Date/Time: Thu, 02 May 2024 02:20:42 +0000
cant dl sc log sent
View Count: 768
[2019-12-09 22:14:14] |
User718663 - Posts: 39 |
i cant download sierra sc. i had to reset the pc and now trying to re-download to same pc.
[2019-12-09 23:14:27] |
John - SC Support - Posts: 31293 |
If you are having trouble installing Sierra Chart, then we would need to see the Installation Log. The best way to get us the log is to perform the installation, then when you have a problem, go to the directory in which you were trying to install Sierra Chart to (typically C:\SierraChart), then go to the Logs directory (typically C:\SierraChart\Logs) and attach the file that starts with "Installer Log" and has the date and time of the install that you just attempted.
[2019-12-09 23:29:52] |
hi John, yes but it won't download. there's no Sierra chart folder. it never gets to that point. it never gets beyond the install screen. there's a log in the install screen but I can't copy it. I did send it from within the install screen with my username and email in it. |
[2019-12-09 23:50:06] |
Ok, we found your installation log. The problem is that you are trying to install to C:\SierraChart, which is the default location, but you do not have permissions to write to that directory. You can do one of the following: - Give your username permissions for that directory. - Install as Administrator (although you may then have to continue to run the software as Administrator, depending on how your PC is setup). - Install to a different location that you do have permissions for. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-10 00:09:35] |
hi, how can i install as admin if it never gets beyond install screen? |
[2019-12-10 14:58:16] |
You would need to be logged into your computer as the Administrator, or have your account be an administrator. The easiest thing is to install Sierra Chart into a location where you do have permissions for your account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-10 16:46:47] |
Refer to help topic 16: Error Messages When Opening Files You would want to run the installer with Administrator access. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-10 23:17:00] |
PLEASE HELP. i sent the log again. this is my 5th day of missing on the market. why cant anyone help me?
[2019-12-11 00:14:49] |
Could we call you now? Make sure your current telephone number is set here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-11 00:17:50] |
Sierra Chart - Max - Posts: 5598 |
We tried calling the number that is set on your account, but were not able to reach you. Please confirm the number and a good time to call. Sierra Chart Support |
[2019-12-11 00:37:05] |
hi, i was able to install it and run it. however, now it says download failed. iknow i have td ameritrade data but that is good until end of this month. i went to the folder and unched "read" only but it still doesnt dl. im runnig sc under admin. |
[2019-12-11 00:41:59] |
heres the log. god this is exhausting. i spend more time adjusting and fixing sc than using it. Reading Internal Order ID file. | 2019-12-11 00:38:47.678 Reading Trade Orders file. | 2019-12-11 00:38:47.766 Reading Trade Positions file. | 2019-12-11 00:38:47.766 Reading Account Balance file. | 2019-12-11 00:38:47.766 UDPListener (1380). Port 22904 | Listening on UDP port 22904. | 2019-12-11 00:38:47.783 Software version: 2021 64-bit | 2019-12-11 00:38:47.784 Usage end date: 2019-12-31 | 2019-12-11 00:38:47.784 Enabled for: Advanced Features 2. | 2019-12-11 00:38:47.784 Enabled for: Sierra Chart Historical Data Service. | 2019-12-11 00:38:47.784 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2019-12-11 00:38:47.784 Allow Support for Sierra Chart Data Feeds is enabled. | 2019-12-11 00:38:47.784 Current selected Data/Trading service: TD Ameritrade | 2019-12-11 00:38:47.784 Custom symbol settings values: enabled | 2019-12-11 00:38:47.784 Chart Update Interval: 500 | 2019-12-11 00:38:47.784 Intraday Data Storage Time Unit: 1 | 2019-12-11 00:38:47.784 Time Zone: +00:00:00 (UTC+00) | 2019-12-11 00:38:47.784 2019-12-10 16:38:47 Local computer time | 2019-12-11 00:38:47.784 2019-12-11 00:38:47 Local computer time in UTC | 2019-12-11 00:38:47.784 2019-12-11 00:38:47 Local computer time in SC Time Zone | 2019-12-11 00:38:47.784 