Date/Time: Mon, 06 May 2024 01:29:38 +0000
Live data
View Count: 482
[2019-12-03 15:30:15] |
BenjFlame - Posts: 305 |
Hello, My CME data is currently delayed when I connect to sierra chart data feed. I'm confused as to why. I connected to the CQG broker to activate the non pro reduced fees, but when I get back on Sierra chart feed data is delayed. Why is that? Is it because I have paid for feed at end of month and now I must pay again? Please clarify. Also I wish to know what is the difference between the Daneli feed, and the regular Sierra Chart real time feed. For CME. Don't they both come from barchart? I read on the board that you have "more freedom" with Daneli feed. Please clarify as I want the best CME feed. Thanks, |
[2019-12-03 15:38:49] |
Make sure you have Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds enabled. If you still have a problem follow the below instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog ---- For CME. Don't they both come from barchart? No. The data comes directly from the CME in each case. The difference just has to do with the vendor of record and the network infrastructure. The network infrastructure is better with the Denali feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-03 15:39:12
