Date/Time: Wed, 23 Sep 2026 02:42:51 +0000
Data Feed Disconnected
View Count: 1509
[2015-01-06 15:35:42]
User46092 - Posts: 17
My data feed won't connect. can you please explain in real simple terms if this is a problem on my end? Does the problem have something to do with my antivirus software? Thanks in advance.
Software version: 1220 | 2015-01-06 10:21:23
Uses New Spreadsheets | 2015-01-06 10:21:23
Usage end date: 2015-03-28 | 2015-01-06 10:21:23
Enabled for: Advanced Features. | 2015-01-06 10:21:23
Enabled for: Advanced Features 2. | 2015-01-06 10:21:23
Enabled for: Sierra Chart Historical Data Service. | 2015-01-06 10:21:23
Allow Support for Sierra Chart Data Feeds is enabled. | 2015-01-06 10:21:23
Active service: Rithmic Trading | 2015-01-06 10:21:23
Data/Trade Service Settings automatically set. | 2015-01-06 10:21:23
Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-01-06 10:21:23
2015-01-06 16:21:23 Local computer clock time | 2015-01-06 10:21:23
2015-01-06 15:21:23 GMT time | 2015-01-06 10:21:23
2015-01-06 10:21:23 Time zone adjusted time | 2015-01-06 10:21:23
Time difference to server time: 2 seconds. | 2015-01-06 10:21:23
Program path: C:\SierraChart\ | 2015-01-06 10:21:23
Data Files path: C:\SierraChart\Data\ | 2015-01-06 10:21:23
OS Version Number: 6.2 | 2015-01-06 10:21:23
Locale Information: C | 2015-01-06 10:21:23
Checking for new symbol settings for rim | 2015-01-06 10:21:23
HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-01-06 10:21:23
HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-01-06 10:21:23
Symbol settings are up-to-date for rim | 2015-01-06 10:21:24
Files to Open on Start up | Opening file: OpenTrader_1.cht | 2015-01-06 10:21:26
Date rule based rollover from ESH5-CME to next contract occurs at 2015-03-12. | 2015-01-06 10:21:26
Checking Intraday data file for symbol ESH5-CME for the date range from 2014-12-11 to 0. | 2015-01-06 10:21:26
Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-01-06. | 2015-01-06 10:21:26
ESH5-CME [CB] 30 Min #4 | Symbols used for continuous contract chart: | 2015-01-06 10:21:26
ESH5-CME | 2015-01-06 10:21:26
ESH5-CME [CB] 30 Min #4: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:26
Date rule based rollover from ESZ4-CME to next contract occurs at 2014-12-11. | 2015-01-06 10:21:26
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 2014-12-11. | 2015-01-06 10:21:26
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-06 10:21:26
ESH5-CME [CB] 1 Min #9 | Symbols used for continuous contract chart: | 2015-01-06 10:21:26
ESZ4-CME | 2015-01-06 10:21:26
ESH5-CME [CB] 1 Min #9: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:26
ESH5-CME [CB] 1 Min #9: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-06 10:21:26
ESH5-CME [CB] 1 Min #9: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-06 10:21:26
ESH5-CME [CB] 1 Min #9: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-06 10:21:26
ESH5-CME [CB] 1 Min #9: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-06 10:21:26
ESH5-CME [CB] 30 Min #15 | Symbols used for continuous contract chart: | 2015-01-06 10:21:26
ESH5-CME [CB] 30 Min #15: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:26
Date rule based rollover from ESH4-CME to next contract occurs at 2014-03-13. | 2015-01-06 10:21:26
Date rule based rollover from ESM4-CME to next contract occurs at 2014-06-12. | 2015-01-06 10:21:26
Date rule based rollover from ESU4-CME to next contract occurs at 2014-09-11. | 2015-01-06 10:21:26
Checking Intraday data file for symbol ESH4-CME for the date range from 2013-12-12 to 2014-03-13. | 2015-01-06 10:21:26
Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-01-06 10:21:26
Checking Intraday data file for symbol ESM4-CME for the date range from 2014-03-13 to 2014-06-12. | 2015-01-06 10:21:26
Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-01-06 10:21:26
Checking Intraday data file for symbol ESU4-CME for the date range from 2014-06-12 to 2014-09-11. | 2015-01-06 10:21:26
Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-01-06 10:21:26
Checking Intraday data file for symbol ESZ4-CME for the date range from 2014-09-11 to 0. | 2015-01-06 10:21:26
Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2015-01-06. | 2015-01-06 10:21:26
Performing historical Daily data download for symbol ESZ14 starting at 0. | 2015-01-06 10:21:26
ESZ4-CME [CB] 120 Min #11 | Symbols used for continuous contract chart: | 2015-01-06 10:21:26
ESH4-CME | 2015-01-06 10:21:26
ESM4-CME | 2015-01-06 10:21:26
ESU4-CME | 2015-01-06 10:21:26
ESZ4-CME [CB] 120 Min #11 | Waiting for historical downloads to complete with the IDs: 1, | 2015-01-06 10:21:26
Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-06 10:21:26 *
Skipping Daily data download for symbol ESZ14 since download was already done in last 24 hours. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6 | Symbols used for continuous contract chart: | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-06 10:21:26
ESZ4-CME [CB] 30 Min #6: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-06 10:21:26
ESH5-CME [CB] 2 Min #17 | Symbols used for continuous contract chart: | 2015-01-06 10:21:26
ESH5-CME [CB] 2 Min #17: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:26
ESH5-CME [CB] 2 Min #17: ESZ4-CME Open price on 2014-12-11 is 2026.25. | 2015-01-06 10:21:26
ESH5-CME [CB] 2 Min #17: ESH5-CME Open price on 2014-12-11 is 2019.75. | 2015-01-06 10:21:26
ESH5-CME [CB] 2 Min #17: ESZ4-CME price difference to ESH5-CME is -6.5. | 2015-01-06 10:21:26
ESH5-CME [CB] 2 Min #17: Back adjust amount for symbol ESZ4-CME is -6.5. | 2015-01-06 10:21:26
Date rule based rollover from TF FMZ0014!-NYBOT to next contract occurs at 2014-12-11. | 2015-01-06 10:21:27
Date rule based rollover from TF FMH0015!-NYBOT to next contract occurs at 2015-03-12. | 2015-01-06 10:21:27
Checking Intraday data file for symbol TF FMZ0014!-NYBOT for the date range from 2014-09-11 to 2014-12-11. | 2015-01-06 10:21:27
Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-01-06 10:21:27
Checking Intraday data file for symbol TF FMH0015!-NYBOT for the date range from 2014-12-11 to 0. | 2015-01-06 10:21:27
Checking Daily data file for symbol RJH15 for the date range from 2014-12-11 to 2015-01-06. | 2015-01-06 10:21:27
TF FMH0015!-NYBOT [CB] 5 Min #12 | Symbols used for continuous contract chart: | 2015-01-06 10:21:27
TF FMZ0014!-NYBOT | 2015-01-06 10:21:27
TF FMH0015!-NYBOT | 2015-01-06 10:21:27
TF FMH0015!-NYBOT [CB] 5 Min #12: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:27
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMZ0014!-NYBOT Open price on 2014-12-11 is 1162.2. | 2015-01-06 10:21:27
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMH0015!-NYBOT Open price on 2014-12-11 is 1157.5. | 2015-01-06 10:21:27
TF FMH0015!-NYBOT [CB] 5 Min #12: TF FMZ0014!-NYBOT price difference to TF FMH0015!-NYBOT is -4.6999998. | 2015-01-06 10:21:27
TF FMH0015!-NYBOT [CB] 5 Min #12: Back adjust amount for symbol TF FMZ0014!-NYBOT is -4.6999998. | 2015-01-06 10:21:27
HD Request # 2 | Downloading Historical Daily chart data for ESZ14. Starting date: 2014-12-18. Service: rim | 2015-01-06 10:21:27
HD Request # 2 | Requesting historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-06 10:21:27
Chart #7 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:28
Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-06 10:21:28
