Date/Time: Fri, 21 Aug 2026 04:17:19 +0000
Problem Connecting to Denali
View Count: 1365
[2019-09-29 14:18:24]
User982025 - Posts: 5
Guys, I'm having a problem connecting to The Denali data feed (all services). Sierra installed last week. This is a new set up.
Below is my Message log. Thanks in advance.
Software version: 1991 64-bit | 2019-09-29 10:12:42.925
Usage end date: 2019-10-29 | 2019-09-29 10:12:42.925
Enabled for: Advanced Features 2. | 2019-09-29 10:12:42.925
Enabled for: Sierra Chart Historical Data Service. | 2019-09-29 10:12:42.925
Enabled for: Denali Real-Time Exchange Data Feed. | 2019-09-29 10:12:42.925
Enabled for exchange2: CME | 2019-09-29 10:12:42.925
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-09-29 10:12:42.925
Current selected Data/Trading service: CTS T4 FIX | 2019-09-29 10:12:42.925
Custom symbol settings values: enabled | 2019-09-29 10:12:42.925
Chart Update Interval: 500 | 2019-09-29 10:12:42.925
Intraday Data Storage Time Unit: 0 | 2019-09-29 10:12:42.925
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2019-09-29 10:12:42.925
2019-09-29 10:12:42 Local computer time | 2019-09-29 10:12:42.925
2019-09-29 14:12:42 Local computer time in UTC | 2019-09-29 10:12:42.925
2019-09-29 10:12:42 Local computer time in SC Time Zone | 2019-09-29 10:12:42.925
2019-09-29 14:10:40 Server time in UTC | 2019-09-29 10:12:42.925
Local computer UTC time and Server UTC time difference: 0 seconds. | 2019-09-29 10:12:42.925
Program path: C:\SierraChart\ | 2019-09-29 10:12:42.925
Data Files path: C:\SierraChart\Data\ | 2019-09-29 10:12:42.925
OS Version Number: 10.0 | 2019-09-29 10:12:42.926
Locale Setting: C | 2019-09-29 10:12:42.926
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-09-29 10:12:42.927
CTS T4 FIX | Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2019-09-29 10:14:41.878
CTS T4 FIX | Firm: 895 | 2019-09-29 10:14:41.878
CTS FIX socket (1) | Creating socket. Using TLS 1.0. | 2019-09-29 10:14:41.928
CTS FIX socket (1) | Connecting to IP: 69.44.110.200. | 2019-09-29 10:14:41.928
CTS FIX: Connected to FIX server. | 2019-09-29 10:14:41.963
CTS FIX | Sending the Logon message. LocalCompID=SierraChart | 2019-09-29 10:14:42.162
CTS FIX socket (1) | Socket gracefully closed by remote side. | 2019-09-29 10:14:42.287
CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2019-09-29 10:14:42.289
CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2019-09-29 10:14:42.289 *
CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2019-09-29 10:14:42.289 *
CTS FIX: Sending a Logout message. Text = Received Logout message. | 2019-09-29 10:14:42.289
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-09-29 10:14:42.289
CTS FIX socket (1) | Write in progress. Shutdown being delayed. | 2019-09-29 10:14:42.289
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-09-29 10:14:42.290
CTS T4 FIX | Disconnected. | 2019-09-29 10:14:42.303
CTS FIX socket (1) | Write has completed. Shutdown being performed. | 2019-09-29 10:14:42.326
CTS FIX socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-09-29 10:14:42.326
CTS FIX socket (1) | Closed. | 2019-09-29 10:14:42.326
[2019-09-29 17:24:48]
What we see is that you are having trouble connecting to CTS :
Did you want to connect to CTS or just to the market data feed only? Do you have a CTS account?
[2019-09-29 22:29:32]
I have trading account at Cunningham commodities, I want to clear my trades there using Sierra. I am told I can route them there using CTS for a 0.10 cent routing fee.
[2019-09-30 15:12:32]
We did have an order routing option for CTS where the per contract fill fee was .10 but there too much complexity in the set up of it so we stopped offering it. But you can use the standard set up which is documented here:
https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions
You should not have any trouble with it. Just make sure you have the right username and password and firm and the Server setting is set correctly.
And then you can ask CTS what they can do in regards to the per contract order fill fees. See if they can give you the .10 cost.
Date Time Of Last Edit: 2019-09-30 15:13:03
