Date/Time: Tue, 15 Sep 2026 04:37:48 +0000
Problems downloading historical intraday data.
View Count: 1821
[2015-03-18 21:50:56]
2garin - Posts: 189
Hello Saporta.
Experiencing problems downloading historical intraday data contract ES.
Loading occurs during clearing (break). Log file is attached.
What is the problem?
Private File
[2015-03-19 03:25:09]
We do see a problem where this historical Intraday data download did not complete in the Message Log:
HD Request # 2 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: cme | 2015-03-19 09:34:55
For help with this, refer to this section here:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Error when Downloading Historical Intraday Data from the Sierra Chart Historical Data Server
We recommend setting the Global Settings >> Data/Trade Service Settings >> Intraday Data Storage Time Unit to 1 second to reduce the amount of data transmitted.
[2015-03-19 05:22:34]
2garin - Posts: 189
Footprint required for tick history.
To determine the problem: Is it possible in the "Message Log" to display the processes download history? (in percentage units)
[2015-03-19 17:17:13]
A percentage progress is not possible.
It is necessary to isolate the source of the problem by adjusting the Intraday Data Storage Time Unit.
Select File >> Disconnect.
Select Global Settings >> Data/Trade Service Settings.
Set the Intraday Data Storage Time Unit to 10 seconds.
Select File >> Connect to Data Feed
If there is any missing data in the chart, follow the instructions here:
See if that corrects the problem.
[2015-03-19 22:40:26]
2garin - Posts: 189
Good afternoon Sapport.
If I understand correctly, you are offering to download intraday historical data in 10-second resolution.
Q: Charts footprint identical to the construction of teak and 10-second story?
The problem with loading the history of ticks during a break of tender (clearing) remained.
[2015-03-20 16:15:25]
The purpose of downloading the data in the 10 second resolution is to see if there any download problems at that interval. If so, then you have some ongoing connectivity problem with your Internet connection between your computer and the server.
Using 10 second records data for Numbers Bars is inaccurate.
Date Time Of Last Edit: 2015-03-20 16:15:37
[2015-03-22 22:52:30]
2garin - Posts: 189
Good evening a support.
Connected to another ISP. The problem with downloading missing.
Wish: you can visualize availability (status) of servers to download history? (similar to the status of the connection terminal)
[2015-03-25 03:54:16]
2garin - Posts: 189
To request the ISP (removing blockages) Please let me know the name / port of the server to download tick historical data.
DTS settings window attached.
PS How to apply (desire) to change the functionality of the terminal?
Date Time Of Last Edit: 2015-03-25 04:02:45
Private File
[2015-03-25 03:58:17]
The port numbers are documented here:
https://www.sierrachart.com/index.php?page=doc/helpdetails1.html#h1.6
Also it is possible to use port 80:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Using Port 80