HD Request # 3 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-06 10:21:28
HD Request # 3 | Download start Date-Time: 2015-01-06 10:21:03.0 | 2015-01-06 10:21:28
HD Request # 3 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:21:28
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:21:28
Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-06 10:21:28
Intraday data recording state for symbol ESZ4-CME is set to download pending. | 2015-01-06 10:21:28
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:28
Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-06 10:21:28
Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-06 10:21:28
Intraday data recording state for symbol NISS-TF is set to download pending. | 2015-01-06 10:21:28
Chart #3 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:28
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:28
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:28
Chart #10 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:28
HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-01-06 10:21:29
HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-01-06 10:21:29
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:29
HD Request # 2 | Receiving historical Daily data for ESZ14 starting at 2014-12-17 | 2015-01-06 10:21:29
Writing historical Daily data for ESZ14 to the file ESZ14.dly | 2015-01-06 10:21:29
HD Request # 2 | Received 3 records from 2014-12-17 00:00:00 to 2014-12-19 00:00:00 (3.0 days) and wrote 2 records for ESZ14 | 2015-01-06 10:21:29
HD Request # 2 | Daily download COMPLETE for ESZ14. Completion time: 2s. Unique request ID: 1 | 2015-01-06 10:21:29
Removed historical data download ID 1 | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: Download is complete for all contract months in chart. Proceeding with data load. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: Performing continuous futures contract back adjustment calculations. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESH4-CME Open price on 2014-03-13 is 1868.75. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESM4-CME Open price on 2014-03-13 is 1861.5. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESH4-CME price difference to ESM4-CME is -7.25. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESM4-CME Open price on 2014-06-12 is 1943.75. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESU4-CME Open price on 2014-06-12 is 1936.75. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESM4-CME price difference to ESU4-CME is -7. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESU4-CME Open price on 2014-09-11 is 1994.5. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESZ4-CME Open price on 2014-09-11 is 1986.75. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: ESU4-CME price difference to ESZ4-CME is -7.75. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: Back adjust amount for symbol ESH4-CME is -22. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: Back adjust amount for symbol ESM4-CME is -14.75. | 2015-01-06 10:21:29
ESZ4-CME [CB] 120 Min #11: Back adjust amount for symbol ESU4-CME is -7.75. | 2015-01-06 10:21:29
Rithmic Trading | Port for executable: 60281 | 2015-01-06 10:21:29
Listening socket (2036), port 60281 | Closed. | 2015-01-06 10:21:29
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:21:29
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60281 | 2015-01-06 10:21:31
Socket (3) | Connected. | 2015-01-06 10:21:31
Rithmic Trading | Connected to server. | 2015-01-06 10:21:31
Rithmic Trading | Sending logon request message. | 2015-01-06 10:21:31
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:21:31
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:21:31
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:21:31
Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-06 10:21:33 *
Socket (2) | Connected. | 2015-01-06 10:21:44
HD Request # 3 | Sending historical data logon request message. | 2015-01-06 10:21:44
HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-01-06 10:21:03. Record interval: 1. Symbol: TICK-NYSE | 2015-01-06 10:21:58
HD Request # 3 | Decompressing data. | 2015-01-06 10:21:58
HD Request # 3 | Receiving Intraday data for TICK-NYSE starting at 2015-01-06 10:21:03 | 2015-01-06 10:21:58
HD Request # 3 | Timestamp of first Intraday data file record written: 2015-01-06 10:21:03 | 2015-01-06 10:21:58
HD Request # 3 | Historical data for TICK-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-01-06 10:21:58
Socket (2) | Shutdown and closed. | 2015-01-06 10:21:58
The network socket for historical data has been closed. | 2015-01-06 10:21:58
HD Request # 3 | Received 54 records from 2015-01-06 10:21:03 to 2015-01-06 10:21:56 (53.0 seconds) and wrote 54 records for TICK-NYSE | 2015-01-06 10:21:58
HD Request # 3 | Intraday download COMPLETE for TICK-NYSE. Completion time: 30s. Unique request ID: 2 | 2015-01-06 10:21:58
Removed historical data download ID 2 | 2015-01-06 10:21:58
HD Request # 4 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-06 10:21:58
HD Request # 4 | Download start Date-Time: 2015-01-06 10:21:03.0 | 2015-01-06 10:21:58
HD Request # 4 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:21:58
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:21:58
Socket (4) | Connected. | 2015-01-06 10:21:58
HD Request # 4 | Sending historical data logon request message. | 2015-01-06 10:21:58
Chart #10 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:59
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:21:59
HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-01-06 10:21:03. Record interval: 1. Symbol: NISS-SP | 2015-01-06 10:21:59
HD Request # 4 | Decompressing data. | 2015-01-06 10:22:00
HD Request # 4 | Receiving Intraday data for NISS-SP starting at 2015-01-06 10:21:03 | 2015-01-06 10:22:00
HD Request # 4 | Timestamp of first Intraday data file record written: 2015-01-06 10:21:03 | 2015-01-06 10:22:00
HD Request # 4 | Historical data for NISS-SP is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-01-06 10:22:00
Socket (4) | Shutdown and closed. | 2015-01-06 10:22:00
The network socket for historical data has been closed. | 2015-01-06 10:22:00
HD Request # 4 | Received 55 records from 2015-01-06 10:21:03 to 2015-01-06 10:21:57 (54.0 seconds) and wrote 55 records for NISS-SP | 2015-01-06 10:22:00
HD Request # 4 | Intraday download COMPLETE for NISS-SP. Completion time: 2s. Unique request ID: 3 | 2015-01-06 10:22:00
Removed historical data download ID 3 | 2015-01-06 10:22:00
HD Request # 5 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: cme | 2015-01-06 10:22:00
HD Request # 5 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-01-06 10:22:00
HD Request # 5 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-06 10:22:00
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-06 10:22:00
Chart #7 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:00
Socket (5) | Connected. | 2015-01-06 10:22:00
HD Request # 5 | Sending historical data logon request message. | 2015-01-06 10:22:00
HD Request # 5 | Requesting Intraday data. Start Date-Time: 2014-12-19 09:29:59. Record interval: 1. Symbol: ESZ4 | 2015-01-06 10:22:00
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:00
HD Request # 5 | Decompressing data. | 2015-01-06 10:22:01
HD Request # 5 | Receiving Intraday data for ESZ4-CME starting at 2014-12-19 09:29:59 | 2015-01-06 10:22:01
