Date/Time: Sun, 19 May 2024 14:29:54 +0000
Bitmex execInst
View Count: 1410
[2018-10-29 12:08:14] |
User465507 - Posts: 74 |
There's a little change I think you can make which'll have a huge impact on your users. There's a 'Close' flag that your software supports. It's slightly different from 'ReduceOnly' in that you don't have to specify order Qty. If no order Qty is specified Bitmex will automatically close your full position and it's not subject to load shedding (which is a serious problem on Bitmex). This will let people get out of their position with a much higher chance of success. See https://blog.bitmex.com/api_announcement/load-shedding-and-close-execinst/ I noticed Sierra always sends some default order Qty even if none is specified, which makes sense, but in this specific instance it's a big disadvantage. |
[2018-10-29 21:09:12] |
Yes, I'm using the latest pre-release (1831) It sends the 'Close' flag but specifies order quantity. This is subject to load shedding. |
[2018-10-30 01:56:04] |
We did have to specify the quantity because we cannot send an order without a quantity but we determined another solution to this. This will be out tomorrow or the next day.
[2020-02-16 18:09:01] |
T44 - Posts: 363 |
Is there an update on this feature please?
[2020-02-25 08:39:46] |
User870514 - Posts: 25 |
One more for this please.
