Date/Time: Thu, 02 May 2024 04:58:36 +0000
Add custom study
View Count: 1468
[2019-12-11 03:32:41] |
User542305 - Posts: 2 |
Hi, I have downloaded today the most recent version of Sierra Charts. However, when I open the studies and try to glance through the "the add custom study" I find its empty, and nothing there. In the previous version I enjoyed many indicators of that group, i.e. Ehlers Indicators and etc.. How do I go about to import those technical indicators. Looking forward for your reply, and help my email address is artleifer@gmail.com Yours Truly, ART |
[2019-12-11 05:36:16] |
Do you know what custom studies name they were listed under previously? Was it User Contributed Studies?
[2019-12-11 08:28:59] |
Ackin - Posts: 1865 |
User542305) This has already been resolved once ECIVWAP Run the installer again through Help >> Download Current Version and enable Install Optional Components.
Also make sure Sierra Chart is not running in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode or In the attachment you have a file that you copy to the Data folder in your Sierrachart directory and after restart Sierrachart you can try "add custom studies" again Date Time Of Last Edit: 2019-12-11 08:30:11
UserContributedStudies_64.dll - Attached On 2019-12-11 08:24:14 UTC - Size: 1.43 MB - 290 views |