HD Request # 5 | Timestamp of first Intraday data file record written: 2014-12-19 09:29:59 | 2015-01-06 10:22:01
HD Request # 5 | Historical data for ESZ4-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-01-06 10:22:01
Socket (5) | Shutdown and closed. | 2015-01-06 10:22:01
The network socket for historical data has been closed. | 2015-01-06 10:22:01
HD Request # 5 | Received 1 record from 2014-12-19 09:29:59 to 2014-12-19 09:29:59 (0.0 seconds) and wrote 1 record for ESZ4-CME | 2015-01-06 10:22:01
HD Request # 5 | Intraday download COMPLETE for ESZ4-CME. Completion time: 1s. Unique request ID: 4 | 2015-01-06 10:22:01
Removed historical data download ID 4 | 2015-01-06 10:22:01
HD Request # 6 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-06 10:22:01
HD Request # 6 | Download start Date-Time: 2015-01-06 10:21:03.0 | 2015-01-06 10:22:01
HD Request # 6 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:22:01
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:22:01
Rithmic Trading | Server Alert: Market Data Connection Opened | 2015-01-06 10:22:01
Socket (6) | Connected. | 2015-01-06 10:22:01
HD Request # 6 | Sending historical data logon request message. | 2015-01-06 10:22:01
Error loading custom studies DLL: C:\SierraChart\Data\ZoneWidth.dll. Windows error code 126: The specified module could not be found. | 2015-01-06 10:22:01 *
Rithmic Trading | Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2015-01-06 10:22:01
HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-01-06 10:21:03. Record interval: 1. Symbol: NISS-NYSE | 2015-01-06 10:22:01
HD Request # 6 | Decompressing data. | 2015-01-06 10:22:01
HD Request # 6 | Receiving Intraday data for NISS-NYSE starting at 2015-01-06 10:21:03 | 2015-01-06 10:22:01
HD Request # 6 | Timestamp of first Intraday data file record written: 2015-01-06 10:21:03 | 2015-01-06 10:22:01
HD Request # 6 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-01-06 10:22:01
Socket (6) | Shutdown and closed. | 2015-01-06 10:22:01
HD Request # 6 | Received 57 records from 2015-01-06 10:21:03 to 2015-01-06 10:21:59 (56.0 seconds) and wrote 57 records for NISS-NYSE | 2015-01-06 10:22:01
HD Request # 6 | Intraday download COMPLETE for NISS-NYSE. Completion time: 0s. Unique request ID: 5 | 2015-01-06 10:22:01
Removed historical data download ID 5 | 2015-01-06 10:22:01
HD Request # 7 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-06 10:22:01
HD Request # 7 | Download start Date-Time: 2015-01-06 10:21:03.0 | 2015-01-06 10:22:01
HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:22:01
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:22:01
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:02
Socket (7) | Connected. | 2015-01-06 10:22:02
HD Request # 7 | Sending historical data logon request message. | 2015-01-06 10:22:02
HD Request # 7 | Requesting Intraday data. Start Date-Time: 2015-01-06 10:21:03. Record interval: 1. Symbol: NISS-NQ | 2015-01-06 10:22:02
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:02
HD Request # 7 | Decompressing data. | 2015-01-06 10:22:02
HD Request # 7 | Receiving Intraday data for NISS-NQ starting at 2015-01-06 10:21:03 | 2015-01-06 10:22:02
HD Request # 7 | Timestamp of first Intraday data file record written: 2015-01-06 10:21:03 | 2015-01-06 10:22:02
HD Request # 7 | Historical data for NISS-NQ is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-01-06 10:22:02
Socket (7) | Shutdown and closed. | 2015-01-06 10:22:02
The network socket for historical data has been closed. | 2015-01-06 10:22:02
HD Request # 7 | Received 58 records from 2015-01-06 10:21:03 to 2015-01-06 10:22:00 (57.0 seconds) and wrote 58 records for NISS-NQ | 2015-01-06 10:22:02
HD Request # 7 | Intraday download COMPLETE for NISS-NQ. Completion time: 0s. Unique request ID: 6 | 2015-01-06 10:22:02
Removed historical data download ID 6 | 2015-01-06 10:22:02
HD Request # 8 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2015-01-06 10:22:02
HD Request # 8 | Download start Date-Time: 2015-01-06 10:21:03.0 | 2015-01-06 10:22:02
HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:22:02
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:22:02
Rithmic Trading | Server Alert: Trading System Connection Opened | 2015-01-06 10:22:02
Socket (8) | Connected. | 2015-01-06 10:22:02
HD Request # 8 | Sending historical data logon request message. | 2015-01-06 10:22:02
Rithmic Trading | Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2015-01-06 10:22:02
HD Request # 8 | Requesting Intraday data. Start Date-Time: 2015-01-06 10:21:03. Record interval: 1. Symbol: NISS-TF | 2015-01-06 10:22:02
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:03
Rithmic Trading | subscribeTradeRoute error. Error code: API_ALREADY_EXISTS | 2015-01-06 10:22:03
HD Request # 8 | Decompressing data. | 2015-01-06 10:22:03
HD Request # 8 | Receiving Intraday data for NISS-TF starting at 2015-01-06 10:21:03 | 2015-01-06 10:22:03
HD Request # 8 | Timestamp of first Intraday data file record written: 2015-01-06 10:21:03 | 2015-01-06 10:22:03
Socket (8) | Shutdown and closed. | 2015-01-06 10:22:03
The network socket for historical data has been closed. | 2015-01-06 10:22:03
HD Request # 8 | Historical data for NISS-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2015-01-06 10:22:03
HD Request # 8 | Received 58 records from 2015-01-06 10:21:03 to 2015-01-06 10:22:00 (57.0 seconds) and wrote 58 records for NISS-TF | 2015-01-06 10:22:03
HD Request # 8 | Intraday download COMPLETE for NISS-TF. Completion time: 1s. Unique request ID: 7 | 2015-01-06 10:22:03
Removed historical data download ID 7 | 2015-01-06 10:22:03
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:03
Chart #3 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:22:03
Rithmic Trading | Server Alert: PnL Connection Opened | 2015-01-06 10:22:42
Rithmic Trading | Server Alert: PnL Connection Login Complete. Result text: "ok" | 2015-01-06 10:22:42
Rithmic Trading | Server Alert: Intraday History Connection Opened | 2015-01-06 10:22:44
Rithmic Trading | Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2015-01-06 10:22:44
Rithmic Trading | Server Name: SC DTC Bridge. | 2015-01-06 10:22:44
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:22:44
Rithmic Trading | Successfully connected. IB='OptimusFutures'. | 2015-01-06 10:22:44
Rithmic Trading | Trading is supported. | 2015-01-06 10:22:44
Rithmic Trading | Order cancel and replace is supported. | 2015-01-06 10:22:44
Rithmic Trading | OCO Orders supported. | 2015-01-06 10:22:44
Rithmic Trading | Starting real-time market data updates for: ESH5-CME. ID: 1 | 2015-01-06 10:22:44
Intraday data recording state for symbol ESH5-CME is set to download pending. | 2015-01-06 10:22:44
HD Request # 9 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: rim | 2015-01-06 10:22:45
HD Request # 9 | Download start Date-Time: 2015-01-06 10:18:54.0 | 2015-01-06 10:22:45
HD Request # 9 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:22:45
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:22:45
SC Market Stats | Starting real-time market data updates for: NISS-NYSE. ID: 2 | 2015-01-06 10:22:45
SC Market Stats | Connecting to the server ds4.sierracharts.com. Port 443 | 2015-01-06 10:22:45
Intraday data recording state for symbol NISS-NYSE is set to download pending. | 2015-01-06 10:22:45
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:22:45
