Date/Time: Tue, 24 Dec 2024 02:30:32 +0000
Cannot login since sunday GMT
View Count: 1004
[2015-11-02 10:47:36]
User845555 - Posts: 43
Hi, haven't been able to log on, also not with forced log on, since sunday.
"CQG WebAPI | Market data logon unsuccessful. Server message: Trader is not enabled to use SierraChartData. Please contact your FCM. | 2015-11-02 11:45:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-11-02 11:45:53
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-11-02 11:45:53
Socket (17) | SSL shutdown indicates not able to send 'close notify'. | 2015-11-02 11:45:53
Socket (17) | SSL has been shut down. | 2015-11-02 11:45:53
Socket (17) | SSL object has been freed. SSL state is now disconnected. | 2015-11-02 11:45:53
Socket (17) | Shutdown and closed. | 2015-11-02 11:45:53
CQG WebAPI | Websocket closed. | 2015-11-02 11:45:53
CQG WebAPI | Disconnected. | 2015-11-02 11:45:53
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-11-02 11:45:53"
And yes I have purchased usage credit until the end of the year.
[2015-11-02 10:54:11]
This is the problem:
You need to contact your broker/trading service about this message. They need to resolve it on their side.
[2015-11-02 11:37:49]
OK thank you will do so
