Date/Time: Sat, 21 Dec 2024 17:49:42 +0000
Historical Data Not Loading Correctly Since Upgrade to 1235 & Higher
View Count: 946
[2015-03-03 21:18:53]
User23386 - Posts: 43
I upgraded to version 1235 and noticed that all the historical data was not loading correctly so I took images of the weekly, monthly & yearly charts on version 1224 versus 1235 to show you guys. I waited a few days to see would any further upgrades from 1235 solve this missing data and after upgrading to 1239 the historical data is still not loading correctly... Any ideas why? Can you fix this? Please find attached weekly, monthly & yearly charts on version 1224 versus 1235 and above...
imageESH15 ESH5-CME [CBV] Yearly Version 1224.png / V - Attached On 2015-03-03 21:16:11 UTC - Size: 13.87 KB - 402 views
imageESH5-CME [CBV] Yearly Version 1235 Data Missing.png / V - Attached On 2015-03-03 21:16:18 UTC - Size: 28.71 KB - 377 views
imageESH15 ESH5-CME [CBV] Monthly Version 1224.png / V - Attached On 2015-03-03 21:16:30 UTC - Size: 70.71 KB - 367 views
imageESH5-CME [CBV] Monthly Version 1235 Data Missing.png / V - Attached On 2015-03-03 21:16:40 UTC - Size: 43.11 KB - 362 views
imageESH15 ESH5-CME [CBV] Weekly Version 1224.png / V - Attached On 2015-03-03 21:17:22 UTC - Size: 92.21 KB - 352 views
imageESH5-CME [CBV] Weekly Version 1235 Data Missing.png / V - Attached On 2015-03-03 21:18:27 UTC - Size: 81.79 KB - 376 views
[2015-03-04 03:29:55]
It does not help to post so many images. Only one image is necessary and briefly explain the problem. We did not look at all of these images. By overdoing the post, it only delays the response and creates more burden on us. It is simply not helpful.
What this indicates is there is missing historical data. Follow the instructions here to re-download the data:
https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
Newer versions will re-download the data into new files with a different name. Why the downloads failed, we are not sure but that is irrelevant at this point.
[2015-03-04 22:18:47]
Excuse my ignorance I didn't know prior to posting that less is more when dealing with support. I understand you guys are out the door with software support so I be brief. I followed your instructions to the T and I still have the missing data using versions 1235 and higher. I have NO missing data when using version 1224. I completely deleted ALL the data files both Historical & Intraday then did new download. You can still see the missing data on version 1239 using the yearly chart image comparison versus version 1224. It's the same on both weekly & monthly charts.
imageESH5-CME [CBV] Yearly #26 2015-03-04 Version 1239.png / V - Attached On 2015-03-04 22:15:38 UTC - Size: 8.32 KB - 328 views
imageESH15 ESH5-CME [CBV] Yearly #26 2015-03-04 Version 1224.png / V - Attached On 2015-03-04 22:16:01 UTC - Size: 17.97 KB - 336 views
[2015-03-04 22:54:59]
We would like to look at this using remote assistance.
We do not need an audio connection. When you would like us to connect could you start an Account Support Ticket:
https://www.sierrachart.com/usercp.php?page=SupportTickets
At that time we need you to select Help >> Accept Remote Assistance. When the Team viewer window appears give us the ID number and password through the account support ticket.
[2015-03-05 18:48:25]
What version do you want loaded when you connect? 1224? 1239? Will I save a new smaller workspace with just the charts that are affected with the missing data (Yearly, Monthly, Weekly, Daily charts)to save on loading the data upon start up and connect? My current workspace takes quite a few minutes to load on this PC and I don't want to delay you guys any longer than needed. Let me know what version you want loaded and if you require a reduced size workspace for the remote log in.
Thank you
[2015-03-05 19:45:28]
We have already connected to your system and looked into the problem so these particular questions are not relevant at this time.
We understand the nature of the problem and we are going to determine a solution.