2019-12-11 00:38:47 Server time in UTC | 2019-12-11 00:38:47.784 Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-12-11 00:38:47.784 Program path: C:\SierraChart\ | 2019-12-11 00:38:47.784 Data Files path: C:\SierraChart\Data\ | 2019-12-11 00:38:47.784 OS Version Number: 10.0 | 2019-12-11 00:38:47.785 Locale Setting: C | 2019-12-11 00:38:47.785 Checking for new symbol settings. Requested symbol settings MD5 for service code tda. Request ID: 1. | 2019-12-11 00:38:47.805 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:38:47.823 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-12-11 00:38:47.984 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-12-11 00:38:47.985 Received 5 login tokens. | 2019-12-11 00:38:48.404 Symbol settings MD5 received. Request ID: 1. | 2019-12-11 00:38:48.546 Symbol settings are up-to-date for tda. | 2019-12-11 00:38:48.546 Files to Open on Start up | Opening file: ExampleChartbook.cht | 2019-12-11 00:38:51.527 XAUUSD 1 Min #1 | Reloading chart. | 2019-12-11 00:38:51.538 XAUUSD Daily #2 | Reloading chart. | 2019-12-11 00:38:51.564 US30 1 Min #3 | Reloading chart. | 2019-12-11 00:38:51.578 USOil 1 Min #4 | Reloading chart. | 2019-12-11 00:38:51.592 ESZ19 1 Min #5 | Reloading chart. | 2019-12-11 00:38:51.608 $INX Daily #6 | Reloading chart. | 2019-12-11 00:38:51.629 EURUSD Daily #7 | Reloading chart. | 2019-12-11 00:38:51.648 EURUSD 5 Min #8 | Reloading chart. | 2019-12-11 00:38:51.664 ESZ19 #9 | Reloading chart. | 2019-12-11 00:38:51.680 ESZ19 1 Min #10 | Reloading chart. | 2019-12-11 00:38:51.850 ESZ19 1 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ19.scid | 2019-12-11 00:38:51.873 EURUSD 5 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\EURUSD.scid | 2019-12-11 00:38:51.880 ESZ19 #9 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ19.scid | 2019-12-11 00:38:51.886 ESZ19 1 Min #10 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\ESZ19.scid | 2019-12-11 00:38:51.910 Using Bid/Ask average for last trade price for XAUUSD | 2019-12-11 00:38:52.040 Starting DelayedDownloadMonitoringTimer | 2019-12-11 00:38:52.040 Starting HDTimeoutTimer | 2019-12-11 00:38:52.040 Added historical Intraday data request for XAUUSD to the queue. | 2019-12-11 00:38:52.040 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2019-12-11 00:38:52.040 Triggering next historical data download in queue. | 2019-12-11 00:38:52.040 HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2019-12-11 00:38:52.043 HD Request # 1 | Download start date-time: 2019-12-11 00:33:09.000 | 2019-12-11 00:38:52.044 HD Request # 1 | Using server: ds4.sierracharts.com port 10150 | 2019-12-11 00:38:52.044 Socket (1) | Creating socket. | 2019-12-11 00:38:52.044 Socket (1) | Connecting to IP: 192.81.56.146. | 2019-12-11 00:38:52.044 Added historical Daily data request for XAUUSD to the queue. | 2019-12-11 00:38:52.057 Triggering next historical data download in queue. | 2019-12-11 00:38:52.057 Using Bid/Ask average for last trade price for US30 | 2019-12-11 00:38:52.073 Added historical Intraday data request for US30 to the queue. | 2019-12-11 00:38:52.073 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2019-12-11 00:38:52.073 Triggering next historical data download in queue. | 2019-12-11 00:38:52.073 Using Bid/Ask average for last trade price for USOil | 2019-12-11 00:38:52.090 Added historical Intraday data request for USOil to the queue. | 2019-12-11 00:38:52.090 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2019-12-11 00:38:52.090 Triggering next historical data download in queue. | 2019-12-11 00:38:52.090 TD Ameritrade | Connecting. | 2019-12-11 00:38:52.109 TD Ameritrade | Logging in. (Step 1 of 3) | 2019-12-11 00:38:52.109 Starting DelayedDownloadMonitoringTimer | 2019-12-11 00:38:52.121 Starting HDTimeoutTimer | 2019-12-11 00:38:52.121 Added historical Daily data request for $INX to the queue. | 2019-12-11 00:38:52.121 Triggering next historical data download in queue. | 2019-12-11 00:38:52.121 HD Request # 2 | Downloading Historical Daily chart data for $INX. Starting date: 2019-12-06. Service: sp.index | 2019-12-11 00:38:52.125 HD Request # 2 | Requesting historical Daily data for $INX starting at 2019-12-05 | 2019-12-11 00:38:52.125 Added historical Daily data request for EURUSD to the queue. | 2019-12-11 