Date/Time: Wed, 25 Dec 2024 06:23:13 +0000
Trade Window not working properly
View Count: 2007
[2015-11-19 15:59:45]
User56044 - Posts: 62
All of sudden my trade window is not working properly.
When I enter an order and it fills the initial line at the entry price disappears from the chart. Also the change in price is no longer recorded in the trade window. This seems to have occurred all of a sudden and I haven't made any changes to Sierra Chart that I know of. Using IB.
[2015-11-19 16:06:58]
This is a common problem with Interactive Brokers.
Basically the problem is the Trade Position data is not being received from Trader Workstation. Try restarting Trader Workstation.
You can see the Trade Positions data received from Interactive Brokers in Trade >> Trade Orders and Positions >> Positions.
This is the relevant documentation:
https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#IncorrectlyReportedTradePosition
Date Time Of Last Edit: 2015-11-19 16:08:52
[2015-11-19 17:13:24]
Restart doesn't help. Also tried this on two different computers.
Not only does the entry trade line disappear from the chart when the price moves past it, but when the target or stop price is hit a REVERSE trade is automatically initiated.
There must be something amiss with my Sierra Chart, but not sure what it might be. What can you suggest?
[2015-11-19 17:25:37]
The problem is with Trader Workstation. If you can avoid using Interactive Brokers that would be best. You can see for yourself just by having a look at
We have other reports of this exact same problem. And has been thoroughly looked into yesterday, and determined to be a problem with Trader Workstation.
Regarding this:
We need to see the lines in the Trade Activity Log for the order which is reversing the Position to see what initiated it. Here are instructions:
https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#TradeActivityLogToSupport
[2015-11-19 18:30:21]
The data you requested is below. Once either the Target or Stop has been hit, the trade reverses and I then have to go into TWS and cancel the reverse trade it has already set up!
I'll switch from IB if I have to. This is really crazy. Any recommendations? Thanks.
ActivityType  DateTime  Symbol  OrderActionSource  InternalOrderID  ServiceOrderID  OrderType  Quantity  BuySell  Price  Price2  OrderStatus  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID
Order  2015-11-19 13:08:53.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.57. Attached Order  56835    Limit    Buy  41.52    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:08:53.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.57. Attached Order  56836    Stop    Buy  41.76    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:08:53.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.57  56834    Limit  1  Sell  41.58    Order Sent      DU4779  Open
Order  2015-11-19 13:08:53.003  CL-201601-NYMEX  IB open order update  56834  111611  Limit  1  Sell  41.58    Open      DU4779  Open
Order  2015-11-19 13:08:59.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56834  111611  Limit  1  Sell  41.58    Pending Modify      DU4779  Open
Order  2015-11-19 13:08:59.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.57. Requested Price: 41.509999. Requested Quantity: 0  56835    Limit    Buy  41.52    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:08:59.002  CL-201601-NYMEX  Order modified internally  56835    Limit    Buy  41.51    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:08:59.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.57. Requested Price: 41.749999. Requested Quantity: 0  56836    Stop    Buy  41.76    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:08:59.004  CL-201601-NYMEX  Order modified internally  56836    Stop    Buy  41.75    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:09:00.001  CL-201601-NYMEX  Auto-sent child from parent fill  56835    Limit  1  Buy  41.51    Order Sent      DU4779  Close  56834  -1
Order  2015-11-19 13:09:00.002  CL-201601-NYMEX  Auto-sent child from parent fill  56836    Stop  1  Buy  41.75    Order Sent      DU4779  Close  56834  -1
Order  2015-11-19 13:09:00.003  CL-201601-NYMEX  IB open order update  56834  111611  Limit  1  Sell  41.57    Pending Open  41.57  1  DU4779  Open    -1
Order  2015-11-19 13:09:00.004  CL-201601-NYMEX  IB open order update  56834  111611  Limit  1  Sell  41.57    Filled  41.57  1  DU4779  Open    -1
Order  2015-11-19 13:09:00.005  CL-201601-NYMEX  IB open order update  56835  111612  Limit  1  Buy  41.51    Open      DU4779  Close  56834  -1
Order  2015-11-19 13:09:00.006  CL-201601-NYMEX  IB open order update  56836  111613  Stop  1  Buy  41.75    Open      DU4779  Close  56834  -1
Order  2015-11-19 13:09:09.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0            0  0  Unspecified      DU4779
Order  2015-11-19 13:09:15.000    Requesting all orders from trading service            0  0  Unspecified      None
Order  2015-11-19 13:09:24.000  CL-201601-NYMEX  User order modification ignored. New price is the same  56835  111612  Limit  1  Buy  41.51    Open      DU4779  Close  56834
Order  2015-11-19 13:09:29.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56836  111613  Stop  1  Buy  41.75    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:09:29.001  CL-201601-NYMEX  IB open order update  56836  111613  Stop  1  Buy  41.72    Open      DU4779  Close  56834
Order  2015-11-19 13:09:35.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.559999. Requested Quantity: 1  56835  111612  Limit  1  Buy  41.51    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:09:35.001  CL-201601-NYMEX  IB open order update  56835  111612  Limit  1  Buy  41.56    Open      DU4779  Close  56834
Order  2015-11-19 13:09:38.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56835  111612  Limit  1  Buy  41.56    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:09:38.001  CL-201601-NYMEX  IB open order update  56835  111612  Limit  1  Buy  41.57    Open      DU4779  Close  56834
Order  2015-11-19 13:09:49.000  CL-201601-NYMEX  IB order fill (execution)  56835  111612  Limit  1  Buy  41.57    Filled  41.57  1  DU4779  Close  56834
Order  2015-11-19 13:09:49.002  CL-201601-NYMEX  Canceling order due to sibling fill  56836  111613  Stop  1  Buy  41.72    Pending Cancel      DU4779  Close  56834  1
Order  2015-11-19 13:09:49.003  CL-201601-NYMEX  IB order status update  56836  111613  Stop  1  Buy  41.72    Canceled      DU4779  Close  56834  1
Order  2015-11-19 13:09:58.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0            0  0  Unspecified      DU4779
Order  2015-11-19 13:09:59.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist            0  0  Unspecified      DU4779
Order  2015-11-19 13:10:04.000    Requesting all orders from trading service                Unspecified      None
Date Time Of Last Edit: 2015-11-20 04:13:24
[2015-11-19 21:01:31]
I just talked to IB and they say this is Sierra Chart issue and that Sierra Chart may not have made the necessary changes as IB changes it's product.
I am able to trade directly from the TWS with no issue at all. Therefore, I think this is NOT a TWS issue, but rather, may well be something amiss at Sierra Chart.
Please get to the bottom of this.
Thanks, Ken
[2015-11-19 21:23:28]
We now recognize the reason for the problem related to the reporting of the Trade Position data.
This could not be an issue within Sierra Chart and is something else unrelated:
[2015-11-19 22:20:18]
So what do I do so I can now trade? Help!!
[2015-11-19 23:20:37]
We are working on the problem. Just give us about 3 to 4 more hours.
[2015-11-19 23:33:01]
Great! Thanks.
[2015-11-20 04:09:59]
See the response here:
Notice: Important Update for Interactive Brokers Users
Also, in the latest release, the problem with these large numbers displaying has been solved:
17976931348623157000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000.00
Date Time Of Last Edit: 2015-11-20 04:10:51
[2015-11-20 04:24:18]
The Trade Activity Log you provided above does not contain the order fills. Provide it again and make sure you select "All Activity" at the top of the Trade Activity Log.
Also, with the problem that existed with the interpretation of a Trade Position symbol year, it would never have caused anything like this:
How do you come to this conclusion? This is not even technically possible unless an order was submitted to reverse the position. We also see no evidence of this issue in the Trade Activity Log you provided.
[2015-11-20 11:24:33]
Everything seems to be working properly now on IB's TWS. Below I have again copied the Trade Activity Log.
Here is what I observed before your most recent fix. When the order was executed the price line at which the trade was filled soon disappeared completely from the chart and there was no evidence of price activity on the Chart DOM. When the order either hit the target or stop the trade appeared to terminate on the chart (Target and Stop lines disappeared) but a Reverse trade was immediately initiated on the TWS. I then had to go into the TWS and cancel that reverse trade. Please don't tell me that this could Never happen because this is what I observed. I am not very smart, but I do know what I see.
Again, everything seems to be working on IB's TWS with your recent fix (hack). Please know that I do very much appreciate all your help.
For what it is worth, the Trade Activity Log is below with "All Activity".
Order  2015-11-17 19:36:47.000    Disconnected from server                Unspecified      None
Order  2015-11-18 06:22:58.000    Connected to server                Unspecified      None
Order  2015-11-18 06:23:28.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 06:23:39.000    Disconnected from server                Unspecified      None
Order  2015-11-18 06:23:44.000    Connected to server                Unspecified      None
Order  2015-11-18 06:23:52.000    Disconnected from server                Unspecified      None
Order  2015-11-18 06:23:57.000    Connected to server                Unspecified      None
Order  2015-11-18 06:24:02.000    Disconnected from server                Unspecified      None
Order  2015-11-18 06:24:07.000    Connected to server                Unspecified      None
Order  2015-11-18 06:24:10.000    Disconnected from server                Unspecified      None
Order  2015-11-18 06:24:15.000    Connected to server                Unspecified      None
Order  2015-11-18 06:24:18.000    Disconnected from server                Unspecified      None
Order  2015-11-18 06:24:23.000    Connected to server                Unspecified      None
Order  2015-11-18 06:24:28.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 07:52:32.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 07:53:21.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 07:53:46.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:06:36.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:35:42.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.239998  56753    Limit  1  Buy  42.21    Order Sent      U154743  Open
Order  2015-11-18 08:35:42.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.239998. Attached Order  56754    Limit  1  Sell  42.27    Order Sent      U154743  Close  56753
Order  2015-11-18 08:35:42.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.239998. Attached Order  56755    Stop  1  Sell  42.07    Order Sent      U154743  Close  56753
Order  2015-11-18 08:35:43.000  CL-201601-NYMEX  IB open order update  56754  444  Limit  1  Sell  42.27    Open      U154743  Close  56753
Order  2015-11-18 08:35:43.001  CL-201601-NYMEX  IB open order update  56755  445  Stop  1  Sell  42.07    Open      U154743  Close  56753
Order  2015-11-18 08:35:43.002  CL-201601-NYMEX  IB open order update  56753  443  Limit  1  Buy  42.21    Open      U154743  Open
Order  2015-11-18 08:35:57.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:36:01.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      U154743
Order  2015-11-18 08:36:01.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56753  443  Limit  1  Buy  42.21    Pending Cancel      U154743  Open
Order  2015-11-18 08:36:01.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56754  444  Limit  1  Sell  42.27    Pending Cancel      U154743  Close  56753
Order  2015-11-18 08:36:01.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56755  445  Stop  1  Sell  42.07    Pending Cancel      U154743  Close  56753
Order  2015-11-18 08:36:01.004  CL-201601-NYMEX  IB order status update  56753  443  Limit  1  Buy  42.21    Canceled      U154743  Open
Order  2015-11-18 08:36:01.005  CL-201601-NYMEX  IB order status update  56754  444  Limit  1  Sell  42.27    Canceled      U154743  Close  56753
Order  2015-11-18 08:36:01.006  CL-201601-NYMEX  IB order status update  56755  445  Stop  1  Sell  42.07    Canceled      U154743  Close  56753
Order  2015-11-18 08:36:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:53:02.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.259998  56756    Stop  1  Buy  42.28    Order Sent      U154743  Open
Order  2015-11-18 08:53:02.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.259998. Attached Order  56757    Limit  1  Sell  42.34    Order Sent      U154743  Close  56756
Order  2015-11-18 08:53:02.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.259998. Attached Order  56758    Stop  1  Sell  42.14    Order Sent      U154743  Close  56756
Order  2015-11-18 08:53:02.003  CL-201601-NYMEX  IB open order update  56757  447  Limit  1  Sell  42.34    Open      U154743  Close  56756
Order  2015-11-18 08:53:02.004  CL-201601-NYMEX  IB open order update  56758  448  Stop  1  Sell  42.14    Open      U154743  Close  56756
Order  2015-11-18 08:53:02.005  CL-201601-NYMEX  IB open order update  56756  446  Stop  1  Buy  42.28    Open      U154743  Open
Order  2015-11-18 08:53:09.000  CL-201601-NYMEX  IB order fill (execution)  56756  446  Stop  1  Buy  42.28    Filled  42.28  1  U154743  Open
Fill  2015-11-18 08:53:09.001  CL-201601-NYMEX  IB order fill (execution)  56756  446  Stop  1  Buy  42.28    Filled  42.28  1  U154743  Open    1  0000e9a5.564bdd57.01.01
Order  2015-11-18 08:53:17.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:53:18.002  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      U154743
Order  2015-11-18 08:54:40.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      U154743
Order  2015-11-18 08:54:40.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56758  448  Stop  1  Sell  42.14    Pending Cancel      U154743  Close  56756
Order  2015-11-18 08:54:40.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56757  447  Limit  1  Sell  42.34    Pending Cancel      U154743  Close  56756
Order  2015-11-18 08:54:40.003  CL-201601-NYMEX  IB open order update  56757  447  Limit  1  Sell  42.34    Canceled      U154743  Close  56756
Order  2015-11-18 08:54:40.004  CL-201601-NYMEX  IB order status update  56758  448  Stop  1  Sell  42.14    Canceled      U154743  Close  56756
Order  2015-11-18 08:54:40.005  CL-201601-NYMEX  IB open order update  56757  447  Limit  1  Sell  42.34    Open      U154743  Close  56756
Order  2015-11-18 08:54:40.006  CL-201601-NYMEX  IB order status update  56757  447  Limit  1  Sell  42.34    Canceled      U154743  Close  56756
Order  2015-11-18 08:54:55.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:57:11.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.299999  56760    Limit  1  Buy  42.28    Order Sent      U154743  Open
Order  2015-11-18 08:57:11.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.299999. Attached Order  56761    Limit  1  Sell  42.34    Order Sent      U154743  Close  56760
Order  2015-11-18 08:57:11.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.299999. Attached Order  56762    Stop  1  Sell  42.14    Order Sent      U154743  Close  56760
Order  2015-11-18 08:57:11.003  CL-201601-NYMEX  IB open order update  56761  451  Limit  1  Sell  42.34    Open      U154743  Close  56760
Order  2015-11-18 08:57:11.004  CL-201601-NYMEX  IB open order update  56762  452  Stop  1  Sell  42.14    Open      U154743  Close  56760
Order  2015-11-18 08:57:11.005  CL-201601-NYMEX  IB open order update  56760  450  Limit  1  Buy  42.28    Open      U154743  Open
Order  2015-11-18 08:57:23.000  CL-201601-NYMEX  IB order fill (execution)  56760  450  Limit  1  Buy  42.28    Filled  42.28  1  U154743  Open
Fill  2015-11-18 08:57:23.001  CL-201601-NYMEX  IB order fill (execution)  56760  450  Limit  1  Buy  42.28    Filled  42.28  1  U154743  Open    1  0000e9a5.564bdded.01.01
