Date/Time: Sun, 05 May 2024 06:31:48 +0000
Cant find micro contracts
View Count: 1242
[2019-08-20 23:50:11] |
user10000 - Posts: 41 |
Looking for the micro es contracts but they arent in the list. i did updated it from server and still no luck. what is the symbol im looking for micro es? i have cme group package from amp futures
[2019-08-21 13:25:51] |
any updates on this?
[2019-08-21 16:14:40] |
John - SC Support - Posts: 31362 |
They should be there, and we see them in the list when we pull it up for both Rithmic and CQG. For example, if you are looking for the Micro ES (MES), then if you are using CQG for your data, it would be under the Futures section with a symbol of F.US.MES?##. If you are using Rithmic for your data, then it would be under the Futures section with a symbol of MES?#-CME. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-21 18:24:59
[2019-08-21 16:23:16] |
i am using cgq and couldnt find that symbol under futures. i attached the symbols under futures. also searched the other lists and did not find it
micro2.JPG / V - Attached On 2019-08-21 16:21:37 UTC - Size: 167.97 KB - 248 views micro3.JPG / V - Attached On 2019-08-21 16:21:58 UTC - Size: 158.6 KB - 233 views |
[2019-08-21 16:56:42] |
Very interesting. Try typing in MES in the Search box at the bottom of the Find Symbol window and then click on Find Next. Let us know if that is able to find the symbol. Refer to the information on this page for more information on how to use that search function: File Menu: Searching for Available Symbols Another thing to also try is just typing in the symbol you are looking for in the Selected Symbol area. In this case, you would type in F.US.MESU19 for the September contract. Refer to this section for more information on entering this information: File Menu: Find Symbol (File) If these do not work, then select File >> Data/Trade Service Settings and let us know what the service is set to at the top of that window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-21 18:08:45] |
Regarding post #4, none of those symbol lists are for CQG. Sierra Chart is not set to use CQG. Follow the CQG set up instructions here: CQG Trading Platform Service: Setup Instructions After you do that, you will find the micro symbols in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-21 18:25:45
[2019-08-21 18:22:28] |
this the only option given to me as it is grayed out (pic attached) i logged in using my cqg under DTC sub Instance Date Time Of Last Edit: 2019-08-21 18:25:51
micro1.JPG / V - Attached On 2019-08-21 18:20:52 UTC - Size: 27.67 KB - 239 views |
[2019-08-21 18:26:23] |
This is a sub instance of Sierra Chart. Exit all running instances of Sierra Chart on your computer and start Sierra Chart again. And make sure the main instance of Sierra Chart is set to use CQG. Link to the instructions are given above. Also we have no idea how you got into a situation like that. We have never seen this before. There is only one access log entry for your account with that sub instance. Does not make any sense. Do not use a sub instance for now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-21 18:27:36
