
Program path: C:\sierrachart\ | 2013-12-28 13:37:35
Data Files path: C:\sierrachart\Data\ | 2013-12-28 13:37:35
OS Version Number: 6.2 | 2013-12-28 13:37:35
Checking for new symbol settings for zf | 2013-12-28 13:37:35
Checking for large (over 250 MB) intraday data files to move data out of. Please wait.... | 2013-12-28 13:37:37
Completed checking of 180 Intraday data files (*.scid). | 2013-12-28 13:37:38
Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2013-12-02 19:30:00. Next Bar Date Time: 2013-11-29 15:30:00. Filename: C:\sierrachart\Data\$TICK.scid | 2013-12-28 13:37:40
HD Request # 2 - Downloading Intraday chart data for $TICK to the file $TICK.scid. Service: ddf | 2013-12-28 13:37:45
HD Request # 2 - Download start Date-Time: 2013-12-27 21:04:59.0 | 2013-12-28 13:37:45
HD Request # 2 - Using server: ds5.sierracharts.com port 10149 | 2013-12-28 13:37:45
Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2013-12-28 13:37:45
The network socket is connected. | 2013-12-28 13:37:45
HD Request # 2 - Sending historical data logon request message. | 2013-12-28 13:37:45
HD Request # 2 - Requesting up to 120 days of Intraday data. Record interval: 0 | 2013-12-28 13:37:45
HD Request # 2 - Decompressing data. | 2013-12-28 13:37:45
HD Request # 2 - Receiving Intraday data for $TICK starting at 2013-12-27 21:04:59 | 2013-12-28 13:37:45
The network socket for historical data has been closed. | 2013-12-28 13:37:45
HD Request # 2 - Historical data for $TICK is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2013-12-28 13:37:45
HD Request # 2 - Received 1 record from 2013-12-27 21:04:59 to 2013-12-27 21:04:59 (0.0 seconds) and wrote 0 records for $TICK | 2013-12-28 13:37:45
HD Request # 2 - Intraday download COMPLETE for $TICK | 2013-12-28 13:37:45
Zen-Fire - Port for executable: 59328 | 2013-12-28 13:37:46
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:37:46
Zen-Fire: Connecting to the server 127.0.0.1. Port 59328 | 2013-12-28 13:37:47
The network socket is connected. | 2013-12-28 13:37:47
Zen-Fire: Connected to server. | 2013-12-28 13:37:47
Zen-Fire: Sending logon request message. | 2013-12-28 13:37:47
Zen-Fire - Starting the connection process to data and trading service. | 2013-12-28 13:37:47
Zen-Fire - Logging is enabled. Log file: Rithmic.log | 2013-12-28 13:37:47
Zen-Fire - Connecting to Zen-Fire server. | 2013-12-28 13:37:47
Zen-Fire - Server Alert: Market Data Connection Opened. Error text: | 2013-12-28 13:37:49
Zen-Fire - Server Alert: Market Data Connection Login Failed. Error text: permission denied | 2013-12-28 13:37:49
Zen-Fire DTC Server Info - Server Name: Sierra Chart DTC Bridge. Server Version: 1.1. Provider Name: Zen-Fire DTC. | 2013-12-28 13:37:49
Zen-Fire DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-28 13:37:49
Zen-Fire DTC - Logon error from server: | 2013-12-28 13:37:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:37:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:37:49
Zen-Fire DTC: Disconnected from the server. | 2013-12-28 13:37:49
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:37:49
Zen-Fire - Port for executable: 63424 | 2013-12-28 13:37:50
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:37:50
Zen-Fire: Connecting to the server 127.0.0.1. Port 63424 | 2013-12-28 13:37:51
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:37:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:37:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:37:52
Zen-Fire: Disconnected from the server. | 2013-12-28 13:37:52
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:37:52
Zen-Fire - Port for executable: 63936 | 2013-12-28 13:37:53
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:37:53
Zen-Fire: Connecting to the server 127.0.0.1. Port 63936 | 2013-12-28 13:37:54
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:37:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:37:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:37:55
Zen-Fire: Disconnected from the server. | 2013-12-28 13:37:55
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:37:55
Zen-Fire - Port for executable: 64448 | 2013-12-28 13:37:56
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:37:56
Zen-Fire: Connecting to the server 127.0.0.1. Port 64448 | 2013-12-28 13:37:57
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:37:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:37:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:37:58
Zen-Fire: Disconnected from the server. | 2013-12-28 13:37:58
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:37:58
Zen-Fire - Port for executable: 64960 | 2013-12-28 13:37:59
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:37:59
Zen-Fire: Connecting to the server 127.0.0.1. Port 64960 | 2013-12-28 13:38:00
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:38:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:01
