Date/Time: Sat, 21 Dec 2024 17:56:51 +0000
Faile To connect and Crash/Lock up on two seperate computers running SC
View Count: 1188
[2014-11-20 13:04:56] |
Handle - Posts: 36 |
Transact Computer #1: Windows 7 SC v1213 Slow to load, then unresponsive to inputs and get the header says SC not responding. Computer #2: Windows 8.1 SC v1202. Same issue as above but then unresponsive and then lock sup computer and can't even bring up task manager. Did a hard shutdown, was able to disable the data feed as per your previous post. No help, get same no response and then locks up computer. |
[2014-11-20 17:52:16] |
We need to understand at what point Sierra Chart is slow. For example, if you open one chart without any studies do you notice a problem? Make sure you do not have any Chartbooks which automatically open. Refer to help topic 30 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-20 17:52:40
[2014-11-20 21:04:01] |
I can make no rhyme or reason why this happens. On the windows 8 machine after having to do a couple of hard boots do to freezing the existing charts books ran fine...but I have not enable the SC data feed again yet either. These machines are on all the time so I am not starting up and loading when the problem occurred. Yes I have chartbooks that auto load. On the windows 7 machine I had to resort to not opening any of my typical chartbooks and just build a few charts so I could get to trading for NY open. At the end of the day I will go back and try and open my typical chartbooks and see what happens. I still get a log message (c locale has changed) whenever I chose file>new intraday chart. Why 2 separate machines running different versions of SC would both have trouble like this at the same time is disconcerting Help 30 has loads of "possibles" but I ma running lots of RAM and SSD's with adeqeuate CPU. Day before charts are fine. Absent the ISP "event" you mentioned in another post who knows. I will monitor and report back. |
[2014-11-20 21:24:40] |
This is interesting: I still get a log message (c locale has changed) whenever I chose file>new intraday chart. This would indicate some sort of operating system issue . When we started hearing about this kind of problem in regards to the locale setting we have suspected it is operating system related. This has nothing to do with the high CPU usage though. In order for us to help us understand this better, copy those few lines around this message and paste them here. Use the Copy Selection button on the Message Log. What do you have the Global Settings >> General Settings >> Chart Update Interval set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-20 21:25:56
[2014-11-21 12:19:04] |
Here is the Message Log that popped up right after I selected file>new intraday chart on my windows 7 machine. What type of "operating system issue" should I be looking for? Both my computers setting is 500 millseconds for chart update interval In Data Trade Service Setting I still have disabled "allow support for SC data feeds". Should this now be enabled? Software version: 1213 | 2014-11-20 08:53:10 Uses New Spreadsheets | 2014-11-20 08:53:10 Usage end date: 2014-12-19 | 2014-11-20 08:53:10 Enabled for: Advanced Features. | 2014-11-20 08:53:10 Enabled for: Advanced Features 2. | 2014-11-20 08:53:10 Enabled for: Sierra Chart Historical Data Service. | 2014-11-20 08:53:10 Allow Support for Sierra Chart Data Feeds is disabled. | 2014-11-20 08:53:10 Active service: TransAct Trading | 2014-11-20 08:53:10 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2014-11-20 08:53:10 2014-11-20 08:53:10 Local computer clock time | 2014-11-20 08:53:10 2014-11-20 13:53:10 GMT time | 2014-11-20 08:53:10 2014-11-20 08:53:10 Time zone adjusted time | 2014-11-20 08:53:10 Time difference to server time: 5 seconds. | 2014-11-20 08:53:10 Program path: C:\SierraChart2\ | 2014-11-20 08:53:10 Data Files path: C:\SierraChart2\Data\ | 2014-11-20 08:53:10 OS Version Number: 6.1 | 2014-11-20 08:53:10 Locale Information: C | 2014-11-20 08:53:10 Checking for new symbol settings for ta | 2014-11-20 08:53:10 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 88.198.13.175 | 2014-11-20 08:53:10 HTTP connection to www.sierrachart.com:80 (2088) | Connected. | 2014-11-20 08:53:10 Symbol settings are up-to-date for ta | 2014-11-20 08:53:10 Files to Open on Start up | Opening file: Chartbook17.cht | 2014-11-20 08:53:13 Intraday data recording state for symbol TFZ4 is set to download pending. | 2014-11-20 08:53:13 HD Request # 2 | Downloading Intraday chart data for TFZ4 to the file TFZ4.scid. Service: ta | 2014-11-20 08:53:13 HD Request # 2 | Download start Date-Time: 2014-11-20 08:13:31.0 | 2014-11-20 08:53:13 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 08:53:13 HD Request # 2 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 08:53:13 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 08:53:13 Socket (2700) | Connected. | 2014-11-20 08:53:13 HD Request # 2 | Sending historical data logon request message. | 2014-11-20 08:53:13 HD Request # 2 | Requesting Intraday data. Start Date-Time: 2014-11-20 08:13:31. Record interval: 0. Symbol: TFZ4 | 2014-11-20 08:53:14 Socket (2700) | Shutdown and closed. | 2014-11-20 08:53:14 The network socket for historical data has been closed. | 2014-11-20 08:53:14 HD Request # 2 | Historical data for TFZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-20 08:53:22 HD Request # 2 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TFZ4 | 2014-11-20 08:53:22 HD Request # 2 | Intraday download COMPLETE for TFZ4. Completion time: 17s. Unique request ID: 1 | 2014-11-20 08:53:30 Removed historical data download ID 1 | 2014-11-20 08:53:30 HTTP connection to www.sierrachart.com:80 (2088) | Closed. No error. | 2014-11-20 08:53:30 HTTP connection to www.sierrachart.com:80 (2088) | Shutdown and closed. | 2014-11-20 08:53:30 HD Request # 3 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 08:53:30 HD Request # 3 | Download start Date-Time: 2014-11-20 08:13:44.0 | 2014-11-20 08:53:30 HD Request # 3 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 08:53:30 Intraday data recording state for symbol ESZ4 is set to download pending. | 2014-11-20 08:53:30 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 08:53:30 Socket (2628) | Connected. | 2014-11-20 08:53:30 HD Request # 3 | Sending historical data logon request message. | 2014-11-20 08:53:30 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2014-11-20 08:13:44. Record interval: 0. Symbol: NISS-TF | 2014-11-20 08:53:30 HD Request # 3 | Decompressing data. | 2014-11-20 08:53:31 HD Request # 3 | Receiving Intraday data for NISS-TF starting at 2014-11-20 08:13:44 | 2014-11-20 08:53:31 HD Request # 3 | Timestamp of first Intraday data file record written: 2014-11-20 08:13:46 | 2014-11-20 08:53:31 Socket (2628) | Shutdown and closed. | 2014-11-20 08:53:31 The network socket for historical data has been closed. | 2014-11-20 08:53:31 HD Request # 3 | Historical data for NISS-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-20 08:53:38 HD Request # 3 | Received 2294 records from 2014-11-20 08:13:44 to 2014-11-20 08:53:35 (39.9 minutes) and wrote 2293 records for NISS-TF | 2014-11-20 08:53:38 HD Request # 3 | Intraday download COMPLETE for NISS-TF. Completion time: 8s. Unique request ID: 2 | 2014-11-20 08:53:38 Removed historical data download ID 2 | 2014-11-20 08:53:38 HD Request # 4 | Downloading Intraday chart data for ESZ4 to the file ESZ4.scid. Service: ta | 2014-11-20 08:53:38 HD Request # 4 | Download start Date-Time: 2014-11-20 08:13:39.0 | 2014-11-20 08:53:38 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2014-11-20 08:53:38 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 08:53:38 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 08:53:38 Socket (2664) | Connected. | 2014-11-20 08:53:38 HD Request # 4 | Sending historical data logon request message. | 2014-11-20 08:53:38 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2014-11-20 08:13:39. Record interval: 0. Symbol: ESZ4 | 2014-11-20 08:53:38 Socket (2664) | Shutdown and closed. | 2014-11-20 08:53:39 The network socket for historical data has been closed. | 2014-11-20 08:53:39 HD Request # 4 | Historical data for ESZ4 is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2014-11-20 08:53:46 HD Request # 4 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ4 | 2014-11-20 08:53:46 HD Request # 4 | Intraday download COMPLETE for ESZ4. Completion time: 8s. Unique request ID: 3 | 2014-11-20 08:53:46 Removed historical data download ID 3 | 2014-11-20 08:53:46 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 08:53:46 Socket (2748) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 08:53:47 Socket (2748) | Shutdown and closed. | 2014-11-20 08:53:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 08:53:47 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 08:53:47 TransAct Trading | Disconnected from the server. | 2014-11-20 08:53:47 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 08:53:47 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 08:53:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 08:53:51 Socket (2712) | Connected. | 2014-11-20 08:53:51 TransAct Trading | Connected to server. | 2014-11-20 08:53:51 TransAct Trading | Sending logon request message. | 2014-11-20 08:53:51 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-11-20 08:53:53 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 08:53:53 TransAct Trading | Successfully connected. Operation Successful. | 2014-11-20 08:53:53 TransAct Trading | Starting real-time market data updates for: ESZ4. ID: 1 | 2014-11-20 08:53:54 Intraday data recording state for symbol ESZ4 is set to download pending. | 2014-11-20 08:53:54 HD Request # 5 | Downloading Intraday chart data for ESZ4 to the file ESZ4.scid. Service: ta | 2014-11-20 08:53:54 HD Request # 5 | Download start Date-Time: 2014-11-20 08:13:39.0 | 2014-11-20 08:53:54 HD Request # 5 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 08:53:54 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 08:53:54 TransAct Trading | Starting real-time market data updates for: TFZ4. ID: 2 | 2014-11-20 08:53:54 Socket (2704) | Connected. | 2014-11-20 08:53:54 HD Request # 5 | Sending historical data logon request message. | 2014-11-20 08:53:54 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2014-11-20 08:13:39. Record interval: 0. Symbol: ESZ4 | 2014-11-20 08:53:54 HD Request # 5 | Decompressing data. | 2014-11-20 08:53:54 HD Request # 5 | Receiving Intraday data for ESZ4 starting at 2014-11-20 08:13:41 | 2014-11-20 08:53:54 HD Request # 5 | Timestamp of first Intraday data file record written: 2014-11-20 08:13:41 | 2014-11-20 08:53:54 Socket (2704) | Shutdown and closed. | 2014-11-20 08:53:54 The network socket for historical data has been closed. | 2014-11-20 08:53:54 Intraday data recording state for symbol TFZ4 is set to download pending. | 2014-11-20 08:54:01 HD Request # 5 | Received 10262 records from 2014-11-20 08:13:41 to 2014-11-20 08:53:52 (40.2 minutes) and wrote 10262 records for ESZ4 | 2014-11-20 08:54:01 Added 5 Time and Sales records to Intraday data file for ESZ4 after download. | 2014-11-20 08:54:01 HD Request # 5 | Intraday download COMPLETE for ESZ4. Completion time: 7s. Unique request ID: 4 | 2014-11-20 08:54:01 Removed historical data download ID 4 | 2014-11-20 08:54:01 Real-time Intraday chart data file updates started for ESZ4 | 2014-11-20 08:54:01 HD Request # 6 | Downloading Intraday chart data for TFZ4 to the file TFZ4.scid. Service: ta | 2014-11-20 08:54:09 HD Request # 6 | Download start Date-Time: 2014-11-20 08:13:31.0 | 2014-11-20 08:54:09 HD Request # 6 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 08:54:09 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 08:54:09 Socket (2768) | Connected. | 2014-11-20 08:54:09 HD Request # 6 | Sending historical data logon request message. | 2014-11-20 08:54:09 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2014-11-20 08:13:31. Record interval: 0. Symbol: TFZ4 | 2014-11-20 08:54:09 HD Request # 6 | Decompressing data. | 2014-11-20 08:54:09 HD Request # 6 | Receiving Intraday data for TFZ4 starting at 2014-11-20 08:13:57 | 2014-11-20 08:54:09 HD Request # 6 | Timestamp of first Intraday data file record written: 2014-11-20 08:13:57 | 2014-11-20 08:54:09 Socket (2768) | Shutdown and closed. | 2014-11-20 08:54:09 The network socket for historical data has been closed. | 2014-11-20 08:54:09 HD Request # 6 | Received 2280 records from 2014-11-20 08:13:57 to 2014-11-20 08:54:10 (40.2 minutes) and wrote 2280 records for TFZ4 | 2014-11-20 08:54:17 HD Request # 6 | Intraday download COMPLETE for TFZ4. Completion time: 15s. Unique request ID: 5 | 2014-11-20 08:54:24 Removed historical data download ID 5 | 2014-11-20 08:54:24 Real-time Intraday chart data file updates started for TFZ4 | 2014-11-20 08:54:24 SC Market Stats | Starting real-time market data updates for: NISS-TF. ID: 3 | 2014-11-20 08:54:24 SC Market Stats | Connecting to the server ds4.sierracharts.com. Port 443 | 2014-11-20 08:54:24 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 08:54:24 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 08:54:24 HD Request # 7 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 08:54:24 HD Request # 7 | Download start Date-Time: 2014-11-20 08:53:35.0 | 2014-11-20 08:54:24 HD Request # 7 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 08:54:24 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 08:54:24 Socket (2772) | Connected. | 2014-11-20 08:54:24 HD Request # 7 | Sending historical data logon request message. | 2014-11-20 08:54:24 Socket (1068) | Connected. | 2014-11-20 08:54:24 SC Market Stats | Connected to server. | 2014-11-20 08:54:24 SC Market Stats | Sending logon request message. | 2014-11-20 08:54:24 HD Request # 7 | Requesting Intraday data. Start Date-Time: 2014-11-20 08:53:35. Record interval: 0. Symbol: NISS-TF | 2014-11-20 08:54:24 HD Request # 7 | Decompressing data. | 2014-11-20 08:54:24 HD Request # 7 | Receiving Intraday data for NISS-TF starting at 2014-11-20 08:53:35 | 2014-11-20 08:54:24 HD Request # 7 | Timestamp of first Intraday data file record written: 2014-11-20 08:53:36 | 2014-11-20 08:54:24 Socket (2772) | Shutdown and closed. | 2014-11-20 08:54:24 The network socket for historical data has been closed. | 2014-11-20 08:54:24 SC Market Stats | Server Name: . | 2014-11-20 08:54:32 SC Market Stats | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 08:54:32 SC Market Stats | Successfully connected. | 2014-11-20 08:54:32 SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2014-11-20 08:54:32 HD Request # 7 | Received 53 records from 2014-11-20 08:53:35 to 2014-11-20 08:54:28 (53.0 seconds) and wrote 52 records for NISS-TF | 2014-11-20 08:54:32 HD Request # 7 | Intraday download COMPLETE for NISS-TF. Completion time: 8s. Unique request ID: 6 | 2014-11-20 08:54:32 Removed historical data download ID 6 | 2014-11-20 08:54:32 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 08:54:32 The C locale was changed. Resetting the locale back to the default setting. | 2014-11-20 08:56:00 The C locale was changed. Resetting the locale back to the default setting. | 2014-11-20 08:57:33 A change to the locale was detected after a call to the ACS function SierraChartStudies.scsf_ZigZagStudy. The ACS function may have changed the locale, or the locale may have been changed before the function was called. | 2014-11-20 08:57:33 * Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2\Data\TISS-TF.scid | 2014-11-20 09:00:45 SC Market Stats | Starting real-time market data updates for: TISS-TF. ID: 4 | 2014-11-20 09:00:46 