Date/Time: Sun, 20 Sep 2026 22:33:12 +0000
Charts keep on pausing
View Count: 1532
| [2015-12-17 10:54:45] |
| User41288 - Posts: 13 |
Hi There, My charts keep on pausing randomly even when cqg feed and sierra green light on top right hand corner are on. I have to log out and retart again. Please advise.
| [2015-12-17 11:02:43] |
When you reconnect to the data feed following the instructions here: File Menu: Procedure to Reconnect to the Data and Trade Servers Does the data feed then resume? If so we will need to get your CQG username and let CQG know about this. You can communicate that through an Account Support Ticket: https://www.sierrachart.com/usercp.php?page=SupportTickets Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-12-17 17:45:29] |
We are contacting CQG about this, but so that we have complete information, does reconnecting to the data feed as we explained cause the data feed to resume? When you notice this problem, wait 90 seconds, does Sierra Chart automatically reconnect to the data feed within that 90 seconds time? You will know this happens by looking at the Status Bar because it will go yellow and then green and then the data feed will automatically resume. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-17 17:46:13
| [2015-12-17 19:28:04] |
I have to log out & log in again when charts stop in the middle without any warning or update. After log in everything work fine for few hours & then pause again even when tho top right hand light is still green
| [2015-12-17 19:30:03] |
I also use my other cqg feed for Ninja & there is no problem there. AMP says both my feeds are fine
| [2015-12-17 19:54:40] |
We do not know what is meant by "log out and log in". We need to know if you reconnect to the data feed does the data feed resume by following this procedure: File Menu: Procedure to Reconnect to the Data and Trade Servers We need to know if you are following the given procedure, does the data feed resume. Based upon what we know so far, this is a CQG issue. Update Sierra Chart to the latest prerelease with Help >> Download Prerelease. The new version logs the session key which CQG will require to analyze the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-12-17 19:56:43
| [2015-12-18 06:44:21] |
Hi there, Yes Data Resumes after that procedure
| [2015-12-18 06:53:32] |
Therefore, this is confirmed to be a CQG issue. When you have this problem provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then provide the session key to CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