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:01
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:01
Zen-Fire - Port for executable: 65472 | 2013-12-28 13:38:02
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:38:02
Zen-Fire: Connecting to the server 127.0.0.1. Port 65472 | 2013-12-28 13:38:03
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:38:04
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:04
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:04
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:04
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:04
Zen-Fire - Port for executable: 449 | 2013-12-28 13:38:05
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:38:05
Zen-Fire: Connecting to the server 127.0.0.1. Port 449 | 2013-12-28 13:38:06
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:38:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:07
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:07
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:07
Zen-Fire - Port for executable: 1217 | 2013-12-28 13:38:08
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:38:08
Zen-Fire: Connecting to the server 127.0.0.1. Port 1217 | 2013-12-28 13:38:09
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:38:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:10
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:10
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:10
Zen-Fire - Port for executable: 1729 | 2013-12-28 13:38:11
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:38:11
Zen-Fire: Connecting to the server 127.0.0.1. Port 1729 | 2013-12-28 13:38:12
The network socket is connected. | 2013-12-28 13:38:12
Zen-Fire: Connected to server. | 2013-12-28 13:38:12
Zen-Fire: Sending logon request message. | 2013-12-28 13:38:12
Zen-Fire - Starting the connection process to data and trading service. | 2013-12-28 13:38:12
Zen-Fire - Logging is enabled. Log file: Rithmic.log | 2013-12-28 13:38:12
Zen-Fire - Connecting to Zen-Fire server. | 2013-12-28 13:38:12
Zen-Fire - Server Alert: Market Data Connection Opened. Error text: | 2013-12-28 13:38:14
Zen-Fire - Server Alert: Market Data Connection Login Failed. Error text: permission denied | 2013-12-28 13:38:14
Zen-Fire DTC Server Info - Server Name: Sierra Chart DTC Bridge. Server Version: 1.1. Provider Name: Zen-Fire DTC. | 2013-12-28 13:38:14
Zen-Fire DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-28 13:38:14
Zen-Fire DTC - Logon error from server: | 2013-12-28 13:38:14
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:14
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:14
Zen-Fire DTC: Disconnected from the server. | 2013-12-28 13:38:14
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:14
Zen-Fire - Port for executable: 4801 | 2013-12-28 13:38:15
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:38:15
Zen-Fire: Connecting to the server 127.0.0.1. Port 4801 | 2013-12-28 13:38:16
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:38:17
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:17
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:17
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:17
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:17
Zen-Fire - Port for executable: 5313 | 2013-12-28 13:38:18
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:38:18
Zen-Fire: Connecting to the server 127.0.0.1. Port 5313 | 2013-12-28 13:38:19
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:38:20
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:38:20
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:38:20
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:20
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:38:20
File >> Disconnect selected. | 2013-12-28 13:38:21
Zen-Fire: Disconnected from the server. | 2013-12-28 13:38:21
Current selected Data/Trading service: Zen-Fire | 2013-12-28 13:39:36
Zen-Fire - Port for executable: 11713 | 2013-12-28 13:39:40
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:40
Zen-Fire: Connecting to the server 127.0.0.1. Port 11713 | 2013-12-28 13:39:41
The network socket is connected. | 2013-12-28 13:39:41
Zen-Fire: Connected to server. | 2013-12-28 13:39:41
Zen-Fire: Sending logon request message. | 2013-12-28 13:39:41
Zen-Fire - Starting the connection process to data and trading service. | 2013-12-28 13:39:41
Zen-Fire - Logging is enabled. Log file: Rithmic.log | 2013-12-28 13:39:41
Zen-Fire - Connecting to Zen-Fire server. | 2013-12-28 13:39:41
Zen-Fire - Server Alert: Market Data Connection Opened. Error text: | 2013-12-28 13:39:43
Zen-Fire - Server Alert: Market Data Connection Login Failed. Error text: permission denied | 2013-12-28 13:39:43
Zen-Fire DTC Server Info - Server Name: Sierra Chart DTC Bridge. Server Version: 1.1. Provider Name: Zen-Fire DTC. | 2013-12-28 13:39:43