Intraday data recording state for symbol TISS-TF is set to download pending. | 2014-11-20 09:00:46 HD Request # 8 | Downloading Intraday chart data for TISS-TF to the file TISS-TF.scid. Service: statscalc | 2014-11-20 09:00:46 Compressing file: C:\SierraChart2\Data\TISS-TF.scid. This may take a while. | 2014-11-20 09:00:46 HD Request # 8 | Download start Date-Time: 2014-05-18 10:00:46.0 | 2014-11-20 09:00:46 HD Request # 8 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 09:00:46 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 09:00:46 Socket (7884) | Connected. | 2014-11-20 09:00:46 HD Request # 8 | Sending historical data logon request message. | 2014-11-20 09:00:46 HD Request # 8 | Requesting Intraday data. Start Date-Time: 2014-05-18 10:00:46. Record interval: 0. Symbol: TISS-TF | 2014-11-20 09:00:46 HD Request # 8 | Decompressing data. | 2014-11-20 09:00:46 HD Request # 8 | Receiving Intraday data for TISS-TF starting at 2014-05-19 04:00:00 | 2014-11-20 09:00:46 HD Request # 8 | Timestamp of first Intraday data file record written: 2014-05-19 04:00:00 | 2014-11-20 09:00:46 Socket (7884) | Shutdown and closed. | 2014-11-20 09:00:55 The network socket for historical data has been closed. | 2014-11-20 09:00:55 HD Request # 8 | Received 4763218 records from 2014-05-19 04:00:00 to 2014-11-20 09:01:00 (185.3 days) and wrote 4763218 records for TISS-TF | 2014-11-20 09:00:55 HD Request # 8 | Intraday download COMPLETE for TISS-TF. Completion time: 10s. Unique request ID: 7 | 2014-11-20 09:00:56 Removed historical data download ID 7 | 2014-11-20 09:00:56 Real-time Intraday chart data file updates started for TISS-TF | 2014-11-20 09:00:56 Real-time data for symbol NISS-TF is currently unavailable. | 2014-11-20 09:03:16 Real-time data for symbol TISS-TF is currently unavailable. | 2014-11-20 09:03:16 The C locale was changed. Resetting the locale back to the default setting. | 2014-11-20 09:03:30 Real-time data for symbol NISS-TF has been restored. | 2014-11-20 09:03:35 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 09:03:35 HD Request # 9 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 09:03:35 HD Request # 9 | Download start Date-Time: 2014-11-20 09:02:32.0 | 2014-11-20 09:03:35 HD Request # 9 | Using server: ds4.sierracharts.com port 10149 | 2014-11-20 09:03:35 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 09:03:35 Socket (10628) | Connected. | 2014-11-20 09:03:35 HD Request # 9 | Sending historical data logon request message. | 2014-11-20 09:03:35 HD Request # 9 | Requesting Intraday data. Start Date-Time: 2014-11-20 09:02:32. Record interval: 0. Symbol: NISS-TF | 2014-11-20 09:03:35 HD Request # 9 | Decompressing data. | 2014-11-20 09:03:35 HD Request # 9 | Receiving Intraday data for NISS-TF starting at 2014-11-20 09:02:32 | 2014-11-20 09:03:35 HD Request # 9 | Timestamp of first Intraday data file record written: 2014-11-20 09:02:33 | 2014-11-20 09:03:35 Socket (10628) | Shutdown and closed. | 2014-11-20 09:03:35 The network socket for historical data has been closed. | 2014-11-20 09:03:35 HD Request # 9 | Received 67 records from 2014-11-20 09:02:32 to 2014-11-20 09:03:40 (68.0 seconds) and wrote 66 records for NISS-TF | 2014-11-20 09:03:35 HD Request # 9 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 8 | 2014-11-20 09:03:35 Removed historical data download ID 8 | 2014-11-20 09:03:35 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 09:03:35 Real-time data for symbol TISS-TF has been restored. | 2014-11-20 09:03:38 Intraday data recording state for symbol TISS-TF is set to download pending. | 2014-11-20 09:03:38 HD Request # 10 | Downloading Intraday chart data for TISS-TF to the file TISS-TF.scid. Service: statscalc | 2014-11-20 09:03:38 HD Request # 10 | Download start Date-Time: 2014-11-20 09:02:32.0 | 2014-11-20 09:03:38 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 09:03:38 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 09:03:38 Socket (7892) | Connected. | 2014-11-20 09:03:38 HD Request # 10 | Sending historical data logon request message. | 2014-11-20 09:03:38 HD Request # 10 | Requesting Intraday data. Start Date-Time: 2014-11-20 09:02:32. Record interval: 0. Symbol: TISS-TF | 2014-11-20 09:03:38 HD Request # 10 | Decompressing data. | 2014-11-20 09:03:39 HD Request # 10 | Receiving Intraday data for TISS-TF starting at 2014-11-20 09:02:32 | 2014-11-20 09:03:39 HD Request # 10 | Timestamp of first Intraday data file record written: 2014-11-20 09:02:33 | 2014-11-20 09:03:39 Socket (7892) | Shutdown and closed. | 2014-11-20 09:03:39 The network socket for historical data has been closed. | 2014-11-20 09:03:39 HD Request # 10 | Received 70 records from 2014-11-20 09:02:32 to 2014-11-20 09:03:43 (71.0 seconds) and wrote 69 records for TISS-TF | 2014-11-20 09:03:39 Added 1 Time and Sales records to Intraday data file for TISS-TF after download. | 2014-11-20 09:03:39 HD Request # 10 | Intraday download COMPLETE for TISS-TF. Completion time: 0s. Unique request ID: 9 | 2014-11-20 09:03:39 Removed historical data download ID 9 | 2014-11-20 09:03:39 Real-time Intraday chart data file updates started for TISS-TF | 2014-11-20 09:03:39 The C locale was changed. Resetting the locale back to the default setting. | 2014-11-20 09:07:14 A change to the locale was detected after a call to the ACS function SierraChartStudies.scsf_DailyOHLC. The ACS function may have changed the locale, or the locale may have been changed before the function was called. | 2014-11-20 09:07:14 * Real-time data for symbol NISS-TF is currently unavailable. | 2014-11-20 14:00:51 Real-time data for symbol TISS-TF is currently unavailable. | 2014-11-20 14:00:51 Real-time data for symbol NISS-TF has been restored. | 2014-11-20 14:01:28 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 14:01:28 HD Request # 11 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 14:01:28 HD Request # 11 | Download start Date-Time: 2014-11-20 14:00:37.0 | 2014-11-20 14:01:28 HD Request # 11 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 14:01:28 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 14:01:28 Socket (36452) | Connected. | 2014-11-20 14:01:28 HD Request # 11 | Sending historical data logon request message. | 2014-11-20 14:01:28 HD Request # 11 | Requesting Intraday data. Start Date-Time: 2014-11-20 14:00:37. Record interval: 0. Symbol: NISS-TF | 2014-11-20 14:01:28 HD Request # 11 | Decompressing data. | 2014-11-20 14:01:29 HD Request # 11 | Receiving Intraday data for NISS-TF starting at 2014-11-20 14:00:37 | 2014-11-20 14:01:29 HD Request # 11 | Timestamp of first Intraday data file record written: 2014-11-20 14:00:38 | 2014-11-20 14:01:29 Socket (36452) | Shutdown and closed. | 2014-11-20 14:01:29 The network socket for historical data has been closed. | 2014-11-20 14:01:29 HD Request # 11 | Received 57 records from 2014-11-20 14:00:37 to 2014-11-20 14:01:33 (56.0 seconds) and wrote 56 records for NISS-TF | 2014-11-20 14:01:29 HD Request # 11 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 10 | 2014-11-20 14:01:29 Removed historical data download ID 10 | 2014-11-20 14:01:29 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 14:01:29 Real-time data for symbol TISS-TF has been restored. | 2014-11-20 14:01:35 Intraday data recording state for symbol TISS-TF is set to download pending. | 2014-11-20 14:01:35 HD Request # 12 | Downloading Intraday chart data for TISS-TF to the file TISS-TF.scid. Service: statscalc | 2014-11-20 14:01:35 HD Request # 12 | Download start Date-Time: 2014-11-20 14:00:37.0 | 2014-11-20 14:01:35 HD Request # 12 | Using server: ds4.sierracharts.com port 10149 | 2014-11-20 14:01:35 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 14:01:35 Socket (36476) | Connected. | 2014-11-20 14:01:35 HD Request # 12 | Sending historical data logon request message. | 2014-11-20 