Date/Time: Tue, 11 Mar 2025 07:03:43 +0000
Live trading with Sierra Chart Exchange Data Feed
View Count: 1051
[2016-02-23 03:00:51] |
User144295 - Posts: 70 |
Hello Sierra Support Board, I am preparing setup for live trading and I am reading the clause listed below. I was wondering how this seamless integration works in live trading environment (with Infinity). Currently I have CME Sierra real time data package activated, and I have Infinity Platform in Live mode ON as well, but when I tried to buy limit below actual price on NQH6, the order does not appear on the Infinity Platform DOM price ladder. It is visible on in Sierra Charts. However, when I performed this test under Simulated trading mode (Trade simulation mode ON in Sierra and Simulated trading mode on Infinity platform DOM ladder) then it worked, and order which I executed within nested little DOM in Sierra Charts then appears on Infinity DOM price ladder. Would you please advise what I am doing wrong that it does not work seamlessly in Live mode? Thank you. This seamless integration means that when you activate the Sierra Chart Exchange Data Feed on your Sierra Chart account, the charts and Trade DOM windows will receive this data feed for any symbol that this data feed provides data for, if you have activated the exchange the symbol trades on. Therefore, when using your Trading account with Sierra Chart, the market data will come from the Sierra Chart Exchange Data Feed! |
[2016-02-23 03:19:07] |
Update Sierra Chart to the current version: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate You are running an older version. This is not relevant to the issue you are having but you are just running an older version and you should update. However, when I performed this test under Simulated trading mode (Trade simulation mode ON in Sierra and Simulated trading mode on Infinity platform DOM ladder) then it worked, and order which I executed within nested little DOM in Sierra Charts then appears on Infinity DOM price ladder.
This is a complete impossibility as described, so there must be a misunderstanding. Make sure you understand the difference between simulated and non-simulated trading: https://www.sierrachart.com/index.php?page=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim Just make sure Sierra Chart is not in Trade Simulation Mode. More information can be found here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-23 03:20:06
[2016-02-23 03:39:56] |
Thanks it works now. I have read also the post you provided and I would like to ask one more follow up question: In this post there is short notice on the end: https://www.sierrachart.com/index.php?page=doc/TransAct.php#Trading "Notice : When trading from Sierra Chart, and you are running the TransAct AT software at the same time, you must disable the Auto Bracket feature in the TransAct AT software if you are using Attached Orders in Sierra Chart. Otherwise, a new order entered from Sierra Chart will cause an automatic bracket to be submitted from TransAct AT, resulting in two sets of brackets." Does it mean that when trading Live from Sierra Chart I don't even have to be running TransAct AT platform at all? Thank you very much for your reply in advance. |
[2016-02-23 03:46:47] |
Yes, you do not need to be running the TransAct AT platform.