00:38:52.153 Triggering next historical data download in queue. | 2019-12-11 00:38:52.153 Using Bid/Ask average for last trade price for EURUSD | 2019-12-11 00:38:52.153 Added historical Intraday data request for EURUSD to the queue. | 2019-12-11 00:38:52.162 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2019-12-11 00:38:52.162 Triggering next historical data download in queue. | 2019-12-11 00:38:52.162 HD Request # 1 | Setting DTC encoding to Binary VLS | 2019-12-11 00:38:52.206 HD Request # 1 | Sending historical data logon request message. | 2019-12-11 00:38:52.206 TD Ameritrade | Authorized for streamer data. Account: 86*** | 2019-12-11 00:38:52.481 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2019-12-11 00:38:52.481 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2019-12-11 00:38:52.700 HD Request # 1 | Requesting Intraday data. Start date-time: 2019-12-11 00:33:09. Record interval: 1. Symbol: XAUUSD | 2019-12-11 00:38:52.768 HD Request # 1 | Decompressing data. | 2019-12-11 00:38:52.844 HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2019-12-11 00:33:09 | 2019-12-11 00:38:52.845 HD Request # 1 | Timestamp of first Intraday data file record written: 2019-12-11 00:33:09 | 2019-12-11 00:38:52.845 Socket (1) | CloseSocket call. | 2019-12-11 00:38:52.845 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:38:52.845 HD Request # 1 | Historical data for XAUUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2019-12-11 00:38:52.845 Historical data download thread signaled to stop. | 2019-12-11 00:38:52.845 HD Request # 1 | Received 158 records from 2019-12-11 00:33:09.000 to 2019-12-11 00:38:49.000 (5.7 minutes) and wrote 158 records for XAUUSD | 2019-12-11 00:38:52.846 HD Request # 1 | Completion time: 0s | 2019-12-11 00:38:52.846 HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1 | 2019-12-11 00:38:52.846 Removing historical data download ID 1. | 2019-12-11 00:38:52.846 Triggering next historical data download in queue. | 2019-12-11 00:38:52.846 HD Request # 3 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2019-12-09. Service: fxcm | 2019-12-11 00:38:52.847 HD Request # 3 | Using server: ds3.sierracharts.com port 10149 | 2019-12-11 00:38:52.847 Socket (2) | Creating socket. | 2019-12-11 00:38:52.847 Socket (2) | Connecting to IP: 65.182.172.42. | 2019-12-11 00:38:52.847 Socket (1) | Socket gracefully closed by remote side. | 2019-12-11 00:38:52.925 Socket (1) | Closed. | 2019-12-11 00:38:52.925 HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-12-11 00:38:52.977 HD Request # 3 | Sending historical data logon request message. | 2019-12-11 00:38:52.977 HD Request # 3 | Requesting historical Daily data starting at 2019-12-09. | 2019-12-11 00:38:53.033 HD Request # 3 | Decompressing data. | 2019-12-11 00:38:53.090 HD Request # 3 | Receiving historical Daily data for XAUUSD starting at 2019-12-09 | 2019-12-11 00:38:53.163 HD Request # 3 | Writing historical Daily data to the file XAUUSD.dly | 2019-12-11 00:38:53.164 Socket (2) | CloseSocket call. | 2019-12-11 00:38:53.226 Socket (2) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:38:53.226 Historical data download thread signaled to stop. | 2019-12-11 00:38:53.226 HD Request # 3 | Received 3 records from 2019-12-09 00:00:00 to 2019-12-11 00:00:00 (3.0 days) and wrote 3 records for XAUUSD | 2019-12-11 00:38:53.226 HD Request # 3 | Completion time: 1s | 2019-12-11 00:38:53.226 HD Request # 3 | Daily data download complete for XAUUSD. Unique request ID: 2 | 2019-12-11 00:38:53.226 Removing historical data download ID 2. | 2019-12-11 00:38:53.226 Triggering next historical data download in queue. | 2019-12-11 00:38:53.226 HD Request # 4 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2019-12-11 00:38:53.226 HD Request # 4 | Download start date-time: 2019-07-19 11:05:22.000 | 2019-12-11 00:38:53.227 HD Request # 4 | Using server: ds4.sierracharts.com port 10150 | 2019-12-11 00:38:53.227 Socket (1) | Creating socket. | 2019-12-11 00:38:53.227 Socket (1) | Connecting to IP: 192.81.56.146. | 2019-12-11 00:38:53.227 Socket (2) | Socket gracefully closed by remote side. | 2019-12-11 00:38:53.288 Socket (2) | Closed. | 2019-12-11 00:38:53.288 HD Request # 4 | Setting DTC encoding to Binary VLS | 2019-12-11 00:38:53.390 HD Request # 4 | Sending