Order  2015-11-18 08:57:26.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:57:31.000  CL-201601-NYMEX  IB order status update  56762  452  Stop  1  Sell  42.14    Canceled      U154743  Close  56760  1
Order  2015-11-18 08:57:31.001  CL-201601-NYMEX  IB order fill (execution)  56761  451  Limit  1  Sell  42.34    Filled  42.34  1  U154743  Close  56760  1
Fill  2015-11-18 08:57:31.002  CL-201601-NYMEX  IB order fill (execution)  56761  451  Limit  1  Sell  42.34    Filled  42.34  1  U154743  Close      0000e9a5.564bddfa.01.01
Order  2015-11-18 08:57:40.002  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      U154743
Order  2015-11-18 08:58:22.000    Disconnected from server                Unspecified      None
Order  2015-11-18 08:58:51.000    Connected to server                Unspecified      None
Order  2015-11-18 08:58:56.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 08:59:24.000    Disconnected from server                Unspecified      None
Order  2015-11-18 08:59:29.000    Connected to server                Unspecified      None
Order  2015-11-18 08:59:31.000    Disconnected from server                Unspecified      None
Order  2015-11-18 08:59:37.000    Connected to server                Unspecified      None
Order  2015-11-18 08:59:43.000    Disconnected from server                Unspecified      None
Order  2015-11-18 08:59:48.000    Connected to server                Unspecified      None
Order  2015-11-18 08:59:53.000    Disconnected from server                Unspecified      None
Order  2015-11-18 08:59:58.000    Connected to server                Unspecified      None
Order  2015-11-18 09:00:04.000    Disconnected from server                Unspecified      None
Order  2015-11-18 09:00:09.000    Connected to server                Unspecified      None
Order  2015-11-18 09:00:10.000    Disconnected from server                Unspecified      None
Order  2015-11-18 09:00:15.000    Connected to server                Unspecified      None
Order  2015-11-18 09:00:25.000    Disconnected from server                Unspecified      None
Order  2015-11-18 09:00:31.000    Connected to server                Unspecified      None
Order  2015-11-18 09:00:37.000    Disconnected from server                Unspecified      None
Order  2015-11-18 09:00:42.000    Connected to server                Unspecified      None
Order  2015-11-18 09:00:50.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 09:42:42.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.16  56763    Stop  1  Sell  42.14    Order Sent      U154743  Open
Order  2015-11-18 09:42:42.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.16. Attached Order  56764    Limit  1  Buy  42.08    Order Sent      U154743  Close  56763
Order  2015-11-18 09:42:42.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.16. Attached Order  56765    Stop  1  Buy  42.28    Order Sent      U154743  Close  56763
Order  2015-11-18 09:42:42.003  CL-201601-NYMEX  IB open order update  56764  455  Limit  1  Buy  42.08    Open      U154743  Close  56763
Order  2015-11-18 09:42:42.004  CL-201601-NYMEX  IB open order update  56765  456  Stop  1  Buy  42.28    Open      U154743  Close  56763
Order  2015-11-18 09:42:42.005  CL-201601-NYMEX  IB open order update  56763  454  Stop  1  Sell  42.14    Open      U154743  Open
Order  2015-11-18 09:42:57.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 09:45:40.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      U154743
Order  2015-11-18 09:45:40.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56763  454  Stop  1  Sell  42.14    Pending Cancel      U154743  Open
Order  2015-11-18 09:45:40.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56765  456  Stop  1  Buy  42.28    Pending Cancel      U154743  Close  56763
Order  2015-11-18 09:45:40.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56764  455  Limit  1  Buy  42.08    Pending Cancel      U154743  Close  56763
Order  2015-11-18 09:45:40.004  CL-201601-NYMEX  IB order status update  56763  454  Stop  1  Sell  42.14    Canceled      U154743  Open
Order  2015-11-18 09:45:40.005  CL-201601-NYMEX  IB order status update  56764  455  Limit  1  Buy  42.08    Canceled      U154743  Close  56763
Order  2015-11-18 09:45:40.006  CL-201601-NYMEX  IB order status update  56765  456  Stop  1  Buy  42.28    Canceled      U154743  Close  56763
Order  2015-11-18 09:45:55.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 10:43:46.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.079998  56766    Limit  1  Buy  42.07    Order Sent      U154743  Open
Order  2015-11-18 10:43:46.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.079998. Attached Order  56767    Limit  1  Sell  42.13    Order Sent      U154743  Close  56766
Order  2015-11-18 10:43:46.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.079998. Attached Order  56768    Stop  1  Sell  41.93    Order Sent      U154743  Close  56766
Order  2015-11-18 10:43:46.003  CL-201601-NYMEX  IB open order update  56767  458  Limit  1  Sell  42.13    Open      U154743  Close  56766
Order  2015-11-18 10:43:46.004  CL-201601-NYMEX  IB open order update  56768  459  Stop  1  Sell  41.93    Open      U154743  Close  56766
Order  2015-11-18 10:43:46.005  CL-201601-NYMEX  IB open order update  56766  457  Limit  1  Buy  42.07    Open      U154743  Open
Order  2015-11-18 10:44:01.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 10:44:03.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      U154743
Order  2015-11-18 10:44:03.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56766  457  Limit  1  Buy  42.07    Pending Cancel      U154743  Open
Order  2015-11-18 10:44:03.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56768  459  Stop  1  Sell  41.93    Pending Cancel      U154743  Close  56766
Order  2015-11-18 10:44:03.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56767  458  Limit  1  Sell  42.13    Pending Cancel      U154743  Close  56766
Order  2015-11-18 10:44:03.004  CL-201601-NYMEX  IB order status update  56766  457  Limit  1  Buy  42.07    Canceled      U154743  Open
Order  2015-11-18 10:44:03.005  CL-201601-NYMEX  IB order status update  56767  458  Limit  1  Sell  42.13    Canceled      U154743  Close  56766
Order  2015-11-18 10:44:03.006  CL-201601-NYMEX  IB order status update  56768  459  Stop  1  Sell  41.93    Canceled      U154743  Close  56766
Order  2015-11-18 10:44:19.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 11:03:55.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42  56769    Limit  1  Sell  42.02    Order Sent      U154743  Open
Order  2015-11-18 11:03:55.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42. Attached Order  56770    Limit  1  Buy  41.96    Order Sent      U154743  Close  56769
Order  2015-11-18 11:03:55.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42. Attached Order  56771    Stop  1  Buy  42.16    Order Sent      U154743  Close  56769
Order  2015-11-18 11:03:55.003  CL-201601-NYMEX  IB open order update  56770  461  Limit  1  Buy  41.96    Open      U154743  Close  56769
Order  2015-11-18 11:03:56.000  CL-201601-NYMEX  IB open order update  56771  462  Stop  1  Buy  42.16    Open      U154743  Close  56769
Order  2015-11-18 11:03:56.001  CL-201601-NYMEX  IB open order update  56769  460  Limit  1  Sell  42.02    Open      U154743  Open
Order  2015-11-18 11:03:58.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.999999. Requested Quantity: 1  56769  460  Limit  1  Sell  42.02    Pending Modify      U154743  Open
Order  2015-11-18 11:03:58.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 42.00. Requested Price: 41.939999. Requested Quantity: 1  56770  461  Limit  1  Buy  41.96    Pending Modify      U154743  Close  56769
Order  2015-11-18 11:03:58.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 42.00. Requested Price: 42.139999. Requested Quantity: 1  56771  462  Stop  1  Buy  42.16    Pending Modify      U154743  Close  56769
Order  2015-11-18 11:03:58.003  CL-201601-NYMEX  IB open order update  56769  460  Limit  1  Sell  42.00    Open      U154743  Open
Order  2015-11-18 11:03:59.000  CL-201601-NYMEX  IB open order update  56770  461  Limit  1  Buy  41.94    Open      U154743  Close  56769
Order  2015-11-18 11:03:59.001  CL-201601-NYMEX  IB open order update  56771  462  Stop  1  Buy  42.14    Open      U154743  Close  56769
Order  2015-11-18 11:04:14.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 11:04:43.000  CL-201601-NYMEX  IB order fill (execution)  56769  460  Limit  1  Sell  42.00    Filled  42.00  1  U154743  Open
Fill  2015-11-18 11:04:43.001  CL-201601-NYMEX  IB order fill (execution)  56769  460  Limit  1  Sell  42.00    Filled  42.00  1  U154743  Open    -1  0000e9a5.564c0442.01.01
Order  2015-11-18 11:04:53.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      U154743
Order  2015-11-18 11:06:16.000  CL-201601-NYMEX  IB order status update  56771  462  Stop  1  Buy  42.14    Canceled      U154743  Close  56769
Order  2015-11-18 11:06:17.000  CL-201601-NYMEX  IB order fill (execution)  56770  461  Limit  1  Buy  41.94    Filled  41.94  1  U154743  Close  56769
Fill  2015-11-18 11:06:17.001  CL-201601-NYMEX  IB order fill (execution)  56770  461  Limit  1  Buy  41.94    Filled  41.94  1  U154743  Open    1  0000e9a5.564c04a9.01.01
Order  2015-11-18 11:06:26.002  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      U154743
Order  2015-11-18 11:37:17.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:40:35.000    Connected to server                Unspecified      None
Order  2015-11-18 11:40:45.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:40:52.000    Connected to server                Unspecified      None
Order  2015-11-18 11:40:54.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:41:00.000    Connected to server                Unspecified      None
Order  2015-11-18 11:41:04.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:41:09.000    Connected to server                Unspecified      None
Order  2015-11-18 11:41:11.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:41:16.000    Connected to server                Unspecified      None
Order  2015-11-18 11:41:23.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:41:29.000    Connected to server                Unspecified      None
Order  2015-11-18 11:41:35.000    Disconnected from server                Unspecified      None
Order  2015-11-18 11:41:40.000    Connected to server                Unspecified      None
Order  2015-11-18 11:41:49.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 11:42:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.77  56772    Stop  1  Sell  41.72    Order Sent      U154743  Open
Order  2015-11-18 11:42:05.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.77. Attached Order  56773    Limit  1  Buy  41.66    Order Sent      U154743  Close  56772
Order  2015-11-18 11:42:05.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.77. Attached Order  56774    Stop  1  Buy  41.86    Order Sent      U154743  Close  56772
Order  2015-11-18 11:42:05.003  CL-201601-NYMEX  IB open order update  56773  465  Limit  1  Buy  41.66    Open      U154743  Close  56772
Order  2015-11-18 11:42:05.004  CL-201601-NYMEX  IB open order update  56774  466  Stop  1  Buy  41.86    Open      U154743  Close  56772
Order  2015-11-18 11:42:05.005  CL-201601-NYMEX  IB open order update  56772  464  Stop  1  Sell  41.72    Open      U154743  Open
Order  2015-11-18 11:42:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 11:43:54.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      U154743
Order  2015-11-18 11:43:54.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56772  464  Stop  1  Sell  41.72    Pending Cancel      U154743  Open
Order  2015-11-18 11:43:54.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56773  465  Limit  1  Buy  41.66    Pending Cancel      U154743  Close  56772
Order  2015-11-18 11:43:54.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56774  466  Stop  1  Buy  41.86    Pending Cancel      U154743  Close  56772
Order  2015-11-18 11:43:54.004  CL-201601-NYMEX  IB order status update  56772  464  Stop  1  Sell  41.72    Canceled      U154743  Open
Order  2015-11-18 11:43:54.005  CL-201601-NYMEX  IB order status update  56773  465  Limit  1  Buy  41.66    Canceled      U154743  Close  56772
Order  2015-11-18 11:43:54.006  CL-201601-NYMEX  IB order status update  56774  466  Stop  1  Buy  41.86    Canceled      U154743  Close  56772
Order  2015-11-18 11:44:10.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 11:46:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.809998  56775    Stop  1  Sell  41.72    Order Sent      U154743  Open
Order  2015-11-18 11:46:05.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.809998. Attached Order  56776    Limit  1  Buy  41.66    Order Sent      U154743  Close  56775
Order  2015-11-18 11:46:05.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.809998. Attached Order  56777    Stop  1  Buy  41.86    Order Sent      U154743  Close  56775
Order  2015-11-18 11:46:05.003  CL-201601-NYMEX  IB open order update  56776  468  Limit  1  Buy  41.66    Open      U154743  Close  56775
Order  2015-11-18 11:46:06.000  CL-201601-NYMEX  IB open order update  56777  469  Stop  1  Buy  41.86    Open      U154743  Close  56775
Order  2015-11-18 11:46:06.001  CL-201601-NYMEX  IB open order update  56775  467  Stop  1  Sell  41.72    Open      U154743  Open
Order  2015-11-18 11:46:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 11:46:44.000  CL-201601-NYMEX  IB order fill (execution)  56775  467  Stop  1  Sell  41.72    Filled  41.72  1  U154743  Open
Fill  2015-11-18 11:46:44.001  CL-201601-NYMEX  IB order fill (execution)  56775  467  Stop  1  Sell  41.72    Filled  41.72  1  U154743  Open    -1  0000e9a5.564c1130.01.01
Order  2015-11-18 11:46:48.000  CL-201601-NYMEX  IB order status update  56777  469  Stop  1  Buy  41.86    Canceled      U154743  Close  56775  -1
Order  2015-11-18 11:46:48.001  CL-201601-NYMEX  IB order fill (execution)  56776  468  Limit  1  Buy  41.66    Filled  41.66  1  U154743  Close  56775  -1
Fill  2015-11-18 11:46:48.002  CL-201601-NYMEX  IB order fill (execution)  56776  468  Limit  1  Buy  41.66    Filled  41.66  1  U154743  Close      0000e9a5.564c119a.01.01
Order  2015-11-18 11:46:58.002  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      U154743
Order  2015-11-18 15:40:04.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-18 15:49:24.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:50:26.000    Connected to server                Unspecified      None
Order  2015-11-19 04:50:56.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:51:02.000    Connected to server                Unspecified      None
Order  2015-11-19 04:51:10.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:51:15.000    Connected to server                Unspecified      None
Order  2015-11-19 04:51:16.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:51:22.000    Connected to server                Unspecified      None
Order  2015-11-19 04:51:24.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:51:29.000    Connected to server                Unspecified      None
Order  2015-11-19 04:51:31.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:51:36.000    Connected to server                Unspecified      None
Order  2015-11-19 04:51:41.000    Disconnected from server                Unspecified      None
Order  2015-11-19 04:51:46.000    Connected to server                Unspecified      None
Order  2015-11-19 04:51:51.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:07:17.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.48  56778    Limit  1  Buy  41.47    Order Sent      U154743  Open
Order  2015-11-19 08:07:17.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.48. Attached Order  56779    Limit  1  Sell  41.53    Order Sent      U154743  Close  56778
Order  2015-11-19 08:07:17.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.48. Attached Order  56780    Stop  1  Sell  41.33    Order Sent      U154743  Close  56778
Order  2015-11-19 08:07:18.000  CL-201601-NYMEX  IB open order update  56779  472  Limit  1  Sell  41.53    Open      U154743  Close  56778
Order  2015-11-19 08:07:18.001  CL-201601-NYMEX  IB open order update  56780  473  Stop  1  Sell  41.33    Open      U154743  Close  56778
Order  2015-11-19 08:07:18.002  CL-201601-NYMEX  IB open order update  56778  471  Limit  1  Buy  41.47    Open      U154743  Open
Order  2015-11-19 08:07:33.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:07:45.000  CL-201601-NYMEX  IB order fill (execution)  56778  471  Limit  1  Buy  41.47    Filled  41.47  1  U154743  Open