14:01:35 HD Request # 12 | Requesting Intraday data. Start Date-Time: 2014-11-20 14:00:37. Record interval: 0. Symbol: TISS-TF | 2014-11-20 14:01:35 HD Request # 12 | Decompressing data. | 2014-11-20 14:01:35 HD Request # 12 | Receiving Intraday data for TISS-TF starting at 2014-11-20 14:00:37 | 2014-11-20 14:01:35 HD Request # 12 | Timestamp of first Intraday data file record written: 2014-11-20 14:00:38 | 2014-11-20 14:01:35 Socket (36476) | Shutdown and closed. | 2014-11-20 14:01:35 The network socket for historical data has been closed. | 2014-11-20 14:01:35 HD Request # 12 | Received 64 records from 2014-11-20 14:00:37 to 2014-11-20 14:01:40 (63.0 seconds) and wrote 63 records for TISS-TF | 2014-11-20 14:01:35 Added 1 Time and Sales records to Intraday data file for TISS-TF after download. | 2014-11-20 14:01:35 HD Request # 12 | Intraday download COMPLETE for TISS-TF. Completion time: 0s. Unique request ID: 11 | 2014-11-20 14:01:35 Removed historical data download ID 11 | 2014-11-20 14:01:35 Real-time Intraday chart data file updates started for TISS-TF | 2014-11-20 14:01:35 Real-time data for symbol NISS-TF is currently unavailable. | 2014-11-20 14:02:14 Real-time data for symbol TISS-TF is currently unavailable. | 2014-11-20 14:02:14 Real-time data for symbol NISS-TF has been restored. | 2014-11-20 14:02:22 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 14:02:22 HD Request # 13 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 14:02:22 HD Request # 13 | Download start Date-Time: 2014-11-20 14:02:12.0 | 2014-11-20 14:02:22 HD Request # 13 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 14:02:22 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 14:02:23 Socket (36476) | Connected. | 2014-11-20 14:02:23 HD Request # 13 | Sending historical data logon request message. | 2014-11-20 14:02:23 HD Request # 13 | Requesting Intraday data. Start Date-Time: 2014-11-20 14:02:12. Record interval: 0. Symbol: NISS-TF | 2014-11-20 14:02:23 HD Request # 13 | Decompressing data. | 2014-11-20 14:02:24 HD Request # 13 | Receiving Intraday data for NISS-TF starting at 2014-11-20 14:02:12 | 2014-11-20 14:02:24 HD Request # 13 | Timestamp of first Intraday data file record written: 2014-11-20 14:02:13 | 2014-11-20 14:02:24 Socket (36476) | Shutdown and closed. | 2014-11-20 14:02:24 The network socket for historical data has been closed. | 2014-11-20 14:02:24 HD Request # 13 | Received 17 records from 2014-11-20 14:02:12 to 2014-11-20 14:02:28 (16.0 seconds) and wrote 16 records for NISS-TF | 2014-11-20 14:02:24 Added 1 Time and Sales records to Intraday data file for NISS-TF after download. | 2014-11-20 14:02:24 HD Request # 13 | Intraday download COMPLETE for NISS-TF. Completion time: 2s. Unique request ID: 12 | 2014-11-20 14:02:24 Removed historical data download ID 12 | 2014-11-20 14:02:24 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 14:02:24 Real-time data for symbol TISS-TF has been restored. | 2014-11-20 14:02:26 Intraday data recording state for symbol TISS-TF is set to download pending. | 2014-11-20 14:02:26 HD Request # 14 | Downloading Intraday chart data for TISS-TF to the file TISS-TF.scid. Service: statscalc | 2014-11-20 14:02:26 HD Request # 14 | Download start Date-Time: 2014-11-20 14:02:12.0 | 2014-11-20 14:02:26 HD Request # 14 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 14:02:26 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 14:02:26 Socket (36412) | Connected. | 2014-11-20 14:02:26 HD Request # 14 | Sending historical data logon request message. | 2014-11-20 14:02:26 HD Request # 14 | Requesting Intraday data. Start Date-Time: 2014-11-20 14:02:12. Record interval: 0. Symbol: TISS-TF | 2014-11-20 14:02:26 HD Request # 14 | Decompressing data. | 2014-11-20 14:02:26 HD Request # 14 | Receiving Intraday data for TISS-TF starting at 2014-11-20 14:02:12 | 2014-11-20 14:02:26 HD Request # 14 | Timestamp of first Intraday data file record written: 2014-11-20 14:02:13 | 2014-11-20 14:02:26 Socket (36412) | Shutdown and closed. | 2014-11-20 14:02:26 The network socket for historical data has been closed. | 2014-11-20 14:02:26 HD Request # 14 | Received 20 records from 2014-11-20 14:02:12 to 2014-11-20 14:02:31 (19.0 seconds) and wrote 19 records for TISS-TF | 2014-11-20 14:02:26 HD Request # 14 | Intraday download COMPLETE for TISS-TF. Completion time: 0s. Unique request ID: 13 | 2014-11-20 14:02:26 Removed historical data download ID 13 | 2014-11-20 14:02:26 Real-time Intraday chart data file updates started for TISS-TF | 2014-11-20 14:02:26 Real-time data for symbol NISS-TF is currently unavailable. | 2014-11-20 14:36:58 Real-time data for symbol TISS-TF is currently unavailable. | 2014-11-20 14:36:58 Real-time data for symbol NISS-TF has been restored. | 2014-11-20 14:37:14 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 14:37:14 HD Request # 15 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 14:37:14 HD Request # 15 | Download start Date-Time: 2014-11-20 14:35:05.0 | 2014-11-20 14:37:14 HD Request # 15 | Using server: ds4.sierracharts.com port 10149 | 2014-11-20 14:37:14 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 14:37:14 Socket (36340) | Connected. | 2014-11-20 14:37:14 HD Request # 15 | Sending historical data logon request message. | 2014-11-20 14:37:14 HD Request # 15 | Requesting Intraday data. Start Date-Time: 2014-11-20 14:35:05. Record interval: 0. Symbol: NISS-TF | 2014-11-20 14:37:14 HD Request # 15 | Decompressing data. | 2014-11-20 14:37:14 HD Request # 15 | Receiving Intraday data for NISS-TF starting at 2014-11-20 14:35:05 | 2014-11-20 14:37:14 HD Request # 15 | Timestamp of first Intraday data file record written: 2014-11-20 14:35:06 | 2014-11-20 14:37:14 Socket (36340) | Shutdown and closed. | 2014-11-20 14:37:14 The network socket for historical data has been closed. | 2014-11-20 14:37:14 HD Request # 15 | Received 135 records from 2014-11-20 14:35:05 to 2014-11-20 14:37:19 (2.2 minutes) and wrote 134 records for NISS-TF | 2014-11-20 14:37:14 HD Request # 15 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 14 | 2014-11-20 14:37:14 Removed historical data download ID 14 | 2014-11-20 14:37:14 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 14:37:14 Real-time data for symbol TISS-TF has been restored. | 2014-11-20 14:37:17 Intraday data recording state for symbol TISS-TF is set to download pending. | 2014-11-20 14:37:17 HD Request # 16 | Downloading Intraday chart data for TISS-TF to the file TISS-TF.scid. Service: statscalc | 2014-11-20 14:37:17 HD Request # 16 | Download start Date-Time: 2014-11-20 14:35:05.0 | 2014-11-20 14:37:17 HD Request # 16 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 14:37:17 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 14:37:17 Socket (36472) | Connected. | 2014-11-20 14:37:17 HD Request # 16 | Sending historical data logon request message. | 2014-11-20 14:37:17 HD Request # 16 | Requesting Intraday data. Start Date-Time: 2014-11-20 14:35:05. Record interval: 0. Symbol: TISS-TF | 2014-11-20 14:37:17 HD Request # 16 | Decompressing data. | 2014-11-20 14:37:19 HD Request # 16 | Receiving Intraday data for TISS-TF starting at 2014-11-20 14:35:05 | 2014-11-20 14:37:19 HD Request # 16 | Timestamp of first Intraday data file record written: 2014-11-20 14:35:06 | 2014-11-20 14:37:19 Socket (36472) | Shutdown and closed. | 2014-11-20 14:37:19 The network socket for historical data has been closed. | 2014-11-20 14:37:19 HD Request # 16 | Received 140 records from 2014-11-20 14:35:05 to 2014-11-20 14:37:24 (2.3 minutes) and wrote 139 records for TISS-TF | 2014-11-20 14:37:19 HD Request # 16 | Intraday download COMPLETE for TISS-TF. Completion time: 2s. Unique request ID: 15 | 2014-11-20 14:37:19 Removed historical data download ID 15 | 2014-11-20 14:37:19 Real-time Intraday chart data file updates started for TISS-TF | 2014-11-20 14:37:19 Date rule based rollover from TFZ3 to next contract occurs at 2013-12-12. | 2014-11-20 16:05:03 Date rule based rollover from TFH4 to next contract occurs at 2014-03-13. | 2014-11-20 16:05:03 Date rule based rollover from TFM4 to next contract occurs at 2014-06-12. | 2014-11-20 16:05:03 Date rule based rollover from TFU4 to next contract occurs at 2014-09-11. | 2014-11-20 16:05:03 Date rule based rollover from TFZ4 to next contract occurs at 2014-12-11. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFZ3 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-20 16:05:03 Checking Daily data file for symbol RJZ13 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFH4 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-20 16:05:03 Checking Daily data file for symbol RJH14 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFM4 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-20 16:05:03 Checking Daily data file for symbol RJM14 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFU4 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-20 16:05:03 Checking Daily data file for symbol RJU14 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFZ4 for the date range from 2014-09-11 to 0. | 2014-11-20 16:05:03 Checking Daily data file for symbol RJZ14 for the date range from 2014-09-11 to 2014-11-20. | 2014-11-20 16:05:03 Performing historical Daily data download for symbol RJZ14 starting at 0. | 2014-11-20 16:05:03 TFZ4 [CB] 240 Min #4 | Symbols used for continuous contract chart: | 2014-11-20 16:05:03 TFZ3 | 2014-11-20 16:05:03 TFH4 | 2014-11-20 16:05:03 TFM4 | 2014-11-20 16:05:03 TFU4 | 2014-11-20 16:05:03 TFZ4 | 2014-11-20 16:05:03 TFZ4 [CB] 240 Min #4 | Waiting for historical downloads to complete with the IDs: 16, | 2014-11-20 16:05:03 Date rule based rollover from TFZ2 to next contract occurs at 2012-12-13. | 2014-11-20 16:05:03 Date rule based rollover from TFH3 to next contract occurs at 2013-03-07. | 2014-11-20 16:05:03 Date rule based rollover from TFM3 to next contract occurs at 2013-06-13. | 2014-11-20 16:05:03 Date rule based rollover from TFU3 to next contract occurs at 2013-09-12. | 2014-11-20 16:05:03 Date rule based rollover from TFZ3 to next contract occurs at 2013-12-12. | 2014-11-20 16:05:03 Date rule based rollover from TFH4 to next contract occurs at 2014-03-13. | 2014-11-20 16:05:03 Date rule based rollover from TFM4 to next contract occurs at 2014-06-12. | 2014-11-20 16:05:03 Date rule based rollover from TFU4 to next contract occurs at 2014-09-11. | 2014-11-20 16:05:03 Date rule based rollover from TFZ4 to next contract occurs at 2014-12-11. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFZ2 for the date range from 2012-09-13 to 2012-12-13. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFH3 for the date range from 2012-12-13 to 2013-03-07. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFM3 for the date range from 2013-03-07 to 2013-06-13. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFU3 for the date range from 2013-06-13 to 2013-09-12. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFZ3 for the date range from 2013-09-12 to 2013-12-12. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFH4 for the date range from 2013-12-12 to 2014-03-13. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFM4 for the date range from 2014-03-13 to 2014-06-12. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFU4 for the date range from 2014-06-12 to 2014-09-11. | 2014-11-20 16:05:03 Checking Intraday data file for symbol TFZ4 for the date range from 2014-09-11 to 0. | 2014-11-20 16:05:03 TFZ4 [C] 405 Min #9 | Symbols used for continuous contract chart: | 2014-11-20 16:05:03 TFZ2 | 2014-11-20 16:05:03 TFH3 | 2014-11-20 16:05:03 TFM3 | 2014-11-20 16:05:03 TFU3 | 2014-11-20 16:05:03 TFZ3 | 2014-11-20 16:05:03 TFH4 | 2014-11-20 16:05:03 TFM4 | 2014-11-20 16:05:03 TFU4 | 2014-11-20 16:05:03 TFZ4 | 2014-11-20 16:05:03 HD Request # 17 | Downloading Historical Daily chart data for RJZ14. Starting date: 2014-10-30. Service: ta | 2014-11-20 16:05:11 Historical data download counter reset. | 2014-11-20 16:05:11 HD Request # 17 | Requesting historical Daily data for RJZ14 starting at 2014-10-29 | 2014-11-20 16:05:11 HD Request # 17 | Receiving historical Daily data for RJZ14 starting at 2014-10-29 | 2014-11-20 16:05:14 Writing historical Daily data for RJZ14 to the file RJZ14.dly | 2014-11-20 16:05:14 HD Request # 17 | Received 17 records from 2014-10-29 00:00:00 to 2014-11-20 00:00:00 (23.0 days) and wrote 16 records for RJZ14 | 2014-11-20 16:05:14 HD Request # 17 | Daily download COMPLETE for RJZ14. Completion time: 3s. Unique request ID: 16 | 2014-11-20 16:05:14 Removed historical data download ID 16 | 2014-11-20 16:05:14 HD Request # 18 | Downloading Historical Daily chart data for RJ#. Starting date: 2014-10-30. Service: ta | 2014-11-20 16:05:15 HD Request # 18 | Requesting historical Daily Continuous data for RJZ10 starting at 2014-10-29 | 2014-11-20 16:05:15 HD Request # 18 | Receiving historical Daily data for RJ# starting at 2014-10-29 | 2014-11-20 16:05:15 Writing historical Daily data for RJ# to the file RJ#.dly | 2014-11-20 16:05:15 HD Request # 18 | Received 17 records from 2014-10-29 00:00:00 to 2014-11-20 00:00:00 (23.0 days) and wrote 16 records for RJ# | 2014-11-20 16:05:15 HD Request # 18 | Daily download COMPLETE for RJ#. Completion time: 0s. Unique request ID: 17 | 2014-11-20 16:05:15 Removed historical data download ID 17 | 2014-11-20 16:05:15 TFZ4 [CB] 240 Min #4: Download is complete for all contract months in chart. Proceeding with data load. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: Performing continuous futures contract back adjustment calculations. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFZ3 Open price on 2013-12-12 is 1102.8. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFH4 Open price on 2013-12-12 is 1098.6. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFZ3 price difference to TFH4 is -4.1999998. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFH4 Open price on 2014-03-13 is 1192.4. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFM4 Open price on 2014-03-13 is 1189.4. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFH4 price difference to TFM4 is -3. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFM4 Open price on 2014-06-12 is 1166.1. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFU4 Open price on 2014-06-12 is 1161.1. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFM4 price difference to TFU4 is -5. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFU4 Open price on 2014-09-11 is 1164.5. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFZ4 Open price on 2014-09-11 is 1159. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: TFU4 price difference to TFZ4 is -5.5. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: Back adjust amount for symbol TFZ3 is -17.700001. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: Back adjust amount for symbol TFH4 is -13.5. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: Back adjust amount for symbol TFM4 is -10.5. | 2014-11-20 16:05:17 TFZ4 [CB] 240 Min #4: Back adjust amount for symbol TFU4 is -5.5. | 2014-11-20 16:05:17 TransAct Trading | Starting real-time market data updates for: TFU4. ID: 7 | 2014-11-20 16:05:17 Intraday data recording state for symbol TFU4 is set to download pending. | 2014-11-20 16:05:17 Symbol Error - TFU4 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2014-11-20 16:05:17 HD Request # 19 | Downloading Intraday chart data for TFU4 to the file TFU4.scid. Service: ta | 2014-11-20 16:05:18 HD Request # 19 | Download start Date-Time: 2014-09-19 09:28:45.0 | 2014-11-20 16:05:18 HD Request # 19 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 16:05:18 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 16:05:18 Socket (36844) | Connected. | 2014-11-20 16:05:18 HD Request # 19 | Sending historical data logon request message. | 2014-11-20 16:05:18 HD Request # 20 | Downloading Historical Daily chart data for ES#. Starting date: 2014-10-30. Service: ta | 2014-11-20 16:05:18 HD Request # 20 | Requesting historical Daily Continuous data for ESZ10 starting at 2014-10-29 | 2014-11-20 16:05:18 HD Request # 19 | Requesting Intraday data. Start Date-Time: 2014-09-19 09:28:45. Record interval: 0. Symbol: TFU4 | 2014-11-20 16:05:18 HD Request # 20 | Receiving historical Daily data for ES# starting at 2014-10-29 | 2014-11-20 16:05:18 Writing historical Daily data for ES# to the file ES#.dly | 2014-11-20 16:05:18 HD Request # 20 | Received 17 records from 2014-10-29 00:00:00 to 2014-11-20 00:00:00 (23.0 days) and wrote 16 records for ES# | 2014-11-20 16:05:18 HD Request # 20 | Daily download COMPLETE for ES#. Completion time: 0s. Unique request ID: 19 | 2014-11-20 16:05:18 Removed historical data download ID 19 | 2014-11-20 16:05:18 HD Request # 19 | Decompressing data. | 2014-11-20 16:05:18 HD Request # 19 | Receiving Intraday data for TFU4 starting at 2014-09-19 09:28:45 | 2014-11-20 16:05:18 Socket (36844) | Shutdown and closed. | 2014-11-20 16:05:18 The network socket for historical data has been closed. | 2014-11-20 16:05:18 HD Request # 19 | Received 1 record from 2014-09-19 09:28:45 to 2014-09-19 09:28:45 (0.0 seconds) and wrote 0 records for TFU4 | 2014-11-20 16:05:21 HD Request # 19 | Intraday download COMPLETE for TFU4. Completion time: 3s. Unique request ID: 18 | 2014-11-20 16:05:21 Removed historical data download ID 18 | 2014-11-20 16:05:21 Real-time Intraday chart data file updates started for TFU4 | 2014-11-20 16:05:21 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:30:46 Socket (2712) | Closed. No error. | 2014-11-20 17:30:46 Socket (2712) | Shutdown and closed. | 2014-11-20 17:30:46 Connection to the external service has been lost. | 2014-11-20 17:30:46 TransAct Trading | Disconnected from the server. | 2014-11-20 17:30:47 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:30:47 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 17:30:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:30:51 Socket (36928) | Connected. | 2014-11-20 17:30:51 TransAct Trading | Connected to server. | 2014-11-20 17:30:51 TransAct Trading | Sending logon request message. | 2014-11-20 17:30:51 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:31:06 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:31:06 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-11-20 17:31:06 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 17:31:06 TransAct Trading | Logon error from server : Communications Error | 2014-11-20 17:31:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:06 Socket (36928) | Shutdown and closed. | 2014-11-20 17:31:06 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:06 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:06 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:08 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:10 Socket (36796) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:11 Socket (36796) | Shutdown and closed. | 2014-11-20 17:31:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:11 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:11 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:11 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:13 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:15 Socket (36720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:16 Socket (36720) | Shutdown and closed. | 2014-11-20 17:31:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:16 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:16 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:16 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:18 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:20 Socket (36908) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:21 Socket (36908) | Shutdown and closed. | 2014-11-20 17:31:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:21 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:21 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:21 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:23 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:25 Socket (36720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:26 Socket (36720) | Shutdown and closed. | 2014-11-20 17:31:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:26 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:26 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:26 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:26 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:28 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:30 Socket (36908) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:31 Socket (36908) | Shutdown and closed. | 2014-11-20 17:31:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:31 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:31 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:31 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:33 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:35 Socket (36720) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:37 Socket (36720) | Shutdown and closed. | 2014-11-20 17:31:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:37 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:37 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:37 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:37 TransAct Trading | Bridge process is still running. | 2014-11-20 17:31:39 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:41 Socket (36908) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:31:42 Socket (36908) | Shutdown and closed. | 2014-11-20 17:31:42 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:42 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:42 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:42 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:42 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 17:31:44 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:31:46 Socket (2764) | Connected. | 2014-11-20 17:31:46 TransAct Trading | Connected to server. | 2014-11-20 17:31:46 TransAct Trading | Sending logon request message. | 2014-11-20 17:31:46 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:31:59 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:31:59 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-11-20 17:31:59 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 17:31:59 TransAct Trading | Logon error from server : Communications Error | 2014-11-20 17:31:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:31:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:31:59 Socket (2764) | Shutdown and closed. | 2014-11-20 17:31:59 TransAct Trading | Disconnected from the server. | 2014-11-20 17:31:59 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:31:59 TransAct Trading | Bridge process is still running. | 2014-11-20 17:32:01 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:32:03 Socket (36936) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:32:04 Socket (36936) | Shutdown and closed. | 2014-11-20 17:32:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:32:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:32:04 TransAct Trading | Disconnected from the server. | 2014-11-20 17:32:04 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:32:04 TransAct Trading | Bridge process is still running. | 2014-11-20 17:32:06 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:32:08 Socket (2764) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:32:09 Socket (2764) | Shutdown and closed. | 2014-11-20 17:32:09 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:32:09 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:32:09 TransAct Trading | Disconnected from the server. | 2014-11-20 17:32:09 Will reconnect to the server in 2.