SC Market Stats | Starting real-time market data updates for: NISS-NQ. ID: 3 | 2015-01-06 10:22:45
Intraday data recording state for symbol NISS-NQ is set to download pending. | 2015-01-06 10:22:45
SC Market Stats | Starting real-time market data updates for: NISS-TF. ID: 4 | 2015-01-06 10:22:45
Intraday data recording state for symbol NISS-TF is set to download pending. | 2015-01-06 10:22:45
Rithmic Trading | Starting real-time market data updates for: TF FMH0015!-NYBOT. ID: 5 | 2015-01-06 10:22:45
Intraday data recording state for symbol TF FMH0015!-NYBOT is set to download pending. | 2015-01-06 10:22:45
SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 6 | 2015-01-06 10:22:45
Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-01-06 10:22:45
SC Market Stats | Starting real-time market data updates for: NISS-SP. ID: 7 | 2015-01-06 10:22:45
Intraday data recording state for symbol NISS-SP is set to download pending. | 2015-01-06 10:22:45
Rithmic Trading | Starting real-time market data updates for: NQH5-CME. ID: 8 | 2015-01-06 10:22:45
Intraday data recording state for symbol NQH5-CME is set to download pending. | 2015-01-06 10:22:45
Socket (10) | Connected. | 2015-01-06 10:22:45
SC Market Stats | Connected to server. | 2015-01-06 10:22:45
SC Market Stats | Sending logon request message. | 2015-01-06 10:22:45
Rithmic Trading | Starting real-time market data updates for: ESZ4-CME. ID: 9 | 2015-01-06 10:22:45
Intraday data recording state for symbol ESZ4-CME is set to download pending. | 2015-01-06 10:22:45
Socket (9) | Connected. | 2015-01-06 10:22:45
HD Request # 9 | Sending historical data logon request message. | 2015-01-06 10:22:45
SC Market Stats | Server Name: SC Realtime Server. | 2015-01-06 10:22:46
SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:22:46
SC Market Stats | Successfully connected. | 2015-01-06 10:22:46
SC Market Stats | Restarting real-time data updates for symbol: NISS-NQ | 2015-01-06 10:22:46
SC Market Stats | Restarting real-time data updates for symbol: NISS-NYSE | 2015-01-06 10:22:46
SC Market Stats | Restarting real-time data updates for symbol: NISS-SP | 2015-01-06 10:22:46
SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2015-01-06 10:22:46
SC Market Stats | Restarting real-time data updates for symbol: TICK-NYSE | 2015-01-06 10:22:46
Rithmic Trading | Requesting Trade Positions data. | 2015-01-06 10:22:49
Requesting market depth updates for: ESH5-CME if supported. | 2015-01-06 10:22:49
Socket (9) | Closed. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2015-01-06 10:23:06
Socket (9) | Shutdown and closed. | 2015-01-06 10:23:06
HD Request # 9 | Error downloading historical Intraday data for ESH5-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:23:06 *
HD Request # 9 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5-CME | 2015-01-06 10:23:06
HD Request # 10 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: rim | 2015-01-06 10:23:06
HD Request # 10 | Download start Date-Time: 2015-01-06 10:18:54.0 | 2015-01-06 10:23:06
HD Request # 10 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:23:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:23:06
Socket (11) | Shutdown and closed. | 2015-01-06 10:23:26
HD Request # 10 | Error downloading historical Intraday data for ESH5-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:23:26 *
HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5-CME | 2015-01-06 10:23:26
HD Request # 11 | Downloading Intraday chart data for ESH5-CME to the file ESH5-CME.scid. Service: rim | 2015-01-06 10:23:26
HD Request # 11 | Download start Date-Time: 2015-01-06 10:18:54.0 | 2015-01-06 10:23:26
HD Request # 11 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:23:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:23:26
Rithmic Trading | Server Alert: Market Data Connection - Heartbeat has been quiet for 53.665 seconds. | 2015-01-06 10:23:39
Rithmic Trading | Server Alert: Trading System Connection - Heartbeat has been quiet for 55.900 seconds. | 2015-01-06 10:23:41
Rithmic Trading | Deleting API object. | 2015-01-06 10:23:41
Rithmic Trading | Server Alert: Intraday History Connection Closed | 2015-01-06 10:23:41
Rithmic Trading | Server Alert: PnL Connection Closed | 2015-01-06 10:23:41
Rithmic Trading | Server Alert: Trading System Connection Closed | 2015-01-06 10:23:41
Rithmic Trading | Server Alert: Market Data Connection Closed | 2015-01-06 10:23:41
Socket (3) | Closed. No error. | 2015-01-06 10:23:41
Socket (3) | Shutdown and closed. | 2015-01-06 10:23:41
Connection to the external service has been lost. | 2015-01-06 10:23:41
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:23:41
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:23:41
Rithmic Trading | Port for executable: 60346 | 2015-01-06 10:23:43
Listening socket (748), port 60346 | Closed. | 2015-01-06 10:23:43
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:23:43
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60346 | 2015-01-06 10:23:45
Socket (13) | Connected. | 2015-01-06 10:23:45
Rithmic Trading | Connected to server. | 2015-01-06 10:23:45
Rithmic Trading | Sending logon request message. | 2015-01-06 10:23:45
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:23:45
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:23:45
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:23:45
Socket (12) | Shutdown and closed. | 2015-01-06 10:23:46
HD Request # 11 | Error downloading historical Intraday data for ESH5-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:23:46 *
HD Request # 11 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESH5-CME | 2015-01-06 10:23:46
HD Request # 11 | Intraday download COMPLETE for ESH5-CME. Completion time: 20s. Unique request ID: 8 | 2015-01-06 10:23:46
Removed historical data download ID 8 | 2015-01-06 10:23:46
HD Request # 12 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-06 10:23:46
HD Request # 12 | Download start Date-Time: 2015-01-06 10:21:59.0 | 2015-01-06 10:23:46
HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:23:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:23:46
Chart #4 has tagged chart #9 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:23:46
Chart #9 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:23:46
Chart #15 has tagged chart #9 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:23:47
Chart #9 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:23:47
Socket (14) | Shutdown and closed. | 2015-01-06 10:24:06
HD Request # 12 | Error downloading historical Intraday data for NISS-NYSE. The network socket has been closed. Retrying download. | 2015-01-06 10:24:06 *
HD Request # 12 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-NYSE | 2015-01-06 10:24:06
HD Request # 13 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-06 10:24:06
HD Request # 13 | Download start Date-Time: 2015-01-06 10:21:59.0 | 2015-01-06 10:24:06
HD Request # 13 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:24:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:24:06
Socket (15) | Shutdown and closed. | 2015-01-06 10:24:26
HD Request # 13 | Error downloading historical Intraday data for NISS-NYSE. The network socket has been closed. Retrying download. | 2015-01-06 10:24:26 *
HD Request # 13 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-NYSE | 2015-01-06 10:24:26
HD Request # 14 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2015-01-06 10:24:26