Fill  2015-11-19 08:07:45.001  CL-201601-NYMEX  IB order fill (execution)  56778  471  Limit  1  Buy  41.47    Filled  41.47  1  U154743  Open    1  0000e9a5.564d23c6.01.01
Order  2015-11-19 08:07:52.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56779  472  Limit  1  Sell  41.53    Pending Modify      U154743  Close  56778  1
Order  2015-11-19 08:07:52.001  CL-201601-NYMEX  IB open order update  56779  472  Limit  1  Sell  41.57    Open      U154743  Close  56778  1
Order  2015-11-19 08:07:54.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      U154743
Order  2015-11-19 08:08:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.369999. Requested Quantity: 1  56780  473  Stop  1  Sell  41.33    Pending Modify      U154743  Close  56778
Order  2015-11-19 08:08:05.001  CL-201601-NYMEX  IB open order update  56780  473  Stop  1  Sell  41.37    Open      U154743  Close  56778
Order  2015-11-19 08:08:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:09:05.000  CL-201601-NYMEX  IB open order update  56779  472  Limit    Sell  41.57    Canceled      U154743  Close  56778
Order  2015-11-19 08:09:05.001  CL-201601-NYMEX  IB order fill (execution)  56780  473  Stop  1  Sell  41.37    Filled  41.37  1  U154743  Close  56778
Fill  2015-11-19 08:09:05.002  CL-201601-NYMEX  IB order fill (execution)  56780  473  Stop  1  Sell  41.37    Filled  41.37  1  U154743  Open    -1  0000e9a5.564d2409.01.01
Order  2015-11-19 08:09:14.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      U154743
Order  2015-11-19 08:09:15.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      U154743
Order  2015-11-19 08:10:18.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.439999  56781    Stop  1  Buy  41.51    Order Sent      U154743  Open
Order  2015-11-19 08:10:18.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.439999. Attached Order  56782    Limit  1  Sell  41.57    Order Sent      U154743  Close  56781
Order  2015-11-19 08:10:18.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.439999. Attached Order  56783    Stop  1  Sell  41.37    Order Sent      U154743  Close  56781
Order  2015-11-19 08:10:19.000  CL-201601-NYMEX  IB open order update  56782  475  Limit  1  Sell  41.57    Open      U154743  Close  56781
Order  2015-11-19 08:10:19.001  CL-201601-NYMEX  IB open order update  56783  476  Stop  1  Sell  41.37    Open      U154743  Close  56781
Order  2015-11-19 08:10:19.002  CL-201601-NYMEX  IB open order update  56781  474  Stop  1  Buy  41.51    Open      U154743  Open
Order  2015-11-19 08:10:34.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:13:03.000  CL-201601-NYMEX  IB order fill (execution)  56781  474  Stop  1  Buy  41.51    Filled  41.51  1  U154743  Open
Fill  2015-11-19 08:13:03.001  CL-201601-NYMEX  IB order fill (execution)  56781  474  Stop  1  Buy  41.51    Filled  41.51  1  U154743  Open    1  0000e9a5.564d24df.01.01
Order  2015-11-19 08:13:13.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      U154743
Order  2015-11-19 08:17:32.000  CL-201601-NYMEX  IB open order update  56782  475  Limit    Sell  41.57    Canceled      U154743  Close  56781
Order  2015-11-19 08:17:32.001  CL-201601-NYMEX  IB order fill (execution)  56783  476  Stop  1  Sell  41.37    Filled  41.37  1  U154743  Close  56781
Fill  2015-11-19 08:17:32.002  CL-201601-NYMEX  IB order fill (execution)  56783  476  Stop  1  Sell  41.37    Filled  41.37  1  U154743  Open    -1  0000e9a5.564d259f.01.01
Order  2015-11-19 08:17:39.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      U154743
Order  2015-11-19 08:17:39.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.41. Current Position quantity: -1  56784    Market  1  Buy      Order Sent      U154743  Close    -1
Order  2015-11-19 08:17:39.002  CL-201601-NYMEX  IB order fill (execution)  56784  477  Market  1  Buy      Filled  41.42  1  U154743  Close    -1
Fill  2015-11-19 08:17:39.003  CL-201601-NYMEX  IB order fill (execution)  56784  477  Market  1  Buy      Filled  41.42  1  U154743  Close      0000e9a5.564d25a7.01.01
Order  2015-11-19 08:17:48.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      U154743
Order  2015-11-19 08:17:54.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:27:07.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.540001  56785    Limit  1  Buy  41.58    Order Sent      U154743  Open
Order  2015-11-19 08:27:07.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.540001. Attached Order  56786    Limit  1  Sell  41.64    Order Sent      U154743  Close  56785
Order  2015-11-19 08:27:07.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.540001. Attached Order  56787    Stop  1  Sell  41.44    Order Sent      U154743  Close  56785
Order  2015-11-19 08:27:07.003  CL-201601-NYMEX  IB open order update  56786  479  Limit  1  Sell  41.64    Open      U154743  Close  56785
Order  2015-11-19 08:27:07.004  CL-201601-NYMEX  IB open order update  56787  480  Stop  1  Sell  41.44    Open      U154743  Close  56785
Order  2015-11-19 08:27:07.005  CL-201601-NYMEX  IB open order update. Order reported as Inactive  56785  478  Limit  1  Buy  41.58    Error      U154743  Open
Order  2015-11-19 08:27:07.006  CL-201601-NYMEX  IB order status update  56786  479  Limit  1  Sell  41.64    Canceled      U154743  Close  56785
Order  2015-11-19 08:27:07.007  CL-201601-NYMEX  IB order status update  56787  480  Stop  1  Sell  41.44    Canceled      U154743  Close  56785
Order  2015-11-19 08:27:22.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:27:47.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.599998  56788    Stop  1  Buy  41.57    Order Sent      U154743  Open
Order  2015-11-19 08:27:47.001  CL-201601-NYMEX  IB open order update. Order reported as Inactive  56788  481  Stop  1  Buy  41.57    Error      U154743  Open
Order  2015-11-19 08:28:02.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:50:19.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 08:52:59.000    Disconnected from server                Unspecified      None
Order  2015-11-19 08:58:41.000    Connected to server                Unspecified      None
Order  2015-11-19 08:58:55.000    Disconnected from server                Unspecified      None
Order  2015-11-19 08:59:00.000    Connected to server                Unspecified      None
Order  2015-11-19 08:59:02.000    Disconnected from server                Unspecified      None
Order  2015-11-19 08:59:07.000    Connected to server                Unspecified      None
Order  2015-11-19 08:59:09.000    Disconnected from server                Unspecified      None
Order  2015-11-19 08:59:14.000    Connected to server                Unspecified      None
Order  2015-11-19 08:59:17.000    Disconnected from server                Unspecified      None
Order  2015-11-19 08:59:22.000    Connected to server                Unspecified      None
Order  2015-11-19 08:59:27.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:00:39.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.66  56790    Limit  1  Buy  41.66    Order Sent      DU4779  Open
Order  2015-11-19 09:00:39.001  CL-201601-NYMEX  IB open order update  56790  111565  Limit  1  Buy  41.66    Open      DU4779  Open
Order  2015-11-19 09:00:40.000  CL-201601-NYMEX  IB order fill (execution)  56790  111565  Limit  1  Buy  41.66    Filled  41.66  1  DU4779  Open
Fill  2015-11-19 09:00:40.001  CL-201601-NYMEX  IB order fill (execution)  56790  111565  Limit  1  Buy  41.66    Filled  41.66  1  DU4779  Open    1  0001f4e5.564d20ae.01.01
Order  2015-11-19 09:00:50.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 09:00:54.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:09:37.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.439999  56791    Stop  1  Sell  41.37    Order Sent      DU4779  Open
Order  2015-11-19 09:09:37.001  CL-201601-NYMEX  IB open order update  56791  111566  Stop  1  Sell  41.37    Open      DU4779  Open
Order  2015-11-19 09:09:52.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:09:52.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      DU4779
Order  2015-11-19 09:09:52.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56791  111566  Stop  1  Sell  41.37    Pending Cancel      DU4779  Open
Order  2015-11-19 09:09:52.003  CL-201601-NYMEX  IB order status update  56791  111566  Stop  1  Sell  41.37    Canceled      DU4779  Open
Order  2015-11-19 09:10:07.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:11:37.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.489998  56792    Stop  1  Buy  41.60    Order Sent      DU4779  Open
Order  2015-11-19 09:11:37.001  CL-201601-NYMEX  IB open order update  56792  111567  Stop  1  Buy  41.60    Open      DU4779  Open
Order  2015-11-19 09:11:41.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      DU4779
Order  2015-11-19 09:11:41.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56792  111567  Stop  1  Buy  41.60    Pending Cancel      DU4779  Open
Order  2015-11-19 09:11:41.002  CL-201601-NYMEX  IB order status update  56792  111567  Stop  1  Buy  41.60    Canceled      DU4779  Open
Order  2015-11-19 09:11:56.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:16:59.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.439999  56793    Stop  1  Buy  41.61    Order Sent      DU4779  Open
Order  2015-11-19 09:16:59.001  CL-201601-NYMEX  IB open order update  56793  111568  Stop  1  Buy  41.61    Open      DU4779  Open
Order  2015-11-19 09:17:07.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      DU4779
Order  2015-11-19 09:17:07.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56793  111568  Stop  1  Buy  41.61    Pending Cancel      DU4779  Open
Order  2015-11-19 09:17:07.002  CL-201601-NYMEX  IB order status update  56793  111568  Stop  1  Buy  41.61    Canceled      DU4779  Open
Order  2015-11-19 09:17:22.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:23:37.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 09:23:46.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.5  56794    Stop  1  Buy  41.65    Order Sent      DU4779  Open
Order  2015-11-19 09:23:46.001  CL-201601-NYMEX  IB open order update  56794  111569  Stop  1  Buy  41.65    Open      DU4779  Open
Order  2015-11-19 09:23:52.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      DU4779
Order  2015-11-19 09:23:52.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56794  111569  Stop  1  Buy  41.65    Pending Cancel      DU4779  Open
Order  2015-11-19 09:23:52.002  CL-201601-NYMEX  IB order status update  56794  111569  Stop  1  Buy  41.65    Canceled      DU4779  Open
Order  2015-11-19 09:24:07.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:32:21.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.59  56795    Stop  1  Buy  41.71    Order Sent      DU4779  Open
Order  2015-11-19 09:32:21.001  CL-201601-NYMEX  IB open order update  56795  111570  Stop  1  Buy  41.71    Open      DU4779  Open
Order  2015-11-19 09:32:25.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account                Unspecified      DU4779
Order  2015-11-19 09:32:25.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account  56795  111570  Stop  1  Buy  41.71    Pending Cancel      DU4779  Open
Order  2015-11-19 09:32:25.002  CL-201601-NYMEX  IB order status update  56795  111570  Stop  1  Buy  41.71    Canceled      DU4779  Open
Order  2015-11-19 09:32:40.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:34:52.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.59  56796    Stop  1  Buy  41.72    Order Sent      DU4779  Open
Order  2015-11-19 09:34:52.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.59. Attached Order  56797    Limit  1  Sell  41.78    Order Sent      DU4779  Close  56796
Order  2015-11-19 09:34:52.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.59. Attached Order  56798    Stop  1  Sell  41.58    Order Sent      DU4779  Close  56796
Order  2015-11-19 09:34:53.000  CL-201601-NYMEX  IB open order update  56797  111572  Limit  1  Sell  41.78    Open      DU4779  Close  56796
Order  2015-11-19 09:34:53.001  CL-201601-NYMEX  IB open order update  56798  111573  Stop  1  Sell  41.58    Open      DU4779  Close  56796
Order  2015-11-19 09:34:53.002  CL-201601-NYMEX  IB open order update  56796  111571  Stop  1  Buy  41.72    Open      DU4779  Open
Order  2015-11-19 09:35:07.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:35:12.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.639999. Requested Quantity: 1  56796  111571  Stop  1  Buy  41.72    Pending Modify      DU4779  Open
Order  2015-11-19 09:35:12.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.64. Requested Price: 41.699999. Requested Quantity: 1  56797  111572  Limit  1  Sell  41.78    Pending Modify      DU4779  Close  56796
Order  2015-11-19 09:35:12.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.64. Requested Price: 41.499999. Requested Quantity: 1  56798  111573  Stop  1  Sell  41.58    Pending Modify      DU4779  Close  56796
Order  2015-11-19 09:35:12.003  CL-201601-NYMEX  IB open order update  56796  111571  Stop  1  Buy  41.64    Open      DU4779  Open
Order  2015-11-19 09:35:12.004  CL-201601-NYMEX  IB open order update  56797  111572  Limit  1  Sell  41.70    Open      DU4779  Close  56796
Order  2015-11-19 09:35:12.005  CL-201601-NYMEX  IB open order update  56798  111573  Stop  1  Sell  41.50    Open      DU4779  Close  56796
Order  2015-11-19 09:35:13.000  CL-201601-NYMEX  IB order fill (execution)  56796  111571  Stop  1  Buy  41.64    Filled  41.64  1  DU4779  Open
Fill  2015-11-19 09:35:13.001  CL-201601-NYMEX  IB order fill (execution)  56796  111571  Stop  1  Buy  41.64    Filled  41.64  1  DU4779  Open    1  0001f4e5.564d2758.01.01
Order  2015-11-19 09:35:23.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 09:35:27.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:35:58.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.509999. Requested Quantity: 1  56798  111573  Stop  1  Sell  41.50    Pending Modify      DU4779  Close  56796
Order  2015-11-19 09:35:58.001  CL-201601-NYMEX  IB open order update  56798  111573  Stop  1  Sell  41.51    Open      DU4779  Close  56796
Order  2015-11-19 09:36:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.709999. Requested Quantity: 1  56797  111572  Limit  1  Sell  41.70    Pending Modify      DU4779  Close  56796
Order  2015-11-19 09:36:05.001  CL-201601-NYMEX  IB open order update  56797  111572  Limit  1  Sell  41.71    Open      DU4779  Close  56796
Order  2015-11-19 09:36:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:36:22.000  CL-201601-NYMEX  IB order status update  56798  111573  Stop  1  Sell  41.51    Canceled      DU4779  Close  56796
Order  2015-11-19 09:36:22.001  CL-201601-NYMEX  IB order fill (execution)  56797  111572  Limit  1  Sell  41.71    Filled  41.71  1  DU4779  Close  56796
Fill  2015-11-19 09:36:22.002  CL-201601-NYMEX  IB order fill (execution)  56797  111572  Limit  1  Sell  41.71    Filled  41.71  1  DU4779  Open    -1  0001f4e5.564d286f.01.01
Order  2015-11-19 09:36:31.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 09:36:31.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.68. Current Position quantity: -1  56799    Market  1  Buy      Order Sent      DU4779  Close    -1
Order  2015-11-19 09:36:31.003  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 09:36:32.000  CL-201601-NYMEX  IB order fill (execution)  56799  111574  Market  1  Buy      Filled  41.70  1  DU4779  Close
Fill  2015-11-19 09:36:32.001  CL-201601-NYMEX  IB order fill (execution)  56799  111574  Market  1  Buy      Filled  41.70  1  DU4779  Open    1  0001f4e5.564d28c3.01.01
Order  2015-11-19 09:36:39.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 09:36:39.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.689999. Current Position quantity: 1  56800    Market  1  Sell      Order Sent      DU4779  Close    1
Order  2015-11-19 09:36:39.002  CL-201601-NYMEX  IB order fill (execution)  56800  111575  Market  1  Sell      Filled  41.69  1  DU4779  Close    1
Fill  2015-11-19 09:36:39.003  CL-201601-NYMEX  IB order fill (execution)  56800  111575  Market  1  Sell      Filled  41.69  1  DU4779  Close      0001f4e5.564d28d2.01.01
Order  2015-11-19 09:36:49.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-19 09:36:54.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:38:24.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.700001  56801    Limit  1  Buy  41.71    Order Sent      DU4779  Open
Order  2015-11-19 09:38:24.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.700001. Attached Order  56802    Limit  1  Sell  41.77    Order Sent      DU4779  Close  56801
