Date/Time: Sun, 19 Jan 2025 17:42:08 +0000
CQG - Unable to Login - Log file included
View Count: 2499
[2018-05-01 18:53:58]
Burns77 - Posts: 5
I just set up my account and must have been using the incorrect password as I kept getting incorrect password message in the log file. I requested a password reset and completed this successfully. Now when I try to login I get a message stating "CQG WebAPI Market data logon unsuccessful.Server message: Too many failed logon attempts. Contact your FCM. See complete log below. Please help. Thank you.
Reading Internal Order ID file. | 2018-05-01 12:37:44
Reading Trade Orders file. | 2018-05-01 12:37:44
Reading Trade Positions file. | 2018-05-01 12:37:44
Listening on UDP port 22903. | 2018-05-01 12:37:44
Software version: 1549 | 2018-05-01 12:37:44
Uses New Spreadsheets | 2018-05-01 12:37:44
Usage end date: 2018-05-16 | 2018-05-01 12:37:44
Enabled for: Advanced Features. | 2018-05-01 12:37:44
Enabled for: Advanced Features 2. | 2018-05-01 12:37:44
Enabled for: Sierra Chart Historical Data Service. | 2018-05-01 12:37:44
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-05-01 12:37:44
Current selected Data/Trading service: CQG WebAPI | 2018-05-01 12:37:44
Chart Update Interval: 500 | 2018-05-01 12:37:44
Time Zone: -06:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-05-01 12:37:44
2018-05-01 12:37:47 Local computer time | 2018-05-01 12:37:44
2018-05-01 18:37:47 Local computer time in UTC | 2018-05-01 12:37:44
2018-05-01 12:37:47 Local computer time in SC Time Zone | 2018-05-01 12:37:44
2018-05-01 18:37:46 Server time in UTC | 2018-05-01 12:37:44
Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-05-01 12:37:44
Program path: C:\SierraChart\ | 2018-05-01 12:37:44
Data Files path: C:\SierraChart\Data\ | 2018-05-01 12:37:44
OS Version Number: 6.2 | 2018-05-01 12:37:44
Locale Setting: C | 2018-05-01 12:37:44
Checking for new symbol settings for service code cqg | 2018-05-01 12:37:44
HTTPS connection to www.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-05-01 12:37:44
Symbol settings are up-to-date for cqg | 2018-05-01 12:37:44
CQG WebAPI | Connecting to server demoapi.cqg.com | 2018-05-01 12:37:52
CQG websocket | Connecting to websocket server. | 2018-05-01 12:37:52
CQG websocket socket (4) | Creating socket. Using TLS 1.2. | 2018-05-01 12:37:52
CQG websocket | Opening websocket. | 2018-05-01 12:37:52
CQG websocket | Sending websocket handshake. | 2018-05-01 12:37:52
CQG websocket | Received websocket handshake acknowledgment. | 2018-05-01 12:37:52
CQG websocket | Web socket state is now open. | 2018-05-01 12:37:52
CQG WebAPI | Websocket connected. | 2018-05-01 12:37:52
CQG WebAPI | Sending market data logon message. | 2018-05-01 12:37:52
HTTPS connection to www.sierrachart.com:443 (3) | Socket gracefully closed by remote side. | 2018-05-01 12:37:52
HTTPS connection to www.sierrachart.com:443 (3) | Received socket Close event | 2018-05-01 12:37:52
HTTPS connection to www.sierrachart.com:443 (3) | Initiating close of socket by core. | 2018-05-01 12:37:52
HTTPS connection to www.sierrachart.com:443 (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-05-01 12:37:52
HTTPS connection to www.sierrachart.com:443 (3) | Closed. | 2018-05-01 12:37:52
CQG WebAPI | Market data logon unsuccessful. Server message: Too many failed logon attempts. Contact your FCM. | 2018-05-01 12:37:52 *
CQG websocket socket (4) | Adding bytes from final send buffer from buffered socket: 8 | 2018-05-01 12:37:52
CQG websocket socket (4) | Initiating close of socket by core. | 2018-05-01 12:37:52
CQG websocket | Websocket closed. | 2018-05-01 12:37:52
CQG WebAPI | Websocket closed. | 2018-05-01 12:37:52
CQG websocket socket (4) | Sending bytes from final send buffer: 8 | 2018-05-01 12:37:52
CQG websocket socket (4) | Write in progress. Shutdown being delayed. | 2018-05-01 12:37:52
CQG WebAPI | Disconnected. | 2018-05-01 12:37:52
CQG websocket socket (4) | Write has completed. Shutdown being performed. | 2018-05-01 12:37:52
CQG websocket socket (4) | Shutdown started. Waiting for graceful close. | 2018-05-01 12:37:52
CQG websocket socket (4) | Socket gracefully closed by remote side. | 2018-05-01 12:37:52
CQG websocket socket (4) | Closed. | 2018-05-01 12:37:52
[2018-05-01 19:03:46]
This section here explains these error messages you are getting:
http://www.sierrachart.com/index.php?page=doc/CQGTrading.php#CommonErrorMessages
This is the relevant message:
You need to contact your broker for help with this.
