Date/Time: Wed, 15 Jan 2025 15:47:57 +0000
BitMex problem : Stoploss NOT executed
View Count: 5436
[2017-08-09 14:53:22]
N!co - Posts: 140
i have noticed this problem twice now
when a stoploss is hit, the attached stoploss and profit orders are canceled
BUT
the stoploss order is not executed !
leaving me with the open position without any stoploss and takeprofit attached
Trade services log below:
BitMEX | Received last Trade Positions report from DTC server. Clearing nonexisting Trade Positions. | 2017-08-09 10:23:00
Order Modification Error: User order modification ignored. New price is the same during a price modify. Internal Order ID: 429. Service Order ID: 98758 | 2017-08-09 11:42:25
BitMEX order update (Order reject). Info: BitMEX Trading Master - DTC order update (Order reject). Order rejected by server. Internal Order ID: 432. Service Order ID: 98772. Symbol: XBTUSD-BMEX | 2017-08-09 12:03:44 *
Order cancellation failed | BitMEX order update (Order cancel reject). Info: Order cancellation failed | Order is already canceled. Internal Order ID: 422. Service Order ID: 98746. Symbol: XBTUSD-BMEX | 2017-08-09 12:03:49 *
Order cancellation failed | BitMEX order update (Order cancel reject). Info: Order cancellation failed | Order is already canceled. Internal Order ID: 423. Service Order ID: 98747. Symbol: XBTUSD-BMEX | 2017-08-09 12:03:49 *
Order cancellation failed | BitMEX order update (Order cancel reject). Info: Order cancellation failed | Order is already canceled. Internal Order ID: 425. Service Order ID: 98749. Symbol: XBTUSD-BMEX | 2017-08-09 12:03:49 *
Order cancellation failed | BitMEX order update (Order cancel reject). Info: Order cancellation failed | Order is already canceled. Internal Order ID: 426. Service Order ID: 98750. Symbol: XBTUSD-BMEX | 2017-08-09 12:03:49 *
BitMEX | Requesting Trade Positions data. | 2017-08-09 14:22:45
BitMEX | No Trade Positions reported by DTC Server. Clearing existing Trade Positions. | 2017-08-09 14:22:45
[2017-08-10 04:52:52]
We have looked at three of these orders.
The first one was rejected BitMEX later after it was submitted for reasons which we have no idea:
ActivityType  DateTime  Symbol  OrderActionSource  ServiceOrderID  InternalOrderID  OrderType  OrderStatus  Quantity  BuySell  Price  Price2  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition
Order  2017-08-09 10:03:48.094  XBTUSD-BMEX  BitMEX Trading Master - DTC order update (Order reject). Order rejected by server  7V03A2EzTbgcrmXp3B5j8g==  98772  Stop  Error  10000  Sell  3345.0        ****:44964  Close  98770  10000
This order was canceled because you canceled the parent order.
Order  2017-08-09 10:03:53.071  XBTUSD-BMEX  Canceling child orders of internal order ID 98745    98747  Stop  Pending Cancel  10000  Buy  3449.7        ****:44964  Close  98745  10000
Order  2017-08-09 10:03:53.072  XBTUSD-BMEX  Canceling child orders of internal order ID 98745    98747  Stop  Canceled  10000  Buy  3449.7        ****:44964  Close  98745  10000
Order  2017-08-09 10:03:53.132  XBTUSD-BMEX  Order cancellation failed | Order is already canceled    98747  Stop  Canceled  10000  Buy  3449.7        ****:44964  Close    10000
If you need further help, follow through the instructions here:
Trade Activity Log Analysis: Support Assisted Trade Activity Log Analysis
You can skip the step by making a payment.
Date Time Of Last Edit: 2017-08-10 04:56:02
[2017-08-10 18:59:26]
Letting you know, we have contacted BitMEX about this order because this kind of behavior makes no sense:
Date Time Of Last Edit: 2017-08-10 18:59:37
[2017-08-10 19:19:58]
OK we have an answer about this from BitMEX:
"Account has insufficient Available Balance, 3424621 XBt required"
When the Stop order was triggered it failed the risk checks and was rejected
There is an option on our frontend called Close-on-Trigger with the description:
If checked, this will be a Close order. Close orders can only reduce your position, not increase it. If the account has insufficient Available Balance when the Close order is triggered, then other {symbol} orders will be canceled or amended down.
Use to ensure your stop reduces your position regardless of other open orders.
[2017-08-10 20:01:56]
N!co - Posts: 140
i looked at this optionand i can confirm that on the front end in BitMex this option (Close-on-Trigger) box was cheacked
thank you very much
[2017-08-10 20:29:03]
We see you are using BitMEX. Look at the order in the Trade >> Trade Orders and Positions >> Orders tab. If you see an Exchange Order ID for the order, it has been submitted to BitMEX. After that if you have any questions about the order, contact BitMEX.
We are not in any position to answer these types of questions. If the order has been received by BitMEX, and there is some execution problem, we have no idea why.
Date Time Of Last Edit: 2017-11-12 20:18:48
[2017-11-12 19:01:57]
User768593 - Posts: 2
Im having the same problem..."close on trigger" is checked
[2017-11-12 20:09:40]
Date Time Of Last Edit: 2017-11-12 20:18:21