Order  2015-11-19 09:38:24.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.700001. Attached Order  56803    Stop  1  Sell  41.57    Order Sent      DU4779  Close  56801
Order  2015-11-19 09:38:24.003  CL-201601-NYMEX  IB open order update  56802  111577  Limit  1  Sell  41.77    Open      DU4779  Close  56801
Order  2015-11-19 09:38:24.004  CL-201601-NYMEX  IB open order update  56803  111578  Stop  1  Sell  41.57    Open      DU4779  Close  56801
Order  2015-11-19 09:38:24.005  CL-201601-NYMEX  IB order fill (execution)  56801  111576  Limit  1  Buy  41.71    Filled  41.70  1  DU4779  Open
Fill  2015-11-19 09:38:24.006  CL-201601-NYMEX  IB order fill (execution)  56801  111576  Limit  1  Buy  41.71    Filled  41.70  1  DU4779  Open    1  0001f4e5.564d29cb.01.01
Order  2015-11-19 09:38:32.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.729999. Requested Quantity: 1  56802  111577  Limit  1  Sell  41.77    Pending Modify      DU4779  Close  56801  1
Order  2015-11-19 09:38:33.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 09:38:34.000  CL-201601-NYMEX  IB open order update  56802  111577  Limit  1  Sell  41.73    Open      DU4779  Close  56801
Order  2015-11-19 09:38:35.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.669999. Requested Quantity: 1  56803  111578  Stop  1  Sell  41.57    Pending Modify      DU4779  Close  56801
Order  2015-11-19 09:38:35.001  CL-201601-NYMEX  IB open order update  56803  111578  Stop  1  Sell  41.67    Open      DU4779  Close  56801
Order  2015-11-19 09:38:46.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.679999. Requested Quantity: 1  56803  111578  Stop  1  Sell  41.67    Pending Modify      DU4779  Close  56801
Order  2015-11-19 09:38:46.001  CL-201601-NYMEX  IB open order update  56803  111578  Stop  1  Sell  41.68    Open      DU4779  Close  56801
Order  2015-11-19 09:38:47.000  CL-201601-NYMEX  IB open order update  56802  111577  Limit    Sell  41.73    Canceled      DU4779  Close  56801
Order  2015-11-19 09:38:47.001  CL-201601-NYMEX  IB order fill (execution)  56803  111578  Stop  1  Sell  41.68    Filled  41.68  1  DU4779  Close  56801
Fill  2015-11-19 09:38:47.002  CL-201601-NYMEX  IB order fill (execution)  56803  111578  Stop  1  Sell  41.68    Filled  41.68  1  DU4779  Open    -1  0001f4e5.564d29de.01.01
Order  2015-11-19 09:38:51.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 09:38:51.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.68. Current Position quantity: -1  56804    Market  1  Buy      Order Sent      DU4779  Close    -1
Order  2015-11-19 09:38:51.002  CL-201601-NYMEX  IB order fill (execution)  56804  111579  Market  1  Buy      Filled  41.69  1  DU4779  Close    -1
Fill  2015-11-19 09:38:51.003  CL-201601-NYMEX  IB order fill (execution)  56804  111579  Market  1  Buy      Filled  41.69  1  DU4779  Close      0001f4e5.564d29e2.01.01
Order  2015-11-19 09:39:01.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-19 09:39:06.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 09:46:24.000    Disconnected from server                Unspecified      None
Order  2015-11-19 11:22:28.000    Connected to server                Unspecified      None
Order  2015-11-19 11:22:42.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:22:44.000    Disconnected from server                Unspecified      None
Order  2015-11-19 11:22:49.000    Connected to server                Unspecified      None
Order  2015-11-19 11:22:55.000    Disconnected from server                Unspecified      None
Order  2015-11-19 11:23:00.000    Connected to server                Unspecified      None
Order  2015-11-19 11:23:04.000    Disconnected from server                Unspecified      None
Order  2015-11-19 11:23:09.000    Connected to server                Unspecified      None
Order  2015-11-19 11:23:19.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:23:20.000    Disconnected from server                Unspecified      None
Order  2015-11-19 11:23:25.000    Connected to server                Unspecified      None
Order  2015-11-19 11:23:30.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:24:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.73  56805    Limit  1  Sell  41.75    Order Sent      DU4779  Open
Order  2015-11-19 11:24:05.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.73. Attached Order  56806    Limit  1  Buy  41.69    Order Sent      DU4779  Close  56805
Order  2015-11-19 11:24:05.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.73. Attached Order  56807    Stop  1  Buy  41.89    Order Sent      DU4779  Close  56805
Order  2015-11-19 11:24:05.003  CL-201601-NYMEX  IB open order update  56806  111582  Limit  1  Buy  41.69    Open      DU4779  Close  56805
Order  2015-11-19 11:24:05.004  CL-201601-NYMEX  IB open order update  56807  111583  Stop  1  Buy  41.89    Open      DU4779  Close  56805
Order  2015-11-19 11:24:05.005  CL-201601-NYMEX  IB open order update  56805  111581  Limit  1  Sell  41.75    Open      DU4779  Open
Order  2015-11-19 11:24:09.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.709999. Requested Quantity: 1  56805  111581  Limit  1  Sell  41.75    Pending Modify      DU4779  Open
Order  2015-11-19 11:24:09.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.71. Requested Price: 41.849999. Requested Quantity: 1  56807  111583  Stop  1  Buy  41.89    Pending Modify      DU4779  Close  56805
Order  2015-11-19 11:24:09.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.71. Requested Price: 41.649999. Requested Quantity: 1  56806  111582  Limit  1  Buy  41.69    Pending Modify      DU4779  Close  56805
Order  2015-11-19 11:24:09.003  CL-201601-NYMEX  IB open order update  56806  111582  Limit  1  Buy  41.65    Pending Open      DU4779  Close  56805
Order  2015-11-19 11:24:09.004  CL-201601-NYMEX  IB open order update  56807  111583  Stop  1  Buy  41.85    Pending Open      DU4779  Close  56805
Fill  2015-11-19 11:24:09.005  CL-201601-NYMEX  IB order fill (execution)  56805  111581  Limit  1  Sell  41.75    Pending Modify  41.71  1  DU4779  Open    -1  0001f4e5.564d4cff.01.01
Order  2015-11-19 11:24:09.006  CL-201601-NYMEX  IB open order update  56805  111581  Limit  1  Sell  41.71    Pending Open  41.71  1  DU4779  Open    -1
Order  2015-11-19 11:24:09.007  CL-201601-NYMEX  IB open order update  56805  111581  Limit  1  Sell  41.71    Filled  41.71  1  DU4779  Open    -1
Order  2015-11-19 11:24:09.008  CL-201601-NYMEX  IB open order update  56807  111583  Stop  1  Buy  41.85    Open      DU4779  Close  56805  -1
Order  2015-11-19 11:24:10.000  CL-201601-NYMEX  IB open order update  56806  111582  Limit  1  Buy  41.65    Open      DU4779  Close  56805  -1
Order  2015-11-19 11:24:19.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 11:24:24.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:24:37.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.699999. Requested Quantity: 1  56806  111582  Limit  1  Buy  41.65    Pending Modify      DU4779  Close  56805
Order  2015-11-19 11:24:37.001  CL-201601-NYMEX  IB order status update  56807  111583  Stop  1  Buy  41.85    Canceled      DU4779  Close  56805
Fill  2015-11-19 11:24:37.002  CL-201601-NYMEX  IB order fill (execution)  56806  111582  Limit  1  Buy  41.65    Pending Modify  41.70  1  DU4779  Open    1  0001f4e5.564d4d20.01.01
Order  2015-11-19 11:24:37.003  CL-201601-NYMEX  IB open order update  56806  111582  Limit  1  Buy  41.70    Pending Open  41.70  1  DU4779  Close  56805  1
Order  2015-11-19 11:24:37.004  CL-201601-NYMEX  IB open order update  56806  111582  Limit  1  Buy  41.70    Filled  41.70  1  DU4779  Close  56805  1
Order  2015-11-19 11:24:45.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 11:24:45.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.689999. Current Position quantity: 1  56808    Market  1  Sell      Order Sent      DU4779  Close    1
Order  2015-11-19 11:24:45.002  CL-201601-NYMEX  IB order fill (execution)  56808  111584  Market  1  Sell      Filled  41.68  1  DU4779  Close    1
Fill  2015-11-19 11:24:45.003  CL-201601-NYMEX  IB order fill (execution)  56808  111584  Market  1  Sell      Filled  41.68  1  DU4779  Close      0001f4e5.564d4d24.01.01
Order  2015-11-19 11:24:54.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-19 11:25:00.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:25:07.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 11:25:51.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 11:29:14.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.75  56810    Stop  1  Buy  41.73    Order Sent      DU4779  Open
Order  2015-11-19 11:29:14.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.75. Attached Order  56811    Limit  1  Sell  41.79    Order Sent      DU4779  Close  56810
Order  2015-11-19 11:29:14.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.75. Attached Order  56812    Stop  1  Sell  41.59    Order Sent      DU4779  Close  56810
Order  2015-11-19 11:29:14.003  CL-201601-NYMEX  IB open order update  56811  111587  Limit  1  Sell  41.79    Open      DU4779  Close  56810
Order  2015-11-19 11:29:14.004  CL-201601-NYMEX  IB open order update  56812  111588  Stop  1  Sell  41.59    Open      DU4779  Close  56810
Order  2015-11-19 11:29:14.005  CL-201601-NYMEX  IB open order update  56810  111586  Stop  1  Buy  41.73    Open      DU4779  Open
Order  2015-11-19 11:29:16.000  CL-201601-NYMEX  IB order fill (execution)  56810  111586  Stop  1  Buy  41.73    Filled  41.78  1  DU4779  Open
Fill  2015-11-19 11:29:16.001  CL-201601-NYMEX  IB order fill (execution)  56810  111586  Stop  1  Buy  41.73    Filled  41.78  1  DU4779  Open    1  0001f4e5.564d4e66.01.01
Order  2015-11-19 11:29:19.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.839999. Requested Quantity: 1  56811  111587  Limit  1  Sell  41.79    Pending Modify      DU4779  Close  56810  1
Order  2015-11-19 11:29:19.001  CL-201601-NYMEX  IB open order update  56811  111587  Limit  1  Sell  41.84    Open      DU4779  Close  56810  1
Order  2015-11-19 11:29:25.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 11:29:26.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.849999. Requested Quantity: 1  56811  111587  Limit  1  Sell  41.84    Pending Modify      DU4779  Close  56810
Order  2015-11-19 11:29:26.001  CL-201601-NYMEX  IB open order update  56811  111587  Limit  1  Sell  41.85    Open      DU4779  Close  56810
Order  2015-11-19 11:29:26.002  CL-201601-NYMEX  User order modification ignored. New price is the same  56811  111587  Limit  1  Sell  41.85    Open      DU4779  Close  56810
Order  2015-11-19 11:29:37.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.779999. Requested Quantity: 1  56812  111588  Stop  1  Sell  41.59    Pending Modify      DU4779  Close  56810
Order  2015-11-19 11:29:37.001  CL-201601-NYMEX  IB open order update  56812  111588  Stop  1  Sell  41.78    Open      DU4779  Close  56810
Order  2015-11-19 11:29:37.002  CL-201601-NYMEX  IB open order update  56811  111587  Limit    Sell  41.85    Canceled      DU4779  Close  56810
Order  2015-11-19 11:29:37.003  CL-201601-NYMEX  IB order fill (execution)  56812  111588  Stop  1  Sell  41.78    Filled  41.77  1  DU4779  Close  56810
Fill  2015-11-19 11:29:37.004  CL-201601-NYMEX  IB order fill (execution)  56812  111588  Stop  1  Sell  41.78    Filled  41.77  1  DU4779  Open    -1  0001f4e5.564d4e87.01.01
Order  2015-11-19 11:29:42.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 11:29:42.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.790001. Current Position quantity: -1  56813    Market  1  Buy      Order Sent      DU4779  Close    -1
Order  2015-11-19 11:29:42.002  CL-201601-NYMEX  IB order fill (execution)  56813  111589  Market  1  Buy      Filled  41.82  1  DU4779  Close    -1
Fill  2015-11-19 11:29:42.003  CL-201601-NYMEX  IB order fill (execution)  56813  111589  Market  1  Buy      Filled  41.82  1  DU4779  Close      0001f4e5.564d4e8d.01.01
Order  2015-11-19 11:29:52.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-19 11:29:57.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:33:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.809998  56814    Limit  1  Buy  41.80    Order Sent      DU4779  Open
Order  2015-11-19 11:33:05.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.809998. Attached Order  56815    Limit  1  Sell  41.86    Order Sent      DU4779  Close  56814
Order  2015-11-19 11:33:05.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.809998. Attached Order  56816    Stop  1  Sell  41.66    Order Sent      DU4779  Close  56814
Order  2015-11-19 11:33:05.003  CL-201601-NYMEX  IB open order update  56815  111591  Limit  1  Sell  41.86    Open      DU4779  Close  56814
Order  2015-11-19 11:33:05.004  CL-201601-NYMEX  IB open order update  56816  111592  Stop  1  Sell  41.66    Open      DU4779  Close  56814
Order  2015-11-19 11:33:05.005  CL-201601-NYMEX  IB open order update  56814  111590  Limit  1  Buy  41.80    Open      DU4779  Open
Order  2015-11-19 11:33:06.000  CL-201601-NYMEX  IB order fill (execution)  56814  111590  Limit  1  Buy  41.80    Filled  41.80  1  DU4779  Open
Fill  2015-11-19 11:33:06.001  CL-201601-NYMEX  IB order fill (execution)  56814  111590  Limit  1  Buy  41.80    Filled  41.80  1  DU4779  Open    1  0001f4e5.564d4f85.01.01
Order  2015-11-19 11:33:15.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 11:33:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:33:24.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.759999. Requested Quantity: 1  56816  111592  Stop  1  Sell  41.66    Pending Modify      DU4779  Close  56814
Order  2015-11-19 11:33:24.001  CL-201601-NYMEX  IB open order update  56816  111592  Stop  1  Sell  41.76    Open      DU4779  Close  56814
Order  2015-11-19 11:33:25.000  CL-201601-NYMEX  IB open order update  56815  111591  Limit    Sell  41.86    Canceled      DU4779  Close  56814
Order  2015-11-19 11:33:25.001  CL-201601-NYMEX  IB order fill (execution)  56816  111592  Stop  1  Sell  41.76    Filled  41.76  1  DU4779  Close  56814
Fill  2015-11-19 11:33:25.002  CL-201601-NYMEX  IB order fill (execution)  56816  111592  Stop  1  Sell  41.76    Filled  41.76  1  DU4779  Open    -1  0001f4e5.564d4f94.01.01
Order  2015-11-19 11:33:28.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 11:33:28.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.759998. Current Position quantity: -1  56817    Market  1  Buy      Order Sent      DU4779  Close    -1
Order  2015-11-19 11:33:29.000  CL-201601-NYMEX  IB order fill (execution)  56817  111593  Market  1  Buy      Filled  41.77  1  DU4779  Close    -1
Fill  2015-11-19 11:33:29.001  CL-201601-NYMEX  IB order fill (execution)  56817  111593  Market  1  Buy      Filled  41.77  1  DU4779  Close      0001f4e5.564d4f95.01.01
Order  2015-11-19 11:33:38.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-19 11:33:43.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 11:33:56.000    Disconnected from server                Unspecified      None
Order  2015-11-19 12:18:17.000    Connected to server                Unspecified      None
Order  2015-11-19 12:18:22.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:19:15.000    Disconnected from server                Unspecified      None
Order  2015-11-19 12:19:20.000    Connected to server                Unspecified      None
Order  2015-11-19 12:19:24.000    Disconnected from server                Unspecified      None
Order  2015-11-19 12:19:30.000    Connected to server                Unspecified      None
Order  2015-11-19 12:19:33.000    Disconnected from server                Unspecified      None
Order  2015-11-19 12:19:38.000    Connected to server                Unspecified      None
Order  2015-11-19 12:19:42.000    Disconnected from server                Unspecified      None
Order  2015-11-19 12:19:47.000    Connected to server                Unspecified      None
Order  2015-11-19 12:19:51.000    Disconnected from server                Unspecified      None
Order  2015-11-19 12:19:56.000    Connected to server                Unspecified      None
Order  2015-11-19 12:20:02.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:20:16.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.559998  56819    Stop  1  Sell  41.50    Order Sent      DU4779  Open
Order  2015-11-19 12:20:16.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.559998. Attached Order  56820    Limit  1  Buy  41.44    Order Sent      DU4779  Close  56819
Order  2015-11-19 12:20:16.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.559998. Attached Order  56821    Stop  1  Buy  41.68    Order Sent      DU4779  Close  56819