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:32:09 TransAct Trading | Bridge process is still running. | 2014-11-20 17:32:11 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:32:13 Socket (36936) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:32:14 Socket (36936) | Shutdown and closed. | 2014-11-20 17:32:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:32:14 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:32:14 TransAct Trading | Disconnected from the server. | 2014-11-20 17:32:14 Will reconnect to the server in 35.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:32:14 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 17:32:49 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:32:51 Socket (36892) | Connected. | 2014-11-20 17:32:51 TransAct Trading | Connected to server. | 2014-11-20 17:32:51 TransAct Trading | Sending logon request message. | 2014-11-20 17:32:51 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:32:56 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:32:56 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-11-20 17:32:56 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 17:32:56 TransAct Trading | Logon error from server : Communications Error | 2014-11-20 17:32:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:32:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:32:56 Socket (36892) | Shutdown and closed. | 2014-11-20 17:32:56 TransAct Trading | Disconnected from the server. | 2014-11-20 17:32:56 Will reconnect to the server in 40.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:32:56 TransAct Trading | Bridge process is still running. | 2014-11-20 17:33:37 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:33:39 Socket (36900) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:33:40 Socket (36900) | Shutdown and closed. | 2014-11-20 17:33:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:33:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:33:40 TransAct Trading | Disconnected from the server. | 2014-11-20 17:33:40 Will reconnect to the server in 40.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:33:40 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 17:34:20 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:34:22 Socket (2764) | Connected. | 2014-11-20 17:34:22 TransAct Trading | Connected to server. | 2014-11-20 17:34:22 TransAct Trading | Sending logon request message. | 2014-11-20 17:34:22 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:34:24 TransAct Trading | Market data feed reported to be lost. | 2014-11-20 17:34:24 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-11-20 17:34:24 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 17:34:24 TransAct Trading | Logon error from server : Communications Error | 2014-11-20 17:34:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:34:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:34:24 Socket (2764) | Shutdown and closed. | 2014-11-20 17:34:24 TransAct Trading | Disconnected from the server. | 2014-11-20 17:34:24 Will reconnect to the server in 45.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:34:24 TransAct Trading | Bridge process is still running. | 2014-11-20 17:35:09 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:35:11 Socket (36928) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-11-20 17:35:12 Socket (36928) | Shutdown and closed. | 2014-11-20 17:35:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-11-20 17:35:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-11-20 17:35:12 TransAct Trading | Disconnected from the server. | 2014-11-20 17:35:12 Will reconnect to the server in 45.0 seconds Select 'File >> Disconnect' to prevent further connection attempts. | 2014-11-20 17:35:12 TransAct Trading | Starting server: C:\SierraChart2\Transact\TransactToSierraBridge.exe | 2014-11-20 17:35:57 TransAct Trading | Connecting to the server 127.0.0.1. Port 1869 | 2014-11-20 17:35:59 Socket (36892) | Connected. | 2014-11-20 17:35:59 TransAct Trading | Connected to server. | 2014-11-20 17:35:59 TransAct Trading | Sending logon request message. | 2014-11-20 17:35:59 TransAct Trading | Server Name: Transact Futures/TransactToSierraBridge/1.3.5.0. | 2014-11-20 17:36:32 TransAct Trading | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 17:36:32 TransAct Trading | Successfully connected. Operation Successful. | 2014-11-20 17:36:32 Socket (1068) | Shutdown and closed. | 2014-11-20 17:36:32 SC Market Stats | Disconnected from the server. | 2014-11-20 17:36:32 TransAct Trading | Starting real-time market data updates for: TFZ4. ID: 1 | 2014-11-20 17:36:32 Intraday data recording state for symbol TFZ4 is set to download pending. | 2014-11-20 17:36:32 HD Request # 21 | Downloading Intraday chart data for TFZ4 to the file TFZ4.scid. Service: ta | 2014-11-20 17:36:32 HD Request # 21 | Download start Date-Time: 2014-11-20 17:30:25.0 | 2014-11-20 17:36:32 HD Request # 21 | Using server: ds4.sierracharts.com port 10149 | 2014-11-20 17:36:32 TransAct Trading | Starting real-time market data updates for: ESZ4. ID: 2 | 2014-11-20 17:36:32 Intraday data recording state for symbol ESZ4 is set to download pending. | 2014-11-20 17:36:33 SC Market Stats | Starting real-time market data updates for: NISS-TF. ID: 3 | 2014-11-20 17:36:33 SC Market Stats | Connecting to the server ds3.sierracharts.com. Port 443 | 2014-11-20 17:36:33 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 17:36:33 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 17:36:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 17:36:33 Socket (10724) | Connected. | 2014-11-20 17:36:33 HD Request # 21 | Sending historical data logon request message. | 2014-11-20 17:36:33 HD Request # 21 | Requesting Intraday data. Start Date-Time: 2014-11-20 17:30:25. Record interval: 0. Symbol: TFZ4 | 2014-11-20 17:36:33 Socket (1080) | Connected. | 2014-11-20 17:36:33 SC Market Stats | Connected to server. | 2014-11-20 17:36:33 SC Market Stats | Sending logon request message. | 2014-11-20 17:36:33 HD Request # 21 | Decompressing data. | 2014-11-20 17:36:33 HD Request # 21 | Receiving Intraday data for TFZ4 starting at 2014-11-20 17:30:31 | 2014-11-20 17:36:33 HD Request # 21 | Timestamp of first Intraday data file record written: 2014-11-20 17:30:31 | 2014-11-20 17:36:33 Socket (10724) | Shutdown and closed. | 2014-11-20 17:36:33 The network socket for historical data has been closed. | 2014-11-20 17:36:33 HD Request # 21 | Received 5 records from 2014-11-20 17:30:31 to 2014-11-20 17:35:50 (5.3 minutes) and wrote 5 records for TFZ4 | 2014-11-20 17:36:33 HD Request # 21 | Intraday download COMPLETE for TFZ4. Completion time: 1s. Unique request ID: 20 | 2014-11-20 17:36:33 Removed historical data download ID 20 | 2014-11-20 17:36:33 Real-time Intraday chart data file updates started for TFZ4 | 2014-11-20 17:36:33 HD Request # 22 | Downloading Intraday chart data for ESZ4 to the file ESZ4.scid. Service: ta | 2014-11-20 17:36:33 HD Request # 22 | Download start Date-Time: 2014-11-20 17:14:54.0 | 2014-11-20 17:36:33 HD Request # 22 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 17:36:33 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 17:36:33 TransAct Trading | Starting real-time market data updates for: TFU4. ID: 4 | 2014-11-20 17:36:33 Intraday data recording state for symbol TFU4 is set to download pending. | 2014-11-20 17:36:33 Symbol Error - TFU4 is unknown, unavailable, or improperly formatted. Failed to Subscribe to Contract | 2014-11-20 17:36:33 Socket (7896) | Connected. | 2014-11-20 17:36:33 HD Request # 22 | Sending historical data logon request message. | 2014-11-20 17:36:33 