Date/Time: Wed, 25 Dec 2024 18:12:49 +0000
FXCM - can't connect to Server - pls fix ASAP
View Count: 7316
[2015-11-29 22:42:48]
Rainer - Posts: 110
Right Now - SC can't connect to FXCM Server
FXCM FIX Trading session | Connecting to address fixreal.fxcorporate.com. Port 8024. | 2015-11-30 09:41:59
FXCM FIX Trading session socket (0) | Resolved address fixreal.fxcorporate.com to IP 204.8.241.24 | 2015-11-30 09:41:59
FXCM FIX Trading session socket (47) | Connected. | 2015-11-30 09:41:59
FXCM FIX Trading session: Sending the Logon message. | 2015-11-30 09:42:00
FXCM FIX Trading session: Session connected. Sending logon user request. | 2015-11-30 09:42:01
FXCM FIX Trading session | User status: 19915;DAS 19915: ZDas Exception
ORA-20101: Wrong user name or password
ORA-06512: at "A10R1.API", line 429
ORA-06512: at line 1
| 2015-11-30 09:42:01
FXCM FIX Trading session: Logon Error. Expecting logout message from server. | 2015-11-30 09:42:01 *
FXCM FIX Trading session: Received a Logout message. Text = user not recognised or password incorrect.2 | 2015-11-30 09:42:01
FXCM FIX Trading session: Sending a Logout message. Text = Received Logout message. | 2015-11-30 09:42:01
FXCM FIX Trading session socket (47) | Shutdown and closed. | 2015-11-30 09:42:01
FXCM FIX Trading session: Logged out and disconnected. | 2015-11-30 09:42:01
FXCM FIX Trading session: Disconnected. | 2015-11-30 09:42:01
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-30 09:42:01
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-30 09:42:01
FXCM FIX Trading: Disconnected. | 2015-11-30 09:42:02
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-30 09:42:02
Date Time Of Last Edit: 2015-11-29 22:43:07
[2015-11-29 22:48:11]
Rainer - Posts: 110
It says wrong username or password, I have not changed any settings since last trading session, have just retyped username & password, but no luck. FXCM's own trading platform is working fine on my PC.
[2015-11-29 23:10:12]
This is the relevant error message:
We recommend going through the set up steps here:
http://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#Setup
If you still have difficulty connecting contact API at FXCM.com for help with this. Be sure to let them know you are getting the above error message.
Date Time Of Last Edit: 2015-11-29 23:10:39
[2015-11-30 00:37:52]
Rainer - Posts: 110
the FIX-API team at FXCM is investigating .... incidentally, have any other users reported a similar problem in the meantime?
[2015-11-30 01:00:59]
No other users reporting a problem at this time.
[2015-11-30 01:13:36]
Rainer - Posts: 110
Could there be a glitch in the FIX-API itself, that a reset or other action (from within SC) would resolve?
...as the Username & Password I am using are 100% correct, as I can successfully login to www.MyFXCM.com to view my account and successfully login to the FXCM platform (Marketscope) on my PC.
[2015-11-30 01:19:59]
No there is nothing like this.
[2015-11-30 02:20:53]
Rainer - Posts: 110
so far, FXCM says: "looks like not your password or account issue"
they further are asking SC ...
Hello Sierra chart
I saw many logout message from your side. Do you see any issue?
INFO (2015-11-29 20:13:52,364) [QF/J Session dispatcher: FIX.4.4:FXCM/AUDMINI->2705077564_client1] (event) - FIX.4.4:FXCM/AUDMINI->2705077564_client1: Logon contains ResetSeqNumFlag=Y, resetting sequence numbers to 1
INFO (2015-11-29 20:13:52,365) [QF/J Session dispatcher: FIX.4.4:FXCM/AUDMINI->2705077564_client1] (event) - FIX.4.4:FXCM/AUDMINI->2705077564_client1: Received logon
INFO (2015-11-29 20:13:52,366) [QF/J Session dispatcher: FIX.4.4:FXCM/AUDMINI->2705077564_client1] (event) - FIX.4.4:FXCM/AUDMINI->2705077564_client1: Responding to logon request
INFO (2015-11-29 20:13:53,227) [QF/J Session dispatcher: FIX.4.4:FXCM/AUDMINI->2705077564_client1] (event) - FIX.4.4:FXCM/AUDMINI->2705077564_client1: Received logout request
INFO (2015-11-29 20:13:53,228) [QF/J Session dispatcher: FIX.4.4:FXCM/AUDMINI->2705077564_client1] (event) - FIX.4.4:FXCM/AUDMINI->2705077564_client1: Sent logout response
INFO (2015-11-29 20:13:53,229) [QF/J Session dispatcher: FIX.4.4:FXCM/AUDMINI->2705077564_client1] (event) - FIX.4.4:FXCM/AUDMINI->2705077564_client1: No responder, not sending message: 8=FIX.4.49=7635=534=649=FXCM50=AUDMINI52=20151130-01:13:53.22956=2705077564_client110=204
Best regards
Lei
[2015-11-30 03:11:21]
We will send the following to FXCM:
We cannot comment on the FXCM logging because we do not know exactly how that works and exactly what is being logged and why.
We can only comment on what we see from the Sierra Chart Log when connecting to the FXCM FIX server.
At this point in time, there has been a successful connection to the FIX server and a BE message is being sent to the FXCM server:
The FXCM server then responds with a User status text from BF message:
"DAS 19915: ZDas Exception
ORA-06512: at line 1"
A logout message is received from the FXCM FIX server:
Sierra chart then sends a logout message and gracefully disconnects.
Date Time Of Last Edit: 2015-11-30 03:17:55
[2015-11-30 03:17:13]
Please do not send the message to FXCM above. We needed to make some corrections to it.
Date Time Of Last Edit: 2015-11-30 03:18:10
[2015-11-30 07:21:39]
Rainer - Posts: 110
any update, as I still have no connection?
incidentally, I had not changed or touched any settings in SC or my OS.
FXCM normally close their Servers on Saturdays and I just click Disconnect in SC (to stop it from trying to reconnect); as it is the weekend. On Sundays (yesterday) before rebooting my PC I usually check SC for any Download Current Version updates, which there were none, but this morning (Monday) it just will not connect.
[2015-11-30 07:53:13]
The last we heard from FXCM is they are looking into the issue on their side.
Since we do not know your Username or Password and it is their server indicating a problem with those, really it is not within our ability to solve this.
We also have provided FXCM the background technical information we have given above.
You may also be interested in this:
Announcement: New Connection Model for FXCM and LMAX
With the new connection model, while your particular case is unusual, it will be less likely with this connection model. Although if our server had a problem connecting to FXCM for the same reason, that it will prevent all users from connecting so that would not be good but we would also expect FXCM to promptly resolve it since the connection will carry a large number of users.
