Date/Time: Fri, 10 Jan 2025 03:48:54 +0000
I cannot connect to the DATA FEED - GAIN / OEC
View Count: 1437
[2016-08-24 14:00:11]
User678047 - Posts: 4
Hello, help me please...
Software version: 1455 | 2016-08-24 15:57:51
Uses New Spreadsheets | 2016-08-24 15:57:51
Usage end date: 2016-09-16 | 2016-08-24 15:57:51
Enabled for: Advanced Features. | 2016-08-24 15:57:51
Enabled for: Sierra Chart Historical Data Service. | 2016-08-24 15:57:51
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-24 15:57:51
Current selected Data/Trading service: GAIN Capital/OEC | 2016-08-24 15:57:51
Chart Update Interval: 500 | 2016-08-24 15:57:51
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-08-24 15:57:51
2016-08-24 15:57:51 Local computer time | 2016-08-24 15:57:51
2016-08-24 13:57:51 Local computer time in UTC | 2016-08-24 15:57:51
2016-08-24 15:57:51 Local computer time in SC Time Zone | 2016-08-24 15:57:51
2016-08-24 13:54:39 Server time in UTC | 2016-08-24 15:57:51
Local computer UTC time and Server UTC time difference: 2 seconds. | 2016-08-24 15:57:51
Program path: C:\SierraChart\ | 2016-08-24 15:57:51
Data Files path: C:\SierraChart\Data\ | 2016-08-24 15:57:51
OS Version Number: 6.2 | 2016-08-24 15:57:51
Locale Setting: C | 2016-08-24 15:57:51
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-08-24 15:57:57
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-08-24 15:57:57
GainCapital FIX Trading socket (16) | Connected. | 2016-08-24 15:57:57
GainCapital FIX Trading socket (16) | Starting TLS 1.2 connection. | 2016-08-24 15:57:57
GainCapital FIX Trading socket (16) | SSL connection established. | 2016-08-24 15:57:57
GainCapital FIX Trading: Sending the Logon message. | 2016-08-24 15:57:57
GainCapital FIX Trading: Sent heartbeat to server. | 2016-08-24 15:58:28
Service connection timed out. Will disconnect and retry. | 2016-08-24 15:58:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-24 15:58:57
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-24 15:58:57
GainCapital FIX Trading: DisconnectFIX called. | 2016-08-24 15:58:57
GainCapital FIX Trading: Sending a Logout message. | 2016-08-24 15:58:57
GAIN Capital/OEC | Disconnected. | 2016-08-24 15:58:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-24 15:58:57
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-08-24 15:59:00
GainCapital FIX Trading: Unable to connect. The last connection is still in the process of logging out. | 2016-08-24 15:59:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-24 15:59:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-24 15:59:00
GainCapital FIX Trading: DisconnectFIX called. | 2016-08-24 15:59:00
GAIN Capital/OEC | Disconnected. | 2016-08-24 15:59:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-24 15:59:00
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-08-24 15:59:01 *
GainCapital FIX Trading socket (16) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-24 15:59:01
GainCapital FIX Trading socket (16) | SSL has been shut down. | 2016-08-24 15:59:01
GainCapital FIX Trading socket (16) | SSL object has been freed. SSL state is now disconnected. | 2016-08-24 15:59:01
GainCapital FIX Trading socket (16) | Shutdown and closed. | 2016-08-24 15:59:01
GAIN Capital/OEC | Disconnected from the trading server. | 2016-08-24 15:59:01
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-08-24 15:59:03
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-08-24 15:59:03
GainCapital FIX Trading socket (18) | Connected. | 2016-08-24 15:59:03
GainCapital FIX Trading socket (18) | Starting TLS 1.2 connection. | 2016-08-24 15:59:03
GainCapital FIX Trading socket (18) | SSL connection established. | 2016-08-24 15:59:03
GainCapital FIX Trading: Sending the Logon message. | 2016-08-24 15:59:04
[2016-08-24 16:04:22]
These are the relevant messages:
The OEC server is not responding.
Are you still having a problem connecting?
[2016-08-25 07:14:51]
I have no problem with the connection.
