Date/Time: Fri, 22 Nov 2024 18:39:31 +0000
CTS T4 Historical Data Request error message "No Permission"
View Count: 1807
[2013-05-30 04:41:44]
TopStepTraderAdmin - Posts: 6
Good evening,
One of our users, presumably currently on the free-trial version of SC, has sent us in the following error message:
I have set my Intraday data storage time unit in sierra to 1 min. I am still getting the permission error.
HD Request # 1 - Downloading Intraday chart data for CME_Eq-ES-CME_20130600_ESM3 to the file CME_Eq-ES-CME_20130600_ESM3.scid. Service: cts | 2013-05-28 20:34:30
HD Request # 1 - CTS T4 Service: Sending request for historical Minute data. TradeDate: 2013-05-18 | 2013-05-28 20:34:30
CTS T4 Service: Error with historical data request. T4 Message: No Permission. | 2013-05-28 20:34:32
Real-Time data appears to be unaffected. I appreciate your help!
-Tim
[2013-05-30 05:54:06]
This means they do not have permission for historical data on the T4 system. Please contact CTS for help with this.
[2013-05-30 20:16:56]
To followup,
I have connected to CTS through SC utilizing this user's CTS connection credentials and do not receive the same errors. In fact, I am able to connect and pull historical data just fine.
Is there some sort of setting on SC that could be preventing the download of historical data or causing some-sort of conflict?
Thank you,
[2013-05-30 20:39:00]
There is no Sierra Chart specific setting which would cause this:
If the CTS T4 connection information as it is entered into Sierra Chart is not correct, they would never even get to this point because they would not be able to connect to the T4 system.
In this particular case, the log files from the users system would have to be checked and sent to CTS. This is the location of the T4 logs:
C:\SierraChart\Trace\T4Logs
Date Time Of Last Edit: 2013-05-30 20:39:46
[2013-05-30 22:45:09]
Trace files are attached.
attachmentSierra_4016_20130530_143622.T4TraceErrorLog - Attached On 2013-05-30 22:44:25 UTC - Size: 1.2 KB - 575 views
attachmentSierra_4016_20130530_143622.T4TraceLog - Attached On 2013-05-30 22:44:34 UTC - Size: 22.54 KB - 752 views
[2013-05-30 22:50:56]
These need to go to Cunningham Trading Systems. We are not qualified to analyze them nor do we have any ability to resolve the problem ourselves.