HD Request # 22 | Requesting Intraday data. Start Date-Time: 2014-11-20 17:14:54. Record interval: 0. Symbol: ESZ4 | 2014-11-20 17:36:33 HD Request # 22 | Decompressing data. | 2014-11-20 17:36:33 HD Request # 22 | Receiving Intraday data for ESZ4 starting at 2014-11-20 17:14:54 | 2014-11-20 17:36:33 HD Request # 22 | Timestamp of first Intraday data file record written: 2014-11-20 17:14:55 | 2014-11-20 17:36:33 Socket (7896) | Shutdown and closed. | 2014-11-20 17:36:33 The network socket for historical data has been closed. | 2014-11-20 17:36:33 HD Request # 22 | Received 44 records from 2014-11-20 17:14:54 to 2014-11-20 17:14:59 (5.0 seconds) and wrote 41 records for ESZ4 | 2014-11-20 17:36:33 HD Request # 22 | Intraday download COMPLETE for ESZ4. Completion time: 0s. Unique request ID: 21 | 2014-11-20 17:36:33 Removed historical data download ID 21 | 2014-11-20 17:36:33 Real-time Intraday chart data file updates started for ESZ4 | 2014-11-20 17:36:33 HD Request # 23 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 17:36:33 HD Request # 23 | Download start Date-Time: 2014-11-20 17:36:36.0 | 2014-11-20 17:36:33 HD Request # 23 | Using server: ds4.sierracharts.com port 10149 | 2014-11-20 17:36:33 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2014-11-20 17:36:33 Socket (1068) | Connected. | 2014-11-20 17:36:33 HD Request # 23 | Sending historical data logon request message. | 2014-11-20 17:36:33 HD Request # 23 | Requesting Intraday data. Start Date-Time: 2014-11-20 17:36:36. Record interval: 0. Symbol: NISS-TF | 2014-11-20 17:36:33 HD Request # 23 | Decompressing data. | 2014-11-20 17:36:33 HD Request # 23 | Receiving Intraday data for NISS-TF starting at 2014-11-20 17:36:36 | 2014-11-20 17:36:33 HD Request # 23 | Timestamp of first Intraday data file record written: 2014-11-20 17:36:38 | 2014-11-20 17:36:33 Socket (1068) | Shutdown and closed. | 2014-11-20 17:36:33 The network socket for historical data has been closed. | 2014-11-20 17:36:33 HD Request # 23 | Received 2 records from 2014-11-20 17:36:36 to 2014-11-20 17:36:38 (2.0 seconds) and wrote 1 record for NISS-TF | 2014-11-20 17:36:33 HD Request # 23 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 22 | 2014-11-20 17:36:33 Removed historical data download ID 22 | 2014-11-20 17:36:33 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 17:36:33 HD Request # 24 | Downloading Intraday chart data for TFU4 to the file TFU4.scid. Service: ta | 2014-11-20 17:36:33 HD Request # 24 | Download start Date-Time: 2014-09-19 09:28:45.0 | 2014-11-20 17:36:33 HD Request # 24 | Using server: ds3.sierracharts.com port 10149 | 2014-11-20 17:36:33 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2014-11-20 17:36:33 Socket (10724) | Connected. | 2014-11-20 17:36:33 HD Request # 24 | Sending historical data logon request message. | 2014-11-20 17:36:33 HD Request # 24 | Requesting Intraday data. Start Date-Time: 2014-09-19 09:28:45. Record interval: 0. Symbol: TFU4 | 2014-11-20 17:36:33 SC Market Stats | Server Name: . | 2014-11-20 17:36:33 SC Market Stats | Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-11-20 17:36:33 SC Market Stats | Successfully connected. | 2014-11-20 17:36:33 Intraday data recording state for symbol NISS-TF is set to download pending. | 2014-11-20 17:36:33 SC Market Stats | Restarting real-time data updates for symbol: NISS-TF | 2014-11-20 17:36:33 HD Request # 24 | Decompressing data. | 2014-11-20 17:36:34 HD Request # 24 | Receiving Intraday data for TFU4 starting at 2014-09-19 09:28:45 | 2014-11-20 17:36:34 Socket (10724) | Shutdown and closed. | 2014-11-20 17:36:34 The network socket for historical data has been closed. | 2014-11-20 17:36:34 HD Request # 24 | Received 1 record from 2014-09-19 09:28:45 to 2014-09-19 09:28:45 (0.0 seconds) and wrote 0 records for TFU4 | 2014-11-20 17:36:34 HD Request # 24 | Intraday download COMPLETE for TFU4. Completion time: 0s. Unique request ID: 23 | 2014-11-20 17:36:34 Removed historical data download ID 23 | 2014-11-20 17:36:34 Real-time Intraday chart data file updates started for TFU4 | 2014-11-20 17:36:34 HD Request # 25 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2014-11-20 17:36:34 HD Request # 25 | Download start Date-Time: 2014-11-20 17:36:38.0 | 2014-11-20 17:36:34 HD Request # 25 | Using server: ds5.sierracharts.com port 10149 | 2014-11-20 17:36:34 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2014-11-20 17:36:34 Socket (7896) | Connected. | 2014-11-20 17:36:34 HD Request # 25 | Sending historical data logon request message. | 2014-11-20 17:36:34 HD Request # 25 | Requesting Intraday data. Start Date-Time: 2014-11-20 17:36:38. Record interval: 0. Symbol: NISS-TF | 2014-11-20 17:36:34 HD Request # 25 | Decompressing data. | 2014-11-20 17:36:34 HD Request # 25 | Receiving Intraday data for NISS-TF starting at 2014-11-20 17:36:38 | 2014-11-20 17:36:34 Socket (7896) | Shutdown and closed. | 2014-11-20 17:36:34 The network socket for historical data has been closed. | 2014-11-20 17:36:34 HD Request # 25 | Received 1 record from 2014-11-20 17:36:38 to 2014-11-20 17:36:38 (0.0 seconds) and wrote 0 records for NISS-TF | 2014-11-20 17:36:34 HD Request # 25 | Intraday download COMPLETE for NISS-TF. Completion time: 0s. Unique request ID: 24 | 2014-11-20 17:36:34 Removed historical data download ID 24 | 2014-11-20 17:36:34 Real-time Intraday chart data file updates started for NISS-TF | 2014-11-20 17:36:34 ES#/ESZ4 Daily #7: Reloading Historical Daily chart due to current quote data for new date received. | 2014-11-21 00:02:20 HD Request # 26 | Downloading Historical Daily chart data for ES#. Starting date: 2014-11-19. Service: ta | 2014-11-21 00:02:21 Historical data download counter reset. | 2014-11-21 00:02:21 HD Request # 26 | Requesting historical Daily Continuous data for ESZ10 starting at 2014-11-18 | 2014-11-21 00:02:21 HD Request # 26 | Receiving historical Daily data for ES# starting at 2014-11-18 | 2014-11-21 00:02:21 Writing historical Daily data for ES# to the file ES#.dly | 2014-11-21 00:02:21 HD Request # 26 | Received 4 records from 2014-11-18 00:00:00 to 2014-11-21 00:00:00 (4.0 days) and wrote 3 records for ES# | 2014-11-21 00:02:21 HD Request # 26 | Daily download COMPLETE for ES#. Completion time: 0s. Unique request ID: 25 | 2014-11-21 00:02:21 Removed historical data download ID 25 | 2014-11-21 00:02:21 RJ#/TFZ4 Daily #3: Reloading Historical Daily chart due to current quote data for new date received. | 2014-11-21 00:02:57 HD Request # 27 | Downloading Historical Daily chart data for RJ#. Starting date: 2014-11-19. Service: ta | 2014-11-21 00:02:57 HD Request # 27 | Requesting historical Daily Continuous data for RJZ10 starting at 2014-11-18 | 2014-11-21 00:02:57 HD Request # 27 | Receiving historical Daily data for RJ# starting at 2014-11-18 | 2014-11-21 00:02:57 Writing historical Daily data for RJ# to the file RJ#.dly | 2014-11-21 00:02:57 HD Request # 27 | Received 4 records from 2014-11-18 00:00:00 to 2014-11-21 00:00:00 (4.0 days) and wrote 3 records for RJ# | 2014-11-21 00:02:57 HD Request # 27 | Daily download COMPLETE for RJ#. Completion time: 0s. Unique request ID: 26 | 2014-11-21 00:02:57 Removed historical data download ID 26 | 2014-11-21 00:02:57 The C locale was changed. Resetting the locale back to the default setting. | 2014-11-21 07:10:49 A change to the locale was detected after a call to the ACS function SierraChartStudies.scsf_Volume. The ACS function may have changed the locale, or the locale may have been changed before the function was called. | 2014-11-21 07:10:49 * |
[2014-11-21 18:29:38] |
In Data Trade Service Setting I still have disabled "allow support for SC data feeds". Should this now be enabled? We have no idea why the operating system is changing the locale when you open a file. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