historical data logon request message. | 2019-12-11 00:38:53.390 HD Request # 4 | Requesting Intraday data. Start date-time: 2019-07-19 11:05:22. Record interval: 1. Symbol: US30 | 2019-12-11 00:38:53.467 HD Request # 2 | Receiving historical Daily data for $INX starting at 2019-12-06 | 2019-12-11 00:38:53.529 HD Request # 2 | Writing historical Daily data to the file $INX.dly | 2019-12-11 00:38:53.529 HD Request # 4 | Decompressing data. | 2019-12-11 00:38:53.549 HD Request # 2 | Received 4 records from 2019-12-06 00:00:00 to 2019-12-10 00:00:00 (5.0 days) and wrote 3 records for $INX | 2019-12-11 00:38:53.578 HD Request # 2 | Completion time: 0s | 2019-12-11 00:38:53.578 HD Request # 2 | Daily data download complete for $INX. Unique request ID: 5 | 2019-12-11 00:38:53.578 Removing historical data download ID 5. | 2019-12-11 00:38:53.578 Triggering next historical data download in queue. | 2019-12-11 00:38:53.578 XAUUSD[M] Daily #2 | Reloading chart. | 2019-12-11 00:38:53.582 $INX Daily #6 | Reloading chart. | 2019-12-11 00:38:53.631 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2019-12-11 00:38:53.926 HD Request # 4 | Receiving Intraday data for US30 starting at 2019-07-19 11:05:22 | 2019-12-11 00:38:53.981 HD Request # 4 | Timestamp of first Intraday data file record written: 2019-07-19 11:05:22 | 2019-12-11 00:38:53.982 TD Ameritrade | Connected to data and trading server. | 2019-12-11 00:38:54.179 Triggering next historical data download in queue. | 2019-12-11 00:38:54.180 Triggering next historical data download in queue. | 2019-12-11 00:38:54.180 Triggering next historical data download in queue. | 2019-12-11 00:38:54.180 Triggering next historical data download in queue. | 2019-12-11 00:38:54.180 TD Ameritrade | Starting real-time market data updates for: ESZ19. ID: 1 | 2019-12-11 00:38:54.183 TD Ameritrade | Requesting security definition data for: ESZ19. ID: 1 | 2019-12-11 00:38:54.183 TD Ameritrade | Using primary service for historical data for ESZ19 | 2019-12-11 00:38:54.183 Starting DelayedDownloadMonitoringTimer | 2019-12-11 00:38:54.183 Starting HDTimeoutTimer | 2019-12-11 00:38:54.183 Added historical Intraday data request for ESZ19 to the queue. | 2019-12-11 00:38:54.183 Intraday data recording state for symbol ESZ19 is set to download 'Pending'. | 2019-12-11 00:38:54.183 Triggering next historical data download in queue. | 2019-12-11 00:38:54.183 Delaying start of download for ESZ19 | 2019-12-11 00:38:54.183 Using Bid/Ask average for last trade price for XAUUSD | 2019-12-11 00:38:54.539 SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 2 Service code: fxcm | 2019-12-11 00:38:54.539 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2019-12-11 00:38:54.539 SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 2 | 2019-12-11 00:38:54.539 Added historical Intraday data request for XAUUSD to the queue. | 2019-12-11 00:38:54.539 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2019-12-11 00:38:54.539 Triggering next historical data download in queue. | 2019-12-11 00:38:54.539 DTC Client socket (2) | Creating socket. | 2019-12-11 00:38:54.540 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2019-12-11 00:38:54.540 Using Bid/Ask average for last trade price for US30 | 2019-12-11 00:38:54.577 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 3 Service code: fxcm | 2019-12-11 00:38:54.577 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 3 | 2019-12-11 00:38:54.577 Using Bid/Ask average for last trade price for USOil | 2019-12-11 00:38:54.589 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 4 Service code: fxcm | 2019-12-11 00:38:54.589 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 4 | 2019-12-11 00:38:54.589 SC DTC Data with Market Depth | Connected to server. | 2019-12-11 00:38:54.618 SC DTC Data with Market Depth | Starting socket receive thread. | 2019-12-11 00:38:54.618 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2019-12-11 00:38:54.619 TD Ameritrade | Starting real-time market data updates for: $INX. ID: 5 Service code: sp.index | 2019-12-11 00:38:54.631 TD Ameritrade | Requesting security definition data for: $INX. ID: 5 | 2019-12-11 00:38:54.631 Using Bid/Ask average for last trade price for EURUSD | 2019-12-11 00:38:54.647 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 