Date/Time: Sat, 12 Sep 2026 14:55:16 +0000
CQG WebAPI 'Username or Password is incorrect'
View Count: 2275
[2019-12-09 21:03:04]
TT46 - Posts: 10
I've received a set of new live CGQ WebAPI credentials from my FCM, Advantage Futures. I've entered the correct login and password information but cannot connect. I just renewed my Level 5 SC service package on Friday night for another 3 months. Wondering if the connection is related to my SC account?
Thank You
[2019-12-09 22:30:54]
John - SC Support - Posts: 47854
Everything about your Sierra Chart account looks good. We see you are on Package 5 and that your current ending date is March 09, 2020. You can follow these instructions to ensure that your software has the latest information from our servers, but this is not the problem:
Sierra Chart - Software Login Instructions: Forced Login
Try re-entering your CQG Username and Password on the Data/Trade Service Settings window. Refer to the following information:
CQG Trading Platform Service: Setup Instructions
If you still have problems after going through the above, then follow these instructions to get us your Message Log.
Reconnect to the data feed:
[2019-12-09 23:06:58]
TT46 - Posts: 10
Software version: 2021 64-bit | 2019-12-09 15:05:21.882
Usage end date: 2020-03-09 | 2019-12-09 15:05:21.882
Enabled for: Advanced Features 2. | 2019-12-09 15:05:21.882
Enabled for: Sierra Chart Historical Data Service. | 2019-12-09 15:05:21.882
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2019-12-09 15:05:21.882
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-12-09 15:05:21.882
Message log attached below.
"Current selected Data/Trading service: CQG WebAPI | 2019-12-09 15:05:21.882
Custom symbol settings values: disabled | 2019-12-09 15:05:21.882
Chart Update Interval: 250 | 2019-12-09 15:05:21.882
Intraday Data Storage Time Unit: 0 | 2019-12-09 15:05:21.882
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-12-09 15:05:21.882
2019-12-09 15:05:21 Local computer time | 2019-12-09 15:05:21.882
2019-12-09 23:05:21 Local computer time in UTC | 2019-12-09 15:05:21.882
2019-12-09 15:05:21 Local computer time in SC Time Zone | 2019-12-09 15:05:21.882
2019-12-09 23:00:20 Server time in UTC | 2019-12-09 15:05:21.882
Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-12-09 15:05:21.882
Program path: C:\SierraChart\ | 2019-12-09 15:05:21.882
Data Files path: C:\SierraChart\Data\ | 2019-12-09 15:05:21.882
OS Version Number: 10.0 | 2019-12-09 15:05:21.882
Locale Setting: C | 2019-12-09 15:05:21.882
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-12-09 15:05:21.882
CQG WebAPI | Connecting to server api.cqg.com | 2019-12-09 15:05:42.812
CQG WebSocket | Connecting to WebSocket server api.cqg.com:443 | 2019-12-09 15:05:42.812
CQG WebSocket socket (1) | Creating socket. Using TLS 1.2. | 2019-12-09 15:05:42.884
CQG WebSocket socket (1) | Connecting to IP: 208.48.16.35. | 2019-12-09 15:05:42.884
CQG WebSocket | Opening WebSocket. | 2019-12-09 15:05:42.956
CQG WebSocket | Sending WebSocket handshake. | 2019-12-09 15:05:42.956
CQG WebSocket | Server header | HTTP/1.1 101 Switching Protocols | 2019-12-09 15:05:43.240
CQG WebSocket | Server header | Connection: upgrade | 2019-12-09 15:05:43.240
CQG WebSocket | Server header | Sec-WebSocket-Accept: +ltabgf8Co67B/djNDJJ2eBNbfA= | 2019-12-09 15:05:43.240
CQG WebSocket | Server header | Server: WebSocket++/0.7.0 | 2019-12-09 15:05:43.240
CQG WebSocket | Server header | Upgrade: websocket | 2019-12-09 15:05:43.240
CQG WebSocket | Server header | | 2019-12-09 15:05:43.240
CQG WebSocket | Web socket state is now open. | 2019-12-09 15:05:43.240
CQG WebAPI | WebSocket connected. | 2019-12-09 15:05:43.240
CQG WebAPI | Sending market data logon message. | 2019-12-09 15:05:43.240
CQG WebAPI | Market data logon unsuccessful. Server message: Username or password is incorrect. | 2019-12-09 15:05:43.401
CQG WebSocket socket (1) | CloseSocket call. | 2019-12-09 15:05:43.426
CQG WebAPI | Disconnected. | 2019-12-09 15:05:43.426
CQG WebSocket | WebSocket closed. | 2019-12-09 15:05:43.427
CQG WebAPI | WebSocket closed. | 2019-12-09 15:05:43.427
CQG WebSocket socket (1) | Write in progress. Shutdown being delayed. | 2019-12-09 15:05:43.427
CQG WebSocket socket (1) | Write has completed. Shutdown being performed. | 2019-12-09 15:05:43.505
CQG WebSocket socket (1) | Shutdown started. Waiting for graceful close. | 2019-12-09 15:05:43.505
CQG WebSocket socket (1) | Socket gracefully closed by remote side. | 2019-12-09 15:05:43.586
CQG WebSocket socket (1) | Closed. | 2019-12-09 15:05:43.586"
[2019-12-09 23:24:08]
As this line shows, the Username or Password is still incorrect:
This message is from CQG and not something we create on our own.
Check with your broker and ensure that you have the correct credentials.
[2019-12-09 23:30:14]
TT46 - Posts: 10
Thank You John, I will circle back with Advantage Futures.