HD Request # 14 | Download start Date-Time: 2015-01-06 10:21:59.0 | 2015-01-06 10:24:26
HD Request # 14 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:24:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:24:26
Socket (16) | Shutdown and closed. | 2015-01-06 10:24:46
HD Request # 14 | Error downloading historical Intraday data for NISS-NYSE. The network socket has been closed. Retrying download. | 2015-01-06 10:24:46 *
HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-NYSE | 2015-01-06 10:24:46
HD Request # 14 | Intraday download COMPLETE for NISS-NYSE. Completion time: 20s. Unique request ID: 9 | 2015-01-06 10:24:46
Removed historical data download ID 9 | 2015-01-06 10:24:46
HD Request # 15 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-06 10:24:46
HD Request # 15 | Download start Date-Time: 2015-01-06 10:22:00.0 | 2015-01-06 10:24:46
HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:24:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:24:46
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:46
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:47
Chart #4 has tagged chart #9 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:47
Chart #9 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:47
Chart #15 has tagged chart #9 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #1 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #3 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #10 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #7 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #9 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:48
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:24:49
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:24:50
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:24:50
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:24:50
Rithmic Trading | Logon error from server | 2015-01-06 10:24:50
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:24:50
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:24:50
Socket (13) | Closed. No error. | 2015-01-06 10:24:50
Socket (13) | Shutdown and closed. | 2015-01-06 10:24:50
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:24:50
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:24:50
Rithmic Trading | Port for executable: 60362 | 2015-01-06 10:24:52
Listening socket (1212), port 60362 | Closed. | 2015-01-06 10:24:52
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:24:52
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60362 | 2015-01-06 10:24:54
Socket (18) | Connected. | 2015-01-06 10:24:54
Rithmic Trading | Connected to server. | 2015-01-06 10:24:54
Rithmic Trading | Sending logon request message. | 2015-01-06 10:24:54
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:24:54
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:24:54
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:24:54
Socket (17) | Shutdown and closed. | 2015-01-06 10:25:06
HD Request # 15 | Error downloading historical Intraday data for NISS-NQ. The network socket has been closed. Retrying download. | 2015-01-06 10:25:06 *
HD Request # 15 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-NQ | 2015-01-06 10:25:06
HD Request # 16 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-06 10:25:06
HD Request # 16 | Download start Date-Time: 2015-01-06 10:22:00.0 | 2015-01-06 10:25:06
HD Request # 16 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:25:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:25:06
Socket (19) | Shutdown and closed. | 2015-01-06 10:25:26
HD Request # 16 | Error downloading historical Intraday data for NISS-NQ. The network socket has been closed. Retrying download. | 2015-01-06 10:25:26 *
HD Request # 16 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-NQ | 2015-01-06 10:25:26
HD Request # 17 | Downloading Intraday chart data for NISS-NQ to the file NISS-NQ.scid. Service: statscalc | 2015-01-06 10:25:26
HD Request # 17 | Download start Date-Time: 2015-01-06 10:22:00.0 | 2015-01-06 10:25:26
HD Request # 17 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:25:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:25:26
Socket (20) | Shutdown and closed. | 2015-01-06 10:25:46
HD Request # 17 | Error downloading historical Intraday data for NISS-NQ. The network socket has been closed. Retrying download. | 2015-01-06 10:25:46 *
HD Request # 17 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-NQ | 2015-01-06 10:25:46
HD Request # 17 | Intraday download COMPLETE for NISS-NQ. Completion time: 20s. Unique request ID: 10 | 2015-01-06 10:25:46
Removed historical data download ID 10 | 2015-01-06 10:25:46
HD Request # 18 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2015-01-06 10:25:46
HD Request # 18 | Download start Date-Time: 2015-01-06 10:22:00.0 | 2015-01-06 10:25:46
HD Request # 18 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:25:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:25:46
Chart #2 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:25:47
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:25:47
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:25:59
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:25:59
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:25:59
Rithmic Trading | Logon error from server | 2015-01-06 10:25:59
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:25:59
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:25:59
Socket (18) | Closed. No error. | 2015-01-06 10:25:59
Socket (18) | Shutdown and closed. | 2015-01-06 10:25:59
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:25:59
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:25:59
Rithmic Trading | Port for executable: 60387 | 2015-01-06 10:26:01
Listening socket (2160), port 60387 | Closed. | 2015-01-06 10:26:01
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:26:01
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60387 | 2015-01-06 10:26:03
Socket (22) | Connected. | 2015-01-06 10:26:03
Rithmic Trading | Connected to server. | 2015-01-06 10:26:03
Rithmic Trading | Sending logon request message. | 2015-01-06 10:26:03
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:26:03
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:26:03
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:26:03
Socket (21) | Shutdown and closed. | 2015-01-06 10:26:06
HD Request # 18 | Error downloading historical Intraday data for NISS-TF. The network socket has been closed. Retrying download. | 2015-01-06 10:26:06 *
HD Request # 18 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-TF | 2015-01-06 10:26:06
HD Request # 19 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2015-01-06 10:26:06
HD Request # 19 | Download start Date-Time: 2015-01-06 10:22:00.0 | 2015-01-06 10:26:06
HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:26:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:26:06
Socket (23) | Shutdown and closed. | 2015-01-06 10:26:26
HD Request # 19 | Error downloading historical Intraday data for NISS-TF. The network socket has been closed. Retrying download. | 2015-01-06 10:26:26 *
HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-TF | 2015-01-06 10:26:26
HD Request # 20 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2015-01-06 10:26:26
HD Request # 20 | Download start Date-Time: 2015-01-06 10:22:00.0 | 2015-01-06 10:26:26
HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:26:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:26:26
File >> Disconnect selected. | 2015-01-06 10:26:43
Socket (22) | Shutdown and closed. | 2015-01-06 10:26:43
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:26:43
Socket (10) | Shutdown and closed. | 2015-01-06 10:26:43
SC Market Stats | Disconnected from the server. | 2015-01-06 10:26:43
Socket (24) | Shutdown and closed. | 2015-01-06 10:26:46
HD Request # 20 | Error downloading historical Intraday data for NISS-TF. The network socket has been closed. Retrying download. | 2015-01-06 10:26:46 *
HD Request # 20 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-TF | 2015-01-06 10:26:46
HD Request # 20 | Intraday download COMPLETE for NISS-TF. Completion time: 20s. Unique request ID: 11 | 2015-01-06 10:26:46
Removed historical data download ID 11 | 2015-01-06 10:26:46
HD Request # 21 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: rim | 2015-01-06 10:26:46
HD Request # 21 | Download start Date-Time: 2015-01-06 10:18:53.0 | 2015-01-06 10:26:46
HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:26:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:26:46
Chart #3 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:26:46
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:26:47
Rithmic Trading | Bridge process is still running. | 2015-01-06 10:26:53
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60387 | 2015-01-06 10:26:55
Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2015-01-06 10:26:56
Socket (26) | Shutdown and closed. | 2015-01-06 10:26:56
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:26:56
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:26:56
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:26:56
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:26:56
Rithmic Trading | Port for executable: 60400 | 2015-01-06 10:26:58
Listening socket (2052), port 60400 | Closed. | 2015-01-06 10:26:58
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:26:58
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60400 | 2015-01-06 10:27:00
Socket (27) | Connected. | 2015-01-06 10:27:00
Rithmic Trading | Connected to server. | 2015-01-06 10:27:00
Rithmic Trading | Sending logon request message. | 2015-01-06 10:27:00
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:27:00
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:27:00
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:27:00
Socket (25) | Shutdown and closed. | 2015-01-06 10:27:06
HD Request # 21 | Error downloading historical Intraday data for TF FMH0015!-NYBOT. The network socket has been closed. Retrying download. | 2015-01-06 10:27:06 *
HD Request # 21 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0015!-NYBOT | 2015-01-06 10:27:06
HD Request # 22 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: rim | 2015-01-06 10:27:06
HD Request # 22 | Download start Date-Time: 2015-01-06 10:18:53.0 | 2015-01-06 10:27:06
HD Request # 22 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:27:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:27:06
Socket (28) | Shutdown and closed. | 2015-01-06 10:27:26
HD Request # 22 | Error downloading historical Intraday data for TF FMH0015!-NYBOT. The network socket has been closed. Retrying download. | 2015-01-06 10:27:26 *
HD Request # 22 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0015!-NYBOT | 2015-01-06 10:27:26
HD Request # 23 | Downloading Intraday chart data for TF FMH0015!-NYBOT to the file TF FMH0015!-NYBOT.scid. Service: rim | 2015-01-06 10:27:26
HD Request # 23 | Download start Date-Time: 2015-01-06 10:18:53.0 | 2015-01-06 10:27:26
HD Request # 23 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:27:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:27:26
Socket (29) | Shutdown and closed. | 2015-01-06 10:27:46
HD Request # 23 | Error downloading historical Intraday data for TF FMH0015!-NYBOT. The network socket has been closed. Retrying download. | 2015-01-06 10:27:46 *
HD Request # 23 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TF FMH0015!-NYBOT | 2015-01-06 10:27:46
HD Request # 23 | Intraday download COMPLETE for TF FMH0015!-NYBOT. Completion time: 20s. Unique request ID: 12 | 2015-01-06 10:27:46
Removed historical data download ID 12 | 2015-01-06 10:27:46
HD Request # 24 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-06 10:27:46
HD Request # 24 | Download start Date-Time: 2015-01-06 10:21:56.0 | 2015-01-06 10:27:46
HD Request # 24 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:27:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:27:46
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:28:05
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:28:05
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:28:05
Rithmic Trading | Logon error from server | 2015-01-06 10:28:05
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:28:05
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:28:05
Socket (27) | Closed. No error. | 2015-01-06 10:28:05
Socket (27) | Shutdown and closed. | 2015-01-06 10:28:05
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:28:05
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:28:05
Socket (30) | Shutdown and closed. | 2015-01-06 10:28:06
HD Request # 24 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2015-01-06 10:28:06 *
HD Request # 24 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2015-01-06 10:28:06
HD Request # 25 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-06 10:28:06
HD Request # 25 | Download start Date-Time: 2015-01-06 10:21:56.0 | 2015-01-06 10:28:06
HD Request # 25 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:28:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:28:06
Rithmic Trading | Port for executable: 60416 | 2015-01-06 10:28:07
Listening socket (2088), port 60416 | Closed. | 2015-01-06 10:28:07
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:28:07
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60416 | 2015-01-06 10:28:09
Socket (32) | Connected. | 2015-01-06 10:28:09
Rithmic Trading | Connected to server. | 2015-01-06 10:28:09
Rithmic Trading | Sending logon request message. | 2015-01-06 10:28:10
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:28:10
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:28:10
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:28:10
Socket (31) | Shutdown and closed. | 2015-01-06 10:28:26
HD Request # 25 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2015-01-06 10:28:26 *
HD Request # 25 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2015-01-06 10:28:26
HD Request # 26 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2015-01-06 10:28:26
HD Request # 26 | Download start Date-Time: 2015-01-06 10:21:56.0 | 2015-01-06 10:28:26
HD Request # 26 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:28:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:28:26
Socket (33) | Shutdown and closed. | 2015-01-06 10:28:46
HD Request # 26 | Error downloading historical Intraday data for TICK-NYSE. The network socket has been closed. Retrying download. | 2015-01-06 10:28:46 *
HD Request # 26 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK-NYSE | 2015-01-06 10:28:46
HD Request # 26 | Intraday download COMPLETE for TICK-NYSE. Completion time: 20s. Unique request ID: 13 | 2015-01-06 10:28:46