6 Service code: fxcm | 2019-12-11 00:38:54.647 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 6 | 2019-12-11 00:38:54.647 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2019-12-11 00:38:54.718 SC DTC Data with Market Depth | Sending logon request message. | 2019-12-11 00:38:54.718 SC DTC Data with Market Depth | Received logon response. | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Successfully connected. | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Trading is not supported. | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2019-12-11 00:38:55.279 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2019-12-11 00:38:55.374 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2019-12-11 00:38:55.374 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2019-12-11 00:38:55.374 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2019-12-11 00:38:55.374 TD Ameritrade | Streamer request #1 initiated. | 2019-12-11 00:38:55.723 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-3 | 2019-12-11 00:38:55.921 TD Ameritrade | Total account balances are below 500. Must be >= 500 to use CME trading account required exchanges. | 2019-12-11 00:39:00.180 * HD Request # 5 | Downloading Intraday chart data for ESZ19 to the file ESZ19.scid. Service: tda | 2019-12-11 00:39:00.180 HD Request # 5 | Download start date-time: 2019-06-08 00:39:00.000 | 2019-12-11 00:39:00.181 HD Request # 5 | Requesting 186 days of historical Minute data. | 2019-12-11 00:39:00.181 HD Request # 5 | Error downloading historical Intraday data for ESZ19. Validation failed for 1 of 1 requests.Your request is not valid. | 2019-12-11 00:39:00.472 HD Request # 5 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ESZ19 | 2019-12-11 00:39:00.472 HD Request # 5 | Completion time: 0s | 2019-12-11 00:39:00.472 HD Request # 5 | Intraday data download complete for ESZ19. Unique request ID: 8 | 2019-12-11 00:39:00.472 Removing historical data download ID 8. | 2019-12-11 00:39:00.472 Real-time Intraday chart data file updates started for ESZ19 | 2019-12-11 00:39:00.472 Opened cached Intraday file: C:\SierraChart\Data\ESZ19.scid | 2019-12-11 00:39:00.472 Intraday chart data file opened for ESZ19 | 2019-12-11 00:39:00.472 Triggering next historical data download in queue. | 2019-12-11 00:39:00.472 HD Request # 4 | Re-requesting historical data for US30 to get the latest data since the download was started while not connected to primary service. | 2019-12-11 00:39:54.418 Added historical Intraday data request for US30 to the queue. | 2019-12-11 00:39:54.418 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2019-12-11 00:39:54.418 Triggering next historical data download in queue. | 2019-12-11 00:39:54.418 Socket (1) | CloseSocket call. | 2019-12-11 00:39:54.418 Historical data download thread signaled to stop. | 2019-12-11 00:39:54.418 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:39:54.418 HD Request # 4 | Received 5412371 records from 2019-07-19 11:05:22.000 to 2019-12-11 00:38:53.000 (144.6 days) and wrote 5412371 records for US30 | 2019-12-11 00:39:54.418 HD Request # 4 | Completion time: 1m 1s | 2019-12-11 00:39:54.418 HD Request # 6 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2019-12-11 00:39:54.418 HD Request # 6 | Download start date-time: 2019-12-11 00:38:53.000 | 2019-12-11 00:39:54.418 HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2019-12-11 00:39:54.419 Socket (4) | Creating socket. | 2019-12-11 00:39:54.419 Socket (4) | Connecting to IP: 65.182.172.42. | 2019-12-11 00:39:54.419 Socket (1) | Socket gracefully closed by remote side. | 2019-12-11 00:39:54.496 Socket (1) | Closed. | 2019-12-11 00:39:54.496 HD Request # 6 | Setting DTC encoding to Binary VLS | 2019-12-11 00:39:54.554 HD Request # 6 | Sending historical data logon request message. | 2019-12-11 00:39:54.554 HD Request # 6 | Requesting Intraday data. Start date-time: 2019-12-11 00:38:53. Record interval: 1. Symbol: US30 | 2019-12-11 00:39:54.610 HD Request # 6 | Decompressing data. | 2019-12-11 00:39:54.669 HD Request # 6 | Receiving Intraday data for US30 starting at 2019-12-11 00:38:53 | 2019-12-11 00:39:54.670 HD Request # 6 | Timestamp of first Intraday data file record written: 2019-12-11 00:38:53 | 2019-12-11 00:39:54.670 Socket (4) | CloseSocket call. | 2019-12-11 00:39:54.670 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:39:54.670 Historical data download thread signaled to stop. | 2019-12-11 00:39:54.671 HD Request # 6 | Received 61 records from 2019-12-11 00:38:53.000 to 2019-12-11 00:39:53.000 (60.0 seconds) and wrote 61 records for US30 | 2019-12-11 00:39:54.671 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2019-12-11 00:39:54.671 HD Request # 6 | Completion time: 0s | 2019-12-11 00:39:54.671 HD Request # 6 | Intraday data download complete for US30. Unique request ID: 3 | 2019-12-11 00:39:54.671 Removing historical data download ID 3. | 2019-12-11 00:39:54.671 Real-time Intraday chart data file updates started for US30 | 2019-12-11 00:39:54.671 Opened cached Intraday file: C:\SierraChart\Data\US30.scid | 2019-12-11 00:39:54.671 Intraday chart data file opened for US30 | 2019-12-11 00:39:54.671 Triggering next historical data download in queue. | 2019-12-11 00:39:54.671 HD Request # 7 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2019-12-11 00:39:54.671 HD Request # 7 | Download start date-time: 2019-10-18 09:47:01.000 | 2019-12-11 00:39:54.671 HD Request # 7 | Using server: ds4.sierracharts.com port 10150 | 2019-12-11 00:39:54.672 Socket (1) | Creating socket. | 2019-12-11 00:39:54.672 Socket (1) | Connecting to IP: 192.81.56.146. | 2019-12-11 00:39:54.672 Socket (4) | Socket gracefully closed by remote side. | 2019-12-11 00:39:54.733 Socket (4) | Closed. | 2019-12-11 00:39:54.733 HD Request # 7 | Setting DTC encoding to Binary VLS | 2019-12-11 00:39:54.834 HD Request # 7 | Sending historical data logon request message. | 2019-12-11 00:39:54.834 HD Request # 7 | Requesting Intraday data. Start date-time: 2019-10-18 09:47:01. Record interval: 1. Symbol: USOil | 2019-12-11 00:39:55.426 HD Request # 7 | Decompressing data. | 2019-12-11 00:39:55.508 HD Request # 7 | Receiving Intraday data for USOil starting at 2019-10-18 09:47:01 | 2019-12-11 00:39:55.787 HD Request # 7 | Timestamp of first Intraday data file record written: 2019-10-18 09:47:01 | 2019-12-11 00:39:55.787 Socket (1) | CloseSocket call. | 2019-12-11 00:40:03.738 Historical data download thread signaled to stop. | 2019-12-11 00:40:03.738 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:40:03.738 HD Request # 7 | Received 725857 records from 2019-10-18 09:47:01.000 to 2019-12-11 00:40:01.000 (53.6 days) and wrote 725857 records for USOil | 2019-12-11 00:40:03.738 Added 2 Time and Sales records to Intraday data file for USOil after download. | 2019-12-11 00:40:03.738 HD Request # 7 | Completion time: 9s | 2019-12-11 00:40:03.738 HD Request # 7 | Intraday data download complete for USOil. Unique request ID: 4 | 2019-12-11 00:40:03.738 Removing historical data download ID 4. | 2019-12-11 00:40:03.738 Real-time Intraday chart data file updates started for USOil | 2019-12-11 00:40:03.738 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid | 2019-12-11 00:40:03.738 Intraday chart data file opened for USOil | 2019-12-11 00:40:03.738 Triggering next historical data download in queue. | 2019-12-11 00:40:03.738 HD Request # 8 | Downloading Historical Daily chart data for EURUSD. Starting date: 2016-08-10. Service: fxcm | 2019-12-11 00:40:03.739 HD Request # 8 | Using server: ds3.sierracharts.com port 10149 | 2019-12-11 00:40:03.740 Socket (4) | Creating socket. | 2019-12-11 00:40:03.740 Socket (4) | Connecting to IP: 65.182.172.42. | 2019-12-11 00:40:03.740 Socket (1) | Socket gracefully closed by remote side. | 2019-12-11 00:40:03.818 Socket (1) | Closed. | 2019-12-11 00:40:03.818 HD Request # 8 | Setting DTC encoding to Binary VLS | 2019-12-11 00:40:03.874 HD Request # 8 | Sending historical data logon request message. | 2019-12-11 00:40:03.874 HD Request # 8 | Requesting historical Daily data starting at 2016-08-10. | 2019-12-11 00:40:03.931 HD Request # 8 | Decompressing data. | 2019-12-11 00:40:03.989 HD Request # 8 | Receiving historical Daily data for EURUSD starting at 2016-08-10 | 2019-12-11 00:40:04.165 HD Request # 8 | Writing historical Daily data to the file EURUSD.dly | 2019-12-11 00:40:04.165 Socket (4) | CloseSocket call. | 2019-12-11 00:40:04.195 Socket (4) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:40:04.196 Historical data download thread signaled to