Date/Time: Sun, 19 May 2024 02:02:02 +0000
[User Discussion] - Button size too small
View Count: 863
[2019-10-07 08:24:00] |
User458568 - Posts: 2 |
I have loaded Sierra chart onto my new computer. The buttons that are image (like hand tool or line tool) are veru small and I don't seem to e able to find how to adjust them.
[2019-10-07 11:32:48] |
Mack - Posts: 83 |
Global settings > Graphic Settings - Global > Fonts Tab You can change the "Control Bar Text" size to say 14, to make the buttons and text bigger. |
[2019-10-07 11:59:30] |
It only makes the text font larger. The non-text button (like hand tool) are still small after doing that.
[2019-10-07 16:37:06] |
You cannot make the image graphics larger. This is why you need to choose text (Use Caption option) instead for the buttons that have graphics. Refer to the documentation here for this: Control Bar: Control Bar Button Properties And for anyone else reading this, this is the reason why the default for all the buttons was being made a couple of months ago as text precisely to avoid this problem and if someone still wants to choose the smaller images they can still do that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-10-07 16:40:12
