Date/Time: Tue, 04 Nov 2025 12:10:40 +0000
BUG? - Allow Modifications of chart drawings from other charts
View Count: 1041
[2017-05-03 01:18:46]
User025822 - Posts: 35
Once the chart drawing is modified in another chart, there is no way to REDO or UNDO the chart drawing modification in neither of the two charts.
Is this a bug?
Thank you
[2017-05-03 03:40:19]
This is by design. This will be explained in the documentation.
Although we probably could support this in the source chart. But we will have to see about that later on.
[2017-05-03 04:26:31]
We just finished implementing Undo and Redo capability for when modifying and deleting Chart Drawings on a destination chart.
This functionality only can be invoked though from the original source chart.
[2017-05-04 02:43:59]
I discovered another issue:
I can't change the drawing parameters (color,style, width, etc) on the destination chart of a drawing created in the source chart
[2017-05-04 04:57:01]
This definitely works. This has been verified.
How are you changing these Properties?
Refer to:
Chart Drawing Tools: Modifying and Deleting Drawing Copied to Other Charts
[2017-05-05 01:25:51]
it doesn't work on my version. I am on 1552 pre-release.
i.e. I draw an Ellipse in the source chart. Then I go to destination chart and double click the ellipse to open its properties. Once there I can't make changes because it reverts back to original colors, style, etc...
But, I am able to change the properties if I right click, in the destination chart, on ellipse and change color, line width.. in the right click chart drawing menu. The problem is that this menu doesn't include all the properties for the object.
Date Time Of Last Edit: 2017-05-05 01:30:00
[2017-05-05 02:13:18]
We understand the reason for the problem now. We will fix this in the next release.