Removed historical data download ID 13 | 2015-01-06 10:28:46
HD Request # 27 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-06 10:28:46
HD Request # 27 | Download start Date-Time: 2015-01-06 10:21:57.0 | 2015-01-06 10:28:46
HD Request # 27 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:28:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:28:46
Chart #10 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:28:47
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:28:47
Socket (34) | Shutdown and closed. | 2015-01-06 10:29:06
HD Request # 27 | Error downloading historical Intraday data for NISS-SP. The network socket has been closed. Retrying download. | 2015-01-06 10:29:06 *
HD Request # 27 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-SP | 2015-01-06 10:29:06
HD Request # 28 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-06 10:29:06
HD Request # 28 | Download start Date-Time: 2015-01-06 10:21:57.0 | 2015-01-06 10:29:06
HD Request # 28 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:29:06
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:29:06
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:29:15
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:29:15
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:29:15
Rithmic Trading | Logon error from server | 2015-01-06 10:29:15
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:29:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:29:15
Socket (32) | Closed. No error. | 2015-01-06 10:29:15
Socket (32) | Shutdown and closed. | 2015-01-06 10:29:15
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:29:15
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:29:15
Rithmic Trading | Port for executable: 60430 | 2015-01-06 10:29:17
Listening socket (1212), port 60430 | Closed. | 2015-01-06 10:29:17
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:29:17
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60430 | 2015-01-06 10:29:19
Socket (36) | Connected. | 2015-01-06 10:29:19
Rithmic Trading | Connected to server. | 2015-01-06 10:29:19
Rithmic Trading | Sending logon request message. | 2015-01-06 10:29:19
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:29:19
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:29:19
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:29:19
Socket (35) | Shutdown and closed. | 2015-01-06 10:29:26
HD Request # 28 | Error downloading historical Intraday data for NISS-SP. The network socket has been closed. Retrying download. | 2015-01-06 10:29:26 *
HD Request # 28 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-SP | 2015-01-06 10:29:26
HD Request # 29 | Downloading Intraday chart data for NISS-SP to the file NISS-SP.scid. Service: statscalc | 2015-01-06 10:29:26
HD Request # 29 | Download start Date-Time: 2015-01-06 10:21:57.0 | 2015-01-06 10:29:26
HD Request # 29 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:29:26
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:29:26
Socket (37) | Shutdown and closed. | 2015-01-06 10:29:46
HD Request # 29 | Error downloading historical Intraday data for NISS-SP. The network socket has been closed. Retrying download. | 2015-01-06 10:29:46 *
HD Request # 29 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NISS-SP | 2015-01-06 10:29:46
HD Request # 29 | Intraday download COMPLETE for NISS-SP. Completion time: 20s. Unique request ID: 14 | 2015-01-06 10:29:46
Removed historical data download ID 14 | 2015-01-06 10:29:46
HD Request # 30 | Downloading Intraday chart data for NQH5-CME to the file NQH5-CME.scid. Service: rim | 2015-01-06 10:29:46
HD Request # 30 | Download start Date-Time: 2015-01-06 10:18:54.0 | 2015-01-06 10:29:46
HD Request # 30 | Using server: ds4.sierracharts.com port 10149 | 2015-01-06 10:29:46
Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-01-06 10:29:46
Chart #7 has tagged chart #17 for full recalculation. Chartbook: OpenTrader_1.cht | 2015-01-06 10:29:47
Chart #17 is performing a full recalculation because it has been tagged. Chartbook: OpenTrader_1.cht | 2015-01-06 10:29:47
Socket (38) | Shutdown and closed. | 2015-01-06 10:30:06
HD Request # 30 | Error downloading historical Intraday data for NQH5-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:30:06 *
HD Request # 30 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH5-CME | 2015-01-06 10:30:06
HD Request # 31 | Downloading Intraday chart data for NQH5-CME to the file NQH5-CME.scid. Service: rim | 2015-01-06 10:30:06
HD Request # 31 | Download start Date-Time: 2015-01-06 10:18:54.0 | 2015-01-06 10:30:07
HD Request # 31 | Using server: ds5.sierracharts.com port 10149 | 2015-01-06 10:30:07
Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-01-06 10:30:07
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:30:24
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:30:24
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:30:24
Rithmic Trading | Logon error from server | 2015-01-06 10:30:24
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:30:24
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:30:24
Socket (36) | Closed. No error. | 2015-01-06 10:30:24
Socket (36) | Shutdown and closed. | 2015-01-06 10:30:24
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:30:24
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:30:24
Rithmic Trading | Port for executable: 60445 | 2015-01-06 10:30:26
Listening socket (2100), port 60445 | Closed. | 2015-01-06 10:30:26
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:30:26
Socket (39) | Shutdown and closed. | 2015-01-06 10:30:27
HD Request # 31 | Error downloading historical Intraday data for NQH5-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:30:27 *
HD Request # 31 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH5-CME | 2015-01-06 10:30:27
HD Request # 32 | Downloading Intraday chart data for NQH5-CME to the file NQH5-CME.scid. Service: rim | 2015-01-06 10:30:27
HD Request # 32 | Download start Date-Time: 2015-01-06 10:18:54.0 | 2015-01-06 10:30:27
HD Request # 32 | Using server: ds3.sierracharts.com port 10149 | 2015-01-06 10:30:27
Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-01-06 10:30:27
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60445 | 2015-01-06 10:30:28
Socket (41) | Connected. | 2015-01-06 10:30:28
Rithmic Trading | Connected to server. | 2015-01-06 10:30:28
Rithmic Trading | Sending logon request message. | 2015-01-06 10:30:28
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:30:28
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:30:28
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:30:28
Socket (40) | Shutdown and closed. | 2015-01-06 10:30:47
HD Request # 32 | Error downloading historical Intraday data for NQH5-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:30:47 *
HD Request # 32 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQH5-CME | 2015-01-06 10:30:47
HD Request # 32 | Intraday download COMPLETE for NQH5-CME. Completion time: 20s. Unique request ID: 15 | 2015-01-06 10:30:47
Removed historical data download ID 15 | 2015-01-06 10:30:47
HD Request # 33 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: cme | 2015-01-06 10:30:47
HD Request # 33 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-01-06 10:30:47
HD Request # 33 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-06 10:30:47
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-06 10:30:47
