Date/Time: Tue, 07 May 2024 16:44:54 +0000
Additional qty numbers color input line for the Market Depth Historical Graph study
View Count: 772
[2018-07-29 19:32:35] |
User50927 - Posts: 90 |
Not long ago the company Bookmap added the option to use three colors in the order book heatmap for increased granularity. But now that I only rely on your Market Depth Historical Graph study, it would be very helpful and almost as effective if you could just simply add the option to further customize the quantity numbers color above a certain value. To be clear, what I am suggesting is to add a second quantity numbers color line, in addition to the default numbers color line, that only colors the numbers greater than a certain volume differently. That shouldn't take very long, right? Thanks. |
[2018-07-30 16:48:35] |
This is on our task list. Not sure when we will get to it though.
[2019-01-19 20:04:04] |
Just wanted to let you know that I'm still hoping that the team will find the time soon to follow through on this simple request from last Summer. Thanks!
[2019-01-20 19:59:00] |
We will check on the status of this and make sure it gets done, hopefully next week. Not long ago the company Bookmap added the option to use three colors in the order book heatmap for increased granularity.
[2019-01-20 20:04:35] |
We do apologize this has been long overdue. It is not particularly difficult but it is just one of these items that is not quick and simple and adjust takes a long time for us to get to with all the other priorities that come up and the time we also spend on support which we are trying to manage better as well.
[2019-01-20 22:09:39] |
I'm very grateful for the extra effort guys! I've been a customer for about decade and therefore, I think I understand your operational constraints. On the plus side, I'm very happy that your business continues to grow - I certainly do my part to spread the word in trade/chat rooms whenever I can! I want to make sure that none of your time is wasted on the heatmap coloring logic of the study because it works perfectly fine in my opinion. If possible, what I would like to see is an extra "Quantity Numbers Color" line (ln:7) in the settings window that one can use whenever the "Show Quantity Numbers" option is selected, but that will only color numbers greater than a certain input value. Using the ES contract as an example, my default volume numbers color is black but I would like to color in red the volumes that exceed 450, irrespective of what the heatmap background color might be. Sorry for belaboring the point and thanks. |
