Date/Time: Fri, 31 Jan 2025 11:48:15 +0000
error when entering and canceling order on GAIN
View Count: 2173
[2017-06-26 13:58:10] |
red23 - Posts: 38 |
This is what I get when I enter an order. GAIN Capital FIX Trading: Error in received Execution Report <8> message. Failed to get the value for the Account <1> field. Field not found. | 2017-06-26 06:54:46 FIX Message: 8=FIX.4.49=20635=834=2349=OEC52=20170626-13:54:5156=XXXXX6=014=017=OECFIX:636340203412204505:801837=NONE38=039=858=Object reference not set to an instance of an object.60=20170626-13:54:51.822150=8151=010=119 | 2017-06-26 06:54:46 GAIN Capital FIX Trading: Error in received Execution Report <8> message. Failed to get the value for the Side <54> field. Field not found. | 2017-06-26 06:54:46 FIX Message: 8=FIX.4.49=20635=834=2349=OEC52=20170626-13:54:5156=XXXXXX 6=014=017=OECFIX:636340203412204505:801837=NONE38=039=858=Object reference not set to an instance of an object.60=20170626-13:54:51.822150=8151=010=119 | 2017-06-26 06:54:46 This is what I get when I try to cancel the order. GAIN Capital/OEC order update (Order reject). Info: Order Error - Order timed-out waiting for response from service/exchange server. Internal Order ID: 1964. Service Order ID: 9599. Symbol: GCLQ7 | 2017-06-26 06:56:23 * GAIN Capital/OEC order update (Order reject). Info: Order Error - Order timed-out waiting for response from service/exchange server. Internal Order ID: 1965. Service Order ID: 9600. Symbol: GCLQ7 | 2017-06-26 06:56:23 * GAIN Capital/OEC order update (Order reject). Info: Order Error - Order timed-out waiting for response from service/exchange server. Internal Order ID: 1966. Service Order ID: 9601. Symbol: GCLQ7 | 2017-06-26 06:56:23 * |
[2017-06-26 14:49:13] |
User99934 - Posts: 227 |
same problem!
[2017-06-26 14:52:11] |
User713688 - Posts: 25 |
SAME
[2017-06-26 14:53:16] |
We are contacting Gain Capital about this.
[2017-06-26 15:15:17] |
We have contacted Gain Capital about these order issues with their FIX server.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-26 15:17:44
[2017-06-26 17:18:13] |
Apparently this problem is no longer occurring? Gain Capital has no idea about it at this time but it was certainly a problem on their FIX server. That is clear based upon the messages. There were three problems: Missing fields in execution reports. FIX server not accepting orders and not even responding to them. An error on their side indicating a reference was not sent to an object. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-26 17:19:11] |
Still not working.
[2017-06-26 17:27:24] |
red23 - Posts: 38 |
still same problem. submit order then cancelled - order get stuck as pending. disc and reconnected - same issue. Trading server did not acknowledge new order | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 9603 | 2017-06-26 10:23:29 * Trading server did not acknowledge new order | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 9604 | 2017-06-26 10:23:29 * Trading server did not acknowledge new order | Symbol: GCLQ7 | TradeAccount:| InternalOrderID: 9605 | 2017-06-26 10:23:29 * Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 9608 | 2017-06-26 10:24:47 * Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: InternalOrderID: 9609 | 2017-06-26 10:24:47 * Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 9607 | 2017-06-26 10:24:58 * Order Error - Order timed-out waiting for response from service/exchange server. Internal Order ID: 9608. Service Order ID: (none). Symbol: GCLQ7 | 2017-06-26 10:25:18 * Order Error - Order timed-out waiting for response from service/exchange server. Internal Order ID: 9609. Service Order ID: (none). Symbol: GCLQ7 | 2017-06-26 10:25:18 * Order Error - Order timed-out waiting for response from service/exchange server. Internal Order ID: 9607. Service Order ID: (none). Symbol: GCLQ7 | 2017-06-26 10:25:28 * |
[2017-06-26 17:35:08] |
OK we need your Gain Capital Trade Account identifier. Tell us what it is through an account Support Ticket: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-06-26 17:39:51] |
red23 - Posts: 38 |
ok i sent the account # I think I found the cause of it. seems to be an issue with executing orders on the 2nd instance of sierra chart. So the order works when inputted on the main sierra instance. the 2nd instance causes the hang up. |
[2017-06-26 17:40:41] |
I sent account number.
[2017-06-26 17:42:39] |
red23 - Posts: 38 |
User99934, are you using multiple instances of sierra chart? Try executing on the main one |
[2017-06-26 17:43:40] |
Just one instance.
[2017-06-26 17:44:26] |
I am using multiple. On my main I had issues and needed to reset my OCO orders. On my second still the same mess.
[2017-06-26 17:46:16] |
I think I found the cause of it. seems to be an issue with executing orders on the 2nd instance of sierra chart. So the order works when inputted on the main sierra instance. the 2nd instance causes the hang up. It seems it has to do with server-side OCO and bracket orders. Disable those through Global Settings >> General Trade Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-06-26 17:47:36
[2017-06-26 17:49:08] |
red23 - Posts: 38 |
yes you are right. I put in an OCO order and now the orders are getting stuck again. The time that it worked I just put in a limit order.
[2017-06-26 17:49:16] |
GAIN support manager needs to subscribe to this board. There are often problems - often on Sunday evening. Please ask your broker to ask GAIN support to subscribe and monitor this board. Maybe we can have a GAIN only thread or something - let's do whatever Sierra Support suggests.
[2017-06-26 18:25:29] |
Gain Capital says they are aware of the issue and will resolve it.
[2017-06-27 17:03:30] |
red23 - Posts: 38 |
Still having a similar issue with trailing stop. So part of the problem was fixed. But now the trigtrailstop limit stop order is stuck on my screen. Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 2011 | 2017-06-27 09:58:58 * Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 2011 | 2017-06-27 09:59:58 * Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 2011 | 2017-06-27 10:00:58 * Requesting order status for non-responsive order. | Symbol: GCLQ7 | TradeAccount: | InternalOrderID: 2011 | 2017-06-27 10:01:58 * |
[2017-06-27 17:05:06] |
Please contact your broker about this.
[2019-05-07 18:16:18] |
AlexPereira - Posts: 197 |
Hi, I am trying out a gain oec, and I am getting the same error when using EURO FX and "trade and quote symbol" to a mini or micro. Disabling OCO does kinda solve the problem, but what seems to have really solved the problem was changing the "eurofx" 6EM symbol tick size to the mini or micro tick size. ( now server side oco works properly and orders don't fail ). ( so , 6EM tick size is 0.5, M6EM is 1.0, making 6EM tick size 1.0 makes everything work ). Is there a way to make this work without changing tick size of the 6EM symbol ? Date Time Of Last Edit: 2019-05-07 18:16:51
[2019-05-08 15:53:31] |
Tell us specifically what error you are getting. We do not look back at prior old posts. Refer to: Support Board Posting Information: Providing Lines From Trade Service Log The Tick Size of the chart is going to need to match the symbol actually being traded. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
