Date/Time: Wed, 01 May 2024 15:12:09 +0000
DTC custom server - SECURITY_DEFINITION_RESPONSE
View Count: 596
[2019-08-15 12:55:57] |
Guilherme - Posts: 66 |
I have my own DTC server, and send to SierraChart SECURITY_DEFINITION_RESPONSE messages after the Logon process is complete. Some data services, like the SC Data service, also send other information for the symbol, like "Use Pattern Matching", "Contract Months", and so one. How do I also send this information to SierraChart? Is this information not included in the core DTC protocol messages and fields? Another question is about the button "Update From Server" that exists in Symbol Settings screen. When I click it, I get nothing on my DTC server. No message at all. Is there something I'm missing? []s Guilherme Date Time Of Last Edit: 2019-08-15 12:57:48
[2019-08-16 17:36:01] |
In all cases Symbol Settings are downloaded from the Sierra Chart Web server. They do not come from a DTC server. Those fields are not supported by the DTC protocol. Another question is about the button "Update From Server" that exists in Symbol Settings screen. When I click it, I get nothing on my DTC server. No message at all. This does not interact with the DTC server in any way.You really would need to prepare an XML file with the Symbol Settings and provide that to us and we would have to set up your service as a separate listed service within Sierra Chart. For an example of the format, look at the XML files in the SymbolSettings subfolder with the Sierra Chart installation folder. Or we could support a website address where we could fetch the XML file, in the DTC service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-16 18:43:18