Order  2015-11-19 12:20:16.003  CL-201601-NYMEX  IB open order update  56820  111597  Limit  1  Buy  41.44    Open      DU4779  Close  56819
Order  2015-11-19 12:20:17.000  CL-201601-NYMEX  IB open order update  56821  111598  Stop  1  Buy  41.68    Open      DU4779  Close  56819
Order  2015-11-19 12:20:17.001  CL-201601-NYMEX  IB open order update  56819  111596  Stop  1  Sell  41.50    Open      DU4779  Open
Order  2015-11-19 12:20:24.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.559999. Requested Quantity: 1  56819  111596  Stop  1  Sell  41.50    Pending Modify      DU4779  Open
Order  2015-11-19 12:20:24.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.56. Requested Price: 41.499999. Requested Quantity: 1  56820  111597  Limit  1  Buy  41.44    Pending Modify      DU4779  Close  56819
Order  2015-11-19 12:20:24.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.56. Requested Price: 41.739999. Requested Quantity: 1  56821  111598  Stop  1  Buy  41.68    Pending Modify      DU4779  Close  56819
Order  2015-11-19 12:20:24.003  CL-201601-NYMEX  IB open order update  56819  111596  Stop  1  Sell  41.56    Open      DU4779  Open
Order  2015-11-19 12:20:24.004  CL-201601-NYMEX  IB open order update  56820  111597  Limit  1  Buy  41.50    Open      DU4779  Close  56819
Order  2015-11-19 12:20:24.005  CL-201601-NYMEX  IB open order update  56821  111598  Stop  1  Buy  41.74    Open      DU4779  Close  56819
Order  2015-11-19 12:20:25.000  CL-201601-NYMEX  IB order fill (execution)  56819  111596  Stop  1  Sell  41.56    Filled  41.55  1  DU4779  Open
Fill  2015-11-19 12:20:25.001  CL-201601-NYMEX  IB order fill (execution)  56819  111596  Stop  1  Sell  41.56    Filled  41.55  1  DU4779  Open    -1  0001f4e5.564d597c.01.01
Order  2015-11-19 12:20:33.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 12:20:39.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:20:56.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist. Working orders will be canceled                Unspecified      DU4779
Order  2015-11-19 12:20:56.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 12:20:56.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.  56821  111598  Stop  1  Buy  41.74    Pending Cancel      DU4779  Close  56819
Order  2015-11-19 12:20:56.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.  56820  111597  Limit  1  Buy  41.50    Pending Cancel      DU4779  Close  56819
Order  2015-11-19 12:20:56.004  CL-201601-NYMEX  IB open order update  56820  111597  Limit  1  Buy  41.50    Canceled      DU4779  Close  56819
Order  2015-11-19 12:20:56.005  CL-201601-NYMEX  IB order status update  56821  111598  Stop  1  Buy  41.74    Canceled      DU4779  Close  56819
Order  2015-11-19 12:21:11.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:35:05.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.610001  56823    Market  1  Buy      Order Sent      DU4779  Open
Order  2015-11-19 12:35:05.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.610001. Attached Order  56824    Limit  1  Sell  41.68    Order Sent      DU4779  Close  56823
Order  2015-11-19 12:35:05.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.610001. Attached Order  56825    Stop  1  Sell  41.44    Order Sent      DU4779  Close  56823
Order  2015-11-19 12:35:05.003  CL-201601-NYMEX  IB open order update  56824  111601  Limit  1  Sell  41.68    Open      DU4779  Close  56823
Order  2015-11-19 12:35:05.004  CL-201601-NYMEX  IB open order update  56825  111602  Stop  1  Sell  41.44    Open      DU4779  Close  56823
Order  2015-11-19 12:35:05.005  CL-201601-NYMEX  IB order fill (execution)  56823  111600  Market  1  Buy      Filled  41.62  1  DU4779  Open
Fill  2015-11-19 12:35:05.006  CL-201601-NYMEX  IB order fill (execution)  56823  111600  Market  1  Buy      Filled  41.62  1  DU4779  Open    1  0001f4e5.564d5c21.01.01
Order  2015-11-19 12:35:14.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 12:35:20.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:35:25.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist. Working orders will be canceled                Unspecified      DU4779
Order  2015-11-19 12:35:25.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 12:35:25.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.  56824  111601  Limit  1  Sell  41.68    Pending Cancel      DU4779  Close  56823
Order  2015-11-19 12:35:25.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.  56825  111602  Stop  1  Sell  41.44    Pending Cancel      DU4779  Close  56823
Order  2015-11-19 12:35:25.004  CL-201601-NYMEX  IB order status update  56825  111602  Stop  1  Sell  41.44    Canceled      DU4779  Close  56823
Order  2015-11-19 12:35:26.000  CL-201601-NYMEX  IB order status update  56824  111601  Limit  1  Sell  41.68    Canceled      DU4779  Close  56823
Order  2015-11-19 12:35:27.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 12:35:40.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:46:40.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.599998. Attached Order  56828    Limit    Buy  41.51    Pending Child      DU4779  Close  56827
Order  2015-11-19 12:46:40.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.599998. Attached Order  56829    Stop    Buy  41.75    Pending Child      DU4779  Close  56827
Order  2015-11-19 12:46:40.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.599998  56827    Stop  1  Sell  41.57    Order Sent      DU4779  Open
Order  2015-11-19 12:46:40.003  CL-201601-NYMEX  IB open order update  56827  111604  Stop  1  Sell  41.57    Open      DU4779  Open
Order  2015-11-19 12:46:44.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.609999. Requested Quantity: 1  56827  111604  Stop  1  Sell  41.57    Pending Modify      DU4779  Open
Order  2015-11-19 12:46:44.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.61. Requested Price: 41.549999. Requested Quantity: 0  56828    Limit    Buy  41.51    Pending Modify      DU4779  Close  56827
Order  2015-11-19 12:46:44.002  CL-201601-NYMEX  Order modified internally  56828    Limit    Buy  41.55    Pending Child      DU4779  Close  56827
Order  2015-11-19 12:46:44.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.61. Requested Price: 41.789999. Requested Quantity: 0  56829    Stop    Buy  41.75    Pending Modify      DU4779  Close  56827
Order  2015-11-19 12:46:44.004  CL-201601-NYMEX  Order modified internally  56829    Stop    Buy  41.79    Pending Child      DU4779  Close  56827
Order  2015-11-19 12:46:44.005  CL-201601-NYMEX  IB open order update  56827  111604  Stop  1  Sell  41.61    Open      DU4779  Open
Order  2015-11-19 12:46:46.000  CL-201601-NYMEX  IB order fill (execution)  56827  111604  Stop  1  Sell  41.61    Filled  41.60  1  DU4779  Open
Fill  2015-11-19 12:46:46.001  CL-201601-NYMEX  IB order fill (execution)  56827  111604  Stop  1  Sell  41.61    Filled  41.60  1  DU4779  Open    -1  0001f4e5.564d5de2.01.01
Order  2015-11-19 12:46:46.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.60. Requested Price: 41.539999. Requested Quantity: 0  56828    Limit    Buy  41.55    Pending Modify      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.003  CL-201601-NYMEX  Order modified internally  56828    Limit    Buy  41.54    Pending Child      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.004  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.60. Requested Price: 41.779999. Requested Quantity: 0  56829    Stop    Buy  41.79    Pending Modify      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.005  CL-201601-NYMEX  Order modified internally  56829    Stop    Buy  41.78    Pending Child      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.006  CL-201601-NYMEX  Auto-sent child from parent fill  56828    Limit  1  Buy  41.54    Order Sent      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.007  CL-201601-NYMEX  Auto-sent child from parent fill  56829    Stop  1  Buy  41.78    Order Sent      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.008  CL-201601-NYMEX  IB open order update  56828  111605  Limit  1  Buy  41.54    Open      DU4779  Close  56827  -1
Order  2015-11-19 12:46:46.009  CL-201601-NYMEX  IB open order update  56829  111606  Stop  1  Buy  41.78    Open      DU4779  Close  56827  -1
Order  2015-11-19 12:46:55.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 12:47:01.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:47:03.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.619999. Requested Quantity: 1  56828  111605  Limit  1  Buy  41.54    Pending Modify      DU4779  Close  56827
Order  2015-11-19 12:47:03.001  CL-201601-NYMEX  IB open order update  56828  111605  Limit  1  Buy  41.62    Open      DU4779  Close  56827
Order  2015-11-19 12:47:07.000  CL-201601-NYMEX  IB order fill (execution)  56828  111605  Limit  1  Buy  41.62    Filled  41.62  1  DU4779  Close  56827
Fill  2015-11-19 12:47:07.001  CL-201601-NYMEX  IB order fill (execution)  56828  111605  Limit  1  Buy  41.62    Filled  41.62  1  DU4779  Open    1  0001f4e5.564d5deb.01.01
Order  2015-11-19 12:47:07.002  CL-201601-NYMEX  Canceling order due to sibling fill  56829  111606  Stop  1  Buy  41.78    Pending Cancel      DU4779  Close  56827  1
Order  2015-11-19 12:47:07.003  CL-201601-NYMEX  User order modification ignored. New price is the same  56828  111605  Limit  1  Buy  41.62    Filled  41.62  1  DU4779  Close  56827
Order  2015-11-19 12:47:09.000  CL-201601-NYMEX  IB order status update  56829  111606  Stop  1  Buy  41.78    Canceled      DU4779  Close  56827  1
Order  2015-11-19 12:47:13.000  CL-201601-NYMEX  Canceling all orders for Symbol and Account. Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 12:47:13.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry. Flatten&Cancel | Last: 41.610001. Current Position quantity: 1  56830    Market  1  Sell      Order Sent      DU4779  Close    1
Order  2015-11-19 12:47:13.002  CL-201601-NYMEX  IB order fill (execution)  56830  111607  Market  1  Sell      Filled  41.61  1  DU4779  Close    1
Fill  2015-11-19 12:47:13.003  CL-201601-NYMEX  IB order fill (execution)  56830  111607  Market  1  Sell      Filled  41.61  1  DU4779  Close      0001f4e5.564d5df0.01.01
Order  2015-11-19 12:47:23.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-19 12:47:28.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 12:56:02.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.579998. Attached Order  56832    Limit    Sell  41.63    Pending Child      DU4779  Close  56831
Order  2015-11-19 12:56:02.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.579998. Attached Order  56833    Stop    Sell  41.39    Pending Child      DU4779  Close  56831
Order  2015-11-19 12:56:02.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.579998  56831    Stop  1  Buy  41.57    Order Sent      DU4779  Open
Order  2015-11-19 12:56:02.003  CL-201601-NYMEX  IB open order update  56831  111608  Stop  1  Buy  41.57    Open      DU4779  Open
Order  2015-11-19 12:56:06.000  CL-201601-NYMEX  IB order fill (execution)  56831  111608  Stop  1  Buy  41.57    Filled  41.58  1  DU4779  Open
Fill  2015-11-19 12:56:06.001  CL-201601-NYMEX  IB order fill (execution)  56831  111608  Stop  1  Buy  41.57    Filled  41.58  1  DU4779  Open    1  0001f4e5.564d5f01.01.01
Order  2015-11-19 12:56:06.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.58. Requested Price: 41.639999. Requested Quantity: 0  56832    Limit    Sell  41.63    Pending Modify      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.003  CL-201601-NYMEX  Order modified internally  56832    Limit    Sell  41.64    Pending Child      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.004  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.58. Requested Price: 41.399999. Requested Quantity: 0  56833    Stop    Sell  41.39    Pending Modify      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.005  CL-201601-NYMEX  Order modified internally  56833    Stop    Sell  41.40    Pending Child      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.006  CL-201601-NYMEX  Auto-sent child from parent fill  56832    Limit  1  Sell  41.64    Order Sent      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.007  CL-201601-NYMEX  Auto-sent child from parent fill  56833    Stop  1  Sell  41.40    Order Sent      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.008  CL-201601-NYMEX  Unable to modify order because it is no longer working  56831  111608  Stop  1  Buy  41.57    Filled  41.58  1  DU4779  Open
Order  2015-11-19 12:56:06.009  CL-201601-NYMEX  IB open order update  56832  111609  Limit  1  Sell  41.64    Open      DU4779  Close  56831  1
Order  2015-11-19 12:56:06.010  CL-201601-NYMEX  IB open order update  56833  111610  Stop  1  Sell  41.40    Open      DU4779  Close  56831  1
Order  2015-11-19 12:56:14.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.699999. Requested Quantity: 1  56832  111609  Limit  1  Sell  41.64    Pending Modify      DU4779  Close  56831  1
Order  2015-11-19 12:56:14.001  CL-201601-NYMEX  IB open order update  56832  111609  Limit  1  Sell  41.70    Open      DU4779  Close  56831  1
Order  2015-11-19 12:56:15.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 12:56:28.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.559999. Requested Quantity: 1  56833  111610  Stop  1  Sell  41.40    Pending Modify      DU4779  Close  56831
Order  2015-11-19 12:56:28.001  CL-201601-NYMEX  IB open order update  56833  111610  Stop  1  Sell  41.56    Open      DU4779  Close  56831
Order  2015-11-19 12:56:39.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56833  111610  Stop  1  Sell  41.56    Pending Modify      DU4779  Close  56831
Order  2015-11-19 12:56:39.001  CL-201601-NYMEX  IB open order update  56833  111610  Stop  1  Sell  41.57    Open      DU4779  Close  56831
Order  2015-11-19 12:56:39.002  CL-201601-NYMEX  IB order fill (execution)  56833  111610  Stop  1  Sell  41.57    Filled  41.57  1  DU4779  Close  56831
Fill  2015-11-19 12:56:39.003  CL-201601-NYMEX  IB order fill (execution)  56833  111610  Stop  1  Sell  41.57    Filled  41.57  1  DU4779  Open    -1  0001f4e5.564d5f1b.01.01
Order  2015-11-19 12:56:39.004  CL-201601-NYMEX  Canceling order due to sibling fill  56832  111609  Limit  1  Sell  41.70    Pending Cancel      DU4779  Close  56831  -1
Order  2015-11-19 12:56:39.005  CL-201601-NYMEX  IB order status update  56832  111609  Limit  1  Sell  41.70    Canceled      DU4779  Close  56831  -1
Order  2015-11-19 12:56:51.000  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 12:56:52.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 12:56:55.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 13:08:53.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.57. Attached Order  56835    Limit    Buy  41.52    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:08:53.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.57. Attached Order  56836    Stop    Buy  41.76    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:08:53.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.57  56834    Limit  1  Sell  41.58    Order Sent      DU4779  Open
Order  2015-11-19 13:08:53.003  CL-201601-NYMEX  IB open order update  56834  111611  Limit  1  Sell  41.58    Open      DU4779  Open
Order  2015-11-19 13:08:59.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56834  111611  Limit  1  Sell  41.58    Pending Modify      DU4779  Open
Order  2015-11-19 13:08:59.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.57. Requested Price: 41.509999. Requested Quantity: 0  56835    Limit    Buy  41.52    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:08:59.002  CL-201601-NYMEX  Order modified internally  56835    Limit    Buy  41.51    Pending Child      DU4779  Close  56834
Order  2015-11-19 13:08:59.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.57. Requested Price: 41.749999. Requested Quantity: 0  56836    Stop    Buy  41.76    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:08:59.004  CL-201601-NYMEX  Order modified internally  56836    Stop    Buy  41.75    Pending Child      DU4779  Close  56834
Fill  2015-11-19 13:09:00.000  CL-201601-NYMEX  IB order fill (execution)  56834  111611  Limit  1  Sell  41.58    Pending Modify  41.57  1  DU4779  Open    -1  0001f4e5.564d61b8.01.01
Order  2015-11-19 13:09:00.001  CL-201601-NYMEX  Auto-sent child from parent fill  56835    Limit  1  Buy  41.51    Order Sent      DU4779  Close  56834  -1
Order  2015-11-19 13:09:00.002  CL-201601-NYMEX  Auto-sent child from parent fill  56836    Stop  1  Buy  41.75    Order Sent      DU4779  Close  56834  -1