Socket (42) | Shutdown and closed. | 2015-01-06 10:31:07
HD Request # 33 | Error downloading historical Intraday data for ESZ4-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:31:07 *
HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4-CME | 2015-01-06 10:31:07
HD Request # 34 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: cme | 2015-01-06 10:31:07
HD Request # 34 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-01-06 10:31:07
HD Request # 34 | Using server: scdf2.sierracharts.com port 10149 | 2015-01-06 10:31:07
Socket (0) | Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2015-01-06 10:31:07
Socket (43) | Shutdown and closed. | 2015-01-06 10:31:27
HD Request # 34 | Error downloading historical Intraday data for ESZ4-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:31:27 *
HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4-CME | 2015-01-06 10:31:27
HD Request # 35 | Downloading Intraday chart data for ESZ4-CME to the file ESZ4-CME.scid. Service: cme | 2015-01-06 10:31:27
HD Request # 35 | Download start Date-Time: 2014-12-19 09:29:59.0 | 2015-01-06 10:31:27
HD Request # 35 | Using server: scdf1.sierracharts.com port 10149 | 2015-01-06 10:31:27
Socket (0) | Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2015-01-06 10:31:27
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:31:33
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:31:33
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:31:33
Rithmic Trading | Logon error from server | 2015-01-06 10:31:33
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:31:33
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:31:33
Socket (41) | Closed. No error. | 2015-01-06 10:31:33
Socket (41) | Shutdown and closed. | 2015-01-06 10:31:33
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:31:33
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:31:33
Rithmic Trading | Port for executable: 60462 | 2015-01-06 10:31:35
Listening socket (1916), port 60462 | Closed. | 2015-01-06 10:31:35
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:31:35
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60462 | 2015-01-06 10:31:37
Socket (45) | Connected. | 2015-01-06 10:31:37
Rithmic Trading | Connected to server. | 2015-01-06 10:31:37
Rithmic Trading | Sending logon request message. | 2015-01-06 10:31:37
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:31:37
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:31:37
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:31:37
Socket (44) | Shutdown and closed. | 2015-01-06 10:31:47
HD Request # 35 | Error downloading historical Intraday data for ESZ4-CME. The network socket has been closed. Retrying download. | 2015-01-06 10:31:47 *
HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4-CME | 2015-01-06 10:31:47
HD Request # 35 | Intraday download COMPLETE for ESZ4-CME. Completion time: 20s. Unique request ID: 16 | 2015-01-06 10:31:47
Removed historical data download ID 16 | 2015-01-06 10:31:47
Rithmic Trading | Error creating the main object. Error message: os error | 2015-01-06 10:32:42
Rithmic Trading | Server Name: DTC Bridge. | 2015-01-06 10:32:42
Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-01-06 10:32:42
Rithmic Trading | Logon error from server | 2015-01-06 10:32:42
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-06 10:32:42
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-06 10:32:42
Socket (45) | Closed. No error. | 2015-01-06 10:32:42
Socket (45) | Shutdown and closed. | 2015-01-06 10:32:42
Rithmic Trading | Disconnected from the server. | 2015-01-06 10:32:42
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-06 10:32:42
Rithmic Trading | Port for executable: 60482 | 2015-01-06 10:32:44
Listening socket (2172), port 60482 | Closed. | 2015-01-06 10:32:44
Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2015-01-06 10:32:44
Rithmic Trading | Connecting to the server 127.0.0.1. Port 60482 | 2015-01-06 10:32:46
Socket (46) | Connected. | 2015-01-06 10:32:46
Rithmic Trading | Connected to server. | 2015-01-06 10:32:46
Rithmic Trading | Sending logon request message. | 2015-01-06 10:32:46
Rithmic Trading | Starting the connection process to data and trading service. | 2015-01-06 10:32:46
Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2015-01-06 10:32:46
Rithmic Trading | Connecting to Rithmic 01 US server. | 2015-01-06 10:32:46
[2015-01-06 16:51:33]
This is the relevant error message:
This could be caused by a firewall/anti-malware/antivirus software program . More information about it can be found at step 17 on this page:
Rithmic Trading Platform Service: Setup Instructions
We recommend disabling those programs to rule them out as a cause.
Date Time Of Last Edit: 2015-01-09 08:43:06
[2015-01-07 15:52:56]
optimus Trading Group - Posts: 10
Sierra Chart Engineering, I believe a more appropriate response would have been as follows:
"We are not equipped to handle Rithmic disconnection issues as we do not have access to the Rithmic back-end to analyze server-side connection logs. Disconnections can happen for a variety of reasons. Please contact your broker for further assistance.
However, one item to consider looking at are any anti-virus or firewall programs. More information can be found here on Step 17:
The use of the word troublesome may imply that Rithmic data is not accurate, is delayed, or other negative connotations that could lead to a false impression of the Rithmic service. These negative connotations could not be further from the truth as Rithmic is known to provide fast, unfiltered tick data and low-latency execution. We have had many users switch from alternative feeds who have been ecstatic with data quality and execution over their prior feeds.
After further diagnostics and analysis, it appears that there were several factors involved with this support case:
- An ‘OS’ Error message that was thrown because of an error in the SierraChart pre-release software which has now been resolved in a SierraChart software update
- An older SierraChart Bridge version that needed to be updated.
- Internet connection issues specific to this customer, their locale, and their specific temporary internet connection.
We are in communication with the customer and will ensure that the issue is correct. We are always willing to do the leg work for our customers to trouble shoot the issue, and will be happy to coordinate with affiliated parties, such as SierraChart or Rithmic, when it is necessary to resolve the issue.
Thank you,
Matt
Optimus Futures
Date Time Of Last Edit: 2015-01-07 15:53:40
[2015-01-07 18:02:14]
Your comments are noted and we have made corrections. We suspect the underlying problem was something with security software on the users system.
This is not correct:
The user was on 1220 and they were getting :
This was unrelated to an earlier issue with a prior prerelease. In an attempt to solve the problem the user updated to the pre-release but that installation did not complete properly because the Rithmic software did not shut down in time. Which then brought out a different problem which would not have occurred to begin with if the update did complete properly.
Date Time Of Last Edit: 2015-01-09 08:43:49
[2015-01-07 18:28:47]
User46092 - Posts: 17
The problem has been solved. Optimus Futures quickly responded to my issue and made sure that the problem was solved asap. I'm very grateful to them.
