Date/Time: Sun, 24 Nov 2024 03:39:07 +0000
Software problems
View Count: 1458
[2013-09-22 18:21:59] |
irvolsen - Posts: 12 |
I Have been having a problem with sierra charts running on my PC. Have had no problems until last up upgrade. It can be a login problem, fatal gatekeeper error or abnormal trader.exe problem. Had my broker remotely try and solve the problem. Brought in an IT person to check internet speeds, router firewalls antivirus software Have spent several hundred dollars trying to fix the issue on my side to date. We took off all antirust software and did a fresh down load of 5.5.4 seemed to have it working yesterday. Loaded AVG anti Virus still OK. Was going to install my back up data today and tried logging in again. Same problems. Disabled AVG still no success. Before I bring in my IT person again thought I would see if you had any suggestions. Getting very frustrated. Have been down for over a week. Have attached some screen shots. I am running windows 7 on a very new system. Your suggestions would be appreciated. |
Capture.PNG / V - Attached On 2013-09-22 18:19:21 UTC - Size: 77.53 KB - 519 views Capture1.PNG / V - Attached On 2013-09-22 18:20:02 UTC - Size: 115.23 KB - 506 views Capture2.PNG / V - Attached On 2013-09-22 18:20:39 UTC - Size: 50.91 KB - 525 views |
[2013-09-22 21:28:46] |
We recommend uninstalling any anti-malware/antivirus/Firewall software other than what is from Microsoft. Install a standard installation of Sierra Chart from this page: https://www.sierrachart.com/index.php?l=doc/download.php Log in with the same Account Name and Password that you have used on this Support Board. We have added a week of usage time to your account for testing. See if you can connect to and use the Sierra Chart Real-time and Historical Forex data feed: http://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php This will confirm network connectivity using nonstandard protocols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-22 21:29:04
