Date/Time: Sat, 18 Jan 2025 19:30:16 +0000
Collapsing SierraChart
View Count: 827
[2018-02-21 11:01:21]
User192801 - Posts: 3
Dear admin,
i have problem with my Sierra Chart (Version 1689). An error has occurred since the installation of this version. The collapse is accuring when i want to disable Trade Simulation Mode. I am sending you a video you can see this problem.
Thank you very much for your support.
Dalibor Tfirst
Private File
[2018-02-21 18:43:50]
Run Sierra Chart in Safe Mode:
Sierra Chart - Software Login Instructions: Using Safe Mode
Update Sierra Chart to the current version:
Enable this option:
General Settings Window: Save Message Log to File (Global Settings >> General Settings >> Log >> Log)
When you have the problem again provide the Message Log file associated with the running session of Sierra Chart that abnormally shutdown. Attach it here.
Date Time Of Last Edit: 2018-02-21 18:44:24
[2018-02-22 13:20:38]
Dear SC Support,
my problem still persists. I installed a current version (and enable Save Message Log To File) but my Sierra Chart is still collapsing when i want to disable Trade Simulation Mode. I am sending you a message log file, which was created immediately after another collapse (shutdown).
Thank you for help,
Dalibor Tfirst
Private File
[2018-02-22 18:19:46]
There was nothing unusual in the Message Log. We are going to need to reproduce the exact conditions.
We need you to attach the following files:
-The chartbook you are using.
-The Sierra3.CFG file in the Sierra Chart installation folder. This will be privately attached. It contains no account information.
-The TradeActivityLog.DAT file in the Sierra Chart installation folder. This should be privately attached and make sure it is set to be private.
Here are the instructions to attach files:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
Date Time Of Last Edit: 2018-02-22 18:20:29
[2018-02-23 17:32:53]
Dear SC Support,
i am sending you the required files.
Thank you for your interest,
Dalibor Tfirst
attachmentKrok1_NASDAQonly.cht - Attached On 2018-02-23 17:31:55 UTC - Size: 693.69 KB - 363 views
Private File
Private File
[2018-02-27 04:50:03]
We have started to test this but we cannot reproduce the problem.
However, we see from your Chartbook you are using custom studies and there is a good chance the problem is with one of those.
We also see you did not follow our instructions to use Safe Mode. Run Sierra Chart in Safe Mode:
Date Time Of Last Edit: 2018-02-27 04:50:51