Order  2015-11-19 13:09:00.003  CL-201601-NYMEX  IB open order update  56834  111611  Limit  1  Sell  41.57    Pending Open  41.57  1  DU4779  Open    -1
Order  2015-11-19 13:09:00.004  CL-201601-NYMEX  IB open order update  56834  111611  Limit  1  Sell  41.57    Filled  41.57  1  DU4779  Open    -1
Order  2015-11-19 13:09:00.005  CL-201601-NYMEX  IB open order update  56835  111612  Limit  1  Buy  41.51    Open      DU4779  Close  56834  -1
Order  2015-11-19 13:09:00.006  CL-201601-NYMEX  IB open order update  56836  111613  Stop  1  Buy  41.75    Open      DU4779  Close  56834  -1
Order  2015-11-19 13:09:09.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 13:09:15.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 13:09:24.000  CL-201601-NYMEX  User order modification ignored. New price is the same  56835  111612  Limit  1  Buy  41.51    Open      DU4779  Close  56834
Order  2015-11-19 13:09:29.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56836  111613  Stop  1  Buy  41.75    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:09:29.001  CL-201601-NYMEX  IB open order update  56836  111613  Stop  1  Buy  41.72    Open      DU4779  Close  56834
Order  2015-11-19 13:09:35.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.559999. Requested Quantity: 1  56835  111612  Limit  1  Buy  41.51    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:09:35.001  CL-201601-NYMEX  IB open order update  56835  111612  Limit  1  Buy  41.56    Open      DU4779  Close  56834
Order  2015-11-19 13:09:38.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56835  111612  Limit  1  Buy  41.56    Pending Modify      DU4779  Close  56834
Order  2015-11-19 13:09:38.001  CL-201601-NYMEX  IB open order update  56835  111612  Limit  1  Buy  41.57    Open      DU4779  Close  56834
Order  2015-11-19 13:09:49.000  CL-201601-NYMEX  IB order fill (execution)  56835  111612  Limit  1  Buy  41.57    Filled  41.57  1  DU4779  Close  56834
Fill  2015-11-19 13:09:49.001  CL-201601-NYMEX  IB order fill (execution)  56835  111612  Limit  1  Buy  41.57    Filled  41.57  1  DU4779  Open    1  0001f4e5.564d61dc.01.01
Order  2015-11-19 13:09:49.002  CL-201601-NYMEX  Canceling order due to sibling fill  56836  111613  Stop  1  Buy  41.72    Pending Cancel      DU4779  Close  56834  1
Order  2015-11-19 13:09:49.003  CL-201601-NYMEX  IB order status update  56836  111613  Stop  1  Buy  41.72    Canceled      DU4779  Close  56834  1
Order  2015-11-19 13:09:58.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 13:09:59.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 13:10:04.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 15:37:11.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.700001. Attached Order  56839    Limit    Buy  41.62    Pending Child      DU4779  Close  56838
Order  2015-11-19 15:37:11.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.700001. Attached Order  56840    Stop    Buy  41.86    Pending Child      DU4779  Close  56838
Order  2015-11-19 15:37:11.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.700001  56838    Stop  1  Sell  41.68    Order Sent      DU4779  Open
Order  2015-11-19 15:37:11.003  CL-201601-NYMEX  IB open order update  56838  111615  Stop  1  Sell  41.68    Open      DU4779  Open
Order  2015-11-19 15:37:14.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.699999. Requested Quantity: 1  56838  111615  Stop  1  Sell  41.68    Pending Modify      DU4779  Open
Order  2015-11-19 15:37:14.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.70. Requested Price: 41.639999. Requested Quantity: 0  56839    Limit    Buy  41.62    Pending Modify      DU4779  Close  56838
Order  2015-11-19 15:37:14.002  CL-201601-NYMEX  Order modified internally  56839    Limit    Buy  41.64    Pending Child      DU4779  Close  56838
Order  2015-11-19 15:37:14.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.70. Requested Price: 41.879999. Requested Quantity: 0  56840    Stop    Buy  41.86    Pending Modify      DU4779  Close  56838
Order  2015-11-19 15:37:14.004  CL-201601-NYMEX  Order modified internally  56840    Stop    Buy  41.88    Pending Child      DU4779  Close  56838
Order  2015-11-19 15:37:14.005  CL-201601-NYMEX  IB open order update  56838  111615  Stop  1  Sell  41.70    Open      DU4779  Open
Order  2015-11-19 15:37:15.000  CL-201601-NYMEX  IB order fill (execution)  56838  111615  Stop  1  Sell  41.70    Filled  41.68  1  DU4779  Open
Fill  2015-11-19 15:37:15.001  CL-201601-NYMEX  IB order fill (execution)  56838  111615  Stop  1  Sell  41.70    Filled  41.68  1  DU4779  Open    -1  0001f4e5.564d7613.01.01
Order  2015-11-19 15:37:15.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.68. Requested Price: 41.619999. Requested Quantity: 0  56839    Limit    Buy  41.64    Pending Modify      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.003  CL-201601-NYMEX  Order modified internally  56839    Limit    Buy  41.62    Pending Child      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.004  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.68. Requested Price: 41.859999. Requested Quantity: 0  56840    Stop    Buy  41.88    Pending Modify      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.005  CL-201601-NYMEX  Order modified internally  56840    Stop    Buy  41.86    Pending Child      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.006  CL-201601-NYMEX  Auto-sent child from parent fill  56839    Limit  1  Buy  41.62    Order Sent      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.007  CL-201601-NYMEX  Auto-sent child from parent fill  56840    Stop  1  Buy  41.86    Order Sent      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.008  CL-201601-NYMEX  IB open order update  56839  111616  Limit  1  Buy  41.62    Open      DU4779  Close  56838  -1
Order  2015-11-19 15:37:15.009  CL-201601-NYMEX  IB open order update  56840  111617  Stop  1  Buy  41.86    Open      DU4779  Close  56838  -1
Order  2015-11-19 15:37:25.001  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  2015-11-19 15:37:31.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 15:37:54.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist. Working orders will be canceled                Unspecified      DU4779
Order  2015-11-19 15:37:54.001  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.                Unspecified      DU4779
Order  2015-11-19 15:37:54.002  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.  56839  111616  Limit  1  Buy  41.62    Pending Cancel      DU4779  Close  56838
Order  2015-11-19 15:37:54.003  CL-201601-NYMEX  Canceling all orders for Symbol and Account during Flatten/Reverse.  56840  111617  Stop  1  Buy  41.86    Pending Cancel      DU4779  Close  56838
Order  2015-11-19 15:37:54.004  CL-201601-NYMEX  IB order status update  56839  111616  Limit  1  Buy  41.62    Canceled      DU4779  Close  56838
Order  2015-11-19 15:37:55.000  CL-201601-NYMEX  IB order status update  56840  111617  Stop  1  Buy  41.86    Canceled      DU4779  Close  56838
Order  2015-11-19 15:37:57.000  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  2015-11-19 15:38:09.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 16:13:12.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 16:18:09.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 16:32:11.000    Disconnected from server                Unspecified      None
Order  2015-11-19 21:34:58.000    Connected to server                Unspecified      None
Order  2015-11-19 21:35:03.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 21:35:35.000    Disconnected from server                Unspecified      None
Order  2015-11-19 21:35:40.000    Connected to server                Unspecified      None
Order  2015-11-19 21:35:42.000    Disconnected from server                Unspecified      None
Order  2015-11-19 21:35:47.000    Connected to server                Unspecified      None
Order  2015-11-19 21:35:49.000    Disconnected from server                Unspecified      None
Order  2015-11-19 21:35:54.000    Connected to server                Unspecified      None
Order  2015-11-19 21:36:01.000    Disconnected from server                Unspecified      None
Order  2015-11-19 21:36:06.000    Connected to server                Unspecified      None
Order  2015-11-19 21:36:11.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 21:36:11.001    Disconnected from server                Unspecified      None
Order  2015-11-19 21:36:16.000    Connected to server                Unspecified      None
Order  2015-11-19 21:36:21.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 21:43:34.000    Disconnected from server                Unspecified      None
Order  2015-11-19 21:43:39.000    Connected to server                Unspecified      None
Order  2015-11-19 21:43:44.000    Requesting all orders from trading service                Unspecified      None
Order  2015-11-19 22:10:35.000    Disconnected from server                Unspecified      None
Order  2015-11-20 05:00:59.000    Connected to server                Unspecified      None
Order  2015-11-20 05:01:08.000    Disconnected from server                Unspecified      None
Order  2015-11-20 05:01:13.000    Connected to server                Unspecified      None
Order  2015-11-20 05:01:15.000    Disconnected from server                Unspecified      None
Order  2015-11-20 05:01:21.000    Connected to server                Unspecified      None
Order  2015-11-20 05:01:26.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:01:26.001    Disconnected from server                Unspecified      None
Order  2015-11-20 05:01:31.000    Connected to server                Unspecified      None
Order  2015-11-20 05:01:36.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:02:12.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.959999. Attached Order  56845    Limit    Sell  42.03    Pending Child      DU4779  Close  56844
Order  2015-11-20 05:02:12.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.959999. Attached Order  56846    Stop    Sell  41.69    Pending Child      DU4779  Close  56844
Order  2015-11-20 05:02:12.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.959999  56844    Stop  1  Buy  41.97    Order Sent      DU4779  Open
Order  2015-11-20 05:02:12.003  CL-201601-NYMEX  IB open order update  56844  111622  Stop  1  Buy  41.97    Open      DU4779  Open
Order  2015-11-20 05:02:23.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.949999. Requested Quantity: 1  56844  111622  Stop  1  Buy  41.97    Pending Modify      DU4779  Open
Order  2015-11-20 05:02:23.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.95. Requested Price: 42.009999. Requested Quantity: 0  56845    Limit    Sell  42.03    Pending Modify      DU4779  Close  56844
Order  2015-11-20 05:02:23.002  CL-201601-NYMEX  Order modified internally  56845    Limit    Sell  42.01    Pending Child      DU4779  Close  56844
Order  2015-11-20 05:02:23.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.95. Requested Price: 41.669999. Requested Quantity: 0  56846    Stop    Sell  41.69    Pending Modify      DU4779  Close  56844
Order  2015-11-20 05:02:23.004  CL-201601-NYMEX  Order modified internally  56846    Stop    Sell  41.67    Pending Child      DU4779  Close  56844
Order  2015-11-20 05:02:23.005  CL-201601-NYMEX  User order modification ignored. New price is the same  56844  111622  Stop  1  Buy  41.97    Pending Modify      DU4779  Open
Order  2015-11-20 05:02:23.006  CL-201601-NYMEX  IB open order update  56844  111622  Stop  1  Buy  41.95    Open      DU4779  Open
Order  2015-11-20 05:02:24.000  CL-201601-NYMEX  IB order fill (execution)  56844  111622  Stop  1  Buy  41.95    Filled  41.95  1  DU4779  Open
Fill  2015-11-20 05:02:24.001  CL-201601-NYMEX  IB order fill (execution)  56844  111622  Stop  1  Buy  41.95    Filled  41.95  1  DU4779  Open    1  0001f4e5.564e635a.01.01
Order  2015-11-20 05:02:24.002  CL-201601-NYMEX  Auto-sent child from parent fill  56845    Limit  1  Sell  42.01    Order Sent      DU4779  Close  56844  1
Order  2015-11-20 05:02:24.003  CL-201601-NYMEX  Auto-sent child from parent fill  56846    Stop  1  Sell  41.67    Order Sent      DU4779  Close  56844  1
Order  2015-11-20 05:02:24.004  CL-201601-NYMEX  IB open order update  56845  111623  Limit  1  Sell  42.01    Open      DU4779  Close  56844  1
Order  2015-11-20 05:02:24.005  CL-201601-NYMEX  IB open order update  56846  111624  Stop  1  Sell  41.67    Open      DU4779  Close  56844  1
Order  2015-11-20 05:02:39.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:03:06.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.779999. Requested Quantity: 1  56846  111624  Stop  1  Sell  41.67    Pending Modify      DU4779  Close  56844  1
Order  2015-11-20 05:03:06.001  CL-201601-NYMEX  IB open order update  56846  111624  Stop  1  Sell  41.78    Open      DU4779  Close  56844  1
Order  2015-11-20 05:03:14.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.919999. Requested Quantity: 1  56846  111624  Stop  1  Sell  41.78    Pending Modify      DU4779  Close  56844  1
Order  2015-11-20 05:03:14.001  CL-201601-NYMEX  IB open order update  56846  111624  Stop  1  Sell  41.92    Open      DU4779  Close  56844  1
Order  2015-11-20 05:03:17.000  CL-201601-NYMEX  IB order fill (execution)  56846  111624  Stop  1  Sell  41.92    Filled  41.92  1  DU4779  Close  56844  1
Fill  2015-11-20 05:03:17.001  CL-201601-NYMEX  IB order fill (execution)  56846  111624  Stop  1  Sell  41.92    Filled  41.92  1  DU4779  Close      0001f4e5.564e635f.01.01
Order  2015-11-20 05:03:17.002  CL-201601-NYMEX  Canceling order due to sibling fill  56845  111623  Limit  1  Sell  42.01    Pending Cancel      DU4779  Close  56844
Order  2015-11-20 05:03:17.003  CL-201601-NYMEX  IB order status update  56845  111623  Limit  1  Sell  42.01    Canceled      DU4779  Close  56844
Order  2015-11-20 05:03:27.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:03:32.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:04:15.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.919998. Attached Order  56848    Limit    Sell  41.98    Pending Child      DU4779  Close  56847
Order  2015-11-20 05:04:15.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.919998. Attached Order  56849    Stop    Sell  41.64    Pending Child      DU4779  Close  56847
Order  2015-11-20 05:04:15.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.919998  56847    Limit  1  Buy  41.92    Order Sent      DU4779  Open
Order  2015-11-20 05:04:15.003  CL-201601-NYMEX  IB open order update  56847  111625  Limit  1  Buy  41.92    Open      DU4779  Open
Order  2015-11-20 05:04:27.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.929999. Requested Quantity: 1  56847  111625  Limit  1  Buy  41.92    Pending Modify      DU4779  Open
Order  2015-11-20 05:04:27.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.93. Requested Price: 41.989999. Requested Quantity: 0  56848    Limit    Sell  41.98    Pending Modify      DU4779  Close  56847
Order  2015-11-20 05:04:27.002  CL-201601-NYMEX  Order modified internally  56848    Limit    Sell  41.99    Pending Child      DU4779  Close  56847
Order  2015-11-20 05:04:27.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.93. Requested Price: 41.649999. Requested Quantity: 0  56849    Stop    Sell  41.64    Pending Modify      DU4779  Close  56847
Order  2015-11-20 05:04:27.004  CL-201601-NYMEX  Order modified internally  56849    Stop    Sell  41.65    Pending Child      DU4779  Close  56847
Order  2015-11-20 05:04:27.005  CL-201601-NYMEX  IB open order update  56847  111625  Limit  1  Buy  41.93    Open      DU4779  Open
Order  2015-11-20 05:04:42.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:04:52.000  CL-201601-NYMEX  IB order fill (execution)  56847  111625  Limit  1  Buy  41.93    Filled  41.93  1  DU4779  Open
Fill  2015-11-20 05:04:52.001  CL-201601-NYMEX  IB order fill (execution)  56847  111625  Limit  1  Buy  41.93    Filled  41.93  1  DU4779  Open    1  0001f4e5.564e6371.01.01
Order  2015-11-20 05:04:52.002  CL-201601-NYMEX  Auto-sent child from parent fill  56848    Limit  1  Sell  41.99    Order Sent      DU4779  Close  56847  1
Order  2015-11-20 05:04:52.003  CL-201601-NYMEX  Auto-sent child from parent fill  56849    Stop  1  Sell  41.65    Order Sent      DU4779  Close  56847  1
Order  2015-11-20 05:04:52.004  CL-201601-NYMEX  IB open order update  56848  111626  Limit  1  Sell  41.99    Open      DU4779  Close  56847  1
Order  2015-11-20 05:04:52.005  CL-201601-NYMEX  IB open order update  56849  111627  Stop  1  Sell  41.65    Open      DU4779  Close  56847  1