Zen-Fire DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-28 13:39:43
Zen-Fire DTC - Logon error from server: | 2013-12-28 13:39:43
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:39:43
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:39:43
Zen-Fire DTC: Disconnected from the server. | 2013-12-28 13:39:43
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:39:43
Zen-Fire - Port for executable: 14529 | 2013-12-28 13:39:44
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:44
Zen-Fire: Connecting to the server 127.0.0.1. Port 14529 | 2013-12-28 13:39:45
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:39:46
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:39:46
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:39:46
Zen-Fire: Disconnected from the server. | 2013-12-28 13:39:46
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:39:46
Zen-Fire - Port for executable: 16321 | 2013-12-28 13:39:47
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:47
Zen-Fire: Connecting to the server 127.0.0.1. Port 16321 | 2013-12-28 13:39:48
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:39:49
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:39:49
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:39:49
Zen-Fire: Disconnected from the server. | 2013-12-28 13:39:49
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:39:49
Zen-Fire - Port for executable: 16833 | 2013-12-28 13:39:50
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:50
Zen-Fire: Connecting to the server 127.0.0.1. Port 16833 | 2013-12-28 13:39:51
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:39:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:39:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:39:52
Zen-Fire: Disconnected from the server. | 2013-12-28 13:39:52
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:39:52
Zen-Fire - Port for executable: 17345 | 2013-12-28 13:39:53
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:53
Zen-Fire: Connecting to the server 127.0.0.1. Port 17345 | 2013-12-28 13:39:54
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:39:55
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:39:55
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:39:55
Zen-Fire: Disconnected from the server. | 2013-12-28 13:39:55
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:39:55
Zen-Fire - Port for executable: 17857 | 2013-12-28 13:39:56
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:56
Zen-Fire: Connecting to the server 127.0.0.1. Port 17857 | 2013-12-28 13:39:57
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:39:58
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:39:58
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:39:58
Zen-Fire: Disconnected from the server. | 2013-12-28 13:39:58
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:39:58
Zen-Fire - Port for executable: 18369 | 2013-12-28 13:39:59
Zen-Fire - Starting server: C:\sierrachart\Rim\DTCBridge.exe | 2013-12-28 13:39:59
Zen-Fire: Connecting to the server 127.0.0.1. Port 18369 | 2013-12-28 13:40:00
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-28 13:40:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-28 13:40:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-28 13:40:01
Zen-Fire: Disconnected from the server. | 2013-12-28 13:40:01
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-28 13:40:01
File >> Disconnect selected. | 2013-12-28 13:40:02
Zen-Fire: Disconnected from the server. | 2013-12-28 13:40:02
And I would like to use this opportunity to complain about your approach to the whole ZenFire datafeed problem. I understand that you want your datafeed partners to use your API, but I donĀ“t care about that as your customer. I was very satisfied with SCH so far, but exactly this unability to solve critical issues led me to cancel using NinjaTrader (for which I have lifetime license btw.) and start using SierraChart. There will be more very disappointed customers at the beginning of new year I guess.
[2013-12-28 19:29:36]
You need to contact your broker about this error:
Whether you should be able to connect or not, we do not know. It's not uncommon to have trouble connecting over the weekend.
Zen fire is not strictly a data feed.
We refer to it as a trading platform service. It provides access to trading and also market data.
The situation with Zen-Fire is not ours. This complaint is not fair to us. The interface method to Zen-Fire was changed by them. Not us. We have a very firm policy where we do not support API components. We proceeded to partially support the new Zen-fire API (trading only) to accommodate the existing users, and after working through it, realized it was a mistake and needed to follow our policy:
Http://www.sierrachart.com/index.php?l=doc/helpdetails76.html
This policy has been in place for about a year now.