stop. | 2019-12-11 00:40:04.196 HD Request # 8 | Received 868 records from 2016-08-10 00:00:00 to 2019-12-11 00:00:00 (3.3years) and wrote 868 records for EURUSD | 2019-12-11 00:40:04.196 HD Request # 8 | Completion time: 0s | 2019-12-11 00:40:04.196 HD Request # 8 | Daily data download complete for EURUSD. Unique request ID: 6 | 2019-12-11 00:40:04.196 Removing historical data download ID 6. | 2019-12-11 00:40:04.196 Triggering next historical data download in queue. | 2019-12-11 00:40:04.196 HD Request # 9 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2019-12-11 00:40:04.196 Compressing file: C:\SierraChart\Data\EURUSD.scid. This may take a while. | 2019-12-11 00:40:04.196 HD Request # 9 | Download start date-time: 2019-06-08 00:40:04.000 | 2019-12-11 00:40:04.196 HD Request # 9 | Using server: ds4.sierracharts.com port 10150 | 2019-12-11 00:40:04.196 Socket (1) | Creating socket. | 2019-12-11 00:40:04.196 Socket (1) | Connecting to IP: 192.81.56.146. | 2019-12-11 00:40:04.197 Socket (4) | Socket gracefully closed by remote side. | 2019-12-11 00:40:04.253 Socket (4) | Closed. | 2019-12-11 00:40:04.253 HD Request # 9 | Setting DTC encoding to Binary VLS | 2019-12-11 00:40:04.364 HD Request # 9 | Sending historical data logon request message. | 2019-12-11 00:40:04.364 HD Request # 9 | Requesting Intraday data. Start date-time: 2019-06-08 00:40:04. Record interval: 1. Symbol: EURUSD | 2019-12-11 00:40:04.440 HD Request # 9 | Decompressing data. | 2019-12-11 00:40:04.520 EURUSD[M] Daily #7 | Reloading chart. | 2019-12-11 00:40:04.684 HD Request # 9 | Receiving Intraday data for EURUSD starting at 2019-06-09 21:00:15 | 2019-12-11 00:40:04.898 HD Request # 9 | Timestamp of first Intraday data file record written: 2019-06-09 21:00:15 | 2019-12-11 00:40:04.898 Socket (1) | CloseSocket call. | 2019-12-11 00:40:48.110 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:40:48.110 Historical data download thread signaled to stop. | 2019-12-11 00:40:48.110 HD Request # 9 | Received 5049014 records from 2019-06-09 21:00:15.000 to 2019-12-11 00:40:41.000 (184.2 days) and wrote 5049014 records for EURUSD | 2019-12-11 00:40:48.111 Added 2 Time and Sales records to Intraday data file for EURUSD after download. | 2019-12-11 00:40:48.111 HD Request # 9 | Completion time: 44s | 2019-12-11 00:40:48.111 HD Request # 9 | Intraday data download complete for EURUSD. Unique request ID: 7 | 2019-12-11 00:40:48.111 Removing historical data download ID 7. | 2019-12-11 00:40:48.111 Real-time Intraday chart data file updates started for EURUSD | 2019-12-11 00:40:48.111 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid | 2019-12-11 00:40:48.111 Intraday chart data file opened for EURUSD | 2019-12-11 00:40:48.111 Triggering next historical data download in queue. | 2019-12-11 00:40:48.111 HD Request # 10 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2019-12-11 00:40:48.111 HD Request # 10 | Download start date-time: 2019-12-11 00:38:49.000 | 2019-12-11 00:40:48.111 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2019-12-11 00:40:48.111 Socket (5) | Creating socket. | 2019-12-11 00:40:48.111 Socket (5) | Connecting to IP: 65.182.172.42. | 2019-12-11 00:40:48.112 Socket (1) | Socket gracefully closed by remote side. | 2019-12-11 00:40:48.190 Socket (1) | Closed. | 2019-12-11 00:40:48.190 HD Request # 10 | Setting DTC encoding to Binary VLS | 2019-12-11 00:40:48.241 HD Request # 10 | Sending historical data logon request message. | 2019-12-11 00:40:48.241 HD Request # 10 | Requesting Intraday data. Start date-time: 2019-12-11 00:38:49. Record interval: 1. Symbol: XAUUSD | 2019-12-11 00:40:48.297 HD Request # 10 | Decompressing data. | 2019-12-11 00:40:48.355 HD Request # 10 | Receiving Intraday data for XAUUSD starting at 2019-12-11 00:38:49 | 2019-12-11 00:40:48.356 HD Request # 10 | Timestamp of first Intraday data file record written: 2019-12-11 00:38:49 | 2019-12-11 00:40:48.357 Socket (5) | CloseSocket call. | 2019-12-11 00:40:48.357 Socket (5) | Shutdown started. Waiting for graceful close. | 2019-12-11 00:40:48.357 Historical data download thread signaled to stop. | 2019-12-11 00:40:48.358 HD Request # 10 | Received 110 records from 2019-12-11 00:38:49.000 to 2019-12-11 00:40:47.000 (118.0 seconds) and wrote 110 records for XAUUSD | 