Date/Time: Wed, 15 Jan 2025 23:53:59 +0000
Ask and Bid Market Depth Pulling/Stacking not working.
View Count: 3007
[2017-09-19 14:51:01]
User252419 - Posts: 235
I'm using Sierra Chart Data Feed and Ask and Bid Market Depth Pulling/Stackis is not working.
This is what I see with my Gain Capital Account using SC Data Feed.
http://my.jetscreenshot.com/30734/20170919-bqvs-37kb
Activating my TopStepTrader account with Sierrachart today I realized that it is working well in TopStep account but not in my Gain Capital account. In TopStep Account I see Pulling/Stacking numbers in all the book around price.
Thank you,
[2017-09-19 17:38:18]
Make sure those market data columns are actually added to the chart. Refer to:
Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific)
Select Chart >> Open Market Depth Window. Do you see market depth displayed there?
Provide an image of the chart or Trade DOM, by following these instructions:
Date Time Of Last Edit: 2017-09-19 17:40:05
[2017-09-19 18:54:25]
http://www.sierrachart.com/image.php?Image=1505847062304.png
Yes, I see market depth displayed. What I don't see is Ask and Bid Market Depth Pulling/Stack correctly. I've never seen it correctly.
This is what I should see and what I see with my TopStepTrader Account:
http://www.sierrachart.com/image.php?Image=1505847200787.png
Thank you
[2017-09-20 19:19:45]
Perform a Full Reset of the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
Go to that Trade DOM and select Trade >> Customize Chart/Trade DOM Columns.
Make sure this market data column is added:
Combined Bid/Ask Market Depth Pulling/Stacking
Or the individual ones.
Also add a Custom Title to those columns so we know which one it is. Otherwise, it is hard to tell.
Let us know if you get the issue resolved. We see you are using the Sierra Chart Exchange Data Feed so make sure it is enabled through Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds.
Date Time Of Last Edit: 2017-09-20 19:21:59
[2017-09-20 19:30:16]
I've done all of this but still not working. This is what I see:
http://www.sierrachart.com/image.php?Image=1505935786393.png
[2017-09-20 19:55:33]
How is Global Settings >> Data/Trade Service Settings >> Allow Support for Sierra Chart Data Feeds set?
Do you see a [M] after the symbol on the title bar of the chart?
[2017-09-21 15:03:57]
Yes, Allow support set and [M] appears.
http://my.jetscreenshot.com/30734/20170921-pbiv-95kb
Date Time Of Last Edit: 2017-09-21 15:04:06
[2017-09-21 18:32:08]
This is what we see with the same configuration:
http://www.sierrachart.com/image.php?Image=1506018285630.png
We are thinking of looking at this with remote assistance, but there really is not much more we can think of that we can tell if we do that. There really should not be any problem.
Rather than using a Trade DOM, use a chart and enable Trade >>Show Market Data Columns
And configure the columns as explained here:
[2017-09-21 19:30:40]
In the chart DOM the same happens, not working. Also I don't know and would like to know how you have one over the other (Ask P/S over Bid P/S).
Thank you
[2017-09-22 00:36:30]
Not sure this is going to make a difference, but update Sierra Chart with Help >> Download Current Version.
Here are instructions:
Let us know.
We used the column Combined Ask/Bid Market Depth Pulling/Stacking.
Date Time Of Last Edit: 2017-09-22 00:37:16
[2017-09-26 10:53:48]
I've tried this and not working. I think it is some issue between my Gain Capital Account and Sierra Chart communication. I've never seen P/S well in my Gain Capital Account.
[2017-09-27 07:09:00]
We really need to use remote assistance to look into this. When you are ready for us to look at this with remote assistance could you select Help >> Accept Remote Assistance.
You will see a Team Viewer program display. We will need the ID number and password. Send that to us only through an Account Support Ticket:
https://www.sierrachart.com/usercp.php?page=SupportTickets
If we are able to connect close to the time you send a message, we will do that. If not, we will then we will contact you again.