Order  2015-11-20 05:05:07.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:05:39.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.899998. Attached Order  56851    Limit    Sell  41.96    Pending Child      DU4779  Close  56850  1
Order  2015-11-20 05:05:39.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.899998. Attached Order  56852    Stop    Sell  41.62    Pending Child      DU4779  Close  56850  1
Order  2015-11-20 05:05:39.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.899998  56850    Limit  1  Buy  41.90    Order Sent      DU4779  Open    1
Order  2015-11-20 05:05:39.003  CL-201601-NYMEX  IB open order update  56850  111628  Limit  1  Buy  41.90    Open      DU4779  Open    1
Order  2015-11-20 05:05:51.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.909999. Requested Quantity: 1  56850  111628  Limit  1  Buy  41.90    Pending Modify      DU4779  Open    1
Order  2015-11-20 05:05:51.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.91. Requested Price: 41.969999. Requested Quantity: 0  56851    Limit    Sell  41.96    Pending Modify      DU4779  Close  56850  1
Order  2015-11-20 05:05:51.002  CL-201601-NYMEX  Order modified internally  56851    Limit    Sell  41.97    Pending Child      DU4779  Close  56850  1
Order  2015-11-20 05:05:51.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.91. Requested Price: 41.629999. Requested Quantity: 0  56852    Stop    Sell  41.62    Pending Modify      DU4779  Close  56850  1
Order  2015-11-20 05:05:51.004  CL-201601-NYMEX  Order modified internally  56852    Stop    Sell  41.63    Pending Child      DU4779  Close  56850  1
Order  2015-11-20 05:05:51.005  CL-201601-NYMEX  IB open order update  56850  111628  Limit  1  Buy  41.91    Open      DU4779  Open    1
Order  2015-11-20 05:05:52.000  CL-201601-NYMEX  IB order fill (execution)  56850  111628  Limit  1  Buy  41.91    Filled  41.91  1  DU4779  Open    1
Fill  2015-11-20 05:05:52.001  CL-201601-NYMEX  IB order fill (execution)  56850  111628  Limit  1  Buy  41.91    Filled  41.91  1  DU4779  Open    2  0001f4e5.564e637d.01.01
Order  2015-11-20 05:05:52.002  CL-201601-NYMEX  Auto-sent child from parent fill  56851    Limit  1  Sell  41.97    Order Sent      DU4779  Close  56850  2
Order  2015-11-20 05:05:52.003  CL-201601-NYMEX  Auto-sent child from parent fill  56852    Stop  1  Sell  41.63    Order Sent      DU4779  Close  56850  2
Order  2015-11-20 05:05:52.004  CL-201601-NYMEX  IB open order update  56851  111629  Limit  1  Sell  41.97    Open      DU4779  Close  56850  2
Order  2015-11-20 05:05:52.005  CL-201601-NYMEX  IB open order update  56852  111630  Stop  1  Sell  41.63    Open      DU4779  Close  56850  2
Order  2015-11-20 05:06:01.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.989999. Requested Quantity: 1  56851  111629  Limit  1  Sell  41.97    Pending Modify      DU4779  Close  56850  2
Order  2015-11-20 05:06:01.001  CL-201601-NYMEX  IB open order update  56851  111629  Limit  1  Sell  41.99    Open      DU4779  Close  56850  2
Order  2015-11-20 05:06:07.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.649999. Requested Quantity: 1  56852  111630  Stop  1  Sell  41.63    Pending Modify      DU4779  Close  56850  2
Order  2015-11-20 05:06:07.001  CL-201601-NYMEX  IB open order update  56852  111630  Stop  1  Sell  41.65    Open      DU4779  Close  56850  2
Order  2015-11-20 05:06:18.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.889999. Attached Order  56854    Limit    Sell  41.93    Pending Child      DU4779  Close  56853  2
Order  2015-11-20 05:06:18.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.889999. Attached Order  56855    Stop    Sell  41.59    Pending Child      DU4779  Close  56853  2
Order  2015-11-20 05:06:18.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.889999  56853    Limit  1  Buy  41.87    Order Sent      DU4779  Open    2
Order  2015-11-20 05:06:18.003  CL-201601-NYMEX  IB open order update  56853  111631  Limit  1  Buy  41.87    Open      DU4779  Open    2
Order  2015-11-20 05:06:33.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:06:39.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.879999. Requested Quantity: 1  56853  111631  Limit  1  Buy  41.87    Pending Modify      DU4779  Open    2
Order  2015-11-20 05:06:39.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.88. Requested Price: 41.939999. Requested Quantity: 0  56854    Limit    Sell  41.93    Pending Modify      DU4779  Close  56853  2
Order  2015-11-20 05:06:39.002  CL-201601-NYMEX  Order modified internally  56854    Limit    Sell  41.94    Pending Child      DU4779  Close  56853  2
Order  2015-11-20 05:06:39.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.88. Requested Price: 41.599999. Requested Quantity: 0  56855    Stop    Sell  41.59    Pending Modify      DU4779  Close  56853  2
Order  2015-11-20 05:06:39.004  CL-201601-NYMEX  Order modified internally  56855    Stop    Sell  41.60    Pending Child      DU4779  Close  56853  2
Order  2015-11-20 05:06:39.005  CL-201601-NYMEX  IB open order update  56853  111631  Limit  1  Buy  41.88    Open      DU4779  Open    2
Order  2015-11-20 05:06:47.000  CL-201601-NYMEX  IB order fill (execution)  56853  111631  Limit  1  Buy  41.88    Filled  41.88  1  DU4779  Open    2
Fill  2015-11-20 05:06:47.001  CL-201601-NYMEX  IB order fill (execution)  56853  111631  Limit  1  Buy  41.88    Filled  41.88  1  DU4779  Open    3  0001f4e5.564e6396.01.01
Order  2015-11-20 05:06:47.002  CL-201601-NYMEX  Auto-sent child from parent fill  56854    Limit  1  Sell  41.94    Order Sent      DU4779  Close  56853  3
Order  2015-11-20 05:06:47.003  CL-201601-NYMEX  Auto-sent child from parent fill  56855    Stop  1  Sell  41.60    Order Sent      DU4779  Close  56853  3
Order  2015-11-20 05:06:47.004  CL-201601-NYMEX  IB open order update  56854  111632  Limit  1  Sell  41.94    Open      DU4779  Close  56853  3
Order  2015-11-20 05:06:47.005  CL-201601-NYMEX  IB open order update  56855  111633  Stop  1  Sell  41.60    Open      DU4779  Close  56853  3
Order  2015-11-20 05:06:57.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.989999. Requested Quantity: 1  56854  111632  Limit  1  Sell  41.94    Pending Modify      DU4779  Close  56853  3
Order  2015-11-20 05:06:57.001  CL-201601-NYMEX  IB open order update  56854  111632  Limit  1  Sell  41.99    Open      DU4779  Close  56853  3
Order  2015-11-20 05:07:04.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.649999. Requested Quantity: 1  56855  111633  Stop  1  Sell  41.60    Pending Modify      DU4779  Close  56853  3
Order  2015-11-20 05:07:04.001  CL-201601-NYMEX  IB open order update  56855  111633  Stop  1  Sell  41.65    Open      DU4779  Close  56853  3
Order  2015-11-20 05:07:19.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:15:00.000  CL-201601-NYMEX  IB order fill (execution)  56848  111626  Limit  1  Sell  41.99    Filled  41.99  1  DU4779  Close  56847  3
Fill  2015-11-20 05:15:00.001  CL-201601-NYMEX  IB order fill (execution)  56848  111626  Limit  1  Sell  41.99    Filled  41.99  1  DU4779  Close    2  0001f4e5.564e63ec.01.01
Order  2015-11-20 05:15:00.002  CL-201601-NYMEX  Canceling order due to sibling fill  56849  111627  Stop  1  Sell  41.65    Pending Cancel      DU4779  Close  56847  2
Order  2015-11-20 05:15:01.000  CL-201601-NYMEX  IB order fill (execution)  56851  111629  Limit  1  Sell  41.99    Filled  41.99  1  DU4779  Close  56850  2
Fill  2015-11-20 05:15:01.001  CL-201601-NYMEX  IB order fill (execution)  56851  111629  Limit  1  Sell  41.99    Filled  41.99  1  DU4779  Close    1  0001f4e5.564e63ee.01.01
Order  2015-11-20 05:15:01.002  CL-201601-NYMEX  Canceling order due to sibling fill  56852  111630  Stop  1  Sell  41.65    Pending Cancel      DU4779  Close  56850  1
Order  2015-11-20 05:15:01.003  CL-201601-NYMEX  IB order fill (execution)  56854  111632  Limit  1  Sell  41.99    Filled  41.99  1  DU4779  Close  56853  1
Fill  2015-11-20 05:15:01.004  CL-201601-NYMEX  IB order fill (execution)  56854  111632  Limit  1  Sell  41.99    Filled  41.99  1  DU4779  Close      0001f4e5.564e63ef.01.01
Order  2015-11-20 05:15:01.005  CL-201601-NYMEX  Canceling order due to sibling fill  56855  111633  Stop  1  Sell  41.65    Pending Cancel      DU4779  Close  56853
Order  2015-11-20 05:15:01.006  CL-201601-NYMEX  IB order status update  56849  111627  Stop  1  Sell  41.65    Canceled      DU4779  Close  56847
Order  2015-11-20 05:15:01.007  CL-201601-NYMEX  IB order status update  56852  111630  Stop  1  Sell  41.65    Canceled      DU4779  Close  56850
Order  2015-11-20 05:15:01.008  CL-201601-NYMEX  IB order status update  56855  111633  Stop  1  Sell  41.65    Canceled      DU4779  Close  56853
Order  2015-11-20 05:15:10.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:15:16.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:15:25.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:16:17.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:21:25.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:24:25.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:27:25.000  CL-201601-NYMEX  Removing Position with quantity of 0                Unspecified      DU4779
Order  2015-11-20 05:28:39.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.02. Attached Order  56857    Limit    Sell  42.06    Pending Child      DU4779  Close  56856
Order  2015-11-20 05:28:39.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.02. Attached Order  56858    Stop    Sell  41.72    Pending Child      DU4779  Close  56856
Order  2015-11-20 05:28:39.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.02  56856    Stop  1  Buy  42.00    Order Sent      DU4779  Open
Order  2015-11-20 05:28:40.000  CL-201601-NYMEX  IB open order update  56856  111634  Stop  1  Buy  42.00    Open      DU4779  Open
Order  2015-11-20 05:28:41.000  CL-201601-NYMEX  IB order fill (execution)  56856  111634  Stop  1  Buy  42.00    Filled  42.02  1  DU4779  Open
Fill  2015-11-20 05:28:41.001  CL-201601-NYMEX  IB order fill (execution)  56856  111634  Stop  1  Buy  42.00    Filled  42.02  1  DU4779  Open    1  0001f4e5.564e6452.01.01
Order  2015-11-20 05:28:41.002  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 42.02. Requested Price: 42.079999. Requested Quantity: 0  56857    Limit    Sell  42.06    Pending Modify      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.003  CL-201601-NYMEX  Order modified internally  56857    Limit    Sell  42.08    Pending Child      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.004  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 42.02. Requested Price: 41.739999. Requested Quantity: 0  56858    Stop    Sell  41.72    Pending Modify      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.005  CL-201601-NYMEX  Order modified internally  56858    Stop    Sell  41.74    Pending Child      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.006  CL-201601-NYMEX  Auto-sent child from parent fill  56857    Limit  1  Sell  42.08    Order Sent      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.007  CL-201601-NYMEX  Auto-sent child from parent fill  56858    Stop  1  Sell  41.74    Order Sent      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.008  CL-201601-NYMEX  IB open order update  56857  111635  Limit  1  Sell  42.08    Open      DU4779  Close  56856  1
Order  2015-11-20 05:28:41.009  CL-201601-NYMEX  IB open order update  56858  111636  Stop  1  Sell  41.74    Open      DU4779  Close  56856  1
Order  2015-11-20 05:28:47.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.009998. Attached Order  56860    Limit    Sell  42.06    Pending Child      DU4779  Close  56859  1
Order  2015-11-20 05:28:47.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.009998. Attached Order  56861    Stop    Sell  41.72    Pending Child      DU4779  Close  56859  1
Order  2015-11-20 05:28:47.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42.009998  56859    Limit  1  Buy  42.00    Order Sent      DU4779  Open    1
Order  2015-11-20 05:28:47.003  CL-201601-NYMEX  IB open order update  56859  111637  Limit  1  Buy  42.00    Open      DU4779  Open    1
Order  2015-11-20 05:29:00.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.069999. Requested Quantity: 0  56860    Limit    Sell  42.06    Pending Modify      DU4779  Close  56859  1
Order  2015-11-20 05:29:00.001  CL-201601-NYMEX  Order modified internally  56860    Limit    Sell  42.07    Pending Child      DU4779  Close  56859  1
Order  2015-11-20 05:29:02.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 0  56860    Limit    Sell  42.07    Pending Modify      DU4779  Close  56859  1
Order  2015-11-20 05:29:02.001  CL-201601-NYMEX  Order modified internally  56860    Limit    Sell  42.06    Pending Child      DU4779  Close  56859  1
Order  2015-11-20 05:29:02.002    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:29:12.000  CL-201601-NYMEX  IB order fill (execution)  56859  111637  Limit  1  Buy  42.00    Filled  42.00  1  DU4779  Open    1
Fill  2015-11-20 05:29:12.001  CL-201601-NYMEX  IB order fill (execution)  56859  111637  Limit  1  Buy  42.00    Filled  42.00  1  DU4779  Open    2  0001f4e5.564e6453.01.01
Order  2015-11-20 05:29:12.002  CL-201601-NYMEX  Auto-sent child from parent fill  56860    Limit  1  Sell  42.06    Order Sent      DU4779  Close  56859  2
Order  2015-11-20 05:29:12.003  CL-201601-NYMEX  Auto-sent child from parent fill  56861    Stop  1  Sell  41.72    Order Sent      DU4779  Close  56859  2
Order  2015-11-20 05:29:13.000  CL-201601-NYMEX  IB open order update  56860  111638  Limit  1  Sell  42.06    Open      DU4779  Close  56859  2
Order  2015-11-20 05:29:13.001  CL-201601-NYMEX  IB open order update  56861  111639  Stop  1  Sell  41.72    Open      DU4779  Close  56859  2
Order  2015-11-20 05:29:25.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56858  111636  Stop  1  Sell  41.74    Pending Modify      DU4779  Close  56856  2
Order  2015-11-20 05:29:25.001  CL-201601-NYMEX  IB open order update  56858  111636  Stop  1  Sell  41.72    Open      DU4779  Close  56856  2
Order  2015-11-20 05:29:29.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 1  56857  111635  Limit  1  Sell  42.08    Pending Modify      DU4779  Close  56856  2
Order  2015-11-20 05:29:29.001  CL-201601-NYMEX  IB open order update  56857  111635  Limit  1  Sell  42.06    Open      DU4779  Close  56856  2
Order  2015-11-20 05:29:44.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:29:57.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.98. Attached Order  56863    Limit    Sell  42.04    Pending Child      DU4779  Close  56862  2
Order  2015-11-20 05:29:57.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.98. Attached Order  56864    Stop    Sell  41.70    Pending Child      DU4779  Close  56862  2
Order  2015-11-20 05:29:57.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.98  56862    Limit  1  Buy  41.98    Order Sent      DU4779  Open    2
Order  2015-11-20 05:29:57.003  CL-201601-NYMEX  IB order fill (execution)  56862  111640  Limit  1  Buy  41.98    Filled  41.98  1  DU4779  Open    2
Fill  2015-11-20 05:29:57.004  CL-201601-NYMEX  IB order fill (execution)  56862  111640  Limit  1  Buy  41.98    Filled  41.98  1  DU4779  Open    3  0001f4e5.564e6457.01.01
Order  2015-11-20 05:29:57.005  CL-201601-NYMEX  Auto-sent child from parent fill  56863    Limit  1  Sell  42.04    Order Sent      DU4779  Close  56862  3
Order  2015-11-20 05:29:57.006  CL-201601-NYMEX  Auto-sent child from parent fill  56864    Stop  1  Sell  41.70    Order Sent      DU4779  Close  56862  3
Order  2015-11-20 05:29:57.007  CL-201601-NYMEX  IB open order update  56863  111641  Limit  1  Sell  42.04    Open      DU4779  Close  56862  3
Order  2015-11-20 05:29:57.008  CL-201601-NYMEX  IB open order update  56864  111642  Stop  1  Sell  41.70    Open      DU4779  Close  56862  3
Order  2015-11-20 05:30:02.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 1  56863  111641  Limit  1  Sell  42.04    Pending Modify      DU4779  Close  56862  3
Order  2015-11-20 05:30:02.001  CL-201601-NYMEX  IB open order update  56863  111641  Limit  1  Sell  42.06    Open      DU4779  Close  56862  3
Order  2015-11-20 05:30:06.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56864  111642  Stop  1  Sell  41.70    Pending Modify      DU4779  Close  56862  3
Order  2015-11-20 05:30:06.001  CL-201601-NYMEX  IB open order update  56864  111642  Stop  1  Sell  41.72    Open      DU4779  Close  56862  3
Order  2015-11-20 05:30:21.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:30:25.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42. Attached Order  56866    Limit    Sell  42.00    Pending Child      DU4779  Close  56865  3
