Date/Time: Tue, 04 Nov 2025 11:00:16 +0000
[User Discussion] [Locked] - Bid/Ask volume data on 15 Range candle
View Count: 3927
[2019-12-13 21:59:00]
User287553 - Posts: 33
hi
i tried adding the 'spreadsheet system for trading' and played around with it for a bit, but found it a bit overwhelming. So i removed that THIS study. However, now when i try to 'replay' the chart, and click on the 'replay chart control panel' from the drop down list associated with the chart replay function, nothing happens? previously when i clicked on this, a new chart replay panel will popup and i could reply the chart, but not anymore.
How can I get the chart replay function back?
appreciate response.
JK
[2019-12-13 22:02:43]
John - SC Support - Posts: 42737
Refer to the following:
Replaying Charts: Chart Replay Window Not Visible
[2019-12-16 22:59:56]
Hi
I've applied the 'spreadsheet system for trading' study and have tried my best to follow the instructions but when i run the replay, no buy or sell order gets placed. I've checked that 'auto trading is enabled in Global settings as well as the Trade settings for the chart. Neither am I getting any messages in the Trade Service Log that can help me understand that why the orders are not being placed when the conditions are true for buy and sell. FYI - im using the 'attached order' feature for trading from the charts.
The formula that i normally would use for a BUY condition condition is AND(ID74.SG1>ID17.SG1,C>ID74.SG3,ID67.SG1>0,ID35.SG1>ID55.SG1,ID32.SG1>0,ID33.SG1>ID34.SG1).
But since this is being applied in the spread sheet system so I've tried two different combinations (see below) but none generate a buy order, neither do I see any arrows on the chart.
AND(AD3>AA3,C>AF3,AH3>0,AJ3>AL3,AN3>0,AP3>AR3)
AND(ID74.SG1@3>ID17.SG1@3,C>ID74.SG3@3,ID67.SG1@3>0,ID35.SG1@3>ID55.SG1@3,ID32.SG1@3>0,ID33.SG1@3>ID34.SG1@3)
appreciate if you could point me in the right direction. Any videos on this will be grateful.
JK
[2020-03-19 14:19:41]
Hi
I'm a Canadian living in Canada, using AMP Futures as my broker to trade futures using Sierra Platform. I wanted to know which BROKER I can use in Canada as a Canadian, if I want to trade Futures, Stocks,Options,and ETFs while continuing to use Sierra Software. And any broker that you suggest, will they have the data feed for me to be able to these instruments while using Sierra.
JK
[2020-03-22 22:31:00]
Hi
what type of Data Feed will I require if I want to use Sierra Charts to be able to see LIVE data (level I & II) and charts for US and Canadian Stocks, and ETFs? ad How much will it cost for this type of data feed, and how can I enable this data feed?
I currently use AMP futures and have live data for Futures without any extra monthly fee.
Appreciate response.
JK
[2020-03-23 21:27:28]
Hi
With recent volatility, I'm trying to put a formula on my charts by using 'color bar based on alert condition' study, so that when current price is <> then 5% it can color the price bars/candles for me. I'm trading on 24hour sessions, and will use the 'previous close' as a reference. I know i have to multiply the previous close study with 5 percent. But am struggling to find the right lingo in the formula. Can you kindly assist or point me towards the right formula to do this?
please and thank you.
JK
[2020-04-28 19:22:26]
hi GUYS,
just had a quick question regarding a formula in Sierra. When using a 5 minute candle chart, I know how to plot the delta and volume study values for each individual candle either below or top of the candle.
However, i'm not sure how can I plot the cumulative/total delta and volume study values for each up/down swing on my 5 min chart. What formula can I use to capture this info?
JK
[2020-04-28 19:26:58]
You need to use the Sierra Chart Exchange Data Feed:
But it does not provide level 2 data for stocks/equities.
Have a look at this study:
Zig Zag Cumulative Volume
It is able to calculate the Ask Volume Bid Volume difference across a zig zag line.
Date Time Of Last Edit: 2020-04-28 19:30:35
[2020-06-05 16:32:49]
Hi
hope your team is doing well during these trying times.
Quick question - i'm using bid/ask data to be displayed in the price candle e.g. 8range chart. But when I try to make the increase and/or decrease the spacing between the price candles the bid/ask data becomes crunched or too small. Is their a way to keep the bid/ask font size constant? for e.g. a 12 font size? how can this be done?
JK
[2020-10-30 18:55:22]
Hi
What are the symbols for market internals like $TICK, UpVolume versus DownVolume, Advance/Decline in Sierra? And how can I insert these on my charts for e.g. are these under the indicators section or somewhere else?
JK
[2020-10-30 19:13:16]
Ackin - Posts: 1865
Look:
Accummulated Delta in the ZigZag Study
What are the symbols for market internals like $TICK, UpVolume versus DownVolume, Advance/Decline in Sierra? And how can I insert these on my charts for e.g. ?
All of the symbols can be found here:
Sierra Chart Market Statistics: Symbols
Changing the Symbol of a Chart or Trade DOM Through Chart Settings
Changing the Symbol of a Chart: Changing the Symbol of a Chart or Trade DOM Through Chart Settings
Date Time Of Last Edit: 2020-10-30 19:17:48
[2020-12-05 12:23:45]
Hi ...hope your team is doing well. Is their an indicator in Sierra or from another vendor that I can use to plot the upcoming NEWS events on my charts? appreciate response.
JK
[2020-12-29 19:43:52]
Hi
want to know if there's a way in Sierra to save a set of studies that I'm already using on a given chart for e.g. like a template, so that I can apply the same set of studies to another chart, without adding each study one by one. And how to do this?
[2021-02-03 04:07:34]
Hi. I started having data lag issues after December 28, 2020 b/w my 10min and range charts especially for Micro ES & NQ. So changed my data feed from CQG to Denali. Still having the same issues which is messing up my buy/sell market entries and even trailing if stop loss. The lag is worse (3-6 seconds or more) when markets are fast/volatile. I’ve looked at your help support section but nothing is helping.
Please advise as I’m paying $20 monthly for Denali datafeed which was supposed to have solved this issue.
Appreciate response ASAP. Thanks.
JK
[2021-02-03 07:31:22]
Refer to:
Study Collections
Regarding post #38 and a data lag, there can be some different reasons. Refer to all of help topic 4:
Prices / Data Falling Behind
And also specifically refer to:
Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds
We are now locking this thread. It is getting too long. Start a new thread if necessary.
Date Time Of Last Edit: 2021-02-03 08:02:14
