Date/Time: Wed, 24 Apr 2024 12:29:04 +0000
Notice: New Service Packages Bundling CME data
View Count: 14180
[2019-09-12 07:46:06] |
There is no difference between the two data feeds other than the exchanges.
[2019-09-12 08:42:44] |
markyj - Posts: 5 |
Ok thanks. Just wanted to check as in post #66 this was commented on. "Yes. And actually it is probably better but in general the same." |
[2019-09-12 08:45:42] |
Yes it is the same, but the connectivity for the CME multicast feeds is through a different provider which is always regarded as better, but from an end-user perspective it does not matter.
[2019-10-17 09:42:49] |
User590016 - Posts: 50 |
Do you have a list of the FCM (Futures commission Merchant) supporting/offering your data feed for live trading ? (Denali & Sierra Chart Exchange Data Feed)
[2019-10-17 10:55:00] |
The Denali data feed can be used no matter what FCM you use.
[2019-10-31 19:36:37] |
User379468 - Posts: 508 |
1. Is SC Feed/SC Order Routing still the overall most reliable setup available for live trading now in November 2019, and in the near future? 2. Can SC Feed be offered for same price/symbol limit/number of connections included for multiple sub-instances as Denali Feed for users who want the option for ICE/EUREX? 3. Any update on ICE/EUREX delayed streaming intraday? CQG was able to do this for ICE. Date Time Of Last Edit: 2019-11-01 19:36:24
[2019-11-19 19:28:04] |
User631553 - Posts: 1 |
i just wonder if i subscribe Denali Exchange Datafeed, does it contain Advanced Features ( service Package 5) ? or i still need get 5-Advanced 36/month + Denali Exchange Data feed together 25/months ? |
[2019-11-19 19:50:37] |
User390455 - Posts: 56 |
Yes, For Real Time : SC Package5 (36$/month) + Denali (25$/Month) + Exchange Data Feed (For exemple, 15.75$/month CME Package non pro) If your are fine with delayed data you need just SC Package5 (36$/month). |
[2019-11-20 04:10:00] |
or i still need get 5-Advanced 36/month + Denali Exchange Data feed together 25/months ? Yes.
[2019-11-26 18:36:58] |
grayfrog - Posts: 35 |
Could you please clarify the "Sierra Chart Futures Order Routing Service With Data"? Is this a separate fee (other than the $0.10 order routing fee) in addition to the platform fee (service package), Sierra Chart Exchange Data Feed fee and the actual Exchange fee? Thank you. |
[2019-11-26 19:02:53] |
Is this a separate fee (other than the $0.10 order routing fee) in addition to the platform fee (service package), Sierra Chart Exchange Data Feed fee and the actual Exchange fee? The only additional cost is the .10 per contract fee for order routing. And there is the cost for Sierra Chart, and there is the cost for the data feed.