I tried connect from three different PCs in different internet providers.
Which can be issue ?
[2016-08-25 07:32:32]
I connect to the account via SOL platform or from mobile application ordinarily.
Sierra chart I used every day - routinely - , but the last two days I can not connect.
From log files is apparent that there is a problém with OEC server ?
I did not change any settings.
[2016-08-25 07:41:41]
Could you provide us the current Message Log again to see if there has been any change.
Based upon what we see here, the Gain Capital/OEC server is just not responding to the logon request:
[2016-08-25 08:01:59]
Software version: 1455 | 2016-08-25 09:57:38
Uses New Spreadsheets | 2016-08-25 09:57:38
Usage end date: 2016-09-16 | 2016-08-25 09:57:38
Enabled for: Advanced Features. | 2016-08-25 09:57:38
Enabled for: Sierra Chart Historical Data Service. | 2016-08-25 09:57:38
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-08-25 09:57:38
Current selected Data/Trading service: GAIN Capital/OEC | 2016-08-25 09:57:38
Chart Update Interval: 500 | 2016-08-25 09:57:38
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-08-25 09:57:38
2016-08-25 09:57:37 Local computer time | 2016-08-25 09:57:38
2016-08-25 07:57:37 Local computer time in UTC | 2016-08-25 09:57:38
2016-08-25 09:57:37 Local computer time in SC Time Zone | 2016-08-25 09:57:38
2016-08-25 07:11:12 Server time in UTC | 2016-08-25 09:57:38
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-08-25 09:57:38
Program path: C:\SierraChart\ | 2016-08-25 09:57:38
Data Files path: C:\SierraChart\Data\ | 2016-08-25 09:57:38
OS Version Number: 6.2 | 2016-08-25 09:57:38
Locale Setting: C | 2016-08-25 09:57:38
GainCapital FIX Trading: Waiting for Logout response timed out. Closing the socket now. | 2016-08-25 09:57:40 *
GainCapital FIX Trading socket (58) | SSL shutdown indicates not able to send 'close notify'. | 2016-08-25 09:57:40
GainCapital FIX Trading socket (58) | SSL has been shut down. | 2016-08-25 09:57:40
GainCapital FIX Trading socket (58) | SSL object has been freed. SSL state is now disconnected. | 2016-08-25 09:57:40
GainCapital FIX Trading socket (58) | Shutdown and closed. | 2016-08-25 09:57:40
GAIN Capital/OEC | Disconnected from the trading server. | 2016-08-25 09:57:40
File >> Disconnect selected. | 2016-08-25 09:58:19
GAIN Capital/OEC | Disconnected. | 2016-08-25 09:58:19
GAIN Capital/OEC | Connecting to trading server prod.gainfutures.com. Port: 9400. | 2016-08-25 09:59:38
GainCapital FIX Trading socket (0) | Resolved address prod.gainfutures.com to IP 64.94.37.222. | 2016-08-25 09:59:38
GainCapital FIX Trading socket (61) | Connected. | 2016-08-25 09:59:38
GainCapital FIX Trading socket (61) | Starting TLS 1.2 connection. | 2016-08-25 09:59:38
GainCapital FIX Trading socket (61) | SSL connection established. | 2016-08-25 09:59:39
GainCapital FIX Trading: Sending the Logon message. | 2016-08-25 09:59:39
GainCapital FIX Trading: Sent heartbeat to server. | 2016-08-25 10:00:08
Service connection timed out. Will disconnect and retry. | 2016-08-25 10:00:38 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-08-25 10:00:38
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-08-25 10:00:38
GainCapital FIX Trading: DisconnectFIX called. | 2016-08-25 10:00:38
GainCapital FIX Trading: Sending a Logout message. | 2016-08-25 10:00:38
GAIN Capital/OEC | Disconnected. | 2016-08-25 10:00:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-08-25 10:00:38
[2016-08-25 08:25:17]
Contact us through an Account Support Ticket and provide us your Gain Capital username:
https://www.sierrachart.com/usercp.php?page=SupportTickets
We will then contact them about this.