Order  2015-11-20 05:30:25.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42. Attached Order  56867    Stop    Sell  41.66    Pending Child      DU4779  Close  56865  3
Order  2015-11-20 05:30:25.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 42  56865    Limit  1  Buy  41.94    Order Sent      DU4779  Open    3
Order  2015-11-20 05:30:25.003  CL-201601-NYMEX  IB open order update  56865  111643  Limit  1  Buy  41.94    Open      DU4779  Open    3
Order  2015-11-20 05:30:40.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:32:22.000  CL-201601-NYMEX  IB order fill (execution)  56865  111643  Limit  1  Buy  41.94    Filled  41.94  1  DU4779  Open    3
Fill  2015-11-20 05:32:22.001  CL-201601-NYMEX  IB order fill (execution)  56865  111643  Limit  1  Buy  41.94    Filled  41.94  1  DU4779  Open    4  0001f4e5.564e646e.01.01
Order  2015-11-20 05:32:22.002  CL-201601-NYMEX  Auto-sent child from parent fill  56866    Limit  1  Sell  42.00    Order Sent      DU4779  Close  56865  4
Order  2015-11-20 05:32:22.003  CL-201601-NYMEX  Auto-sent child from parent fill  56867    Stop  1  Sell  41.66    Order Sent      DU4779  Close  56865  4
Order  2015-11-20 05:32:23.000  CL-201601-NYMEX  IB open order update  56866  111644  Limit  1  Sell  42.00    Open      DU4779  Close  56865  4
Order  2015-11-20 05:32:23.001  CL-201601-NYMEX  IB open order update  56867  111645  Stop  1  Sell  41.66    Open      DU4779  Close  56865  4
Order  2015-11-20 05:32:37.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:32:43.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 1  56866  111644  Limit  1  Sell  42.00    Pending Modify      DU4779  Close  56865  4
Order  2015-11-20 05:32:43.001  CL-201601-NYMEX  IB open order update  56866  111644  Limit  1  Sell  42.06    Open      DU4779  Close  56865  4
Order  2015-11-20 05:32:50.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56867  111645  Stop  1  Sell  41.66    Pending Modify      DU4779  Close  56865  4
Order  2015-11-20 05:32:51.000  CL-201601-NYMEX  IB open order update  56867  111645  Stop  1  Sell  41.72    Open      DU4779  Close  56865  4
Order  2015-11-20 05:33:06.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:33:31.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.91. Attached Order  56869    Limit    Sell  41.94    Pending Child      DU4779  Close  56868  4
Order  2015-11-20 05:33:31.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.91. Attached Order  56870    Stop    Sell  41.60    Pending Child      DU4779  Close  56868  4
Order  2015-11-20 05:33:31.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.91  56868    Limit  1  Buy  41.88    Order Sent      DU4779  Open    4
Order  2015-11-20 05:33:31.003  CL-201601-NYMEX  IB open order update  56868  111646  Limit  1  Buy  41.88    Open      DU4779  Open    4
Order  2015-11-20 05:33:46.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:40:19.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.899999. Requested Quantity: 1  56868  111646  Limit  1  Buy  41.88    Pending Modify      DU4779  Open    4
Order  2015-11-20 05:40:19.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.90. Requested Price: 41.959999. Requested Quantity: 0  56869    Limit    Sell  41.94    Pending Modify      DU4779  Close  56868  4
Order  2015-11-20 05:40:19.002  CL-201601-NYMEX  Order modified internally  56869    Limit    Sell  41.96    Pending Child      DU4779  Close  56868  4
Order  2015-11-20 05:40:19.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.90. Requested Price: 41.619999. Requested Quantity: 0  56870    Stop    Sell  41.60    Pending Modify      DU4779  Close  56868  4
Order  2015-11-20 05:40:19.004  CL-201601-NYMEX  Order modified internally  56870    Stop    Sell  41.62    Pending Child      DU4779  Close  56868  4
Order  2015-11-20 05:40:19.005  CL-201601-NYMEX  IB open order update  56868  111646  Limit  1  Buy  41.90    Open      DU4779  Open    4
Order  2015-11-20 05:40:25.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.909999. Requested Quantity: 1  56868  111646  Limit  1  Buy  41.90    Pending Modify      DU4779  Open    4
Order  2015-11-20 05:40:25.001  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.91. Requested Price: 41.969999. Requested Quantity: 0  56869    Limit    Sell  41.96    Pending Modify      DU4779  Close  56868  4
Order  2015-11-20 05:40:25.002  CL-201601-NYMEX  Order modified internally  56869    Limit    Sell  41.97    Pending Child      DU4779  Close  56868  4
Order  2015-11-20 05:40:25.003  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.91. Requested Price: 41.629999. Requested Quantity: 0  56870    Stop    Sell  41.62    Pending Modify      DU4779  Close  56868  4
Order  2015-11-20 05:40:25.004  CL-201601-NYMEX  Order modified internally  56870    Stop    Sell  41.63    Pending Child      DU4779  Close  56868  4
Fill  2015-11-20 05:40:25.005  CL-201601-NYMEX  IB order fill (execution)  56868  111646  Limit  1  Buy  41.90    Pending Modify  41.91  1  DU4779  Open    5  0001f4e5.564e64aa.01.01
Order  2015-11-20 05:40:25.006  CL-201601-NYMEX  Auto-sent child from parent fill  56869    Limit  1  Sell  41.97    Order Sent      DU4779  Close  56868  5
Order  2015-11-20 05:40:25.007  CL-201601-NYMEX  Auto-sent child from parent fill  56870    Stop  1  Sell  41.63    Order Sent      DU4779  Close  56868  5
Order  2015-11-20 05:40:25.008  CL-201601-NYMEX  IB open order update  56868  111646  Limit  1  Buy  41.91    Pending Open  41.91  1  DU4779  Open    5
Order  2015-11-20 05:40:25.009  CL-201601-NYMEX  IB open order update  56868  111646  Limit  1  Buy  41.91    Filled  41.91  1  DU4779  Open    5
Order  2015-11-20 05:40:25.010  CL-201601-NYMEX  IB open order update  56869  111647  Limit  1  Sell  41.97    Open      DU4779  Close  56868  5
Order  2015-11-20 05:40:25.011  CL-201601-NYMEX  IB open order update  56870  111648  Stop  1  Sell  41.63    Open      DU4779  Close  56868  5
Order  2015-11-20 05:40:32.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 1  56869  111647  Limit  1  Sell  41.97    Pending Modify      DU4779  Close  56868  5
Order  2015-11-20 05:40:32.001  CL-201601-NYMEX  IB open order update  56869  111647  Limit  1  Sell  42.06    Open      DU4779  Close  56868  5
Order  2015-11-20 05:40:38.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56870  111648  Stop  1  Sell  41.63    Pending Modify      DU4779  Close  56868  5
Order  2015-11-20 05:40:38.001  CL-201601-NYMEX  IB open order update  56870  111648  Stop  1  Sell  41.72    Open      DU4779  Close  56868  5
Order  2015-11-20 05:40:53.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:41:14.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.049999. Requested Quantity: 1  56869  111647  Limit  1  Sell  42.06    Pending Modify      DU4779  Close  56868  5
Order  2015-11-20 05:41:14.001  CL-201601-NYMEX  IB open order update  56869  111647  Limit  1  Sell  42.05    Open      DU4779  Close  56868  5
Order  2015-11-20 05:41:18.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 1  56869  111647  Limit  1  Sell  42.05    Pending Modify      DU4779  Close  56868  5
Order  2015-11-20 05:41:18.001  CL-201601-NYMEX  IB open order update  56869  111647  Limit  1  Sell  42.06    Open      DU4779  Close  56868  5
Order  2015-11-20 05:41:33.000    Requesting Open orders from trading service                Unspecified      None
Order  2015-11-20 05:43:04.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.889999. Attached Order  56872    Limit    Sell  41.94    Pending Child      DU4779  Close  56871  5
Order  2015-11-20 05:43:04.001  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.889999. Attached Order  56873    Stop    Sell  41.60    Pending Child      DU4779  Close  56871  5
Order  2015-11-20 05:43:04.002  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.889999  56871    Limit  1  Buy  41.88    Order Sent      DU4779  Open    5
Order  2015-11-20 05:43:04.003  CL-201601-NYMEX  IB order fill (execution)  56871  111649  Limit  1  Buy  41.88    Filled  41.88  1  DU4779  Open    5
Fill  2015-11-20 05:43:04.004  CL-201601-NYMEX  IB order fill (execution)  56871  111649  Limit  1  Buy  41.88    Filled  41.88  1  DU4779  Open    6  0001f4e5.564e64b9.01.01
Order  2015-11-20 05:43:04.005  CL-201601-NYMEX  Auto-sent child from parent fill  56872    Limit  1  Sell  41.94    Order Sent      DU4779  Close  56871  6
Order  2015-11-20 05:43:04.006  CL-201601-NYMEX  Auto-sent child from parent fill  56873    Stop  1  Sell  41.60    Order Sent      DU4779  Close  56871  6
Order  2015-11-20 05:43:04.007  CL-201601-NYMEX  IB open order update  56872  111650  Limit  1  Sell  41.94    Open      DU4779  Close  56871  6
Order  2015-11-20 05:43:05.000  CL-201601-NYMEX  IB open order update  56873  111651  Stop  1  Sell  41.60    Open      DU4779  Close  56871  6
Order  2015-11-20 05:43:18.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 42.059999. Requested Quantity: 1  56872  111650  Limit  1  Sell  41.94    Pending Modify      DU4779  Close  56871  6
Order  2015-11-20 05:43:18.001  CL-201601-NYMEX  IB open order update  56872  111650  Limit  1  Sell  42.06    Open      DU4779  Close  56871  6
Order  2015-11-20 05:43:25.000  CL-201601-NYMEX  User order modification ignored. New price is the same  56870  111648  Stop  1  Sell  41.72    Open      DU4779  Close  56868
Order  2015-11-20 05:43:28.000  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.719999. Requested Quantity: 1  56873  111651  Stop  1  Sell  41.60    Pending Modify      DU4779  Close  56871  6
Order  2015-11-20 05:43:28.001  CL-201601-NYMEX  IB open order update  56873  111651  Stop  1  Sell  41.72    Open      DU4779  Close  56871  6
Order  2015-11-20 05:43:43.000    Requesting Open orders from trading service                Unspecified      None
[2015-11-20 17:19:00]
When the order either hit the target or stop the trade appeared to terminate on the chart (Target and Stop lines disappeared) but a Reverse trade was immediately initiated on the TWS. I then had to go into the TWS and cancel that reverse trade. Please don't tell me that this could Never happen because this is what I observed. I am not very smart, but I do know what I see.
Regarding this, it is not possible that Sierra Chart would be submitting another order in response to a Target or Stop order being filled, unless you have an automated trading system that is doing that and we assume you do not.
However, we want to locate in the Trade Activity Log you provided where this happened so we can explain what happened as best as we can based on the information we see.
But we do not know where to look in this log because it is very long. Do you have an order number (Service Order ID)? Or the exact Date-Time this occurred? Look through the trading log in the Trader Workstation and provide us some order information from there that we can use to match up to this log.
Date Time Of Last Edit: 2015-11-23 01:44:51
[2015-11-20 18:10:06]
User56044 - Posts: 62
I believe that at the 12:56 and 13:08 times on 11-19-15 I had purposely put in an order on the chart DOM, noted that the entry price line disappeared within 5-10 seconds later, the DOM no longer registered the value of the trade, I then exited the trade with either the stop or target line, and then found that the TWS had initiated a Reverse Trade at my exit price that I then cancelled through the TWS.
Hope this helps.
Everything is working properly now.
Thanks, ken.
[2015-11-20 18:21:51]
OK we will check on this. We know everything is working properly now but we still want to understand exactly what happened previously and explain it. That is very important to us.
[2015-11-23 01:54:27]
At the 12:56 time on 2015-11-19 there is no evidence at all of any other orders other than the original bracket order set where each of those orders has a quantity of 1.
Reference:
Order  19/11/2015 12:56:02  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.579998. Attached Order  56832    Limit    Sell  41.63    Pending Child      DU4779  Close  56831
Order  19/11/2015 12:56:02  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.579998. Attached Order  56833    Stop    Sell  41.39    Pending Child      DU4779  Close  56831
Order  19/11/2015 12:56:02  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order entry | Last: 41.579998  56831    Stop  1  Buy  41.57    Order Sent      DU4779  Open
Order  19/11/2015 12:56:02  CL-201601-NYMEX  IB open order update  56831  111608  Stop  1  Buy  41.57    Open      DU4779  Open
Order  19/11/2015 12:56:06  CL-201601-NYMEX  IB order fill (execution)  56831  111608  Stop  1  Buy  41.57    Filled  41.58  1  DU4779  Open
Fill  19/11/2015 12:56:06  CL-201601-NYMEX  IB order fill (execution)  56831  111608  Stop  1  Buy  41.57    Filled  41.58  1  DU4779  Open    1  0001f4e5.564d5f01.01.01
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.58. Requested Price: 41.639999. Requested Quantity: 0  56832    Limit    Sell  41.63    Pending Modify      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Order modified internally  56832    Limit    Sell  41.64    Pending Child      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Modifying Attached Order from parent modification/fill. Ref price: 41.58. Requested Price: 41.399999. Requested Quantity: 0  56833    Stop    Sell  41.39    Pending Modify      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Order modified internally  56833    Stop    Sell  41.4    Pending Child      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Auto-sent child from parent fill  56832    Limit  1  Sell  41.64    Order Sent      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Auto-sent child from parent fill  56833    Stop  1  Sell  41.4    Order Sent      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  Unable to modify order because it is no longer working  56831  111608  Stop  1  Buy  41.57    Filled  41.58  1  DU4779  Open
Order  19/11/2015 12:56:06  CL-201601-NYMEX  IB open order update  56832  111609  Limit  1  Sell  41.64    Open      DU4779  Close  56831  1
Order  19/11/2015 12:56:06  CL-201601-NYMEX  IB open order update  56833  111610  Stop  1  Sell  41.4    Open      DU4779  Close  56831  1
Order  19/11/2015 12:56:14  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.699999. Requested Quantity: 1  56832  111609  Limit  1  Sell  41.64    Pending Modify      DU4779  Close  56831  1
Order  19/11/2015 12:56:14  CL-201601-NYMEX  IB open order update  56832  111609  Limit  1  Sell  41.7    Open      DU4779  Close  56831  1
Order  19/11/2015 12:56:15  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  19/11/2015 12:56:28  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.559999. Requested Quantity: 1  56833  111610  Stop  1  Sell  41.4    Pending Modify      DU4779  Close  56831
Order  19/11/2015 12:56:28  CL-201601-NYMEX  IB open order update  56833  111610  Stop  1  Sell  41.56    Open      DU4779  Close  56831
Order  19/11/2015 12:56:39  CL-201601-NYMEX  CL-201601-NYMEX Renko 7t #46 | User order modification. Requested Price: 41.569999. Requested Quantity: 1  56833  111610  Stop  1  Sell  41.56    Pending Modify      DU4779  Close  56831
Order  19/11/2015 12:56:39  CL-201601-NYMEX  IB open order update  56833  111610  Stop  1  Sell  41.57    Open      DU4779  Close  56831
Order  19/11/2015 12:56:39  CL-201601-NYMEX  IB order fill (execution)  56833  111610  Stop  1  Sell  41.57    Filled  41.57  1  DU4779  Close  56831
Fill  19/11/2015 12:56:39  CL-201601-NYMEX  IB order fill (execution)  56833  111610  Stop  1  Sell  41.57    Filled  41.57  1  DU4779  Open    -1  0001f4e5.564d5f1b.01.01
Order  19/11/2015 12:56:39  CL-201601-NYMEX  Canceling order due to sibling fill  56832  111609  Limit  1  Sell  41.7    Pending Cancel      DU4779  Close  56831  -1
Order  19/11/2015 12:56:39  CL-201601-NYMEX  IB order status update  56832  111609  Limit  1  Sell  41.7    Canceled      DU4779  Close  56831  -1
Order  19/11/2015 12:56:51  CL-201601-NYMEX  Synchronized Internal Position to current Service Position. Current Position quantity: 0                Unspecified      DU4779
Order  19/11/2015 12:56:52  CL-201601-NYMEX  Unable to Flatten or Reverse because a Position does not exist                Unspecified      DU4779
Order  19/11/2015 12:56:55    Requesting all orders from trading service                Unspecified      None
Same thing at the 13:08 time. 0% evidence of any problem. Whatever happened, was strictly some issue with TWS. There was no order at all for the CL-201601-NYMEX symbol submitted from Sierra Chart other than the orders that you submitted. That is with certainty.
Date Time Of Last Edit: 2015-11-23 01:55:23