It is also unheard of, to have a very short amount of time to support a completely new interface method to a backend system. In my more than 17 years of experience, I have never seen anything like this. They should have allowed at least a one-year transition time. It was very surprising what they did.
It is very critical, that trading and data service providers provide open and clearly documented basic communication protocols. The most well-established protocol is FIX and we have started an initiative for this industry to establish DTC:
https://www.sierrachart.com/index.php?l=doc/doc_GeneralDataTradeServiceProtocol.php
We desire to have a working group formed to work out differences and establish a clear standard.
What is meant by "SCH"? We know that SC is Sierra Chart.
Date Time Of Last Edit: 2013-12-28 19:36:29
[2013-12-29 23:03:44]
GaryD - Posts: 61
I am not able to connect either. Is it possible the change has occurred prior to 1/1/14?
Zen-Fire - Port for executable: 5126 | 2013-12-29 18:01:26
Zen-Fire - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2013-12-29 18:01:26
Zen-Fire: Connecting to the server 127.0.0.1. Port 5126 | 2013-12-29 18:01:27
The network socket is connected. | 2013-12-29 18:01:27
Zen-Fire: Connected to server. | 2013-12-29 18:01:27
Zen-Fire: Sending logon request message. | 2013-12-29 18:01:27
Zen-Fire - Starting the connection process to data and trading service. | 2013-12-29 18:01:27
Zen-Fire - Logging is enabled. Log file: Rithmic.log | 2013-12-29 18:01:27
Zen-Fire - Connecting to Zen-Fire server. | 2013-12-29 18:01:27
Zen-Fire - Server Alert: Market Data Connection Opened. Error text: | 2013-12-29 18:01:29
Zen-Fire - Server Alert: Market Data Connection Login Failed. Error text: permission denied | 2013-12-29 18:01:29
Zen-Fire DTC Server Info - Server Name: Sierra Chart DTC Bridge. Server Version: 1.1. Provider Name: Zen-Fire DTC. | 2013-12-29 18:01:29
Zen-Fire DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-12-29 18:01:29
Zen-Fire DTC - Logon error from server: | 2013-12-29 18:01:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2013-12-29 18:01:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2013-12-29 18:01:29
Zen-Fire DTC: Disconnected from the server. | 2013-12-29 18:01:29
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-12-29 18:01:29
[2013-12-29 23:05:28]
GaryD - Posts: 61
Zen-Fire - Port for executable: 20742 | 2013-12-29 18:04:47
Zen-Fire - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2013-12-29 18:04:47
Zen-Fire: Connecting to the server 127.0.0.1. Port 20742 | 2013-12-29 18:04:48
Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-12-29 18:04:49
"actively refused" sounds like it is not wanting to play
Date Time Of Last Edit: 2013-12-29 23:07:31
[2013-12-29 23:28:43]
Could be. This is the relevant error:
Please contact your broker about this. While we want to remain neutral, keep in mind we do support many different backend trading platforms. So if Zen-Fire is not available, you can use another one which we support:
http://www.sierrachart.com/index.php?l=doc/data.php#Services
It is important for us to point this out because you do have a significant amount of paid usage time on your Sierra Chart account.
Date Time Of Last Edit: 2013-12-29 23:33:44
[2013-12-29 23:35:28]
kamicrazy - Posts: 18
Mirus supports T4, just ask them to convert your account
[2013-12-29 23:41:08]
Yes, this is a good solution.
[2013-12-29 23:51:21]
GaryD - Posts: 61
Thanks. I am not upset with any party about this. Things change, I will find a solution.
BTW, having used 4 other trading platforms, I find Sierra Charts to be by far the best, smoothest, easiest on my computer resources, most complete, and reliable.
[2013-12-30 00:00:48]
Good. This is especially true with the most recent versions. We have made significant performance improvements .
For anyone who will be using switching to CTS T4 from Zen-Fire. Please refer to this thread:
Switching to CTS T4
Date Time Of Last Edit: 2013-12-30 00:01:03