2019-12-11 00:40:48.358 Added 13 Time and Sales records to Intraday data file for XAUUSD after download. | 2019-12-11 00:40:48.358 HD Request # 10 | Completion time: 0s | 2019-12-11 00:40:48.358 HD Request # 10 | Intraday data download complete for XAUUSD. Unique request ID: 9 | 2019-12-11 00:40:48.358 Removing historical data download ID 9. | 2019-12-11 00:40:48.358 Real-time Intraday chart data file updates started for XAUUSD | 2019-12-11 00:40:48.358 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid | 2019-12-11 00:40:48.358 Intraday chart data file opened for XAUUSD | 2019-12-11 00:40:48.358 Triggering next historical data download in queue. | 2019-12-11 00:40:48.358 Socket (5) | Socket gracefully closed by remote side. | 2019-12-11 00:40:48.419 Socket (5) | Closed. | 2019-12-11 00:40:48.419 ROKU 1 Min #1 | Reloading chart. | 2019-12-11 00:40:49.944 ROKU 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\roku.scid | 2019-12-11 00:40:49.959 TD Ameritrade | Starting real-time market data updates for: ROKU. ID: 7 Service code: equities.us | 2019-12-11 00:40:50.445 TD Ameritrade | Requesting security definition data for: ROKU. ID: 7 | 2019-12-11 00:40:50.445 TD Ameritrade | Using primary service for historical data for ROKU | 2019-12-11 00:40:50.445 Added historical Intraday data request for ROKU to the queue. | 2019-12-11 00:40:50.445 Intraday data recording state for symbol ROKU is set to download 'Pending'. | 2019-12-11 00:40:50.445 Triggering next historical data download in queue. | 2019-12-11 00:40:50.445 Delaying start of download for ROKU | 2019-12-11 00:40:50.445 TD Ameritrade | Old streamer request finished. Request ID: 1. | 2019-12-11 00:40:51.443 TD Ameritrade | Streamer request #2 initiated. | 2019-12-11 00:40:52.449 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-3 | 2019-12-11 00:40:52.656 HTTPS connection ID:1 to streamer-ext-bin.tdameritrade.com:443 for request ID:1 (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-12-11 00:40:52.658 * HD Request # 11 | Downloading Intraday chart data for ROKU to the file ROKU.scid. Service: equities.us | 2019-12-11 00:40:57.183 HD Request # 11 | Download start date-time: 2019-06-08 00:40:57.000 | 2019-12-11 00:40:57.183 HD Request # 11 | Requesting 186 days of historical Minute data. | 2019-12-11 00:40:57.183 HD Request # 11 | Error downloading historical Intraday data for ROKU. Validation failed for 1 of 1 requests.Your request is not valid. | 2019-12-11 00:40:57.373 HD Request # 11 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ROKU | 2019-12-11 00:40:57.373 HD Request # 11 | Completion time: 0s | 2019-12-11 00:40:57.374 HD Request # 11 | Intraday data download complete for ROKU. Unique request ID: 10 | 2019-12-11 00:40:57.374 Removing historical data download ID 10. | 2019-12-11 00:40:57.374 Real-time Intraday chart data file updates started for ROKU | 2019-12-11 00:40:57.374 Opened cached Intraday file: C:\SierraChart\Data\ROKU.scid | 2019-12-11 00:40:57.374 Intraday chart data file opened for ROKU | 2019-12-11 00:40:57.374 Triggering next historical data download in queue. | 2019-12-11 00:40:57.374 |
[2019-12-11 01:00:13] |
We cannot help you accessing any stock data from TD Ameritrade. We no longer provide technical support for TD Ameritrade. If you just need CME group of futures, we recommend using the Denali Exchange Data Feed: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-11 01:36:15] |
hi john, technical support for td doesnt end unti 12/31. why are you not able to help me? |
[2019-12-12 05:27:52] |
The basic reason is you are encountering an error on the Ameritrade side that we do not have any control over. This is out of our control. Also there is a difference between the ending of technical integration to Ameritrade which is caused by Ameritrade themselves and providing technical support from us. And we have stated for years now on the TD Ameritrade page on the Sierra Chart the website that we may not provide support for TD Ameritrade issues. Effectively TD Ameritrade support has been discontinued for years. This has been made abundantly clear for years now. We want you to switch to the Sierra Chart historical data service so you can access delayed historical data: Sierra Chart Historical Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
